[petsc-users] Output cell data related to DMDA
Denis Davydov
davydden at gmail.com
Fri Dec 18 02:29:05 CST 2020
Hi Matt,
By global vector you mean one created with
VecCreateMPI(..., nel, PETSC_DETERMINE,...)
? If so, that gives segfault (even with 1 MPI process) in user write function, which is just
VecView((Vec)obj,viewer);
which clearly indicates that I misunderstand your comment.
Would you please clarify what PETSc expect as a “global” vector in case of cell-based quantities as opposed to unknowns/fields associated with the DMDA discretization?
Sincerely,
Denis
> Am 17.12.2020 um 18:58 schrieb Matthew Knepley <knepley at gmail.com>:
>> On Thu, Dec 17, 2020 at 12:18 PM Denis Davydov <davydden at gmail.com> wrote:
>> Dear all,
>> I would like to output cell data (eg conductivity coefficient) in VTK for DMDA setup.
>> Given that I know how many elements/cells are owned locally, I hoped that PetscViewerVTKAddField with PETSC_VTK_CELL_FIELD would do the job.
>> However I am not sure whether provided vector should be fully distributed (no ghosts)? If not, can I get the required ghosts from DMDA created with DMDACreate3D ?
> I believe that it outputs global vectors, meaning that there are no ghosts.
> Thanks,
> Matt
>> Ps. I saw just one relevant discussion on the mailing list.
>> Sincerely,
>> Denis
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201218/6edbd9a2/attachment-0001.html>
