[petsc-users] BCs for a EPS solver
Emmanuel Ayala
juaneah at gmail.com
Mon Feb 17 15:33:26 CST 2020
Thank you for the clarification, now I understand what means change those
values, and I tried to do that.
But if I put the row i to the identity in A, and zero in B, the solver
crash:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Error in external library
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Error in external library
[1]PETSC ERROR: Error reported by MUMPS in numerical factorization phase:
INFOG(1)=-10, INFO(2)=0
[1]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.12.3, Jan, 03, 2020
[1]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message
[2]PETSC ERROR: Error in external library
[2]PETSC ERROR: Error reported by MUMPS in numerical factorization phase:
[2]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
[2]PETSC ERROR: Petsc Release Version 3.12.3, Jan, 03, 2020
[2]PETSC ERROR: ./comp on a arch-linux-c-opt-O2-mumps named ayala by ayala
Mon Feb 17 15:28:01 2020
[3]PETSC ERROR: --------------------- Error Message
[3]PETSC ERROR: Error in external library
[3]PETSC ERROR: Error reported by MUMPS in numerical factorization phase:
[3]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
[3]PETSC ERROR: Petsc Release Version 3.12.3, Jan, 03, 2020
[3]PETSC ERROR: ./comp on a arch-linux-c-opt-O2-mumps named ayala by ayala
[3]PETSC ERROR: Configure options --with-debugging=0 COPTFLAGS="-O2
-march=native -mtune=native" CXXOPTFLAGS="-O2 -march=native -mtune=native"
FOPTFLAGS="-O2 -march=native -mtune=native" --download-mpich
--download-mumps --download-scalapack --download-parmetis --download-metis
--download-superlu_dist --download-cmake --download-fblaslapack=1
--with-cxx-dialect=C++11
[3]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 1365 in
/home/ayala/Documents/PETSc/petsc-3.12.3/src/mat/impls/aij/mpi/mumps/mumps.c
[0]PETSC ERROR: Error reported by MUMPS in numerical factorization phase:
INFOG(1)=-10, INFO(2)=33
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
[0]PETSC ERROR: Petsc Release Version 3.12.3, Jan, 03, 2020
[0]PETSC ERROR: ./comp on a arch-linux-c-opt-O2-mumps named ayala by ayala
[0]PETSC ERROR: Configure options --with-debugging=0 COPTFLAGS="-O2
[0]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 1365 in
./comp on a arch-linux-c-opt-O2-mumps named ayala by ayala Mon Feb 17
15:28:01 2020
[1]PETSC ERROR: Configure options --with-debugging=0 COPTFLAGS="-O2
[1]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 1365 in
[1]PETSC ERROR: #2 MatLUFactorNumeric() line 3057 in
/home/ayala/Documents/PETSc/petsc-3.12.3/src/mat/interface/matrix.c
[2]PETSC ERROR: Configure options --with-debugging=0 COPTFLAGS="-O2
[2]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 1365 in
[2]PETSC ERROR: #2 MatLUFactorNumeric() line 3057 in
[2]PETSC ERROR: [3]PETSC ERROR: #2 MatLUFactorNumeric() line 3057 in
[3]PETSC ERROR: #3 PCSetUp_LU() line 126 in
/home/ayala/Documents/PETSc/petsc-3.12.3/src/ksp/pc/impls/factor/lu/lu.c
[3]PETSC ERROR: #4 PCSetUp() line 894 in
/home/ayala/Documents/PETSc/petsc-3.12.3/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #2 MatLUFactorNumeric() line 3057 in
[0]PETSC ERROR: #3 PCSetUp_LU() line 126 in
[0]PETSC ERROR: [1]PETSC ERROR: #3 PCSetUp_LU() line 126 in
[1]PETSC ERROR: #4 PCSetUp() line 894 in
[2]PETSC ERROR: #4 PCSetUp() line 894 in
[2]PETSC ERROR: #5 KSPSetUp() line 376 in
/home/ayala/Documents/PETSc/petsc-3.12.3/src/ksp/ksp/interface/itfunc.c
[3]PETSC ERROR: #5 KSPSetUp() line 376 in
[3]PETSC ERROR: #6 STSetUp_Shift() line 120 in
/home/ayala/Documents/SLEPc/slepc-3.12.2/src/sys/classes/st/impls/shift/shift.c
[0]PETSC ERROR: #5 KSPSetUp() line 376 in
[0]PETSC ERROR: #6 STSetUp_Shift() line 120 in
[1]PETSC ERROR: #6 STSetUp_Shift() line 120 in
[1]PETSC ERROR: #7 STSetUp() line 271 in
/home/ayala/Documents/SLEPc/slepc-3.12.2/src/sys/classes/st/interface/stsolve.c
[1]PETSC ERROR: #8 EPSSetUp() line 273 in
/home/ayala/Documents/SLEPc/slepc-3.12.2/src/eps/interface/epssetup.c
[2]PETSC ERROR: #6 STSetUp_Shift() line 120 in
[2]PETSC ERROR: #7 STSetUp() line 271 in
[2]PETSC ERROR: #8 EPSSetUp() line 273 in
[2]PETSC ERROR: #9 FourBar_NaturalPulsation() line 3937 in
/home/ayala/Nextcloud/cpp_projects/2020-02-13-muboto-balancing-v17-mma/Multibody.cc
El lun., 17 de feb. de 2020 a la(s) 13:20, Matthew Knepley (
knepley at gmail.com) escribió:
> On Mon, Feb 17, 2020 at 1:59 PM Emmanuel Ayala <juaneah at gmail.com> wrote:
>> Hi, thanks for the quick answer.
>> I just did it, and it does not work. My problem is GNHEP and I use the
>> default solver (Krylov-Schur). Moreover I run the code with the options:
>> -st_ksp_type preonly -st_pc_type lu -st_pc_factor_mat_solver_type mumps
> I guess a better question is: What do you expect to work?
> For a linear solve,
> A x = b
> if a row i is 0 except for a one on the diagonal, then I get
> x_i = b_i
> so hopefully you put the correct boundary value in b_i. For the
> generalized eigenproblem
> A x = \lambda B x
> if you set row i to the identity in A, and zero in B, we get
> x_i = 0
> and you must put the boundary values into x after you have finished the
> solve. Is this what you did?
> Thanks,
> Matt
>> Any other suggestions?
>> Kind regards.
>> El lun., 17 de feb. de 2020 a la(s) 12:39, Jeremy Theler (
>> jeremy at seamplex.com) escribió:
>>> The usual trick is to set ones in one matrix and zeros in the other
>>> one.
>>> On Mon, 2020-02-17 at 12:35 -0600, Emmanuel Ayala wrote:
>>> > Hi everyone,
>>> > I have an eigenvalue problem where I need to apply BCs to the
>>> > stiffness and mass matrix.
>>> > Usually, for KSP solver, it is enough to set to zero the rows and
>>> > columns related to the boundary conditions. I used to apply it with
>>> > MatZeroRowsColumns, with a 1s on the diagonal. Then the solver works
>>> > well.
>>> > There is something similar to KSP for EPS solver ?
>>> > I already used MatZeroRowsColumns (for EPS solver), with a 1s on the
>>> > diagonal, and I got wrong result.
>>> > Kind regards.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200217/701a7c3e/attachment-0001.html>
