[petsc-users] Fwd: Installation problem when Configuring SUPERLU_DIST
Fande Kong
fdkong.jd at gmail.com
Wed Apr 22 17:46:24 CDT 2020
We did not get a stack back this time.
Let us ping PETSc guys.
Fande,
---------- Forwarded message ---------
Date: Tue, Apr 21, 2020 at 10:55 AM
Subject: Re: Installation problem when Configuring SUPERLU_DIST
To: moose-users <moose-users at googlegroups.com>
Thanks, Fande.
I removed the packages. However, the same problem. It seems that "*Configuring
SUPERLU_DIST" *does not work. There is no error message in the
configure.log file.
Am I missing something?
Zi-Le Wang
You received this message because you are subscribed to the Google Groups
"moose-users" group.
To unsubscribe from this group and stop receiving emails from it, send an
email to moose-users+unsubscribe at googlegroups.com.
To view this discussion on the web visit
https://groups.google.com/d/msgid/moose-users/1fa97190-389c-4c2a-b23d-8a741ba12651%40googlegroups.com
<https://groups.google.com/d/msgid/moose-users/1fa97190-389c-4c2a-b23d-8a741ba12651%40googlegroups.com?utm_medium=email&utm_source=footer>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200422/9c1a5704/attachment-0001.html>
Starting configure run at Wed, 22 Apr 2020 00:37:15 +0800
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --prefix=/home/wangzl/moose-compilers/petsc-3.11.4 --with-debugging=0 --with-ssl=0 --with-pic=1 --with-openmp=1 --with-mpi=1 --with-shared-libraries=1 --with-cxx-dialect=C++11 --with-fortran-bindings=0 --with-sowing=0 --download-hypre=/home/wangzl/packages/hypre-2.15.1.tar.gz --download-fblaslapack=/home/wangzl/packages/fblaslapack-3.4.2.tar.gz --download-metis=/home/wangzl/packages/petsc-pkg-metis-49e61501c498.tar.gz --download-ptscotch=/home/wangzl/packages/petsc-pkg-scotch-c15036faac5f.tar.gz --download-parmetis=/home/wangzl/packages/petsc-pkg-parmetis-73dab469aa36.tar.gz --download-scalapack=/home/wangzl/packages/petsc-pkg-scalapack-459410776585.tar.gz --download-mumps=/home/wangzl/packages/petsc-pkg-mumps-5fe5b9e56f78.tar.gz --download-slepc=/home/wangzl/packages/slepc --download-superlu_dist=/home/wangzl/packages/superlu_dist-6.1.1.tar.gz PETSC_DIR=/tmp/stack_temp.rFVgkc/petsc-3.11.4 PETSC_ARCH=linux-opt
Working directory: /tmp/stack_temp.rFVgkc/petsc-3.11.4
Machine platform:
uname_result(system='Linux', node='w003', release='5.3.18-lp152.10-default', version='#1 SMP Wed Apr 1 11:48:53 UTC 2020 (ccee559)', machine='x86_64', processor='x86_64')
Python version:
3.5.1 |Continuum Analytics, Inc.| (default, Dec 7 2015, 11:16:01)
[GCC 4.4.7 20120313 (Red Hat 4.4.7-1)]
TEST configureExternalPackagesDir from config.framework(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/framework.py:830)
TESTING: configureExternalPackagesDir from config.framework(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/framework.py:830)
TEST configureDebuggers from config.utilities.debuggers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/debuggers.py:21)
TESTING: configureDebuggers from config.utilities.debuggers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/debuggers.py:21)
Find a default debugger and determine its arguments
Checking for program /home/wangzl/miniconda3/bin/gdb...not found
Checking for program /home/wangzl/projects/moose/python/peacock/gdb...not found
Checking for program /home/wangzl/software/fftwmpi/bin/gdb...not found
Checking for program /home/wangzl/software/byacc/bin/gdb...not found
Checking for program /home/wangzl/software/m4/bin/gdb...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/gdb...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/gdb...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/gdb...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/gdb...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/gdb...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/gdb...not found
Checking for program /home/wangzl/bin/gdb...not found
Checking for program /usr/local/bin/gdb...not found
Checking for program /usr/bin/gdb...found
Defined make macro "GDB" to "/usr/bin/gdb"
Checking for program /home/wangzl/miniconda3/bin/dbx...not found
Checking for program /home/wangzl/projects/moose/python/peacock/dbx...not found
Checking for program /home/wangzl/software/fftwmpi/bin/dbx...not found
Checking for program /home/wangzl/software/byacc/bin/dbx...not found
Checking for program /home/wangzl/software/m4/bin/dbx...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/dbx...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/dbx...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/dbx...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/dbx...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/dbx...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/dbx...not found
Checking for program /home/wangzl/bin/dbx...not found
Checking for program /usr/local/bin/dbx...not found
Checking for program /usr/bin/dbx...not found
Checking for program /bin/dbx...not found
Checking for program /opt/pbs/bin/dbx...not found
Checking for program /home/apps/dbx...not found
Checking for program /home/wangzl/miniconda3/bin/xdb...not found
Checking for program /home/wangzl/projects/moose/python/peacock/xdb...not found
Checking for program /home/wangzl/software/fftwmpi/bin/xdb...not found
Checking for program /home/wangzl/software/byacc/bin/xdb...not found
Checking for program /home/wangzl/software/m4/bin/xdb...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/xdb...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/xdb...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/xdb...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/xdb...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/xdb...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/xdb...not found
Checking for program /home/wangzl/bin/xdb...not found
Checking for program /usr/local/bin/xdb...not found
Checking for program /usr/bin/xdb...not found
Checking for program /bin/xdb...not found
Checking for program /opt/pbs/bin/xdb...not found
Checking for program /home/apps/xdb...not found
Executing: uname -s
stdout: Linux
Defined make macro "DSYMUTIL" to "true"
Defined "USE_GDB_DEBUGGER" to "1"
TEST configureGit from config.sourceControl(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/sourceControl.py:24)
TESTING: configureGit from config.sourceControl(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/sourceControl.py:24)
Find the Git executable
Checking for program /home/wangzl/miniconda3/bin/git...not found
Checking for program /home/wangzl/projects/moose/python/peacock/git...not found
Checking for program /home/wangzl/software/fftwmpi/bin/git...not found
Checking for program /home/wangzl/software/byacc/bin/git...not found
Checking for program /home/wangzl/software/m4/bin/git...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/git...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/git...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/git...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/git...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/git...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/git...not found
Checking for program /home/wangzl/bin/git...not found
Checking for program /usr/local/bin/git...not found
Checking for program /usr/bin/git...found
Defined make macro "GIT" to "git"
Executing: git --version
stdout: git version 2.25.0
TEST configureMercurial from config.sourceControl(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/sourceControl.py:35)
TESTING: configureMercurial from config.sourceControl(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/sourceControl.py:35)
Find the Mercurial executable
Checking for program /home/wangzl/miniconda3/bin/hg...not found
Checking for program /home/wangzl/projects/moose/python/peacock/hg...not found
Checking for program /home/wangzl/software/fftwmpi/bin/hg...not found
Checking for program /home/wangzl/software/byacc/bin/hg...not found
Checking for program /home/wangzl/software/m4/bin/hg...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/hg...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/hg...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/hg...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/hg...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/hg...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/hg...not found
Checking for program /home/wangzl/bin/hg...not found
Checking for program /usr/local/bin/hg...not found
Checking for program /usr/bin/hg...not found
Checking for program /bin/hg...not found
Checking for program /opt/pbs/bin/hg...not found
Checking for program /home/apps/hg...not found
TEST configureDirectories from PETSc.options.petscdir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/petscdir.py:23)
TESTING: configureDirectories from PETSc.options.petscdir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/petscdir.py:23)
Checks PETSC_DIR and sets if not set
Version Information:
#define PETSC_VERSION_RELEASE 1
#define PETSC_VERSION_MAJOR 3
#define PETSC_VERSION_MINOR 11
#define PETSC_VERSION_SUBMINOR 4
#define PETSC_VERSION_PATCH 0
#define PETSC_VERSION_DATE "Sep, 28, 2019"
#define PETSC_VERSION_GIT "v3.11.4"
#define PETSC_VERSION_DATE_GIT "2019-09-28 13:30:42 -0500"
#define PETSC_VERSION_EQ(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_ PETSC_VERSION_EQ
#define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
TEST getDatafilespath from PETSc.options.dataFilesPath(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.options.dataFilesPath(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/dataFilesPath.py:29)
Checks what DATAFILESPATH should be
TEST configureInstallationMethod from PETSc.options.petscclone(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/petscclone.py:20)
TESTING: configureInstallationMethod from PETSc.options.petscclone(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/petscclone.py:20)
This is a tarball installation
TEST setNativeArchitecture from PETSc.options.arch(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/arch.py:25)
TESTING: setNativeArchitecture from PETSc.options.arch(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/arch.py:25)
TEST configureArchitecture from PETSc.options.arch(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/arch.py:37)
TESTING: configureArchitecture from PETSc.options.arch(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/arch.py:37)
Checks PETSC_ARCH and sets if not set
TEST setInstallDir from PETSc.options.installDir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/installDir.py:35)
TESTING: setInstallDir from PETSc.options.installDir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/installDir.py:35)
setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
Defined make macro "PREFIXDIR" to "/home/wangzl/moose-compilers/petsc-3.11.4"
TEST saveReconfigure from PETSc.options.installDir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/installDir.py:79)
TESTING: saveReconfigure from PETSc.options.installDir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/installDir.py:79)
TEST cleanConfDir from PETSc.options.installDir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/installDir.py:72)
TESTING: cleanConfDir from PETSc.options.installDir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/installDir.py:72)
TEST configureInstallDir from PETSc.options.installDir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/installDir.py:56)
TESTING: configureInstallDir from PETSc.options.installDir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/installDir.py:56)
Makes installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
Changed persistence directory to /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/lib/petsc/conf
TEST restoreReconfigure from PETSc.options.installDir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/installDir.py:92)
TESTING: restoreReconfigure from PETSc.options.installDir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/installDir.py:92)
TEST setExternalPackagesDir from PETSc.options.externalpackagesdir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/externalpackagesdir.py:15)
TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/externalpackagesdir.py:15)
TEST cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/externalpackagesdir.py:22)
TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/externalpackagesdir.py:22)
TEST printEnvVariables from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1650)
TESTING: printEnvVariables from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1650)
**** printenv ****
__LMOD_REF_COUNT_INFOPATH=/opt/intel/documentation_2019/en/debugger/gdb-ia/info:1
CSHEDIT=emacs
LMOD_PKG=/usr/share/lmod/lmod
XDG_RUNTIME_DIR=/run/user/1043
USER=wangzl
http_proxy=http://127.0.0.1:25463
SSH_TTY=/dev/pts/0
UBUNTU_MENUPROXY=1
XAUTHLOCALHOSTNAME=w003
CXX=mpicxx
HOSTTYPE=x86_64
ALSA_CONFIG_PATH=/etc/alsa-pulse.conf
