[petsc-users] Best practices for solving Dense Linear systems
Nidish nb25 at rice.edu
Fri Aug 7 01:25:31 CDT 2020
Indeed - I was just using the default solver (GMRES with ILU).
Using just standard LU (direct solve with "-pc_type lu -ksp_type
preonly"), I find elemental to be extremely slow even for a 1000x1000
matrix. For MPIaij it's throwing me an error if I tried "-pc_type lu".
I'm attaching the code here, in case you'd like to have a look at what
I've been trying to do.
The two configurations of interest are,
    $> mpirun -n 4 ./ksps -N 1000 -mat_type mpiaij
    $> mpirun -n 4 ./ksps -N 1000 -mat_type elemental
(for the GMRES with ILU) and,
    $> mpirun -n 4 ./ksps -N 1000 -mat_type mpiaij -pc_type lu -ksp_type
    preonly
    $> mpirun -n 4 ./ksps -N 1000 -mat_type elemental -pc_type lu
    -ksp_type preonly
elemental seems to perform poorly in both cases.
Nidish
On 8/7/20 12:50 AM, Barry Smith wrote:
>   What is the output of -ksp_view  for the two case?
>   It is not only the matrix format but also the matrix solver that
> matters. For example if you are using an iterative solver the
> elemental format won't be faster, you should use the PETSc MPIDENSE
> format. The elemental format is really intended when you use a direct
> LU solver for the matrix. For tiny matrices like this an iterative
> solver could easily be faster than the direct solver, it depends on
> the conditioning (eigenstructure) of the dense matrix. Also the
> default PETSc solver uses block Jacobi with ILU on each process if
> using a sparse format, ILU applied to a dense matrix is actually LU so
> your solver is probably different also between the MPIAIJ and the
> elemental.
>   Barry
>> On Aug 7, 2020, at 12:30 AM, Nidish <nb25 at rice.edu
>> <mailto:nb25 at rice.edu>> wrote:
>> Thank you for the response.
>> I've just been running some tests with matrices up to 2e4 dimensions
>> (dense). When I compared the solution times for "-mat_type elemental"
>> and "-mat_type mpiaij" running with 4 cores, I found the mpidense
>> versions running way faster than elemental. I have not been able to
>> make the elemental version finish up for 2e4 so far (my patience runs
>> out faster).
>> What's going on here? I thought elemental was supposed to be superior
>> for dense matrices.
>> I can share the code if that's appropriate for this forum (sorry, I'm
>> new here).
>> Nidish
>> On Aug 6, 2020, at 23:01, Barry Smith <bsmith at petsc.dev
>> <mailto:bsmith at petsc.dev>> wrote:
>>         On Aug 6, 2020, at 7:32 PM, Nidish <nb25 at rice.edu
>>         <mailto:nb25 at rice.edu>> wrote: I'm relatively new to PETSc,
>>         and my applications involve (for the most part) dense matrix
>>         solves. I read in the documentation that this is an area
>>         PETSc does not specialize in but instead recommends external
>>         libraries such as Elemental. I'm wondering if there are any
>>         "best" practices in this regard. Some questions I'd like
>>         answered are: 1. Can I just declare my dense matrix as a
>>         sparse one and fill the whole matrix up? Do any of the others
>>         go this route? What're possible pitfalls/unfavorable outcomes
>>         for this? I understand the memory overhead probably shoots up.
>>        No, this isn't practical, the performance will be terrible.
>>         2. Are there any specific guidelines on when I can expect
>>         elemental to perform better in parallel than in serial?
>>        Because the computation to communication ratio for dense matrices is higher than for sparse you will see better parallel performance for dense problems of a given size than sparse problems of a similar size. In other words parallelism can help for dense matrices for relatively small problems, of course the specifics of your machine hardware and software also play a role.
>>         Barry
>>         Of course, I'm interesting in any other details that may be
>>         important in this regard. Thank you, Nidish
Nidish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200807/b82c1293/attachment-0001.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200807/b82c1293/attachment-0001.bin>
