[petsc-users] MatAssemblyEnd taking too long
Stefano Zampini stefano.zampini at gmail.com
Thu Aug 20 08:31:26 CDT 2020
Manav
Can you add a MPI_Barrier before
ierr = MatAssemblyBegin(aij->A,mode);CHKERRQ(ierr);
Also, in order to assess where the issue is, we need to see the values (per rank) of
((Mat_SeqAIJ*)aij->B->data)->nonew
mat->was_assembled
aij->donotstash
mat->nooffprocentries
Another question: is this the first matrix assembly of the code?
If you change to pc_none, do you get the same issue?
> On Aug 20, 2020, at 3:10 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
>> On Aug 19, 2020, at 9:39 PM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> Jed is more knowledgeable about the communication, but I have a simple question about the FEM method. Normally, the way
>> we divide unknowns is that the only unknowns which might have entries computed off-process are those on the partition boundary.
>> However, it sounds like you have a huge number of communicated values. Is it possible that the division of rows in your matrix does
>> not match the division of the cells you compute element matrices for?
> I hope that is not the case. I am using libMesh to manage the mesh and creation of sparsity pattern, which uses Parmetis to create the partitions.
> libMesh ensures that off-process entries are only at the partition boundary (unless an extra set of DoFs are marked for coupling.
> I also printed and looked at the n_nz and n_oz values on each rank and it does not seem to raise any flags.
> I will try to dig in a bit further to make sure everything checks out.
> Looking at the screenshots I had shared yesterday, all processes are in this function:
> PetscErrorCode MatAssemblyEnd_MPIAIJ(Mat mat,MatAssemblyType mode)
>   Mat_MPIAIJ     *aij = (Mat_MPIAIJ*)mat->data;
>   Mat_SeqAIJ     *a   = (Mat_SeqAIJ*)aij->A->data;
>   PetscErrorCode ierr;
>   PetscMPIInt    n;
>   PetscInt       i,j,rstart,ncols,flg;
>   PetscInt       *row,*col;
>   PetscBool      other_disassembled;
>   PetscScalar    *val;
>   /* do not use 'b = (Mat_SeqAIJ*)aij->B->data' as B can be reset in disassembly */
>   PetscFunctionBegin;
>   if (!aij->donotstash && !mat->nooffprocentries) {
>     while (1) {
>       ierr = MatStashScatterGetMesg_Private(&mat->stash,&n,&row,&col,&val,&flg);CHKERRQ(ierr);
>       if (!flg) break;
>       for (i=0; i<n; ) {
>         /* Now identify the consecutive vals belonging to the same row */
>         for (j=i,rstart=row[j]; j<n; j++) {
>           if (row[j] != rstart) break;
>         if (j < n) ncols = j-i;
>         else       ncols = n-i;
>         /* Now assemble all these values with a single function call */
>         ierr = MatSetValues_MPIAIJ(mat,1,row+i,ncols,col+i,val+i,mat->insertmode);CHKERRQ(ierr);
>         i = j;
>     ierr = MatStashScatterEnd_Private(&mat->stash);CHKERRQ(ierr);
>   ierr = MatAssemblyEnd(aij->A,mode);CHKERRQ(ierr);
>   /* determine if any processor has disassembled, if so we must
>      also disassemble ourselfs, in order that we may reassemble. */
>      if nonzero structure of submatrix B cannot change then we know that
>      no processor disassembled thus we can skip this stuff
>   if (!((Mat_SeqAIJ*)aij->B->data)->nonew) {
>     ierr = MPIU_Allreduce(&mat->was_assembled,&other_disassembled,1,MPIU_BOOL,MPI_PROD,PetscObjectComm((PetscObject)mat));CHKERRQ(ierr);
>     if (mat->was_assembled && !other_disassembled) {
>       ierr = MatDisAssemble_MPIAIJ(mat);CHKERRQ(ierr);
>   if (!mat->was_assembled && mode == MAT_FINAL_ASSEMBLY) {
>     ierr = MatSetUpMultiply_MPIAIJ(mat);CHKERRQ(ierr);
>   ierr = MatSetOption(aij->B,MAT_USE_INODES,PETSC_FALSE);CHKERRQ(ierr);
>   ierr = MatAssemblyBegin(aij->B,mode);CHKERRQ(ierr);
>   ierr = MatAssemblyEnd(aij->B,mode);CHKERRQ(ierr);
>   ierr = PetscFree2(aij->rowvalues,aij->rowindices);CHKERRQ(ierr);
>   aij->rowvalues = 0;
>   ierr = VecDestroy(&aij->diag);CHKERRQ(ierr);
>   if (a->inode.size) mat->ops->multdiagonalblock = MatMultDiagonalBlock_MPIAIJ;
>   /* if no new nonzero locations are allowed in matrix then only set the matrix state the first time through */
>   if ((!mat->was_assembled && mode == MAT_FINAL_ASSEMBLY) || !((Mat_SeqAIJ*)(aij->A->data))->nonew) {
>     PetscObjectState state = aij->A->nonzerostate + aij->B->nonzerostate;
>     ierr = MPIU_Allreduce(&state,&mat->nonzerostate,1,MPIU_INT64,MPI_SUM,PetscObjectComm((PetscObject)mat));CHKERRQ(ierr);
>   PetscFunctionReturn(0);
>  I noticed that of the 8 MPI processes, 2 were stuck at
> Other two were stuck at
> And remaining four were under
> Is it expected for processes to be at different stages in this function?
> -Manav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200820/e95a31cb/attachment-0001.html>
