[petsc-users] BCs for a EPS solver
Matthew Knepley
knepley at gmail.com
Mon Feb 17 17:41:15 CST 2020
On Mon, Feb 17, 2020 at 4:33 PM Emmanuel Ayala <juaneah at gmail.com> wrote:
> Hi,
> Thank you for the clarification, now I understand what means change those
> values, and I tried to do that.
> But if I put the row i to the identity in A, and zero in B, the solver
> crash:
So if you need to factor B, maybe reverse it?
Matt
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Error in external library
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Error in external library
> [1]PETSC ERROR: Error reported by MUMPS in numerical factorization phase:
> INFOG(1)=-10, INFO(2)=0
> [1]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.12.3, Jan, 03, 2020
> [1]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message
> [2]PETSC ERROR: Error in external library
> [2]PETSC ERROR: Error reported by MUMPS in numerical factorization phase:
> [2]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [2]PETSC ERROR: Petsc Release Version 3.12.3, Jan, 03, 2020
> [2]PETSC ERROR: ./comp on a arch-linux-c-opt-O2-mumps named ayala by ayala
> Mon Feb 17 15:28:01 2020
> [3]PETSC ERROR: --------------------- Error Message
> [3]PETSC ERROR: Error in external library
> [3]PETSC ERROR: Error reported by MUMPS in numerical factorization phase:
> [3]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [3]PETSC ERROR: Petsc Release Version 3.12.3, Jan, 03, 2020
> [3]PETSC ERROR: ./comp on a arch-linux-c-opt-O2-mumps named ayala by ayala
> [3]PETSC ERROR: Configure options --with-debugging=0 COPTFLAGS="-O2
> -march=native -mtune=native" CXXOPTFLAGS="-O2 -march=native -mtune=native"
> FOPTFLAGS="-O2 -march=native -mtune=native" --download-mpich
> --download-mumps --download-scalapack --download-parmetis --download-metis
> --download-superlu_dist --download-cmake --download-fblaslapack=1
> --with-cxx-dialect=C++11
> [3]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 1365 in
> /home/ayala/Documents/PETSc/petsc-3.12.3/src/mat/impls/aij/mpi/mumps/mumps.c
> [0]PETSC ERROR: Error reported by MUMPS in numerical factorization phase:
> INFOG(1)=-10, INFO(2)=33
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [0]PETSC ERROR: Petsc Release Version 3.12.3, Jan, 03, 2020
> [0]PETSC ERROR: ./comp on a arch-linux-c-opt-O2-mumps named ayala by ayala
> [0]PETSC ERROR: Configure options --with-debugging=0 COPTFLAGS="-O2
> [0]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 1365 in
> ./comp on a arch-linux-c-opt-O2-mumps named ayala by ayala Mon Feb 17
> 15:28:01 2020
> [1]PETSC ERROR: Configure options --with-debugging=0 COPTFLAGS="-O2
> [1]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 1365 in
> [1]PETSC ERROR: #2 MatLUFactorNumeric() line 3057 in
> /home/ayala/Documents/PETSc/petsc-3.12.3/src/mat/interface/matrix.c
> [2]PETSC ERROR: Configure options --with-debugging=0 COPTFLAGS="-O2
> [2]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 1365 in
> [2]PETSC ERROR: #2 MatLUFactorNumeric() line 3057 in
> [2]PETSC ERROR: [3]PETSC ERROR: #2 MatLUFactorNumeric() line 3057 in
> [3]PETSC ERROR: #3 PCSetUp_LU() line 126 in
> /home/ayala/Documents/PETSc/petsc-3.12.3/src/ksp/pc/impls/factor/lu/lu.c
