[petsc-users] Singular Eigenproblem with SLEPc
Jose E. Roman jroman at dsic.upv.es
Sun Aug 16 01:50:42 CDT 2020
Nothing special is required for solving a GHEP with singular M, except for setting the problem type as GHEP, see https://slepc.upv.es/documentation/current/src/eps/tutorials/ex13.c.html
Jose
> El 16 ago 2020, a las 1:09, Nidish <nb25 at rice.edu> escribió:
> Hello,
> I'm presently working with a large finite element model with several RBE3 constraints with "virtual" 6DOF nodes in the model.
> I have about ~36000 3DOF nodes making up my model and about ~10 RBE3 virtual nodes (which have zero intrinsic mass and stiffness). I've extracted the matrices from Abaqus.
> The way these constraints are implemented is by introducing static linear constraints (populating the stiffness matrix) and padding the mass matrix with zero rows and columns in the rows corresponding to the virtual nodes. So this leaves me with an eigenproblem of the form,
> K.v = lam*M.v
> where M is singular but the eigenproblem is well defined. Abaqus seems to solve this perfectly well, but after exporting the matrices, I'm struggling to get slepc to solve this. The manual talks about deflation, etc., but I couldn't really understand too much.
> Is there any example code for such a case with a singular matrix where these procedures are carried out? Or could you provide references/guidances for approaching the problem?
> Thank you,
> Nidish