__LMOD_STACK_DAALROOT=L29wdC9pbnRlbC9jb21waWxlcnNfYW5kX2xpYnJhcmllc18yMDE5LjUuMjgxL2xpbnV4L2RhYWw=
__LMOD_REF_COUNT_LOADEDMODULES=impi/19u5:1;mkl/19u5:1;intel/19u5:1
HOST=w003
SHELL=/bin/bash
OSTYPE=linux
MALLOC_PERTURB_=69
__LMOD_STACK_INTEL_PYTHONHOME=L29wdC9pbnRlbC9kZWJ1Z2dlcl8yMDE5L3B5dGhvbi9pbnRlbDY0Lw==
__LMOD_REF_COUNT_PATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/bin:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64:1;/opt/intel/debugger_2019/gdb/intel64/bin:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin:1;/home/wangzl/miniconda3/bin:1;/home/wangzl/projects/moose/python/peacock:1;/home/wangzl/software/fftwmpi/bin:1;/home/wangzl/software/byacc/bin:1;/home/wangzl/software/m4/bin:1;/home/wangzl/software/flex-2.6.4/bin:1;/home/wangzl/bin:1;/usr/local/bin:1;/usr/bin:1;/bin:1;/opt/pbs/bin:1;/home/apps:1
F77=mpif77
LS_OPTIONS=-N --color=tty -T 0
__LMOD_STACK_PSTLROOT=L29wdC9pbnRlbC9jb21waWxlcnNfYW5kX2xpYnJhcmllc18yMDE5LjUuMjgxL2xpbnV4L3BzdGw=
PAGER=less
LS_COLORS=no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=41;33;01:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.lzma=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.xz=00;31:*.avi=01;35:*.bmp=01;35:*.dl=01;35:*.fli=01;35:*.gif=01;35:*.gl=01;35:*.jpg=01;35:*.jpeg=01;35:*.mkv=01;35:*.mng=01;35:*.mov=01;35:*.mp4=01;35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.svg=01;35:*.tga=01;35:*.tif=01;35:*.webm=01;35:*.webp=01;35:*.wmv=01;35:*.xbm=01;35:*.xcf=01;35:*.xpm=01;35:*.aiff=00;32:*.ape=00;32:*.au=00;32:*.flac=00;32:*.m4a=00;32:*.mid=00;32:*.mp3=00;32:*.mpc=00;32:*.ogg=00;32:*.voc=00;32:*.wav=00;32:*.wma=00;32:*.wv=00;32:
HISTSIZE=1000
__LMOD_REF_COUNT_MANPATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/man:1;/opt/intel/man/common:1;/opt/intel/documentation_2019/en/debugger/gdb-ia/man:1;/usr/local/man:1;/usr/share/man:1;/opt/pbs/share/man:1
__LMOD_STACK_FI_PROVIDER_PATH=L29wdC9pbnRlbC9jb21waWxlcnNfYW5kX2xpYnJhcmllc18yMDE5LjUuMjgxL2xpbnV4L21waS9pbnRlbDY0L2xpYmZhYnJpYy9saWIvcHJvdg==
OLDPWD=/tmp/stack_temp.rFVgkc
CPU=x86_64
TERM=xterm
__LMOD_REF_COUNT_NLSPATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64/locale/%l_%t/%N:1;/opt/intel/debugger_2019/gdb/intel64/share/locale/%l_%t/%N:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin/locale/%l_%t/%N:1
F90=mpif90
LESSOPEN=lessopen.sh %s
QEMU_AUDIO_DRV=pa
LIBGL_DEBUG=quiet
LANG=en_US.UTF-8
MORE=-sl
LESS_ADVANCED_PREPROCESSOR=no
MODULEPATH=/opt/lmod/modulefiles:/usr/share/lmod/modulefiles
BASH_FUNC_ml%%=() { eval $($LMOD_DIR/ml_cmd "$@")
LMOD_SETTARG_FULL_SUPPORT=no
JAVA_BINDIR=/usr/lib64/jvm/jre-11-openjdk/bin
LMOD_PREPEND_BLOCK=normal
XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB
INTEL_LICENSE_FILE=/opt/intel/compilers_and_libraries_2019.5.281/linux/licenses:/opt/intel/licenses:/root/intel/licenses
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1043/bus
MAIL=/var/spool/mail/wangzl
MAN_KEEP_FORMATTING=yes
SDL_AUDIODRIVER=pulse
JAVA_HOME=/usr/lib64/jvm/jre-11-openjdk
PKG_CONFIG_PATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/bin/pkgconfig
SSH_CLIENT=59.66.60.150 7586 22
MPI_HOME=/home/wangzl/software/mpich-3.2.1
FI_PROVIDER_PATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib/prov
XNLSPATH=/usr/share/X11/nls
LMOD_SETTARG_CMD=:
PACKAGES_DIR=/home/wangzl/moose-compilers
FC=mpif90
PETSC_DIR=/home/wangzl/moose-compilers/petsc-3.11.4
QT_SYSTEM_DIR=/usr/share/desktop-data
PYTHONSTARTUP=/etc/pythonstart
__LMOD_STACK_MKLROOT=L29wdC9pbnRlbC9jb21waWxlcnNfYW5kX2xpYnJhcmllc18yMDE5LjUuMjgxL2xpbnV4L21rbA==
PROFILEREAD=true
HOME=/home/wangzl
COLORTERM=1
LOGNAME=wangzl
JAVA_ROOT=/usr/lib64/jvm/jre-11-openjdk
XDG_CONFIG_DIRS=/etc/xdg
AUDIODRIVER=pulseaudio
LMOD_VERSION=8.3.6
LOADEDMODULES=impi/19u5:mkl/19u5:intel/19u5
PATH=/home/wangzl/miniconda3/bin:/home/wangzl/projects/moose/python/peacock:/home/wangzl/software/fftwmpi/bin:/home/wangzl/software/byacc/bin:/home/wangzl/software/m4/bin:/home/wangzl/software/flex-2.6.4/bin:/opt/intel/compilers_and_libraries_2019.5.281/linux/bin:/opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64:/opt/intel/debugger_2019/gdb/intel64/bin:/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin:/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin:/home/wangzl/miniconda3/bin:/home/wangzl/projects/moose/python/peacock:/home/wangzl/software/fftwmpi/bin:/home/wangzl/software/byacc/bin:/home/wangzl/software/m4/bin:/home/wangzl/software/flex-2.6.4/bin:/home/wangzl/bin:/usr/local/bin:/usr/bin:/bin:/opt/pbs/bin:/home/apps
LESS=-M -I -R
LESSCLOSE=lessclose.sh %s %s
_ModuleTable001_=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
LMOD_COLORIZE=no
GTK2_MODULES=unity-gtk-module
LMOD_FULL_SETTARG_SUPPORT=no
XDG_SESSION_ID=1368
G_BROKEN_FILENAMES=1
WINDOWMANAGER=/usr/bin/startplasma-x11
__LMOD_STACK_IPPROOT=L29wdC9pbnRlbC9jb21waWxlcnNfYW5kX2xpYnJhcmllc18yMDE5LjUuMjgxL2xpbnV4L2lwcA==
SSH_CONNECTION=59.66.60.150 7586 166.111.26.45 22
G_FILENAME_ENCODING=@locale,UTF-8,GB2312,GB18030,GBK,ISO-8859-1
FROM_HEADER=
XCRYSDEN_TOPDIR=/home/fujh/opt/xcrysden-1.5.60-bin-semishared
__LMOD_REF_COUNT_CLASSPATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/daal.jar:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/mpi.jar:1
_ModuleTable002_=PTAsWyJzdGF0dXMiXT0iYWN0aXZlIixbInVzZXJOYW1lIl09ImludGVsLzE5dTUiLH0sbWtsPXtbImZuIl09Ii9vcHQvbG1vZC9tb2R1bGVmaWxlcy9ta2wvMTl1NS5sdWEiLFsiZnVsbE5hbWUiXT0ibWtsLzE5dTUiLFsibG9hZE9yZGVyIl09Mixwcm9wVD17fSxbInN0YWNrRGVwdGgiXT0xLFsic3RhdHVzIl09ImFjdGl2ZSIsWyJ1c2VyTmFtZSJdPSJta2wvMTl1NSIsfSx9LG1wYXRoQT17Ii9vcHQvbG1vZC9tb2R1bGVmaWxlcyIsIi91c3Ivc2hhcmUvbG1vZC9tb2R1bGVmaWxlcyIsfSxbInN5c3RlbUJhc2VNUEFUSCJdPSIvdXNyL3NoYXJlL2xtb2QvbW9kdWxlZmlsZXMiLH0=
LMOD_CMD=/usr/share/lmod/lmod/libexec/lmod
I_MPI_ROOT=/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi
LMOD_DIR=/usr/share/lmod/lmod/libexec
MODULESHOME=/usr/share/lmod/lmod
_=./configure
__LMOD_REF_COUNT_LD_LIBRARY_PATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64:1;/opt/intel/debugger_2019/libipt/intel64/lib:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib:1;/usr/lib64:1;/home/wangzl/software/fftwmpi/lib64:1;/home/wangzl/software/flex-2.6.4/lib64:1;/home/wangzl/software/jpeg-9c/lib:1
NLSPATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64/locale/%l_%t/%N:/opt/intel/debugger_2019/gdb/intel64/share/locale/%l_%t/%N:/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin/locale/%l_%t/%N
MACHTYPE=x86_64-suse-linux
LIBRARY_PATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin:/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7:/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin:/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib:/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64:/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin:/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4
__LMOD_STACK_INTEL_LICENSE_FILE=L29wdC9pbnRlbC9jb21waWxlcnNfYW5kX2xpYnJhcmllc18yMDE5LjUuMjgxL2xpbnV4L2xpY2Vuc2VzOi9vcHQvaW50ZWwvbGljZW5zZXM6L3Jvb3QvaW50ZWwvbGljZW5zZXM=
BASH_FUNC_module%%=() { eval $($LMOD_CMD bash "$@") && eval $(${LMOD_SETTARG_CMD:-:} -s sh)
MKLROOT=/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl
MINICOM=-c on
STACK_SRC=/tmp/stack_temp.rFVgkc
CONFIG_SITE=/usr/share/site/x86_64-unknown-linux-gnu
DAALROOT=/opt/intel/compilers_and_libraries_2019.5.281/linux/daal
_LMFILES_=/opt/lmod/modulefiles/impi/19u5.lua:/opt/lmod/modulefiles/mkl/19u5.lua:/opt/lmod/modulefiles/intel/19u5.lua
__LMOD_STACK_TBBROOT=L29wdC9pbnRlbC9jb21waWxlcnNfYW5kX2xpYnJhcmllc18yMDE5LjUuMjgxL2xpbnV4L3RiYg==
https_proxy=http://127.0.0.1:25463
CVS_RSH=ssh
BASH_ENV=/usr/share/lmod/8.3.6/init/bash
TBBROOT=/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb
DISPLAY=localhost:11.0
__LMOD_REF_COUNT__LMFILES_=/opt/lmod/modulefiles/impi/19u5.lua:1;/opt/lmod/modulefiles/mkl/19u5.lua:1;/opt/lmod/modulefiles/intel/19u5.lua:1
LESSKEY=/etc/lesskey.bin
CLASSPATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/daal.jar:/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/mpi.jar
GTK3_MODULES=unity-gtk-module
PWD=/tmp/stack_temp.rFVgkc/petsc-3.11.4
MANPATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/man:/opt/intel/man/common:/opt/intel/documentation_2019/en/debugger/gdb-ia/man:/usr/local/man:/usr/share/man:/opt/pbs/share/man
EDITOR=vim
CC=mpicc
LD_LIBRARY_PATH=/usr/lib64:/home/wangzl/software/fftwmpi/lib64:/home/wangzl/software/flex-2.6.4/lib64:/home/wangzl/software/jpeg-9c/lib:/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64:/opt/intel/debugger_2019/libipt/intel64/lib:/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin:/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4:/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin:/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7:/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin:/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib:/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release:/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib:/usr/lib64:/home/wangzl/software/fftwmpi/lib64:/home/wangzl/software/flex-2.6.4/lib64:/home/wangzl/software/jpeg-9c/lib::
MALLOC_CHECK_=3
XDG_DATA_DIRS=/home/wangzl/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share
PSTLROOT=/opt/intel/compilers_and_libraries_2019.5.281/linux/pstl
SHLVL=1
__LMOD_REF_COUNT_PKG_CONFIG_PATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/bin/pkgconfig:1
GPG_TTY=/dev/pts/0
__LMOD_REF_COUNT_LIBRARY_PATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4:1
INTEL_PYTHONHOME=/opt/intel/debugger_2019/python/intel64/
LMOD_ROOT=/usr/share/lmod
HOSTNAME=w003
JRE_HOME=/usr/lib64/jvm/java-11-openjdk-11
__LMOD_REF_COUNT_CPATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/include:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/pstl/include:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/include:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/include:1;/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/include:1
IPPROOT=/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp
CPATH=/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/include:/opt/intel/compilers_and_libraries_2019.5.281/linux/pstl/include:/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/include:/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/include:/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/include
__LMOD_STACK_I_MPI_ROOT=L29wdC9pbnRlbC9jb21waWxlcnNfYW5kX2xpYnJhcmllc18yMDE5LjUuMjgxL2xpbnV4L21waQ==
__LMOD_REF_COUNT_MODULEPATH=/opt/lmod/modulefiles:1;/usr/share/lmod/modulefiles:1
_ModuleTable_Sz_=2
TEST resetEnvCompilers from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1657)
TESTING: resetEnvCompilers from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1657)
***** WARNING: CC (set to mpicc) found in environment variables - ignoring
use ./configure CC=$CC if you really want to use that value ******
***** WARNING: CXX (set to mpicxx) found in environment variables - ignoring
use ./configure CXX=$CXX if you really want to use that value ******
***** WARNING: FC (set to mpif90) found in environment variables - ignoring
use ./configure FC=$FC if you really want to use that value ******
***** WARNING: F77 (set to mpif77) found in environment variables - ignoring
use ./configure F77=$F77 if you really want to use that value ******
***** WARNING: F90 (set to mpif90) found in environment variables - ignoring
use ./configure F90=$F90 if you really want to use that value ******
TEST checkEnvCompilers from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1687)
TESTING: checkEnvCompilers from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1687)
TEST checkMPICompilerOverride from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1620)
TESTING: checkMPICompilerOverride from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1620)
Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1641)
TESTING: requireMpiLdPath from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1641)
OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:444)
TESTING: checkVendor from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:444)
Determine the compiler vendor
Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:454)
TESTING: checkInitialFlags from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:454)
Initialize the compiler and linker flags
Initialized CFLAGS to
Initialized LDFLAGS to
Initialized CUDAFLAGS to
Initialized CXXFLAGS to
Initialized CXX_CXXFLAGS to
Initialized FFLAGS to
Initialized CPPFLAGS to
Initialized CUDAPPFLAGS to -Wno-deprecated-gpu-targets
Initialized CXXCPPFLAGS to
Initialized CC_LINKER_FLAGS to []
Initialized CXX_LINKER_FLAGS to []
Initialized FC_LINKER_FLAGS to []
Initialized CUDAC_LINKER_FLAGS to []
Initialized sharedLibraryFlags to []
Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:587)
TESTING: checkCCompiler from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:587)
Locate a functional C compiler
Executing: mpicc --help
stdout:
Usage: gcc [options] file...
