[petsc-users] error: invalid types ‘PetscScalar* {aka double*}[PetscScalar {aka double}]’ for array subscript
Fri Aug 21 11:19:34 CDT 2020
On Fri, Aug 21, 2020 at 11:49 AM Smit Thijs <thijs.smit at hest.ethz.ch> wrote:
> Hi All,
> I am having the following error when I try to do a mapping with vectors
> and I can’t figure out how to solve this or what is going wrong:
>              xpMMA[i] = xp[indicesMap[i]];
> Herewith two code snippets:
>     // total number of elements on core
>     PetscInt nel;
>     VecGetLocalSize(xPhys, &nel);
>     // create xPassive vector
>     ierr = VecDuplicate(xPhys, &xPassive);
>     CHKERRQ(ierr);
>     // create mapping vector
>     ierr = VecDuplicate(xPhys, &indicator);
>     CHKERRQ(ierr);
>     // index set for xPassive and indicator
>     PetscScalar *xpPassive, *xpIndicator;
>     ierr = VecGetArray(xPassive, &xpPassive);
>     CHKERRQ(ierr);
>     ierr = VecGetArray(indicator, &xpIndicator);
>     CHKERRQ(ierr);
>     // counters for total and active elements on this processor
>     PetscInt tcount = 0; // total number of elements
>     PetscInt acount = 0; // number of active elements
>     PetscInt scount = 0; // number of solid elements
>     PetscInt rcount = 0; // number of rigid element
>     // loop over all elements and update xPassive from wrapper data
>     // count number of active elements, acount
>     // set indicator vector
>     for (PetscInt el = 0; el < nel; el++) {
>         if (data.xPassive_w.size() > 1) {
>             xpPassive[el] = data.xPassive_w[el];
>             tcount++;
>             if (xpPassive[el] < 0) {
>                 xpIndicator[acount] = el;
>                 acount++;
>         } else {
>             xpPassive[el] = -1.0; // default, if no xPassive_w than all
> elements are active = -1.0
>     // printing
>     //PetscPrintf(PETSC_COMM_WORLD, "tcount: %i\n", tcount);
>     //PetscPrintf(PETSC_COMM_WORLD, "acount: %i\n", acount);
>     // Allreduce, get number of active elements over all processes
>     // tmp number of var on proces
>     // acount total number of var sumed
>     PetscInt tmp = acount;
>     acount = 0.0;
>     MPI_Allreduce(&tmp, &(acount), 1, MPIU_INT, MPI_SUM, PETSC_COMM_WORLD);
>     //// create xMMA vector
> VecCreateMPI(PETSC_COMM_WORLD, tmp, acount, &xMMA);
>    // Pointers to the vectors
>     PetscScalar *xp, *xpMMA, *indicesMap;
Here you declare indicesMap as PetscScalar[]. You cannot index an array
with this. I see that you
want to store these indices in a Vec. You should use an IS instead.
     Matt
>     //PetscInt indicesMap;
>     ierr = VecGetArray(MMAVector, &xpMMA);
>     CHKERRQ(ierr);
>     ierr = VecGetArray(elementVector, &xp);
>     CHKERRQ(ierr);
>     // Index set
>     PetscInt nLocalVar;
>     VecGetLocalSize(xMMA, &nLocalVar);
>     // print number of var on pocessor
>     PetscPrintf(PETSC_COMM_WORLD, "Local var: %i\n", nLocalVar);
>     ierr = VecGetArray(indicator, &indicesMap);
>     CHKERRQ(ierr);
>     // Run through the indices
>     for (PetscInt i = 0; i < nLocalVar; i++) {
>         if (updateDirection > 0) {
>             //PetscPrintf(PETSC_COMM_WORLD, "i: %i, xp[%i] = %f\n", i,
> indicesMap[i], xp[indicesMap[i]]);
>         } else if (updateDirection < 0) {
>             xp[indicesMap[i]] = xpMMA[i];
>     // Restore
>     ierr = VecRestoreArray(elementVector, &xp);
>     CHKERRQ(ierr);
>     ierr = VecRestoreArray(MMAVector, &xpMMA);
>     CHKERRQ(ierr);
>     ierr = VecRestoreArray(indicator, &indicesMap);
>     CHKERRQ(ierr);
>     PetscPrintf(PETSC_COMM_WORLD, "FINISHED UpdateVariables \n");
> The error message says that the type with which I try to index is wrong, I
> think. But VecGetArray only excepts scalars. Furthermore, the el variable
> is an int, but is seams like to turn out to be a scalar. Does anybody see
> how to proceed with this?
> Best regards,
> Thijs Smit
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200821/f8d4a19b/attachment.html>
