[petsc-users] Efficiently move matrix from single processor to multiple
    Hector E Barrios Molano
    hectorb at utexas.edu
    Tue Feb 18 14:30:44 CST 2020
Dear PETSc Experts!
Do you know if there is an efficient way to move a matrix from a single
processor (MatCreateSeqBAIJ) to a matrix contained in all processors?
As a little bit of context, I have a code in which only one processor
creates a matrix and a vector for a linear system of equations. Then we
want to use a parallel solver to get the solution and give it back to a
single processor
I tried MatView to create a binary file and MatLoad to load the matrix
in parallel. This seems to work but performance is significantly
decreased independent of the number of processors used.
I have some questions:
Can I share the matrix without having to write it to a file, for
example, through a buffer?
Is there a way to efficiently avoid the overhead of writing, reading
loading matrices to and from processors?
Thanks for your comments,
Hector
*Hector Barrios*
PhD Student, Graduate Research Assistant
Hildebrand Department of Petroleum and Geosystems Engineering
The University of Texas at Austin
hectorb at utexas.edu <mailto:hectorb at utexas.edu>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200218/0968a21b/attachment.html>
