[petsc-users] Multiplying a row-vector to each row in a dense matrix, sliced or full
    Matthew Knepley
    knepley at gmail.com
    Tue Dec  8 12:26:35 CST 2020
On Tue, Dec 8, 2020 at 1:13 PM Roland Richter <roland.richter at ntnu.no>
wrote:
> Hei,
> I would like to multiply a row-vector to each row in a dense matrix,
> either full or sliced (i.e. if the row-vector is larger than the row
> length of the matrix). Armadillo offers a each_row()-function, where I
> can iterate over all rows in a matrix and multiply the vector to them
> (similar to the operation VecPointwiseMult()). Is there a similar
> operation in PETSc? Ideally with the option of only multiplying a
> part/slice of the row vector to each row, if the corresponding row of
> the target matrix is shorter than the initial row vector.
It helps to write in linear algebra notation so that we can be sure we are
talking
about the same thing. Say we have the matrix A and vector v
  A = / a b \  v = <m, n>
        \ c d /
and you want
  A * m = / ma nb \ = / a b \ / m 0 \ = A . diag(v)
               \ mc nd /    \ c d /  \ 0  n /
which you can get using
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatDiagonalScale.html
is that what you want? I do not have a clear picture of what you want
slicing for.
     Matt
> Thanks,
> Roland
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201208/9552b031/attachment.html>
