[petsc-users] Unexplained memory leaks
Fri Aug 28 06:40:12 CDT 2020
OpenMPI leaks memory at the end. As you can see it is small, so they are
unmotivated to fix that.
     Matt
On Fri, Aug 28, 2020 at 4:31 AM baikadi pranay <pranayreddy865 at gmail.com>
wrote:
> Hi,
> I am building a 2D solver for the semiconductor Poisson-Boltzmann
> equation. I detected a memory leak when running the program using valgrind
> but I am unable to solve this issue as there are no signs in the valgrind
> output indicating that the source of the error is in the modules I have
> written. I am attaching you a text file containing the valgrind output.
> I have seen that a similar question was asked earlier (found here
> <https://lists.mcs.anl.gov/pipermail/petsc-users/2010-October/007132.html>)
> but I could not find a final solution to that problem. Could you let me
> know the source of the problem?
> Please let me know if you need any further information.
> Thank you,
> Pranay.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200828/59accfa6/attachment.html>
