[petsc-users] Load a dense matrix, distribute it over several MPI nodes and retrieve it afterwards
Matthew Knepley
knepley at gmail.com
Fri Dec 4 06:13:18 CST 2020
On Fri, Dec 4, 2020 at 6:51 AM Roland Richter <roland.richter at ntnu.no>
wrote:
> Hei,
> is it possible to fill a dense distributed matrix from existing data in
> rank 0, distribute it to all involved nodes and retrieve it afterwards,
> such that it can be stored in a single matrix in rank 0 again? The
> background behind this question is the following thought process:
> - I generate the matrix locally on node 0
> I do not understand why you would ever want to do this.
> - I distribute it to all involved nodes
> Just create your distributed matrix, but set the values from rank 0.
> - I use the matrix for data processing/process the matrix data on all
> nodes
> I assume you change the matrix here.
> - For storing the data I need it back on node 0 in a single matrix
> You can use
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateRedundantMatrix.html
to easily create serial matrices from it. You can throw away any you do not
want.
Matt
> For testing I wrote the following code (and using armadillo for generating
> the initial matrices within arma-namespace):
> * Mat C, F;*
> * Vec x, y, z;*
> * PetscViewer viewer;*
> * PetscMPIInt rank, size;*
> * PetscInitialize(&argc, &args, (char*) 0, help);*
> * MPI_Comm_size(PETSC_COMM_WORLD, &size);*
> * MPI_Comm_rank(PETSC_COMM_WORLD, &rank);*
> * PetscPrintf(PETSC_COMM_WORLD,"Number of processors = %d, rank =
> %d\n", size, rank);*
> * PetscViewerCreate(PETSC_COMM_WORLD, &viewer);*
> * PetscViewerSetType(viewer, PETSCVIEWERASCII);*
> * arma::cx_mat local_mat, local_zero_mat;*
> * const size_t matrix_size = 5;*
> * if(rank == 0) {*
> * local_mat = arma::randu<arma::cx_mat>(matrix_size, matrix_size);*
> * local_zero_mat = arma::zeros<arma::cx_mat>(matrix_size,
> matrix_size);*
> * MatCreateDense(PETSC_COMM_WORLD, matrix_size, matrix_size,
> PETSC_DECIDE, PETSC_DECIDE, local_mat.memptr(), &C);*
> * MatAssemblyBegin(C, MAT_FINAL_ASSEMBLY);*
> * MatAssemblyEnd(C, MAT_FINAL_ASSEMBLY);*
> PETSC_DECIDE, PETSC_DECIDE, NULL, &F);*
> * if(rank == 0)*
> * MatCopy(C, F, SAME_NONZERO_PATTERN);*
> * MatAssemblyBegin(F, MAT_FINAL_ASSEMBLY);*
> * MatAssemblyEnd(F, MAT_FINAL_ASSEMBLY);*
> * if(rank == 0) {*
> * MatView(C, viewer);*
> * std::cout << local_mat << '\n';*
> * std::cout << local_zero_mat << '\n';*
> * //How can I retrieve the distributed data from F to C again when
> running on multiple nodes?*
> * if(rank == 0) {*
> * MatDestroy(&C);*
> * MatDestroy(&F);*
> * PetscViewerDestroy(&viewer);*
> Running the code with mpirun -n 1 works fine, but when running it with
> mpirun -n 2 it just stops after *PetscPrintf() *and hangs.
> Moreover, how can I retrieve the data from matrix F afterwards? For
> vectors I have the function/class VecScatter, but can I apply this for
> matrices (mpidense) too?
> Thanks!
> Cheers,
> Roland
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201204/b87272d5/attachment.html>
