[petsc-users] [Ext] change matrix
Barry Smith bsmith at petsc.dev
Mon Aug 31 14:11:10 CDT 2020
> On Aug 31, 2020, at 2:08 PM, Kun Jiao <KJiao at slb.com> wrote:
> If I am correct, to do this, it will double the peak memory usage.
  Yes
> Is there any way no to double the peak memory usage?
  The only way would be to destroy the old matrix, allocate a new one and recompute the entries.
  Barry
  Depending on the application etc the extra memory for storing two copies of the matrix may not be a fundamental problem.
> Schlumberger-Private
> From: Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>
> Sent: Monday, August 31, 2020 1:56 PM
> To: Kun Jiao <KJiao at slb.com <mailto:KJiao at slb.com>>
> Cc: petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
> Subject: [Ext] Re: [petsc-users] change matrix
>   Kun,
>    This is not possible, PETSc matrices have a static size (resizing in parallel is tricky so we don't support it).
>    If it is more efficient to reuse the matrix entries than recompute them you can create a larger matrix and then loop over the old matrix calling MatGetRow() and then call MatSetValues() to copy that row into the new matrix.
>   Barry
> On Aug 31, 2020, at 1:51 PM, Kun Jiao via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Hi Petsc Experts,
> Trying to do something like appending some rows (~100 rows) to an already created matrix, but could not find any document about it.
> Could anyone provide some information about it?
> Regards,
> Kun
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200831/2c72452f/attachment-0001.html>
