[petsc-users] TS tutorial ex11 in Fortran
Thibault Bridel-Bertomeu thibault.bridelbertomeu at gmail.com
Mon Dec 28 11:02:23 CST 2020
Hi Jed,
Thanks for your message.
I implemented everything in C as you suggested and it works fine except for
one thing : the ts->vec_sol does not seem to get updated when seen from the
C code (it is on the Fortran side though the solution is correct).
As a result, the time step (that uses among other things the max velocity
in the domain) is always at the value it gets from the initial solution.
Any idea why ts->vec_sol does not seem to be updated ? (I checked the
stepnum and time is updated though , when accessed with TSGetTime for
instance).
Cheers,
Thibault
Le lun. 28 déc. 2020 à 15:30, Jed Brown <jed at jedbrown.org> a écrit :
> Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com> writes:
> > Good morning everyone,
> > Thank you Barry for the answer, it works now !
> > I am facing (yet) another situation: the TSAdaptRegister function.
> > In the MR on gitlab, Jed mentioned that sometimes, when function pointers
> > are not stored in PETSc objects, one can use stack memory to pass that
> > pointer from fortran to C.
> The issue with stack memory is that when it returns, that memory is
> invalid. You can't use it in this instance.
> I think you're going to have problems implementing a TSAdaptCreate_XYZ in
> Fortran (because the body of that function will need to access private
> struct members; see below).
> I would implement what you need in C and you can call out to Fortran if
> you want from inside TSAdaptChoose_YourMethod().
> PETSC_EXTERN PetscErrorCode TSAdaptCreate_DSP(TSAdapt adapt)
>   TSAdapt_DSP    *dsp;
>   PetscErrorCode ierr;
>   PetscFunctionBegin;
>   ierr = PetscNewLog(adapt,&dsp);CHKERRQ(ierr);
>   adapt->reject_safety = 1.0; /* unused */
>   adapt->data                = (void*)dsp;
>   adapt->ops->choose         = TSAdaptChoose_DSP;
>   adapt->ops->setfromoptions = TSAdaptSetFromOptions_DSP;
>   adapt->ops->destroy        = TSAdaptDestroy_DSP;
>   adapt->ops->view           = TSAdaptView_DSP;
>   ierr =
> PetscObjectComposeFunction((PetscObject)adapt,"TSAdaptDSPSetFilter_C",TSAdaptDSPSetFilter_DSP);CHKERRQ(ierr);
>   ierr =
> PetscObjectComposeFunction((PetscObject)adapt,"TSAdaptDSPSetPID_C",TSAdaptDSPSetPID_DSP);CHKERRQ(ierr);
>   ierr = TSAdaptDSPSetFilter_DSP(adapt,"PI42");CHKERRQ(ierr);
>   ierr = TSAdaptRestart_DSP(adapt);CHKERRQ(ierr);
>   PetscFunctionReturn(0);
> > Can anyone develop that idea ? Because for TSAdaptRegister, i guess the
> > wrapper would start like :
> > PETSC_EXTERN void tsadaptregister_(char *sname,
> >                                    void
> (*func)(TSAdapt*,PetscErrorCode*),
> >                                    PetscErrorCode *ierr,
> >                                    PETSC_FORTRAN_CHARLEN_T snamelen)
> > but then the C TSAdaptRegister function takes a PetscErrorCode
> > (*func)(TSAdapt) function pointer as argument ... I cannot use any
> > FORTRAN_CALLBACK here since I do not have any object to hook it to, and I
> > could not find a similar situation among the pre-existing wrappers. Does
> > anyone have an idea on how to proceed ?
> > Thanks !!
> > Thibault
> > Le mar. 22 déc. 2020 à 21:20, Barry Smith <bsmith at petsc.dev> a écrit :
> >> PetscObjectUseFortranCallback((PetscDS)ctx,
> >> *ierr = PetscObjectSetFortranCallback((PetscObject)*prob
> >>   It looks like the problem is that these user provided functions do not
> >> take a PetscDS directly as an argument so the Fortran callback
> information
> >> cannot be obtained from them.
> >> The manual page for PetscDSAddBoundary() says
> >>  - ctx         - An optional user context for bcFunc
> >> but then when it lists the calling sequence for bcFunc it does not list
> >> the ctx as an argument, so either the manual page or code is wrong.