Options:
-pass-exit-codes Exit with highest error code from a phase.
--help Display this information.
--target-help Display target specific command line options.
--help={common|optimizers|params|target|warnings|[^]{joined|separate|undocumented}}[,...].
Display specific types of command line options.
(Use '-v --help' to display command line options of sub-processes).
--version Display compiler version information.
-dumpspecs Display all of the built in spec strings.
-dumpversion Display the version of the compiler.
-dumpmachine Display the compiler's target processor.
-print-search-dirs Display the directories in the compiler's search path.
-print-libgcc-file-name Display the name of the compiler's companion library.
-print-file-name=<lib> Display the full path to library <lib>.
-print-prog-name=<prog> Display the full path to compiler component <prog>.
-print-multiarch Display the target's normalized GNU triplet, used as
a component in the library path.
-print-multi-directory Display the root directory for versions of libgcc.
-print-multi-lib Display the mapping between command line options and
multiple library search directories.
-print-multi-os-directory Display the relative path to OS libraries.
-print-sysroot Display the target libraries directory.
-print-sysroot-headers-suffix Display the sysroot suffix used to find headers.
-Wa,<options> Pass comma-separated <options> on to the assembler.
-Wp,<options> Pass comma-separated <options> on to the preprocessor.
-Wl,<options> Pass comma-separated <options> on to the linker.
-Xassembler <arg> Pass <arg> on to the assembler.
-Xpreprocessor <arg> Pass <arg> on to the preprocessor.
-Xlinker <arg> Pass <arg> on to the linker.
-save-temps Do not delete intermediate files.
-save-temps=<arg> Do not delete intermediate files.
-no-canonical-prefixes Do not canonicalize paths when building relative
prefixes to other gcc components.
-pipe Use pipes rather than intermediate files.
-time Time the execution of each subprocess.
-specs=<file> Override built-in specs with the contents of <file>.
-std=<standard> Assume that the input sources are for <standard>.
--sysroot=<directory> Use <directory> as the root directory for headers
and libraries.
-B <directory> Add <directory> to the compiler's search paths.
-v Display the programs invoked by the compiler.
-### Like -v but options quoted and commands not executed.
-E Preprocess only; do not compile, assemble or link.
-S Compile only; do not assemble or link.
-c Compile and assemble, but do not link.
-o <file> Place the output into <file>.
-pie Create a position independent executable.
-shared Create a shared library.
-x <language> Specify the language of the following input files.
Permissible languages include: c c++ assembler none
'none' means revert to the default behavior of
guessing the language based on the file's extension.
Options starting with -g, -f, -m, -O, -W, or --param are automatically
passed on to the various sub-processes invoked by gcc. In order to pass
other options on to these processes the -W<letter> options must be used.
For bug reporting instructions, please see:
<https://bugs.opensuse.org/>.
Checking for program /home/wangzl/miniconda3/bin/mpicc...not found
Checking for program /home/wangzl/projects/moose/python/peacock/mpicc...not found
Checking for program /home/wangzl/software/fftwmpi/bin/mpicc...not found
Checking for program /home/wangzl/software/byacc/bin/mpicc...not found
Checking for program /home/wangzl/software/m4/bin/mpicc...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/mpicc...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/mpicc...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/mpicc...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/mpicc...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/mpicc...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc...found
Defined make macro "CC" to "mpicc"
All intermediate test results are stored in /tmp/petsc-wjcu960y
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.setCompilers
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/conftest /tmp/petsc-wjcu960y/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/conftest /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 1
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: error: ld returned 1 exit status
Successful compile:
Source:
int main() {
return 0;
Testing executable /tmp/petsc-wjcu960y/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-wjcu960y/config.setCompilers/conftest
TEST checkCPreprocessor from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:620)
TESTING: checkCPreprocessor from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:620)
Locate a functional C preprocessor
Defined make macro "CPP" to "mpicc -E"
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Preprocess stderr before filtering::
Preprocess stderr after filtering::
TEST checkCUDACompiler from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:661)
TESTING: checkCUDACompiler from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:661)
Locate a functional CUDA compiler
TEST checkCUDAPreprocessor from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:701)
TESTING: checkCUDAPreprocessor from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:701)
Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:814)
TESTING: checkCxxCompiler from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:814)
Locate a functional Cxx compiler
Executing: mpicxx --help
stdout:
Usage: g++ [options] file...
Options:
and libraries.
passed on to the various sub-processes invoked by g++. In order to pass
Checking for program /home/wangzl/miniconda3/bin/mpicxx...not found
Checking for program /home/wangzl/projects/moose/python/peacock/mpicxx...not found
Checking for program /home/wangzl/software/fftwmpi/bin/mpicxx...not found
Checking for program /home/wangzl/software/byacc/bin/mpicxx...not found
Checking for program /home/wangzl/software/m4/bin/mpicxx...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/mpicxx...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/mpicxx...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/mpicxx...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/mpicxx...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/mpicxx...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicxx...found
Defined make macro "CXX" to "mpicxx"
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Executing: mpicxx -o /tmp/petsc-wjcu960y/config.setCompilers/conftest /tmp/petsc-wjcu960y/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
return 0;
Executing: mpicxx -o /tmp/petsc-wjcu960y/config.setCompilers/conftest /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
return 0;
TEST checkCxxPreprocessor from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:852)
TESTING: checkCxxPreprocessor from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:852)
Locate a functional Cxx preprocessor
Defined make macro "CXXCPP" to "mpicxx -E"
Executing: mpicxx -E -I/tmp/petsc-wjcu960y/config.setCompilers /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
TEST checkFortranCompiler from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:970)
TESTING: checkFortranCompiler from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:970)
Locate a functional Fortran compiler
Executing: mpif90 --help
stdout:
Usage: gfortran [options] file...
Options:
and libraries.
passed on to the various sub-processes invoked by gfortran. In order to pass
Checking for program /home/wangzl/miniconda3/bin/mpif90...not found
Checking for program /home/wangzl/projects/moose/python/peacock/mpif90...not found
Checking for program /home/wangzl/software/fftwmpi/bin/mpif90...not found
Checking for program /home/wangzl/software/byacc/bin/mpif90...not found
Checking for program /home/wangzl/software/m4/bin/mpif90...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/mpif90...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/mpif90...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/mpif90...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/mpif90...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/mpif90...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpif90...found
Defined make macro "FC" to "mpif90"
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers /tmp/petsc-wjcu960y/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Successful compile:
Source:
program main
end
Executing: mpif90 -o /tmp/petsc-wjcu960y/config.setCompilers/conftest /tmp/petsc-wjcu960y/config.setCompilers/conftest.o
Successful compile:
Source:
program main
end
Executing: mpif90 -o /tmp/petsc-wjcu960y/config.setCompilers/conftest /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
program main
end
TEST checkFortranComments from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:991)
TESTING: checkFortranComments from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:991)
Make sure fortran comment "!" works
Successful compile:
Source:
program main
! comment
end
Fortran comments can use ! in column 1
TEST checkLargeFileIO from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1121)
TESTING: checkLargeFileIO from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1121)
TEST checkArchiver from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1220)
TESTING: checkArchiver from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1220)
Check that the archiver exists and can make a library usable by the compiler
Executing: ar -V
stdout:
GNU ar (GNU Binutils; openSUSE Leap 15.2) 2.34.0.20200325-lp152.1
Copyright (C) 2020 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) any later version.
This program has absolutely no warranty.
Executing: ar -V
stdout:
Defined make macro "FAST_AR_FLAGS" to "Scq"
Successful compile:
Source:
int foo(int a) {
return a+1;
Checking for program /home/wangzl/miniconda3/bin/ar...not found
Checking for program /home/wangzl/projects/moose/python/peacock/ar...not found
Checking for program /home/wangzl/software/fftwmpi/bin/ar...not found
Checking for program /home/wangzl/software/byacc/bin/ar...not found
Checking for program /home/wangzl/software/m4/bin/ar...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/ar...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/ar...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/ar...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/ar...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/ar...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/ar...not found
Checking for program /home/wangzl/bin/ar...not found
Checking for program /usr/local/bin/ar...not found
Checking for program /usr/bin/ar...found
Defined make macro "AR" to "/usr/bin/ar"
Checking for program /home/wangzl/miniconda3/bin/ranlib...not found
Checking for program /home/wangzl/projects/moose/python/peacock/ranlib...not found
Checking for program /home/wangzl/software/fftwmpi/bin/ranlib...not found
Checking for program /home/wangzl/software/byacc/bin/ranlib...not found
Checking for program /home/wangzl/software/m4/bin/ranlib...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/ranlib...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/ranlib...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/ranlib...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/ranlib...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/ranlib...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/ranlib...not found
Checking for program /home/wangzl/bin/ranlib...not found
Checking for program /usr/local/bin/ranlib...not found
Checking for program /usr/bin/ranlib...found
Defined make macro "RANLIB" to "/usr/bin/ranlib -c"
Executing: /usr/bin/ar cr /tmp/petsc-wjcu960y/config.setCompilers/libconf1.a /tmp/petsc-wjcu960y/config.setCompilers/conf1.o
Executing: /usr/bin/ranlib -c /tmp/petsc-wjcu960y/config.setCompilers/libconf1.a
Possible ERROR while running ranlib:
stderr:
/usr/bin/ranlib: invalid option -- 'c'
Ranlib is not functional with your archiver. Try --with-ranlib=true if ranlib is unnecessary.
