[petsc-users] Multiplying a row-vector to each row in a dense matrix, sliced or full
Roland Richter
roland.richter at ntnu.no
Tue Dec 8 16:16:29 CST 2020
Yes, that would be exactly what I need, I have not thought about that
possibility, thanks!
Concerning slicing: Assumed my matrix A and vector v are defined by
A = |a b|
|c d|
v = |w x y z|
After v is larger than the row size of A, I only can take some elements
for multiplication and therefore I have to use only a slice of vector v:
A*v[1:2] = |xa yb|
|xc yd|
or
A*v[0:1] = |wa xb|
|wc xd|
How could I do that?
Roland
Am 08.12.2020 um 19:26 schrieb Matthew Knepley:
> On Tue, Dec 8, 2020 at 1:13 PM Roland Richter <roland.richter at ntnu.no
> <mailto:roland.richter at ntnu.no>> wrote:
> Hei,
> I would like to multiply a row-vector to each row in a dense matrix,
> either full or sliced (i.e. if the row-vector is larger than the row
> length of the matrix). Armadillo offers a each_row()-function, where I
> can iterate over all rows in a matrix and multiply the vector to them
> (similar to the operation VecPointwiseMult()). Is there a similar
> operation in PETSc? Ideally with the option of only multiplying a
> part/slice of the row vector to each row, if the corresponding row of
> the target matrix is shorter than the initial row vector.
> It helps to write in linear algebra notation so that we can be sure we
> are talking
> about the same thing. Say we have the matrix A and vector v
> A = / a b \ v = <m, n>
> \ c d /
> and you want
> A * m = / ma nb \ = / a b \ / m 0 \ = A . diag(v)
> \ mc nd / \ c d / \ 0 n /
> which you can get
> using https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatDiagonalScale.html
> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatDiagonalScale.html>
> is that what you want? I do not have a clear picture of what you want
> slicing for.
> Thanks,
> Matt
> Thanks,
> Roland
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201208/a73b8caf/attachment.html>