> >> It looks  like you make the ctx be the PetscDS prob argument when you
> >> call PetscDSAddBoundary
> >> In principle this sounds like it might work. I think you need to track
> >> through the debugger to see if the ctx passed to ourbocofunc() is
> >> actually the PetscDS prob variable and if not why it is not.
> >>   Barry
> >> On Dec 22, 2020, at 5:49 AM, Thibault Bridel-Bertomeu <
> >> thibault.bridelbertomeu at gmail.com> wrote:
> >> Dear all,
> >> I have hit two snags while implementing the missing wrappers necessary
> to
> >> transcribe ex11 to Fortran.
> >> First is about the PetscDSAddBoundary wrapper, that I have done so :
> >> static PetscErrorCode ourbocofunc(PetscReal time, const PetscReal *c,
> >> const PetscReal *n, const PetscScalar *a_xI, const PetscScalar *a_xG,
> void
> >> *ctx)
> >>     PetscObjectUseFortranCallback((PetscDS)ctx, bocofunc,
> >>                                   (PetscReal*,const PetscReal*,const
> >> PetscReal*,const PetscScalar*,const PetscScalar*,void*,PetscErrorCode*),
> >>                                   (&time,c,n,a_xI,a_xG,ctx,&ierr));
> >> static PetscErrorCode ourbocofunc_time(PetscReal time, const PetscReal
> *c,
> void
> >> *ctx)
> >>     PetscObjectUseFortranCallback((PetscDS)ctx, bocofunc_time,
> >> PETSC_EXTERN void petscdsaddboundary_(PetscDS *prob,
> >> DMBoundaryConditionType *type, char *name, char *labelname, PetscInt
> >> *field, PetscInt *numcomps, PetscInt *comps,
> >>                                       void (*bcFunc)(void),
> >>                                       void (*bcFunc_t)(void),
> >>                                       PetscInt *numids, const PetscInt
> >> *ids, void *ctx, PetscErrorCode *ierr,
> >>                                       PETSC_FORTRAN_CHARLEN_T namelen,
> >> PETSC_FORTRAN_CHARLEN_T labelnamelen)
> >>     char *newname, *newlabelname;
> >>     FIXCHAR(name, namelen, newname);
> >>     FIXCHAR(labelname, labelnamelen, newlabelname);
> >>     *ierr = PetscObjectSetFortranCallback((PetscObject)*prob,
> >> PETSC_FORTRAN_CALLBACK_CLASS, &bocofunc,      (PetscVoidFunction)bcFunc,
> >> ctx);
> >> PETSC_FORTRAN_CALLBACK_CLASS, &bocofunc_time,
> (PetscVoidFunction)bcFunc_t,
> >> ctx);
> >>     *ierr = PetscDSAddBoundary(*prob, *type, newname, newlabelname,
> >> *field, *numcomps, comps,
> >>                                (void (*)(void))ourbocofunc,
> >>                                (void (*)(void))ourbocofunc_time,
> >>                                *numids, ids, *prob);
> >>     FREECHAR(name, newname);
> >>     FREECHAR(labelname, newlabelname);
> >> but when I call it in the program, with adequate routines,  I obtain the
> >> following error :
> >> [0]PETSC ERROR: --------------------- Error Message
> --------------------------------------------------------------[0]PETSC
> ERROR: Corrupt argument:
> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC
> ERROR: Fortran callback not set on this object[0]PETSC ERROR: See
> https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> shooting.[0]PETSC ERROR: Petsc Development GIT revision:
> v3.14.2-297-gf36a7edeb8  GIT Date: 2020-12-18 04:42:53 +0000[0]PETSC ERROR:
> ../../../bin/eulerian3D on a  named macbook-pro-de-thibault.home by tbridel
> Sun Dec 20 15:05:15 2020[0]PETSC ERROR: Configure options --with-clean=0
> --prefix=/Users/tbridel/Documents/1-CODES/04-PETSC/build --with-make-np=2
> --with-windows-graphics=0 --with-debugging=0 --download-fblaslapack
