[petsc-users] About KSPConvergedReasonView
Jose E. Roman jroman at dsic.upv.es
Fri Aug 28 04:52:48 CDT 2020
Thibaut: the changes that Barry mentioned are already in master. Can you try?
Barry: I think the issue is with the PetscViewer argument. KSPView() has a custom Fortran stub that calls PetscPatchDefaultViewers_Fortran(), but this is missing in KSPConvergedReasonView().
Jose
> El 27 ago 2020, a las 17:59, Barry Smith <bsmith at petsc.dev> escribió:
>  This is probably due to the final argument being a character string which PETSc has difficulty managing by default for Fortran.
>  I just removed the format argument from the call so this problem will gone soon.
>  You could just comment out the call for now and put a print statement in instead.
>  The problem will be fixed as soon as my merge request gets into master.
>  Sorry about this.
>  Barry
>> On Aug 27, 2020, at 10:25 AM, Thibaut Appel <t.appel17 at imperial.ac.uk> wrote:
>> Dear PETSc users,
>> I found out that (at least in the master branch) that KSPReasonView has been recently deprecated in favor of KSPConvergedReasonView.
>> After changing my application code, I thought I was using the function correctly:
>>    CALL KSPGetConvergedReason(ksp,ksp_reason,ierr)
>>    CHKERRA(ierr)
>>    IF (ksp_reason < 0) THEN
>>      CALL KSPConvergedReasonView(ksp,PETSC_VIEWER_STDOUT_WORLD,PETSC_VIEWER_DEFAULT,ierr)
>>      CHKERRA(ierr)
>>    END IF
>> but I still get the following backtrace
>> Program received signal SIGSEGV, Segmentation fault.
>> 0x00007ffff51dea59 in PetscObjectTypeCompare (obj=0x8,
>>    type_name=0x7ffff75b5b88 "ascii", same=0x7fffffffd7b8)
>>    at /home/Packages/petsc/src/sys/objects/destroy.c:160
>> 160      else if (!type_name || !obj->type_name) *same = PETSC_FALSE;
>> (gdb) bt
>> #0  0x00007ffff51dea59 in PetscObjectTypeCompare (obj=0x8,
>> #1  0x00007ffff6ba1d83 in KSPConvergedReasonView (ksp=0x555555bb2510, viewer=0x8,
>>    format=PETSC_VIEWER_DEFAULT)
>>    at /home/Packages/petsc/src/ksp/ksp/interface/itfunc.c:452
>> #2  0x00007ffff6beb37a in kspconvergedreasonview_ (
>>    ksp=0x55555593f3c0 <__solver_MOD_ksp>, viewer=0x7fffffffda50,
>>    format=0x5555558fae48, __ierr=0x7fffffffda6c)
>>    at /home/Packages/petsc/src/ksp/ksp/interface/ftn-auto/itfuncf.c:295
>> #3  0x00005555555e040d in solver::solve_linear_problem (vec_rhs=..., vec_sol=...)
>>    at mod_solver.F90:1872
>> #4  0x0000555555614453 in solver::solve () at mod_solver.F90:164
>> #5  0x00005555555ba3c6 in main () at main.F90:67
>> #6  0x00005555555ba437 in main (argc=1, argv=0x7fffffffe17e) at main.F90:3
>> #7  0x00007ffff46fa1e3 in __libc_start_main ()
>>   from /usr/lib/x86_64-linux-gnu/libc.so.6
>> #8  0x000055555555cd7e in _start ()
>> as if there was a type mismatch. Could anyone pinpoint what's wrong?
>> Thank you,
>> Thibaut
