[petsc-users] About KSPConvergedReasonView
Barry Smith
bsmith at petsc.dev
Thu Aug 27 10:59:33 CDT 2020
This is probably due to the final argument being a character string which PETSc has difficulty managing by default for Fortran.
I just removed the format argument from the call so this problem will gone soon.
You could just comment out the call for now and put a print statement in instead.
The problem will be fixed as soon as my merge request gets into master.
Sorry about this.
Barry
> On Aug 27, 2020, at 10:25 AM, Thibaut Appel <t.appel17 at imperial.ac.uk> wrote:
> Dear PETSc users,
> I found out that (at least in the master branch) that KSPReasonView has been recently deprecated in favor of KSPConvergedReasonView.
> After changing my application code, I thought I was using the function correctly:
> CALL KSPGetConvergedReason(ksp,ksp_reason,ierr)
> CHKERRA(ierr)
> IF (ksp_reason < 0) THEN
> CALL KSPConvergedReasonView(ksp,PETSC_VIEWER_STDOUT_WORLD,PETSC_VIEWER_DEFAULT,ierr)
> CHKERRA(ierr)
> END IF
> but I still get the following backtrace
> Program received signal SIGSEGV, Segmentation fault.
> 0x00007ffff51dea59 in PetscObjectTypeCompare (obj=0x8,
> type_name=0x7ffff75b5b88 "ascii", same=0x7fffffffd7b8)
> at /home/Packages/petsc/src/sys/objects/destroy.c:160
> 160 else if (!type_name || !obj->type_name) *same = PETSC_FALSE;
> (gdb) bt
> #0 0x00007ffff51dea59 in PetscObjectTypeCompare (obj=0x8,
> #1 0x00007ffff6ba1d83 in KSPConvergedReasonView (ksp=0x555555bb2510, viewer=0x8,
> format=PETSC_VIEWER_DEFAULT)
> at /home/Packages/petsc/src/ksp/ksp/interface/itfunc.c:452
> #2 0x00007ffff6beb37a in kspconvergedreasonview_ (
> ksp=0x55555593f3c0 <__solver_MOD_ksp>, viewer=0x7fffffffda50,
> format=0x5555558fae48, __ierr=0x7fffffffda6c)
> at /home/Packages/petsc/src/ksp/ksp/interface/ftn-auto/itfuncf.c:295
> #3 0x00005555555e040d in solver::solve_linear_problem (vec_rhs=..., vec_sol=...)
> at mod_solver.F90:1872
> #4 0x0000555555614453 in solver::solve () at mod_solver.F90:164
> #5 0x00005555555ba3c6 in main () at main.F90:67
> #6 0x00005555555ba437 in main (argc=1, argv=0x7fffffffe17e) at main.F90:3
> #7 0x00007ffff46fa1e3 in __libc_start_main ()
> from /usr/lib/x86_64-linux-gnu/libc.so.6
> #8 0x000055555555cd7e in _start ()
> as if there was a type mismatch. Could anyone pinpoint what's wrong?
> Thank you,
> Thibaut
