[petsc-users] MatSetValues vs MatSetValuesBlocked
Jed Brown jed at jedbrown.org
Mon Aug 10 16:55:07 CDT 2020
It looks like you haven't called MatSetBlockSize.  Is this a 1D model with scalar displacement, thus block size of 1?
Nidish <nb25 at rice.edu> writes:
> Hello,
> I've written a basic FE code of an Euler-Bernoulli Beam (4th order
> spatial deriv interpolated using Hermite elements).
> While assembling matrices I noticed something peculiar - if I conducted
> assembly using MatSetValues it works, while if I did so using
> MatSetValuesBlocked it throws me an argument out of range error. You can
> observe this in the attached file in lines 94-95 where I have one
> version commented out and the other version active.
> I.O.W., using
>      MatSetValues(jac, 4, (const PetscInt*)idx, 4, (const
> PetscInt*)idx,(const PetscScalar*)elstiff, ADD_VALUES);
> works, while
>      MatSetValuesBlocked(jac, 4, (const PetscInt*)idx, 4, (const
> does NOT work.
> Also from the documentation I could not really understand what the
> difference was between these two.
> Thank you,
> Nidish
> static char help[] = "1D Euler-Bernoulli Beam.\n";
> #include <petscdm.h>
> #include <petscdmda.h>
> #include <petscvec.h>
> #include <petscksp.h>
> #include <petscmat.h>
> PetscErrorCode RHSFun(KSP, Vec, void*);
> PetscErrorCode StiffMat(KSP, Mat, Mat, void*);
> typedef struct {
>   PetscScalar A, E, I2, rho, L, F;
> }Mater;
> int main(int nargs, char *sargs[])
>   PetscErrorCode ierr;
>   PetscInt N=10;
>   PetscMPIInt rank, size;
>   ierr = PetscInitialize(&nargs, &sargs, (char*)0, help);
>   MPI_Comm_rank(PETSC_COMM_WORLD, &rank);
>   MPI_Comm_size(PETSC_COMM_WORLD, &size);
>   PetscOptionsGetInt(NULL, NULL, "-N", &N, NULL);
>   DM mshdm;
>   Mater steelbm = {1.0, 2e11, 1.0/12.0, 7800, 3.0, 1e6};
>   KSP ksp;
>   DMDACreate1d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE, N, 2, 1, NULL, &mshdm);
>   DMSetFromOptions(mshdm);
>   DMSetUp(mshdm);
>   DMSetApplicationContext(mshdm, &steelbm);  /* User Context */
>   KSPCreate(PETSC_COMM_WORLD, &ksp);
>   KSPSetDM(ksp, mshdm);
>   KSPSetComputeRHS(ksp, RHSFun, &steelbm);
>   KSPSetComputeOperators(ksp, StiffMat, &steelbm);
>   KSPSetFromOptions(ksp);
>   KSPSolve(ksp, NULL, NULL);
>   DMDestroy(&mshdm);
>   KSPDestroy(&ksp);
>   PetscFinalize();
>   return 0;
> PetscErrorCode RHSFun(KSP ksp, Vec b, void* ctx)
>   Mater* steelbm = (Mater*)ctx;
>   PetscInt N;
>   VecGetSize(b, &N);
>   for (int i=0; i<N; ++i)
>     VecSetValue(b, i, 0.0, INSERT_VALUES);
>   VecSetValue(b, N-2, steelbm->F, INSERT_VALUES);
>   VecAssemblyBegin(b);
>   ierr = VecAssemblyEnd(b);
>   PetscFunctionReturn(0);
> PetscErrorCode StiffMat(KSP ksp, Mat J, Mat jac, void* ctx)
>   PetscInt N, ix, n;
>   PetscScalar Le, EIbLec;
>   DM mshdm;
>   ierr = KSPGetDM(ksp, &mshdm);
>   ierr = DMDAGetInfo(mshdm, NULL, &N, NULL, NULL, &n, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL);
>   DMDAGetCorners(mshdm, &ix, NULL, NULL, &n, NULL, NULL);
>   Le = steelbm->L/(N-1);
>   EIbLec = steelbm->E*steelbm->I2/pow(Le, 3);
>   PetscInt idx[4];
>   PetscScalar elstiff[4][4] = {{EIbLec*12.0, EIbLec*6*Le, -EIbLec*12.0, EIbLec*6*Le},
>   			       {EIbLec*6*Le, EIbLec*4*Le*Le, -EIbLec*6*Le, EIbLec*2*Le*Le},
>   			       {-EIbLec*12.0, -EIbLec*6.0*Le, EIbLec*12.0, -EIbLec*6*Le},
>   			       {EIbLec*6*Le, EIbLec*2*Le*Le, -EIbLec*6.0*Le, EIbLec*4*Le*Le}};
>   PetscInt is, ie;
>   is = ix;  ie = ix+n;
>   PetscMPIInt rank;
>   for (int e=is; e<((ie<N-1)?ie:(N-1)); ++e) {
>     idx[0] = 2*e; idx[1] = 2*e+1; idx[2] = 2*e+2; idx[3] = 2*e+3;
>     /* MatSetValuesBlocked(jac, 4, (const PetscInt*)idx, 4, (const PetscInt*)idx, */
>     /* 			(const PetscScalar*)elstiff, ADD_VALUES); */
>     MatSetValues(jac, 4, (const PetscInt*)idx, 4, (const PetscInt*)idx,
>   MatAssemblyBegin(jac, MAT_FINAL_ASSEMBLY);
>   ierr = MatAssemblyEnd(jac, MAT_FINAL_ASSEMBLY);
>   PetscInt rows[] = {0, 1};
>   MatZeroRowsColumns(jac, 2, rows, EIbLec*12.0, NULL, NULL);