Executing: ar -V
stdout:
Executing: ar -V
stdout:
Successful compile:
Source:
int foo(int a) {
return a+1;
Defined make macro "RANLIB" to "/usr/bin/ranlib"
Executing: /usr/bin/ranlib /tmp/petsc-wjcu960y/config.setCompilers/libconf1.a
Successful compile:
Source:
extern int foo(int);
int main() {
int b = foo(1); if (b);
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/conftest /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -L/tmp/petsc-wjcu960y/config.setCompilers -lconf1
Defined make macro "AR_FLAGS" to "cr"
Defined make macro "AR_LIB_SUFFIX" to "a"
TEST checkSharedLinker from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1334)
TESTING: checkSharedLinker from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1334)
Check that the linker can produce shared libraries
Executing: uname -s
stdout: Linux
Checking shared linker mpicc using flags ['-shared']
Defined make macro "LD_SHARED" to "mpicc"
Trying C compiler flag
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/conftest -shared /tmp/petsc-wjcu960y/config.setCompilers/conftest.o
Valid C linker flag -shared
Successful compile:
Source:
#include <stdio.h>
int (*fprintf_ptr)(FILE*,const char*,...) = fprintf;
void foo(void){
fprintf_ptr(stdout,"hello");
return;
void bar(void){foo();}
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/libconftest.so -shared /tmp/petsc-wjcu960y/config.setCompilers/conftest.o
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.setCompilers/conftest.o: relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
Rejected C compiler flag because it was not compatible with shared linker mpicc using flags ['-shared']
Trying C compiler flag -fPIC
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag -fPIC
Successful compile:
Source:
int main() {
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/conftest -shared -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.o
Successful compile:
Source:
#include <stdio.h>
void foo(void){
return;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/libconftest.so -shared -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.o
Successful compile:
Source:
int foo(void);
int main() {
int ret = foo();
if (ret) {}
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/conftest -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -L/tmp/petsc-wjcu960y/config.setCompilers -lconftest
Using shared linker mpicc with flags ['-shared'] and library extension so
Executing: uname -s
stdout: Linux
TEST checkPIC from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1069)
TESTING: checkPIC from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1069)
Determine the PIC option for each compiler
Trying C for PIC code without any compiler flag
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
#include <stdio.h>
void foo(void){
return;
Accepted C PIC code without compiler flag
Trying Cxx for PIC code without any compiler flag
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
#include <stdio.h>
void foo(void){
return;
stderr:
Rejected Cxx compiler flag because shared linker cannot handle it
Trying Cxx compiler flag -fPIC for PIC code
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag -fPIC
Successful compile:
Source:
#include <stdio.h>
void foo(void){
return;
Accepted Cxx compiler flag -fPIC for PIC code
Trying FC for PIC code without any compiler flag
Successful compile:
Source:
program main
end
Successful compile:
Source:
function foo(a)
real:: a,x,bar
common /xx/ x
x=a
foo = bar(x)
end
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.setCompilers/conftest.o: relocation R_X86_64_32 against symbol `xx_' can not be used when making a shared object; recompile with -fPIC
Rejected FC compiler flag because shared linker cannot handle it
Trying FC compiler flag -fPIC for PIC code
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Added FC compiler flag -fPIC
Successful compile:
Source:
function foo(a)
real:: a,x,bar
common /xx/ x
x=a
foo = bar(x)
end
Accepted FC compiler flag -fPIC for PIC code
TEST checkSharedLinkerPaths from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1428)
TESTING: checkSharedLinkerPaths from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1428)
Determine the shared linker path options
- IRIX: -rpath
- Linux, OSF: -Wl,-rpath,
- Solaris: -R
- FreeBSD: -Wl,-R,
Executing: uname -s
stdout: Linux
Executing: mpicc -V
Trying C linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/conftest -Wl,-rpath,/tmp/stack_temp.rFVgkc/petsc-3.11.4 -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.o
Valid C linker flag -Wl,-rpath,/tmp/stack_temp.rFVgkc/petsc-3.11.4
Executing: uname -s
stdout: Linux
Executing: mpicc -V
Trying Cxx linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
return 0;
Executing: mpicxx -o /tmp/petsc-wjcu960y/config.setCompilers/conftest -Wl,-rpath,/tmp/stack_temp.rFVgkc/petsc-3.11.4 /tmp/petsc-wjcu960y/config.setCompilers/conftest.o
Valid Cxx linker flag -Wl,-rpath,/tmp/stack_temp.rFVgkc/petsc-3.11.4
Executing: uname -s
stdout: Linux
Executing: mpicc -V
Trying FC linker flag -Wl,-rpath,
Successful compile:
Source:
program main
end
Executing: mpif90 -o /tmp/petsc-wjcu960y/config.setCompilers/conftest -Wl,-rpath,/tmp/stack_temp.rFVgkc/petsc-3.11.4 -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.o
Valid FC linker flag -Wl,-rpath,/tmp/stack_temp.rFVgkc/petsc-3.11.4
TEST checkLibC from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1463)
TESTING: checkLibC from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1463)
Test whether we need to explicitly include libc in shared linking
- Mac OSX requires an explicit reference to libc for shared linking
Successful compile:
Source:
#include <stdlib.h>
int foo(void) {void *chunk = malloc(31); free(chunk); return 0;}
Shared linking does not require an explicit libc reference
TEST checkDynamicLinker from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1512)
TESTING: checkDynamicLinker from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1512)
Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.headers
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers /tmp/petsc-wjcu960y/config.headers/conftest.c
Defined "HAVE_DLFCN_H" to "1"
Checking for functions [dlopen dlsym dlclose] in library ['dl'] []
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.libraries
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC /tmp/petsc-wjcu960y/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char dlopen();
static void _check_dlopen() { dlopen(); }
char dlsym();
static void _check_dlsym() { dlsym(); }
char dlclose();
static void _check_dlclose() { dlclose(); }
int main() {
_check_dlopen();
_check_dlsym();
_check_dlclose();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC /tmp/petsc-wjcu960y/config.libraries/conftest.o -ldl
Defined "HAVE_LIBDL" to "1"
Adding ['dl'] to LIBS
Executing: uname -s
stdout: Linux
Checking dynamic linker mpicc using flags ['-shared']
Defined make macro "DYNAMICLINKER" to "mpicc"
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/conftest -shared -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("test");return 0;}
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/libconftest.so -shared -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -ldl
Possible ERROR while running compiler:
stderr:
/tmp/petsc-wjcu960y/config.setCompilers/conftest.c: In function ���main���:
/tmp/petsc-wjcu960y/config.setCompilers/conftest.c:11:3: warning: implicit declaration of function ���printf��� [-Wimplicit-function-declaration]
printf("Could not load symbol\n");
/tmp/petsc-wjcu960y/config.setCompilers/conftest.c:11:3: warning: incompatible implicit declaration of built-in function ���printf���
/tmp/petsc-wjcu960y/config.setCompilers/conftest.c:11:3: note: include ���<stdio.h>��� or provide a declaration of ���printf���
/tmp/petsc-wjcu960y/config.setCompilers/conftest.c:15:3: warning: incompatible implicit declaration of built-in function ���printf���
printf("Invalid return from foo()\n");
/tmp/petsc-wjcu960y/config.setCompilers/conftest.c:15:3: note: include ���<stdio.h>��� or provide a declaration of ���printf���
/tmp/petsc-wjcu960y/config.setCompilers/conftest.c:19:3: warning: incompatible implicit declaration of built-in function ���printf���
printf("Could not close library\n");
/tmp/petsc-wjcu960y/config.setCompilers/conftest.c:19:3: note: include ���<stdio.h>��� or provide a declaration of ���printf���
Source:
#include<dlfcn.h>
int main() {
void *handle = dlopen("/tmp/petsc-wjcu960y/config.setCompilers/libconftest.so", 0);
int (*foo)(void) = (int (*)(void)) dlsym(handle, "foo");
if (!foo) {
return -1;
if ((*foo)()) {
return -1;
if (dlclose(handle)) {
return -1;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/conftest -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -ldl
Using dynamic linker mpicc with flags ['-shared'] and library extension so
TEST output from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1564)
TESTING: output from config.setCompilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/setCompilers.py:1564)
Output module data as defines and substitutions
Substituting "CC" with "mpicc"
Substituting "CFLAGS" with " -fPIC"
Defined make macro "CC_LINKER_SLFLAG" to "-Wl,-rpath,"
Substituting "CPP" with "mpicc -E"
Substituting "CPPFLAGS" with ""
Substituting "CXX" with "mpicxx"
Substituting "CXX_CXXFLAGS" with " -fPIC"
Substituting "CXXFLAGS" with ""
Substituting "CXX_LINKER_SLFLAG" with "-Wl,-rpath,"
Substituting "CXXCPP" with "mpicxx -E"
Substituting "CXXCPPFLAGS" with ""
Substituting "FC" with "mpif90"
Substituting "FFLAGS" with " -fPIC"
Defined make macro "FC_LINKER_SLFLAG" to "-Wl,-rpath,"
Substituting "LDFLAGS" with ""
Substituting "LIBS" with "-ldl "
Substituting "SHARED_LIBRARY_FLAG" with "-shared"
TEST checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/sharedLibraries.py:36)
TESTING: checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/sharedLibraries.py:36)
TEST configureSharedLibraries from PETSc.options.sharedLibraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/sharedLibraries.py:52)
TESTING: configureSharedLibraries from PETSc.options.sharedLibraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/sharedLibraries.py:52)
Checks whether shared libraries should be used, for which you must
- Specify --with-shared-libraries
- Have found a working shared linker
Defines PETSC_USE_SHARED_LIBRARIES if they are used
Executing: uname -s
stdout: Linux
Defined make rule "shared_arch" with dependencies "shared_linux" and code []
Defined make macro "SONAME_FUNCTION" to "$(1).so.$(2)"
Defined make macro "SL_LINKER_FUNCTION" to "-shared -Wl,-soname,$(call SONAME_FUNCTION,$(notdir $(1)),$(2))"
Defined make macro "BUILDSHAREDLIB" to "yes"
Defined "HAVE_SHARED_LIBRARIES" to "1"
Defined "USE_SHARED_LIBRARIES" to "1"
TEST configureDynamicLibraries from PETSc.options.sharedLibraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/sharedLibraries.py:96)
TESTING: configureDynamicLibraries from PETSc.options.sharedLibraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/sharedLibraries.py:96)
Checks whether dynamic loading is available (with dlfcn.h and libdl)
Defined "HAVE_DYNAMIC_LIBRARIES" to "1"
TEST configureSerializedFunctions from PETSc.options.sharedLibraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/sharedLibraries.py:102)
TESTING: configureSerializedFunctions from PETSc.options.sharedLibraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/sharedLibraries.py:102)
Defines PETSC_SERIALIZE_FUNCTIONS if they are used
Requires shared libraries
TEST configureIndexSize from PETSc.options.indexTypes(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/indexTypes.py:30)
TESTING: configureIndexSize from PETSc.options.indexTypes(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/indexTypes.py:30)
Defined make macro "PETSC_INDEX_SIZE" to "32"
TEST configureCompilerFlags from config.compilerFlags(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilerFlags.py:72)
TESTING: configureCompilerFlags from config.compilerFlags(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilerFlags.py:72)
Get the default compiler flags
Defined make macro "MPICC_SHOW" to "gcc -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -Xlinker --enable-new-dtags -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -Wl,-z,now -Wl,-z,relro -Wl,-z,noexecstack -Xlinker --enable-new-dtags -ldl"
Trying C compiler flag -Wall
Trying C compiler flag -Wwrite-strings
Trying C compiler flag -Wno-strict-aliasing
Trying C compiler flag -Wno-unknown-pragmas
Trying C compiler flag -fstack-protector
Trying C compiler flag -mfp16-format=ieee
Rejected C compiler flag -mfp16-format=ieee
Trying C compiler flag -fvisibility=hidden
Trying C compiler flag -g
Trying C compiler flag -O
Defined make macro "MPICXX_SHOW" to "g++ -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -Xlinker --enable-new-dtags -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpicxx -lmpifort -lmpi -lrt -lpthread -Wl,-z,now -Wl,-z,relro -Wl,-z,noexecstack -Xlinker --enable-new-dtags -ldl"
Trying Cxx compiler flag -Wall
Trying Cxx compiler flag -Wwrite-strings
Trying Cxx compiler flag -Wno-strict-aliasing
Trying Cxx compiler flag -Wno-unknown-pragmas
Trying Cxx compiler flag -fstack-protector
Trying Cxx compiler flag -fvisibility=hidden
Trying Cxx compiler flag -g
Trying Cxx compiler flag -O
Defined make macro "MPIFC_SHOW" to "gfortran -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0 -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -Xlinker --enable-new-dtags -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -Wl,-z,now -Wl,-z,relro -Wl,-z,noexecstack -Xlinker --enable-new-dtags -ldl"
Trying FC compiler flag -Wall
Trying FC compiler flag -ffree-line-length-0
Trying FC compiler flag -Wno-unused-dummy-argument
Trying FC compiler flag -g
Trying FC compiler flag -O
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag -Wall
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -Wwrite-strings /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag -Wwrite-strings
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag -Wno-strict-aliasing
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag -Wno-unknown-pragmas
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag -fstack-protector
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -mfp16-format=ieee /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Possible ERROR while running compiler: exit code 1
stderr:
gcc: error: unrecognized command line option ���-mfp16-format=ieee���
Source:
int main() {
return 0;
Rejecting compiler flag -mfp16-format=ieee due to nonzero status from link
PETSc Error: No output file produced
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag -fvisibility=hidden
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag -g
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag -O
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag -Wall
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -Wwrite-strings -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag -Wwrite-strings
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -Wwrite-strings -Wno-strict-aliasing -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag -Wno-strict-aliasing
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag -Wno-unknown-pragmas
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag -fstack-protector
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag -fvisibility=hidden
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag -g
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag -O
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall /tmp/petsc-wjcu960y/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Added FC compiler flag -Wall
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -ffree-line-length-0 /tmp/petsc-wjcu960y/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Added FC compiler flag -ffree-line-length-0
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument /tmp/petsc-wjcu960y/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Added FC compiler flag -Wno-unused-dummy-argument
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g /tmp/petsc-wjcu960y/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Added FC compiler flag -g
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Added FC compiler flag -O
Executing: mpicc --version
stdout:
gcc (SUSE Linux) 7.5.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
getCompilerVersion: mpicc gcc (SUSE Linux) 7.5.0
Executing: mpicc -show
stdout: gcc -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -Xlinker --enable-new-dtags -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -Wl,-z,now -Wl,-z,relro -Wl,-z,noexecstack -Xlinker --enable-new-dtags -ldl
stdout:
Options:
and libraries.
