[petsc-users] Efficiently move matrix from single processor to multiple
Jed Brown
jed at jedbrown.org
Tue Feb 18 14:49:32 CST 2020
Hector E Barrios Molano <hectorb at utexas.edu> writes:
> Dear PETSc Experts!
> Do you know if there is an efficient way to move a matrix from a single
> processor (MatCreateSeqBAIJ) to a matrix contained in all processors?
How did you create the original SeqBAIJ? Could you just call
MatSetValues on a parallel matrix instead (even if only setting values
from rank 0)? Many of our tutorials suggest this mode if you can't
parallelize your assembly.
> As a little bit of context, I have a code in which only one processor
> creates a matrix and a vector for a linear system of equations. Then we
> want to use a parallel solver to get the solution and give it back to a
> single processor
> I tried MatView to create a binary file and MatLoad to load the matrix
> in parallel. This seems to work but performance is significantly
> decreased independent of the number of processors used.
> I have some questions:
> Can I share the matrix without having to write it to a file, for
> example, through a buffer?
> Is there a way to efficiently avoid the overhead of writing, reading
> loading matrices to and from processors?
> Thanks for your comments,
> Hector
> *Hector Barrios*
> PhD Student, Graduate Research Assistant
> Hildebrand Department of Petroleum and Geosystems Engineering
> The University of Texas at Austin
> hectorb at utexas.edu <mailto:hectorb at utexas.edu>