> --download-mpich-shared=0 --with-x=0 --with-pthread=0 --with-valgrind=0
> --PETSC_ARCH=macosx
> --with-fc=/usr/local/Cellar/open-mpi/4.0.1_2/bin/mpifort
> --with-cc=/usr/local/Cellar/open-mpi/4.0.1_2/bin/mpicc
> --with-cxx=/usr/local/Cellar/open-mpi/4.0.1_2/bin/mpic++ --with-openmp=0
> --download-hypre=yes --download-sowing=yes --download-metis=yes
> --download-parmetis=yes --download-triangle=yes --download-tetgen=yes
> --download-ctetgen=yes --download-p4est=yes --download-zlib=yes
> --download-c2html=yes --download-eigen=yes --download-pragmatic=yes
> --with-hdf5-dir=/usr/local/Cellar/hdf5/1.10.5_1
> --with-cmake-dir=/usr/local/Cellar/cmake/3.15.3[0]PETSC ERROR: #1
> PetscObjectGetFortranCallback() line 258 in
> /Users/tbridel/Documents/1-CODES/04-PETSC/src/sys/objects/inherit.c[0]PETSC
> ERROR: #2 ourbocofunc() line 141 in
> /Users/tbridel/Documents/1-CODES/59-EULERIAN3D/sources/petsc_wrapping/wrapper_petsc.c[0]PETSC
> ERROR: #3 DMPlexInsertBoundaryValuesRiemann() line 989 in
> /Users/tbridel/Documents/1-CODES/04-PETSC/src/dm/impls/plex/plexfem.c[0]PETSC
> ERROR: #4 DMPlexInsertBoundaryValues_Plex() line 1052 in
> ERROR: #5 DMPlexInsertBoundaryValues() line 1142 in
> ERROR: #6 DMPlexComputeResidual_Internal() line 4524 in
> ERROR: #7 DMPlexTSComputeRHSFunctionFVM() line 74 in
> /Users/tbridel/Documents/1-CODES/04-PETSC/src/ts/utils/dmplexts.c[0]PETSC
> ERROR: #8 ourdmtsrhsfunc() line 186 in
> ERROR: #9 TSComputeRHSFunction_DMLocal() line 105 in
> /Users/tbridel/Documents/1-CODES/04-PETSC/src/ts/utils/dmlocalts.c[0]PETSC
> ERROR: #10 TSComputeRHSFunction() line 653 in
> /Users/tbridel/Documents/1-CODES/04-PETSC/src/ts/interface/ts.c[0]PETSC
> ERROR: #11 TSSSPStep_RK_3() line 120 in
> /Users/tbridel/Documents/1-CODES/04-PETSC/src/ts/impls/explicit/ssp/ssp.c[0]PETSC
> ERROR: #12 TSStep_SSP() line 208 in
> ERROR: #13 TSStep() line 3757 in
> ERROR: #14 TSSolve() line 4154 in
> ERROR: #15 User provided function() line 0 in User file
> >> Second is about the DMProjectFunction wrapper, that I have done so :
> >> static PetscErrorCode ourdmprojfunc(PetscInt dim, PetscReal time,
> >> PetscReal x[], PetscInt Nf, PetscScalar u[], void *ctx)
> >>     PetscObjectUseFortranCallback((DM)ctx, dmprojfunc,
> (PetscInt*,PetscReal*,PetscReal*,PetscInt*,PetscScalar*,void*,PetscErrorCode*),
> >>                                   (&dim,&time,x,&Nf,u,_ctx,&ierr))
> >> PETSC_EXTERN void dmprojectfunction_(DM *dm, PetscReal *time,
> >>                                      void
> (*func)(PetscInt*,PetscReal*,PetscReal*,PetscInt*,PetscScalar*,void*,PetscErrorCode*),
> >>                                      void *ctx, InsertMode *mode, Vec X,
> >> PetscErrorCode *ierr)
> >>     PetscErrorCode (*funcarr[1]) (PetscInt dim, PetscReal time,
> PetscReal
> >> x[], PetscInt Nf, PetscScalar *u, void *ctx);
> >>     *ierr = PetscObjectSetFortranCallback((PetscObject)*dm,
> >> PETSC_FORTRAN_CALLBACK_CLASS, &dmprojfunc, (PetscVoidFunction)func,
> ctx);
> >>     funcarr[0] = ourdmprojfunc;
> >>     *ierr = DMProjectFunction(*dm, *time, funcarr, &ctx, *mode, X);
> >> This time there is no error because I cannot reach this point in the
> >> program, but I am not sure anyways how to write this wrapper, especially
> >> because of the double pointers that DMProjectFunction takes as
> arguments.
> >> Does anyone have any idea what could be going wrong with those two
> >> wrappers ?
> >> Thank you very much in advance !!