Executing: uname -s
stdout: Linux
stdout:
Options:
and libraries.
stdout:
Options:
and libraries.
***** WARNING: Using default optimization C flags -g -O
You might consider manually setting optimal optimization flags for your system with
COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples
Executing: mpicxx --version
stdout:
g++ (SUSE Linux) 7.5.0
getCompilerVersion: mpicxx g++ (SUSE Linux) 7.5.0
Executing: mpicxx -show
stdout: g++ -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -Xlinker --enable-new-dtags -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpicxx -lmpifort -lmpi -lrt -lpthread -Wl,-z,now -Wl,-z,relro -Wl,-z,noexecstack -Xlinker --enable-new-dtags -ldl
stdout:
Options:
and libraries.
Executing: uname -s
stdout: Linux
stdout:
Options:
and libraries.
***** WARNING: Using default C++ optimization flags -g -O
CXXOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples
Executing: mpif90 --version
stdout:
GNU Fortran (SUSE Linux) 7.5.0
getCompilerVersion: mpif90 GNU Fortran (SUSE Linux) 7.5.0
Executing: mpif90 -show
stdout: gfortran -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0 -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -Xlinker --enable-new-dtags -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/release -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -Wl,-z,now -Wl,-z,relro -Wl,-z,noexecstack -Xlinker --enable-new-dtags -ldl
stdout:
Options:
and libraries.
stdout:
stdout:
stdout:
***** WARNING: Using default FORTRAN optimization flags -g -O
FOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples
TEST checkRestrict from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:146)
TESTING: checkRestrict from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:146)
Check for the C/CXX restrict keyword
Executing: mpicc -V
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.compilers
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.compilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.c
stderr:
/tmp/petsc-wjcu960y/config.compilers/conftest.c: In function ���main���:
/tmp/petsc-wjcu960y/config.compilers/conftest.c:5:20: warning: unused variable ���x��� [-Wunused-variable]
float * __restrict x;;
Source:
int main() {
return 0;
compilers: Set C restrict keyword to __restrict
Defined "C_RESTRICT" to "__restrict"
TEST checkCFormatting from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:399)
TESTING: checkCFormatting from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:399)
Activate format string checking if using the GNU compilers
TEST checkCInline from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:116)
TESTING: checkCInline from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:116)
Check for C inline keyword
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.compilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.c
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
return 0;
compilers: Set C Inline keyword to inline
Defined "C_INLINE" to "inline"
TEST checkDynamicLoadFlag from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:410)
TESTING: checkDynamicLoadFlag from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:410)
Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LAZY);
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.compilers/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.o -ldl
Defined "HAVE_RTLD_LAZY" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_NOW);
return 0;
Defined "HAVE_RTLD_NOW" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LOCAL);
return 0;
Defined "HAVE_RTLD_LOCAL" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_GLOBAL);
return 0;
Defined "HAVE_RTLD_GLOBAL" to "1"
TEST checkCLibraries from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:210)
TESTING: checkCLibraries from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:210)
Determines the libraries needed to link with C compiled code
Successful compile:
Source:
#include <stdio.h>
void asub(void)
{char s[16];printf("testing %s",s);}
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.compilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.F90
Successful compile:
Source:
program main
print*,'testing'
stop
end
Executing: mpif90 -o /tmp/petsc-wjcu960y/config.compilers/conftest -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.o /tmp/petsc-wjcu960y/config.compilers/confc.o -ldl
C libraries are not needed when using Fortran linker
Successful compile:
Source:
#include <stdio.h>
void asub(void)
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.compilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fPIC /tmp/petsc-wjcu960y/config.compilers/conftest.cc
Successful compile:
Source:
int main(int argc,char **args)
{return 0;}
Executing: mpicxx -o /tmp/petsc-wjcu960y/config.compilers/conftest -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.o /tmp/petsc-wjcu960y/config.compilers/confc.o -ldl
C libraries are not needed when using C++ linker
TEST checkDependencyGenerationFlag from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1599)
TESTING: checkDependencyGenerationFlag from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1599)
Check if -MMD works for dependency generation, and add it if it does
Trying C compiler flag -MMD -MP
Defined make macro "C_DEPFLAGS" to "-MMD -MP"
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -MMD -MP /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Trying Cxx compiler flag -MMD -MP
Defined make macro "CXX_DEPFLAGS" to "-MMD -MP"
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fPIC -MMD -MP /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Trying FC compiler flag -MMD -MP
Defined make macro "FC_DEPFLAGS" to "-MMD -MP"
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O -MMD -MP /tmp/petsc-wjcu960y/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
TEST checkC99Flag from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1645)
TESTING: checkC99Flag from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1645)
Check for -std=c99 or equivalent flag
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
stderr:
/tmp/petsc-wjcu960y/config.setCompilers/conftest.c:7:11: warning: variable ���x��� set but not used [-Wunused-but-set-variable]
float x[2],y;
Source:
#include <float.h>
int main() {
float x[2],y;
y = FLT_ROUNDS;
// c++ comment
int j = 2;
for (int i=0; i<2; i++){
x[i] = i*j*y;
return 0;
Accepted C99 compile flag:
Defined "HAVE_C99" to "1"
Executing: mpicc -V
stderr:
/tmp/petsc-wjcu960y/config.compilers/conftest.cc: In function ���int main()���:
/tmp/petsc-wjcu960y/config.compilers/conftest.cc:5:20: warning: unused variable ���x��� [-Wunused-variable]
Source:
int main() {
return 0;
compilers: Set Cxx restrict keyword to __restrict
Defined "CXX_RESTRICT" to "__restrict"
TEST checkCxxNamespace from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:450)
TESTING: checkCxxNamespace from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:450)
Checks that C++ compiler supports namespaces, and if it does defines HAVE_CXX_NAMESPACE
Successful compile:
Source:
namespace petsc {int dummy;}
int main() {
return 0;
Successful compile:
Source:
template <class dummy> struct a {};
namespace trouble{
template <class dummy> struct a : public ::a<dummy> {};
trouble::a<int> uugh;
int main() {
return 0;
compilers: C++ has namespaces
Defined "HAVE_CXX_NAMESPACE" to "1"
TEST checkCxxOptionalExtensions from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:423)
TESTING: checkCxxOptionalExtensions from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:423)
Check whether the C++ compiler (IBM xlC, OSF5) need special flag for .c files which contain C++
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
class somename { int i; };;
return 0;
TEST checkCxxInline from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:131)
TESTING: checkCxxInline from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:131)
Check for C++ inline keyword
Successful compile:
Source:
int main() {
foo(1);;
return 0;
compilers: Set Cxx Inline keyword to inline
Defined "CXX_INLINE" to "inline"
TEST checkCxxLibraries from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:508)
TESTING: checkCxxLibraries from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:508)
Determines the libraries needed to link with C++
Successful compile:
Source:
#include <iostream>
#include <vector>
void asub(void)
{std::vector<int> v;
try { throw 20; } catch (int e) { std::cout << "An exception occurred"; }}
Successful compile:
Source:
{return 0;}
Executing: mpicc -o /tmp/petsc-wjcu960y/config.compilers/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.o /tmp/petsc-wjcu960y/config.compilers/confc.o -ldl
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/confc.o: in function `asub()':
/tmp/petsc-wjcu960y/config.compilers/conftest.cc:7: undefined reference to `__cxa_allocate_exception'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/conftest.cc:7: undefined reference to `typeinfo for int'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/conftest.cc:7: undefined reference to `__cxa_throw'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/conftest.cc:7: undefined reference to `__cxa_begin_catch'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/conftest.cc:7: undefined reference to `std::cout'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/conftest.cc:7: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/conftest.cc:7: undefined reference to `__cxa_end_catch'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/confc.o: in function `_GLOBAL__sub_I_conftest.cc':
/usr/include/c++/7/iostream:74: undefined reference to `std::ios_base::Init::Init()'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/confc.o: in function `__static_initialization_and_destruction_0':
/usr/include/c++/7/iostream:74: undefined reference to `std::ios_base::Init::~Init()'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/confc.o:(.data.rel.local.DW.ref._ZTIi[DW.ref._ZTIi]+0x0): undefined reference to `typeinfo for int'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/confc.o:(.data.rel.local.DW.ref.__gxx_personality_v0[DW.ref.__gxx_personality_v0]+0x0): undefined reference to `__gxx_personality_v0'
Successful compile:
Source:
#include <iostream>
#include <vector>
void asub(void)
Successful compile:
Source:
{return 0;}
Executing: mpicc -o /tmp/petsc-wjcu960y/config.compilers/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.o /tmp/petsc-wjcu960y/config.compilers/confc.o -lstdc++ -ldl
compilers: C++ requires -lstdc++ to link with C compiler
Successful compile:
Source:
#include <iostream>
#include <vector>
void asub(void)
Successful compile:
Source:
program main
print*,'testing'
stop
end
Executing: mpif90 -o /tmp/petsc-wjcu960y/config.compilers/conftest -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.o /tmp/petsc-wjcu960y/config.compilers/confc.o -lstdc++ -ldl
C++ libraries are not needed when using FC linker
TEST checkCxx11 from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:465)
TESTING: checkCxx11 from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:465)
Determine the option needed to support the C++11 dialect
We auto-detect C++11 if the compiler supports it without options,
otherwise we require with-cxx-dialect=C++11 to try adding flags to
support it.
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
stderr:
/tmp/petsc-wjcu960y/config.setCompilers/conftest.cc: In function ���int main()���:
/tmp/petsc-wjcu960y/config.setCompilers/conftest.cc:13:24: warning: unused variable ���x��� [-Wunused-variable]
const double x = dist(mt);
Source:
#include <random>
template<typename T> constexpr T Cubed( T x ) { return x*x*x; }
int main() {
std::random_device rd;
std::mt19937 mt(rd());
std::normal_distribution<double> dist(0,1);
return 0;
TEST checkFortranTypeSizes from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:722)
TESTING: checkFortranTypeSizes from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:722)
Check whether real*8 is supported and suggest flags which will allow support
stderr:
/tmp/petsc-wjcu960y/config.compilers/conftest.F90:2:21:
real*8 variable
1
Warning: Unused variable ���variable��� declared at (1) [-Wunused-variable]
Source:
program main
real*8 variable
end
TEST checkFortranNameMangling from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:782)
TESTING: checkFortranNameMangling from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:782)
Checks Fortran name mangling, and defines HAVE_FORTRAN_UNDERSCORE, HAVE_FORTRAN_NOUNDERSCORE, HAVE_FORTRAN_CAPS, or HAVE_FORTRAN_STDCALL
Testing Fortran mangling type underscore with code void d1chk_(void){return;}
Successful compile:
Source:
Successful compile:
Source:
program main
call d1chk()
end
compilers: Fortran name mangling is underscore
Defined "HAVE_FORTRAN_UNDERSCORE" to "1"
stdout:
Defined "FORTRAN_CHARLEN_T" to "int"
TEST checkFortranNameManglingDouble from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:823)
TESTING: checkFortranNameManglingDouble from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:823)
Checks if symbols containing an underscore append an extra underscore, and defines HAVE_FORTRAN_UNDERSCORE_UNDERSCORE if necessary
Successful compile:
Source:
void d1_chk__(void){return;}
Successful compile:
Source:
program main
call d1_chk()
end
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/conftest.o: in function `main':
/tmp/petsc-wjcu960y/config.compilers/conftest.F90:2: undefined reference to `d1_chk_'
TEST checkFortranPreprocessor from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:833)
TESTING: checkFortranPreprocessor from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:833)
Determine if Fortran handles preprocessing properly
compilers: Fortran uses CPP preprocessor
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
#define dummy
dummy
#ifndef dummy
fooey
#endif
end
TEST checkFortranDefineCompilerOption from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:857)
TESTING: checkFortranDefineCompilerOption from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:857)
Check if -WF,-Dfoobar or -Dfoobar is the compiler option to define a macro
Defined make macro "FC_DEFINE_FLAG" to "-D"
compilers: Fortran uses -D for defining macro
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O -DTesting /tmp/petsc-wjcu960y/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
#define dummy
dummy
#ifndef Testing
fooey
#endif
end
TEST checkFortranLibraries from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:877)
TESTING: checkFortranLibraries from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:877)
Substitutes for FLIBS the libraries needed to link with Fortran
This macro is intended to be used in those situations when it is
necessary to mix, e.g. C++ and Fortran 77, source code into a single
program or shared library.