> [3]PETSC ERROR: #4 PCSetUp() line 894 in
> /home/ayala/Documents/PETSc/petsc-3.12.3/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #2 MatLUFactorNumeric() line 3057 in
> [0]PETSC ERROR: #3 PCSetUp_LU() line 126 in
> [0]PETSC ERROR: [1]PETSC ERROR: #3 PCSetUp_LU() line 126 in
> [1]PETSC ERROR: #4 PCSetUp() line 894 in
> [2]PETSC ERROR: #4 PCSetUp() line 894 in
> [2]PETSC ERROR: #5 KSPSetUp() line 376 in
> /home/ayala/Documents/PETSc/petsc-3.12.3/src/ksp/ksp/interface/itfunc.c
> [3]PETSC ERROR: #5 KSPSetUp() line 376 in
> [3]PETSC ERROR: #6 STSetUp_Shift() line 120 in
> /home/ayala/Documents/SLEPc/slepc-3.12.2/src/sys/classes/st/impls/shift/shift.c
> [0]PETSC ERROR: #5 KSPSetUp() line 376 in
> [0]PETSC ERROR: #6 STSetUp_Shift() line 120 in
> [1]PETSC ERROR: #6 STSetUp_Shift() line 120 in
> [1]PETSC ERROR: #7 STSetUp() line 271 in
> /home/ayala/Documents/SLEPc/slepc-3.12.2/src/sys/classes/st/interface/stsolve.c
> [1]PETSC ERROR: #8 EPSSetUp() line 273 in
> /home/ayala/Documents/SLEPc/slepc-3.12.2/src/eps/interface/epssetup.c
> [2]PETSC ERROR: #6 STSetUp_Shift() line 120 in
> [2]PETSC ERROR: #7 STSetUp() line 271 in
> [2]PETSC ERROR: #8 EPSSetUp() line 273 in
> [2]PETSC ERROR: #9 FourBar_NaturalPulsation() line 3937 in
> /home/ayala/Nextcloud/cpp_projects/2020-02-13-muboto-balancing-v17-mma/Multibody.cc
> El lun., 17 de feb. de 2020 a la(s) 13:20, Matthew Knepley (
> knepley at gmail.com) escribió:
>> On Mon, Feb 17, 2020 at 1:59 PM Emmanuel Ayala <juaneah at gmail.com> wrote:
>>> Hi, thanks for the quick answer.
>>> I just did it, and it does not work. My problem is GNHEP and I use the
>>> default solver (Krylov-Schur). Moreover I run the code with the options:
>>> -st_ksp_type preonly -st_pc_type lu -st_pc_factor_mat_solver_type mumps
>> I guess a better question is: What do you expect to work?
>> For a linear solve,
>> A x = b
>> if a row i is 0 except for a one on the diagonal, then I get
>> x_i = b_i
>> so hopefully you put the correct boundary value in b_i. For the
>> generalized eigenproblem
>> A x = \lambda B x
>> if you set row i to the identity in A, and zero in B, we get
>> x_i = 0
>> and you must put the boundary values into x after you have finished the
>> solve. Is this what you did?
>> Thanks,
>> Matt
>>> Any other suggestions?
>>> Kind regards.
>>> El lun., 17 de feb. de 2020 a la(s) 12:39, Jeremy Theler (
>>> jeremy at seamplex.com) escribió:
>>>> The usual trick is to set ones in one matrix and zeros in the other
>>>> one.
>>>> On Mon, 2020-02-17 at 12:35 -0600, Emmanuel Ayala wrote:
>>>> > Hi everyone,
>>>> > I have an eigenvalue problem where I need to apply BCs to the
>>>> > stiffness and mass matrix.
>>>> > Usually, for KSP solver, it is enough to set to zero the rows and
>>>> > columns related to the boundary conditions. I used to apply it with
>>>> > MatZeroRowsColumns, with a 1s on the diagonal. Then the solver works
>>>> > well.
>>>> > There is something similar to KSP for EPS solver ?
>>>> > I already used MatZeroRowsColumns (for EPS solver), with a 1s on the
>>>> > diagonal, and I got wrong result.
>>>> > Kind regards.
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200217/33a7e02e/attachment.html>