> >> Thibault
> >> Le ven. 18 déc. 2020 à 11:02, Thibault Bridel-Bertomeu <
> >> thibault.bridelbertomeu at gmail.com> a écrit :
> >>> Aah that is a nice trick, I was getting ready to fork, clone the fork
> and
> >>> redo the work, but that worked fine ! Thank you Barry !
> >>> The MR will appear in a little while !
> >>> Thibault
> >>> Le ven. 18 déc. 2020 à 10:16, Barry Smith <bsmith at petsc.dev> a écrit :
> >>>>   Good question.  There is a trick to limit the amount of work you
> need
> >>>> to do with a  new fork after you have already made changes with a
> PETSc
> >>>> clone, but it looks like we do not document this clearly in the
> webpages.
> >>>> (I couldn't find it).
> >>>>   Yes, you do need to make a fork, but after you have made the fork on
> >>>> the GitLab website (and have done nothing on your machine) edit the
> file
> >>>> $PETSC_DIR/.git/config  for your clone on your machine
> >>>>   Locate the line that has url = git at gitlab.com:petsc/petsc.git
> (this
> >>>> may have an https at the beginning of the line)
> >>>>   Change this line to point to the fork url instead with git@ not
> >>>> https, which will be pretty much the same URL but with your user id
> instead
> >>>> of petsc in the address.  Then git push and it will push to your fork.
> >>>>   Now you changes will be in your fork and you can make the MR from
> your
> >>>> fork URL on Gitlab. (In other words this editing trick converts your
> PETSc
> >>>> clone on your machine to a PETSc fork).
> >>>>   I hope I have explained this clearly enough it goes smoothly.
> >>>>   Barry
> >>>> On Dec 18, 2020, at 3:00 AM, Thibault Bridel-Bertomeu <
> >>>> Hello Barry,
> >>>> I'll start the MR as soon as possible then so that specialists can
> >>>> indeed have a look. Do I have to fork PETSc to start a MR or are
> PETSc repo
> >>>> settings such that can I push a branch from the PETSc clone I got ?
> >>>> Thibault
> >>>> Le mer. 16 déc. 2020 à 07:47, Barry Smith <bsmith at petsc.dev> a écrit
> >>>>>   Thibault,
> >>>>>   A subdirectory for the example is fine; we have other examples that
> >>>>> use subdirectories and multiple files.
> >>>>>   Note: even if you don't have something completely working you can
> >>>>> still make MR and list it as DRAFT request for comments, some other
> PETSc
> >>>>> members who understand the packages you are using and Fortran better
> than I
> >>>>> may be able to help as you develop the code.
> >>>>>   Barry
> >>>>> On Dec 16, 2020, at 12:35 AM, Thibault Bridel-Bertomeu <
> >>>>> Hello everyone,
> >>>>> Thank you Barry for the feedback.
> >>>>> OK, yes I'll work up an MR as soon as I have got something working.
> By
> >>>>> the way, does the fortran-version of the example have to be a single
> file ?
> >>>>> If my push contains a directory with several files (different
> modules and
> >>>>> the main), and the Makefile that goes with it, is that ok ?
> >>>>> Le mer. 16 déc. 2020 à 04:46, Barry Smith <bsmith at petsc.dev> a
> écrit :
> >>>>>>   This is great. If you make a branch off of the PETSc  git
> repository
> >>>>>> with these additions and work on ex11 you can make a merge request
> and we
> >>>>>> can run the code easily on all our test systems (for security
> reasons one
> >>>>>> of use needs to launch the tests from your MR).
> >>>>>> https://docs.petsc.org/en/latest/developers/integration/
> >>>>>>    Barry
> >>>>>> On Dec 15, 2020, at 5:35 AM, Thibault Bridel-Bertomeu <
> >>>>>> Hello everyone,
> >>>>>> So far, I have the wrappers in the files attached to this e-mail. I
> >>>>>> still do not know if they work properly - at least the code
> compiles and
> >>>>>> the calls to the wrapped-subroutine do not fail - but I wanted to
> put this
> >>>>>> here in case someone sees something really wrong with it already.
> >>>>>> Thank you again for your help, I'll try to post updates of the F90
> >>>>>> version of ex11 regularly in this thread.
> >>>>>> Stay safe,
> >>>>>> Le dim. 13 déc. 2020 à 16:39, Jed Brown <jed at jedbrown.org> a écrit
> writes:
> >>>>>>> > Thank you Mark for your answer.