For example, if object files from a C++ and Fortran 77 compiler must
be linked together, then the C++ compiler/linker must be used for
linking (since special C++-ish things need to happen at link time
like calling global constructors, instantiating templates, enabling
exception support, etc.).
However, the Fortran 77 intrinsic and run-time libraries must be
linked in as well, but the C++ compiler/linker does not know how to
add these Fortran 77 libraries.
This code was translated from the autoconf macro which was packaged in
its current form by Matthew D. Langston <langston at SLAC.Stanford.EDU>.
However, nearly all of this macro came from the OCTAVE_FLIBS macro in
octave-2.0.13/aclocal.m4, and full credit should go to John W. Eaton
for writing this extremely useful macro.
Successful compile:
Source:
program main
#include <mpif.h>
call MPI_Allreduce()
end
Executing: mpif90 -o /tmp/petsc-wjcu960y/config.compilers/conftest -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.o -lstdc++ -ldl
Successful compile:
Source:
subroutine asub()
print*,'testing'
return
end
Successful compile:
Source:
{return 0;}
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/confc.o: in function `asub_':
/tmp/petsc-wjcu960y/config.compilers/conftest.F90:2: undefined reference to `_gfortran_st_write'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/conftest.F90:2: undefined reference to `_gfortran_transfer_character_write'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.compilers/conftest.F90:2: undefined reference to `_gfortran_st_write_done'
Fortran code cannot directly be linked with C linker, therefor will determine needed Fortran libraries
Successful compile:
Source:
subroutine asub()
print*,'testing'
return
end
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
{return 0;}
Executing: mpicxx -o /tmp/petsc-wjcu960y/config.compilers/conftest -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.o /tmp/petsc-wjcu960y/config.compilers/confc.o -lstdc++ -ldl
Possible ERROR while running linker: exit code 1
stderr:
collect2: error: ld returned 1 exit status
Fortran code cannot directly be linked with C++ linker, therefor will determine needed Fortran libraries
Executing: mpif90 -V
Successful compile:
Source:
program main
end
Executing: mpif90 -o /tmp/petsc-wjcu960y/config.compilers/conftest -v -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.o -lstdc++ -ldl
stdout:
mpif90 for the Intel(R) MPI Library 2019 Update 5 for Linux*
Copyright 2003-2019, Intel Corporation.
stdout:
Copyright 2003-2019, Intel Corporation.stderr:
Driving: gfortran -o /tmp/petsc-wjcu960y/config.compilers/conftest -v -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.o -lstdc++ -ldl -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0 -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -Xlinker --enable-new-dtags -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -Wl,-z,now -Wl,-z,relro -Wl,-z,noexecstack -Xlinker --enable-new-dtags -ldl -l gfortran -l m -shared-libgcc
Using built-in specs.
COLLECT_GCC=gfortran
COLLECT_LTO_WRAPPER=/usr/lib64/gcc/x86_64-suse-linux/7/lto-wrapper
OFFLOAD_TARGET_NAMES=hsa:nvptx-none
Target: x86_64-suse-linux
Configured with: ../configure --prefix=/usr --infodir=/usr/share/info --mandir=/usr/share/man --libdir=/usr/lib64 --libexecdir=/usr/lib64 --enable-languages=c,c++,objc,fortran,obj-c++,ada,go --enable-offload-targets=hsa,nvptx-none=/usr/nvptx-none, --without-cuda-driver --enable-checking=release --disable-werror --with-gxx-include-dir=/usr/include/c++/7 --enable-ssp --disable-libssp --disable-libvtv --disable-libcc1 --disable-plugin --with-bugurl=https://bugs.opensuse.org/ --with-pkgversion='SUSE Linux' --with-slibdir=/lib64 --with-system-zlib --enable-libstdcxx-allocator=new --disable-libstdcxx-pch --enable-version-specific-runtime-libs --with-gcc-major-version-only --enable-linker-build-id --enable-linux-futex --enable-gnu-indirect-function --program-suffix=-7 --without-system-libunwind --enable-multilib --with-arch-32=x86-64 --with-tune=generic --build=x86_64-suse-linux --host=x86_64-suse-linux
Thread model: posix
gcc version 7.5.0 (SUSE Linux)
Reading specs from /usr/lib64/gcc/x86_64-suse-linux/7/libgfortran.spec
rename spec lib to liborig
COLLECT_GCC_OPTIONS='-o' '/tmp/petsc-wjcu960y/config.compilers/conftest' '-v' '-fPIC' '-Wall' '-ffree-line-length-0' '-Wno-unused-dummy-argument' '-g' '-O' '-I' '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0' '-I' '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include' '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt' '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib' '-shared-libgcc' '-mtune=generic' '-march=x86-64'
COMPILER_PATH=/usr/lib64/gcc/x86_64-suse-linux/7/:/usr/lib64/gcc/x86_64-suse-linux/7/:/usr/lib64/gcc/x86_64-suse-linux/:/usr/lib64/gcc/x86_64-suse-linux/7/:/usr/lib64/gcc/x86_64-suse-linux/:/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/
LIBRARY_PATH=/usr/lib64/gcc/x86_64-suse-linux/7/:/usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin/:/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7/:/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin/:/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib/:/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64/:/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin/:/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4/:/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/lib/:/usr/lib64/gcc/x86_64-suse-linux/7/../../../:/lib/:/usr/lib/
/usr/lib64/gcc/x86_64-suse-linux/7/collect2 -plugin /usr/lib64/gcc/x86_64-suse-linux/7/liblto_plugin.so -plugin-opt=/usr/lib64/gcc/x86_64-suse-linux/7/lto-wrapper -plugin-opt=-fresolution=/tmp/ccBpEEeu.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lquadmath -plugin-opt=-pass-through=-lm -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --build-id --eh-frame-hdr -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o /tmp/petsc-wjcu960y/config.compilers/conftest /usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64/crt1.o /usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64/crti.o /usr/lib64/gcc/x86_64-suse-linux/7/crtbegin.o -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -L/usr/lib64/gcc/x86_64-suse-linux/7 -L/usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -L/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/lib -L/usr/lib64/gcc/x86_64-suse-linux/7/../../.. /tmp/petsc-wjcu960y/config.compilers/conftest.o -lstdc++ -ldl --enable-new-dtags -rpath /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -rpath /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -z now -z relro -z noexecstack --enable-new-dtags -ldl -lgfortran -lm -lgcc_s -lgcc -lquadmath -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib64/gcc/x86_64-suse-linux/7/crtend.o /usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64/crtn.o
compilers: Checking arg mpif90
compilers: Unknown arg mpif90
compilers: Checking arg for
compilers: Unknown arg for
compilers: Checking arg the
compilers: Unknown arg the
compilers: Checking arg Intel(R)
compilers: Unknown arg Intel(R)
compilers: Checking arg MPI
compilers: Unknown arg MPI
compilers: Checking arg Library
compilers: Unknown arg Library
compilers: Checking arg 2019
compilers: Unknown arg 2019
compilers: Checking arg Update
compilers: Unknown arg Update
compilers: Checking arg 5
compilers: Unknown arg 5
compilers: Checking arg Linux*
compilers: Unknown arg Linux*
compilers: Checking arg Copyright
compilers: Unknown arg Copyright
compilers: Checking arg 2003-2019,
compilers: Unknown arg 2003-2019,
compilers: Checking arg Corporation.
compilers: Unknown arg Corporation.
compilers: Checking arg Driving:
compilers: Unknown arg Driving:
compilers: Checking arg gfortran
compilers: Unknown arg gfortran
compilers: Checking arg -o
compilers: Unknown arg -o
compilers: Checking arg /tmp/petsc-wjcu960y/config.compilers/conftest
compilers: Unknown arg /tmp/petsc-wjcu960y/config.compilers/conftest
compilers: Checking arg -v
compilers: Unknown arg -v
compilers: Checking arg -fPIC
compilers: Unknown arg -fPIC
compilers: Checking arg -Wall
compilers: Unknown arg -Wall
compilers: Checking arg -ffree-line-length-0
compilers: Unknown arg -ffree-line-length-0
compilers: Checking arg -Wno-unused-dummy-argument
compilers: Unknown arg -Wno-unused-dummy-argument
compilers: Checking arg -g
compilers: Unknown arg -g
compilers: Checking arg -O
compilers: Unknown arg -O
compilers: Checking arg /tmp/petsc-wjcu960y/config.compilers/conftest.o
compilers: Unknown arg /tmp/petsc-wjcu960y/config.compilers/conftest.o
compilers: Checking arg -lstdc++
compilers: Found library: -lstdc++
compilers: Checking arg -ldl
compilers: Found library: -ldl
compilers: Checking arg -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0
compilers: Found include directory: /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0
compilers: Checking arg -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt
compilers: Found library directory: -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt
compilers: Checking arg -Xlinker
compilers: Unknown arg -Xlinker
compilers: Checking arg --enable-new-dtags
compilers: Unknown arg --enable-new-dtags
compilers: Checking arg -rpath
compilers: Checking arg /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt
compilers: Unknown arg /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt
compilers: Checking arg -lmpifort
compilers: Found library: -lmpifort
compilers: Checking arg -lrt
compilers: Found library: -lrt
compilers: Checking arg -lpthread
compilers: Found library: -lpthread
compilers: Checking arg -Wl,-z,now
compilers: Unknown arg -Wl,-z,now
compilers: Checking arg -Wl,-z,relro
compilers: Unknown arg -Wl,-z,relro
compilers: Checking arg -Wl,-z,noexecstack
compilers: Unknown arg -Wl,-z,noexecstack
compilers: Already in lflags: -ldl
compilers: Found canonical library: -lgfortran
compilers: Found canonical library: -lm
compilers: Checking arg -shared-libgcc
compilers: Unknown arg -shared-libgcc
compilers: Checking arg Using
compilers: Unknown arg Using
compilers: Checking arg built-in
compilers: Unknown arg built-in
compilers: Checking arg specs.
compilers: Unknown arg specs.
