[petsc-users] Problems about tolerances set in TS
    Zhang, Hong
    hongzhang at anl.gov
    Tue Apr 28 09:51:48 CDT 2020
-ts_error_if_step_fails 0
You might want to find out why the nonlinear solver does not converge first. If you have a hand-written Jacobian, you can validate it with -snes_test_jacobian 1 (for a small test case).
Hong (Mr.)
> On Apr 28, 2020, at 8:21 AM, Yingjie Wu <yjwu16 at gmail.com> wrote:
> Dear PETSc developers
> Hi,
> I have recently used TS to solve nonlinear equations with time terms. since the convergence of my model is not very good, i would like to set to iterative fixed nonlinear steps per time step. If the problem does not meet the SNES convergence criteria after fixed number of nonlinear steps , then go to the next time step calculation. I tried -snes_max_it , but didn't achieve the effect I wanted, and the program stopped after iterating the fixed number of steps. How should I set up in the program?
> Thanks,
> Yingjie
