[petsc-users] MatSetValues vs MatSetValuesBlocked
Nidish nb25 at rice.edu
Mon Aug 10 15:26:33 CDT 2020
Hello,
I've written a basic FE code of an Euler-Bernoulli Beam (4th order
spatial deriv interpolated using Hermite elements).
While assembling matrices I noticed something peculiar - if I conducted
assembly using MatSetValues it works, while if I did so using
MatSetValuesBlocked it throws me an argument out of range error. You can
observe this in the attached file in lines 94-95 where I have one
version commented out and the other version active.
I.O.W., using
     MatSetValues(jac, 4, (const PetscInt*)idx, 4, (const
PetscInt*)idx,(const PetscScalar*)elstiff, ADD_VALUES);
works, while
     MatSetValuesBlocked(jac, 4, (const PetscInt*)idx, 4, (const
does NOT work.
Also from the documentation I could not really understand what the
difference was between these two.
Thank you,
Nidish
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200810/553a4a2d/attachment.bin>