compilers: Checking arg COLLECT_GCC=gfortran
compilers: Unknown arg COLLECT_GCC=gfortran
compilers: Checking arg COLLECT_LTO_WRAPPER=/usr/lib64/gcc/x86_64-suse-linux/7/lto-wrapper
compilers: Unknown arg COLLECT_LTO_WRAPPER=/usr/lib64/gcc/x86_64-suse-linux/7/lto-wrapper
compilers: Checking arg OFFLOAD_TARGET_NAMES=hsa:nvptx-none
compilers: Unknown arg OFFLOAD_TARGET_NAMES=hsa:nvptx-none
compilers: Checking arg Target:
compilers: Unknown arg Target:
compilers: Checking arg x86_64-suse-linux
compilers: Unknown arg x86_64-suse-linux
compilers: Checking arg Configured
compilers: Unknown arg Configured
compilers: Checking arg with:
compilers: Unknown arg with:
compilers: Checking arg ../configure
compilers: Unknown arg ../configure
compilers: Checking arg --prefix=/usr
compilers: Unknown arg --prefix=/usr
compilers: Checking arg --infodir=/usr/share/info
compilers: Unknown arg --infodir=/usr/share/info
compilers: Checking arg --mandir=/usr/share/man
compilers: Unknown arg --mandir=/usr/share/man
compilers: Checking arg --libdir=/usr/lib64
compilers: Unknown arg --libdir=/usr/lib64
compilers: Checking arg --libexecdir=/usr/lib64
compilers: Unknown arg --libexecdir=/usr/lib64
compilers: Checking arg --enable-languages=c,c++,objc,fortran,obj-c++,ada,go
compilers: Unknown arg --enable-languages=c,c++,objc,fortran,obj-c++,ada,go
compilers: Checking arg --enable-offload-targets=hsa,nvptx-none=/usr/nvptx-none,
compilers: Unknown arg --enable-offload-targets=hsa,nvptx-none=/usr/nvptx-none,
compilers: Checking arg --without-cuda-driver
compilers: Unknown arg --without-cuda-driver
compilers: Checking arg --enable-checking=release
compilers: Unknown arg --enable-checking=release
compilers: Checking arg --disable-werror
compilers: Unknown arg --disable-werror
compilers: Checking arg --with-gxx-include-dir=/usr/include/c++/7
compilers: Unknown arg --with-gxx-include-dir=/usr/include/c++/7
compilers: Checking arg --enable-ssp
compilers: Unknown arg --enable-ssp
compilers: Checking arg --disable-libssp
compilers: Unknown arg --disable-libssp
compilers: Checking arg --disable-libvtv
compilers: Unknown arg --disable-libvtv
compilers: Checking arg --disable-libcc1
compilers: Unknown arg --disable-libcc1
compilers: Checking arg --disable-plugin
compilers: Unknown arg --disable-plugin
compilers: Checking arg --with-bugurl=https://bugs.opensuse.org/
compilers: Unknown arg --with-bugurl=https://bugs.opensuse.org/
compilers: Checking arg --with-pkgversion=
compilers: Unknown arg --with-pkgversion=
compilers: Checking arg --with-slibdir=/lib64
compilers: Unknown arg --with-slibdir=/lib64
compilers: Checking arg --with-system-zlib
compilers: Unknown arg --with-system-zlib
compilers: Checking arg --enable-libstdcxx-allocator=new
compilers: Unknown arg --enable-libstdcxx-allocator=new
compilers: Checking arg --disable-libstdcxx-pch
compilers: Unknown arg --disable-libstdcxx-pch
compilers: Checking arg --enable-version-specific-runtime-libs
compilers: Unknown arg --enable-version-specific-runtime-libs
compilers: Checking arg --with-gcc-major-version-only
compilers: Unknown arg --with-gcc-major-version-only
compilers: Checking arg --enable-linker-build-id
compilers: Unknown arg --enable-linker-build-id
compilers: Checking arg --enable-linux-futex
compilers: Unknown arg --enable-linux-futex
compilers: Checking arg --enable-gnu-indirect-function
compilers: Unknown arg --enable-gnu-indirect-function
compilers: Checking arg --program-suffix=-7
compilers: Unknown arg --program-suffix=-7
compilers: Checking arg --without-system-libunwind
compilers: Unknown arg --without-system-libunwind
compilers: Checking arg --enable-multilib
compilers: Unknown arg --enable-multilib
compilers: Checking arg --with-arch-32=x86-64
compilers: Unknown arg --with-arch-32=x86-64
compilers: Checking arg --with-tune=generic
compilers: Unknown arg --with-tune=generic
compilers: Checking arg --build=x86_64-suse-linux
compilers: Unknown arg --build=x86_64-suse-linux
compilers: Checking arg --host=x86_64-suse-linux
compilers: Unknown arg --host=x86_64-suse-linux
compilers: Checking arg Thread
compilers: Unknown arg Thread
compilers: Checking arg model:
compilers: Unknown arg model:
compilers: Checking arg posix
compilers: Unknown arg posix
compilers: Checking arg gcc
compilers: Unknown arg gcc
compilers: Checking arg version
compilers: Unknown arg version
compilers: Checking arg 7.5.0
compilers: Unknown arg 7.5.0
compilers: Checking arg (SUSE
compilers: Unknown arg (SUSE
compilers: Checking arg Linux)
compilers: Unknown arg Linux)
compilers: Checking arg Reading
compilers: Unknown arg Reading
compilers: Checking arg from
compilers: Unknown arg from
compilers: Checking arg /usr/lib64/gcc/x86_64-suse-linux/7/libgfortran.spec
compilers: Unknown arg /usr/lib64/gcc/x86_64-suse-linux/7/libgfortran.spec
compilers: Checking arg rename
compilers: Unknown arg rename
compilers: Checking arg lib
compilers: Unknown arg lib
compilers: Checking arg to
compilers: Unknown arg to
compilers: Checking arg liborig
compilers: Unknown arg liborig
compilers: Checking arg COLLECT_GCC_OPTIONS=
compilers: Unknown arg COLLECT_GCC_OPTIONS=
compilers: Checking arg COMPILER_PATH=/usr/lib64/gcc/x86_64-suse-linux/7/:/usr/lib64/gcc/x86_64-suse-linux/7/:/usr/lib64/gcc/x86_64-suse-linux/:/usr/lib64/gcc/x86_64-suse-linux/7/:/usr/lib64/gcc/x86_64-suse-linux/:/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/
compilers: Skipping arg COMPILER_PATH=/usr/lib64/gcc/x86_64-suse-linux/7/:/usr/lib64/gcc/x86_64-suse-linux/7/:/usr/lib64/gcc/x86_64-suse-linux/:/usr/lib64/gcc/x86_64-suse-linux/7/:/usr/lib64/gcc/x86_64-suse-linux/:/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/
compilers: Checking arg LIBRARY_PATH=/usr/lib64/gcc/x86_64-suse-linux/7/:/usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin/:/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7/:/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin/:/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib/:/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64/:/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin/:/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4/:/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/lib/:/usr/lib64/gcc/x86_64-suse-linux/7/../../../:/lib/:/usr/lib/
compilers: Skipping arg LIBRARY_PATH=/usr/lib64/gcc/x86_64-suse-linux/7/:/usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin/:/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7/:/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin/:/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib/:/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64/:/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin/:/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4/:/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/lib/:/usr/lib64/gcc/x86_64-suse-linux/7/../../../:/lib/:/usr/lib/
compilers: Checking arg /usr/lib64/gcc/x86_64-suse-linux/7/collect2
compilers: Unknown arg /usr/lib64/gcc/x86_64-suse-linux/7/collect2
compilers: Checking arg -plugin
compilers: Unknown arg -plugin
compilers: Checking arg /usr/lib64/gcc/x86_64-suse-linux/7/liblto_plugin.so
compilers: Unknown arg /usr/lib64/gcc/x86_64-suse-linux/7/liblto_plugin.so
compilers: Checking arg -plugin-opt=/usr/lib64/gcc/x86_64-suse-linux/7/lto-wrapper
compilers: Unknown arg -plugin-opt=/usr/lib64/gcc/x86_64-suse-linux/7/lto-wrapper
compilers: Checking arg -plugin-opt=-fresolution=/tmp/ccBpEEeu.res
compilers: Unknown arg -plugin-opt=-fresolution=/tmp/ccBpEEeu.res
compilers: Checking arg -plugin-opt=-pass-through=-lgcc_s
compilers: Unknown arg -plugin-opt=-pass-through=-lgcc_s
compilers: Checking arg -plugin-opt=-pass-through=-lquadmath
compilers: Unknown arg -plugin-opt=-pass-through=-lquadmath
compilers: Checking arg -plugin-opt=-pass-through=-lm
compilers: Unknown arg -plugin-opt=-pass-through=-lm
compilers: Checking arg -plugin-opt=-pass-through=-lc
compilers: Unknown arg -plugin-opt=-pass-through=-lc
compilers: Checking arg --build-id
compilers: Unknown arg --build-id
compilers: Checking arg --eh-frame-hdr
compilers: Unknown arg --eh-frame-hdr
compilers: Checking arg -m
compilers: Unknown arg -m
compilers: Checking arg elf_x86_64
compilers: Unknown arg elf_x86_64
compilers: Checking arg -dynamic-linker
compilers: Unknown arg -dynamic-linker
compilers: Checking arg /lib64/ld-linux-x86-64.so.2
compilers: Unknown arg /lib64/ld-linux-x86-64.so.2
compilers: Checking arg /usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64/crt1.o
compilers: Unknown arg /usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64/crt1.o
compilers: Checking arg /usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64/crti.o
compilers: Unknown arg /usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64/crti.o
compilers: Checking arg /usr/lib64/gcc/x86_64-suse-linux/7/crtbegin.o
compilers: Unknown arg /usr/lib64/gcc/x86_64-suse-linux/7/crtbegin.o
compilers: Already in lflags so skipping: -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt
compilers: Checking arg -L/usr/lib64/gcc/x86_64-suse-linux/7
compilers: Found library directory: -L/usr/lib64/gcc/x86_64-suse-linux/7
compilers: Checking arg -L/usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64
compilers: Checking arg -L/lib/../lib64
compilers: Checking arg -L/usr/lib/../lib64
compilers: Checking arg -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin
compilers: Found library directory: -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin
compilers: Checking arg -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7
compilers: Found library directory: -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7
compilers: Checking arg -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin
compilers: Found library directory: -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin
compilers: Checking arg -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib
compilers: Found library directory: -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib
compilers: Checking arg -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64
compilers: Found library directory: -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64
compilers: Checking arg -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin
compilers: Found library directory: -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin
compilers: Checking arg -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4
compilers: Found library directory: -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4
compilers: Checking arg -L/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/lib
compilers: Found library directory: -L/usr/x86_64-suse-linux/lib
compilers: Already in lflags: -lstdc++
compilers: Found -rpath library: /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt
compilers: Already in lflags: -lmpifort
compilers: Already in lflags: -lrt
compilers: Already in lflags: -lpthread
compilers: Checking arg -z
compilers: Unknown arg -z
compilers: Checking arg now
compilers: Unknown arg now
compilers: Checking arg relro
compilers: Unknown arg relro
compilers: Checking arg noexecstack
compilers: Unknown arg noexecstack
compilers: Checking arg -lgfortran
compilers: Found library: -lgfortran
compilers: Checking arg -lgcc_s
compilers: Found library: -lgcc_s
compilers: Found system library therefor skipping: -lgcc
compilers: Checking arg -lquadmath
compilers: Found library: -lquadmath
compilers: Already in lflags: -lgcc_s
compilers: Checking arg -lc
compilers: Found system library therefor skipping: -lc
compilers: Checking arg /usr/lib64/gcc/x86_64-suse-linux/7/crtend.o
compilers: Unknown arg /usr/lib64/gcc/x86_64-suse-linux/7/crtend.o
compilers: Checking arg /usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64/crtn.o
compilers: Unknown arg /usr/lib64/gcc/x86_64-suse-linux/7/../../../../lib64/crtn.o
compilers: Libraries needed to link Fortran code with the C linker: ['-lstdc++', '-ldl', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lmpifort', '-lmpi', '-lrt', '-lpthread', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7', '-L/usr/lib64/gcc/x86_64-suse-linux/7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-Wl,-rpath,/usr/x86_64-suse-linux/lib', '-L/usr/x86_64-suse-linux/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath']
compilers: Libraries needed to link Fortran main with the C linker: []
compilers: Check that Fortran libraries can be used from C
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -lstdc++ -ldl -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7 -L/usr/lib64/gcc/x86_64-suse-linux/7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl
Successful compile:
Source:
int main() {
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -lstdc++ -ldl -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7 -L/usr/lib64/gcc/x86_64-suse-linux/7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
Successful compile:
Source:
int main() {
return 0;
Testing executable /tmp/petsc-wjcu960y/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-wjcu960y/config.setCompilers/conftest
compilers: Check that Fortran libraries can be used from C++
compilers: Fortran libraries can be used from C++
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Executing: mpicxx -o /tmp/petsc-wjcu960y/config.setCompilers/conftest -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -lstdc++ -ldl -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7 -L/usr/lib64/gcc/x86_64-suse-linux/7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl
Successful compile:
Source:
int main() {
return 0;
Executing: mpicxx -o /tmp/petsc-wjcu960y/config.setCompilers/conftest -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -lstdc++ -ldl -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7 -L/usr/lib64/gcc/x86_64-suse-linux/7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
return 0;
TEST checkFortranLinkingCxx from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1273)
TESTING: checkFortranLinkingCxx from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1273)
Check that Fortran can be linked against C++
