[petsc-users] [Ext] Re: change matrix
Kun Jiao KJiao at slb.com
Mon Aug 31 14:08:27 CDT 2020
If I am correct, to do this, it will double the peak memory usage.
Is there any way no to double the peak memory usage?
Schlumberger-Private
Sent: Monday, August 31, 2020 1:56 PM
To: Kun Jiao <KJiao at slb.com>
Cc: petsc-users <petsc-users at mcs.anl.gov>
Subject: [Ext] Re: [petsc-users] change matrix
  Kun,
   This is not possible, PETSc matrices have a static size (resizing in parallel is tricky so we don't support it).
   If it is more efficient to reuse the matrix entries than recompute them you can create a larger matrix and then loop over the old matrix calling MatGetRow() and then call MatSetValues() to copy that row into the new matrix.
  Barry
On Aug 31, 2020, at 1:51 PM, Kun Jiao via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hi Petsc Experts,
Trying to do something like appending some rows (~100 rows) to an already created matrix, but could not find any document about it.
Could anyone provide some information about it?
Kun
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200831/e52352b8/attachment.html>