> >>>>>>> > I am not sure what you think could be in the setBC1 routine ? How
> >>>>>>> to make
> >>>>>>> > the connection with the PetscDS ?
> >>>>>>> > On the other hand, I actually found after a while TSMonitorSet
> has a
> >>>>>>> > fortran wrapper, and it does take as arguments two function
> >>>>>>> pointers, so I
> >>>>>>> > guess it is possible ? Although I am not sure exactly how to play
> >>>>>>> with the
> >>>>>>> > PetscObjectSetFortranCallback & PetscObjectUseFortranCallback
> >>>>>>> macros -
> >>>>>>> > could anybody advise please ?
> >>>>>>> tsmonitorset_ is a good example to follow. In your file, create one
> >>>>>>> of these static structs with a member for each callback. These are
> IDs that
> >>>>>>> will be used as keys for Fortran callbacks and their contexts. The
> salient
> >>>>>>> parts of the file are below.
> >>>>>>> static struct {
> >>>>>>>   PetscFortranCallbackId prestep;
> >>>>>>>   PetscFortranCallbackId poststep;
> >>>>>>>   PetscFortranCallbackId rhsfunction;
> >>>>>>>   PetscFortranCallbackId rhsjacobian;
> >>>>>>>   PetscFortranCallbackId ifunction;
> >>>>>>>   PetscFortranCallbackId ijacobian;
> >>>>>>>   PetscFortranCallbackId monitor;
> >>>>>>>   PetscFortranCallbackId mondestroy;
> >>>>>>>   PetscFortranCallbackId transform;
> >>>>>>> #if defined(PETSC_HAVE_F90_2PTR_ARG)
> >>>>>>>   PetscFortranCallbackId function_pgiptr;
> >>>>>>> #endif
> >>>>>>> } _cb;
> >>>>>>>    Note ctx is the same as ts so we need to get the Fortran context
> >>>>>>> out of the TS; this gets put in _ctx using the callback ID
> >>>>>>> static PetscErrorCode ourmonitor(TS ts,PetscInt i,PetscReal d,Vec
> >>>>>>> v,void *ctx)
> PetscObjectUseFortranCallback(ts,_cb.monitor,(TS*,PetscInt*,PetscReal*,Vec
> >>>>>>> *,void*,PetscErrorCode*),(&ts,&i,&d,&v,_ctx,&ierr));
> >>>>>>> Then follow as in tsmonitorset_, which sets two callbacks.
> >>>>>>> PETSC_EXTERN void tsmonitorset_(TS *ts,void
> >>>>>>> (*func)(TS*,PetscInt*,PetscReal*,Vec*,void*,PetscErrorCode*),void
> >>>>>>> *mctx,void (*d)(void*,PetscErrorCode*),PetscErrorCode *ierr)
> >>>>>>>   CHKFORTRANNULLFUNCTION(d);
> >>>>>>>   if ((PetscVoidFunction)func == (PetscVoidFunction)
> >>>>>>> tsmonitordefault_) {
> >>>>>>>     *ierr = TSMonitorSet(*ts,(PetscErrorCode
> (*)(TS,PetscInt,PetscReal,Vec,void*))TSMonitorDefault,*(PetscViewerAndFormat**)mctx,(PetscErrorCode
> >>>>>>> (*)(void **))PetscViewerAndFormatDestroy);
> >>>>>>>   } else {
> >>>>>>>     *ierr =
> PetscObjectSetFortranCallback((PetscObject)*ts,PETSC_FORTRAN_CALLBACK_CLASS,&_cb.monitor,(PetscVoidFunction)func,mctx);
> >>>>>>>     *ierr =
> PetscObjectSetFortranCallback((PetscObject)*ts,PETSC_FORTRAN_CALLBACK_CLASS,&_cb.mondestroy,(PetscVoidFunction)d,mctx);
> >>>>>>>     *ierr = TSMonitorSet(*ts,ourmonitor,*ts,ourmonitordestroy);
> >>>>>> <wrapper_petsc.h90><wrapper_petsc.c>
Eng, MSc, PhD
Research Engineer
CEA/CESTA
33114 LE BARP
Tel.: (+33)557046924
Mob.: (+33)611025322
Mail: thibault.bridelbertomeu at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201228/1f5c0d73/attachment-0001.html>