Successful compile:
Source:
extern "C" void d1chk_(void);
void foo(void){d1chk_();}
Successful compile:
Source:
Successful compile:
Source:
program main
call d1chk()
end
Executing: mpif90 -o /tmp/petsc-wjcu960y/config.compilers/conftest -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.o /tmp/petsc-wjcu960y/config.compilers/cxxobj.o /tmp/petsc-wjcu960y/config.compilers/confc.o -lstdc++ -ldl
compilers: Fortran can link C++ functions
TEST checkFortran90 from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1339)
TESTING: checkFortran90 from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1339)
Determine whether the Fortran compiler handles F90
Successful compile:
Source:
program main
INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8)
INTEGER (KIND=int) :: ierr
ierr = 1
end
Defined "USING_F90" to "1"
Fortran compiler supports F90
TEST checkFortran90FreeForm from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1352)
TESTING: checkFortran90FreeForm from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1352)
Determine whether the Fortran compiler handles F90FreeForm
We also require that the compiler handles lines longer than 132 characters
Successful compile:
Source:
program main
INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8); INTEGER (KIND=int) :: ierr; ierr = 1
end
Defined "USING_F90FREEFORM" to "1"
Fortran compiler supports F90FreeForm
TEST checkFortran2003 from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1366)
TESTING: checkFortran2003 from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1366)
Determine whether the Fortran compiler handles F2003
Successful compile:
Source:
module Base_module
type, public :: base_type
integer :: A
contains
procedure, public :: Print => BasePrint
end type base_type
contains
subroutine BasePrint(this)
class(base_type) :: this
end subroutine BasePrint
end module Base_module
program main
use,intrinsic :: iso_c_binding
Type(C_Ptr),Dimension(:),Pointer :: CArray
character(kind=c_char),pointer :: nullc => null()
character(kind=c_char,len=5),dimension(:),pointer::list1
allocate(list1(5))
CArray = (/(c_loc(list1(i)),i=1,5),c_loc(nullc)/)
end
Defined "USING_F2003" to "1"
Fortran compiler supports F2003
TEST checkFortran90Array from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1401)
TESTING: checkFortran90Array from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1401)
Check for F90 array interfaces
Executing: uname -s
stdout: Linux
Successful compile:
Source:
#include<stdio.h>
#include <stdlib.h>
void f90arraytest_(void* a1, void* a2,void* a3, void* i)
printf("arrays [%p %p %p]\n",a1,a2,a3);
fflush(stdout);
return;
void f90ptrtest_(void* a1, void* a2,void* a3, void* i, void* p1 ,void* p2, void* p3)
if ((p1 == p3) && (p1 != p2)) {
printf("pointers match! [%p %p] [%p]\n",p1,p3,p2);
fflush(stdout);
} else {
printf("pointers do not match! [%p %p] [%p]\n",p1,p3,p2);
fflush(stdout);
exit(111);
return;
Successful compile:
Source:
program main
Interface
Subroutine f90ptrtest(p1,p2,p3,i)
integer, pointer :: p1(:,:)
integer, pointer :: p2(:,:)
integer, pointer :: p3(:,:)
integer i
End Subroutine
End Interface
integer, pointer :: ptr1(:,:),ptr2(:,:)
integer, target :: array(6:8,9:21)
integer in
in = 25
ptr1 => array
ptr2 => array
call f90arraytest(ptr1,ptr2,ptr1,in)
call f90ptrtest(ptr1,ptr2,ptr1,in)
end
Executing: mpif90 -o /tmp/petsc-wjcu960y/config.compilers/conftest -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.o /tmp/petsc-wjcu960y/config.compilers/fooobj.o -lstdc++ -ldl
Testing executable /tmp/petsc-wjcu960y/config.compilers/conftest to see if it can be run
Executing: /tmp/petsc-wjcu960y/config.compilers/conftest
stdout:
arrays [0x7ffd664e06f0 0x7ffd664e06f0 0x7ffd664e06f0]
arrays [0x7ffd664e06a0 0x7ffd664e0650 0x7ffd664e06a0]
pointers do not match! [0x14ee72e20400 0x7ffd664e06f0] [0x14ee759542c0]
ERROR while running executable: Could not execute "['/tmp/petsc-wjcu960y/config.compilers/conftest']":
compilers: F90 uses a single argument for array pointers
TEST checkFortranModuleInclude from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1488)
TESTING: checkFortranModuleInclude from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1488)
Figures out what flag is used to specify the include path for Fortran modules
Successful compile:
Source:
module configtest
integer testint
parameter (testint = 42)
end module configtest
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.compilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers/confdir -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.F90
Successful compile:
Source:
program main
use configtest
write(*,*) testint
end
Executing: mpif90 -o /tmp/petsc-wjcu960y/config.compilers/conftest -I/tmp/petsc-wjcu960y/config.compilers/confdir -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.o /tmp/petsc-wjcu960y/config.compilers/configtest.o -lstdc++ -ldl
compilers: Fortran module include flag -I found
TEST checkFortranModuleOutput from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1554)
TESTING: checkFortranModuleOutput from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1554)
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.compilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -module /tmp/petsc-wjcu960y/config.compilers/confdir -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.F90
Possible ERROR while running compiler: exit code 1
stderr:
gfortran: error: unrecognized command line option ���-module���; did you mean ���-mhle���?
Source:
module configtest
integer testint
compilers: Fortran module output flag -module compile failed
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.compilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -module:/tmp/petsc-wjcu960y/config.compilers/confdir -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.F90
stderr:
gfortran: error: unrecognized command line option ���-module:/tmp/petsc-wjcu960y/config.compilers/confdir���
Source:
module configtest
integer testint
compilers: Fortran module output flag -module: compile failed
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.compilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -fmod=/tmp/petsc-wjcu960y/config.compilers/confdir -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.F90
stderr:
gfortran: error: unrecognized command line option ���-fmod=/tmp/petsc-wjcu960y/config.compilers/confdir���
Source:
module configtest
integer testint
compilers: Fortran module output flag -fmod= compile failed
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.compilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -J/tmp/petsc-wjcu960y/config.compilers/confdir -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.F90
Successful compile:
Source:
module configtest
integer testint
compilers: Fortran module output flag -J found
TEST checkFortranTypeStar from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1328)
TESTING: checkFortranTypeStar from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1328)
Determine whether the Fortran compiler handles type(*)
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.compilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.compilers/conftest.F90
Successful compile:
Source:
program main
interface
subroutine a(b)
type(*) :: b(:)
end subroutine
end interface
end
Defined "HAVE_FORTRAN_TYPE_STAR" to "1"
Fortran compiler supports type(*)
TEST checkFortranTypeInitialize from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1317)
TESTING: checkFortranTypeInitialize from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1317)
Determines if PETSc objects in Fortran are initialized by default (doesn't work with common blocks)
Defined "HAVE_FORTRAN_TYPE_INITIALIZE" to "-2"
Defined "FORTRAN_TYPE_INITIALIZE" to " = -2"
Initializing Fortran objects
TEST configureFortranFlush from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1308)
TESTING: configureFortranFlush from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1308)
Successful compile:
Source:
program main
call flush(6)
end
Defined "HAVE_FORTRAN_FLUSH" to "1"
TEST setupFrameworkCompilers from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1721)
TESTING: setupFrameworkCompilers from config.compilers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/compilers.py:1721)
TEST configureClosure from config.utilities.closure(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/closure.py:17)
TESTING: configureClosure from config.utilities.closure(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/closure.py:17)
Determine if Apple ^close syntax is supported in C
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.utilities.closure
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.utilities.closure/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.utilities.closure/conftest.c
stderr:
/tmp/petsc-wjcu960y/config.utilities.closure/conftest.c: In function ���main���:
/tmp/petsc-wjcu960y/config.utilities.closure/conftest.c:6:6: error: expected identifier or ���(��� before ���^��� token
int (^closure)(int);;
Source:
#include <stdio.h>
int main() {
return 0;
Compile failed inside link
TEST configureFortranCPP from PETSc.options.fortranCPP(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/fortranCPP.py:20)
TESTING: configureFortranCPP from PETSc.options.fortranCPP(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/fortranCPP.py:20)
Handle case where Fortran cannot preprocess properly
Defined make rule ".f.o .f90.o .f95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} -o $@ $<']
Defined make rule ".f.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
Defined make rule ".F.o .F90.o .F95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} -o $@ $<']
Defined make rule ".F.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
TEST configureCLanguage from PETSc.options.languages(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/languages.py:27)
TESTING: configureCLanguage from PETSc.options.languages(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/languages.py:27)
Choose whether to compile the PETSc library using a C or C++ compiler
C language is C
Defined "CLANGUAGE_C" to "1"
TEST checkStdC from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:105)
TESTING: checkStdC from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:105)
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.headers/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.headers/conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdarg.h>
#include <string.h>
#include <float.h>
int main() {
return 0;
Source:
#include <string.h>
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers /tmp/petsc-wjcu960y/config.headers/conftest.c
Source:
#include <stdlib.h>
Successful compile:
Source:
#include <stdlib.h>
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
#define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
int main() {
int i;
for(i = 0; i < 256; i++) if (XOR(islower(i), ISLOWER(i)) || toupper(i) != TOUPPER(i)) exit(2);
exit(0);
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.headers/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.headers/conftest.o -lstdc++ -ldl
Testing executable /tmp/petsc-wjcu960y/config.headers/conftest to see if it can be run
Executing: /tmp/petsc-wjcu960y/config.headers/conftest
Defined "STDC_HEADERS" to "1"
TEST checkStat from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:138)
TESTING: checkStat from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:138)
Checks whether stat file-mode macros are broken, and defines STAT_MACROS_BROKEN if they are
Source:
#include <sys/types.h>
#include <sys/stat.h>
#if defined(S_ISBLK) && defined(S_IFDIR)
# if S_ISBLK (S_IFDIR)
You lose.
# endif
#endif
#if defined(S_ISBLK) && defined(S_IFCHR)
# if S_ISBLK (S_IFCHR)
You lose.
# endif
#endif
#if defined(S_ISLNK) && defined(S_IFREG)
# if S_ISLNK (S_IFREG)
You lose.
# endif
#endif
#if defined(S_ISSOCK) && defined(S_IFREG)
# if S_ISSOCK (S_IFREG)
You lose.
# endif
#endif
TEST checkSysWait from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:173)
TESTING: checkSysWait from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:173)
Check for POSIX.1 compatible sys/wait.h, and defines HAVE_SYS_WAIT_H if found
Successful compile:
Source:
#include <sys/wait.h>
#ifndef WEXITSTATUS
#define WEXITSTATUS(stat_val) ((unsigned)(stat_val) >> 8)
#endif
#ifndef WIFEXITED
#define WIFEXITED(stat_val) (((stat_val) & 255) == 0)
#endif
int main() {
int s;
wait (&s);
s = WIFEXITED (s) ? WEXITSTATUS (s) : 1;
return 0;
Defined "HAVE_SYS_WAIT_H" to "1"
TEST checkTime from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:195)
TESTING: checkTime from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:195)
Checks if you can safely include both <sys/time.h> and <time.h>, and if so defines TIME_WITH_SYS_TIME
Checking for header: time.h
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Defined "HAVE_TIME_H" to "1"
Checking for header: sys/time.h
Defined "HAVE_SYS_TIME_H" to "1"
Successful compile:
Source:
#include <sys/time.h>
#include <time.h>
int main() {
struct tm *tp = 0;
if (tp);
return 0;
Defined "TIME_WITH_SYS_TIME" to "1"
TEST checkMath from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:203)
TESTING: checkMath from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:203)
Checks for the math headers and defines
Checking for header: math.h
Defined "HAVE_MATH_H" to "1"
Successful compile:
Source:
#include <math.h>
int main() {
double pi = M_PI;
if (pi);
return 0;
Found math #defines, like M_PI
Successful compile:
Source:
#include <math.h>
int main() {
double f = INFINITY;
if (f);
return 0;
Defined "HAVE_MATH_INFINITY" to "1"
Found math INFINITY
TEST check from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:77)
Checks for "header", and defines HAVE_"header" if found
Checking for header: setjmp.h
Defined "HAVE_SETJMP_H" to "1"
Checking for header: dos.h
Possible ERROR while running preprocessor: exit code 1
stdout:
# 1 "/tmp/petsc-wjcu960y/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "<command-line>" 2
# 1 "/tmp/petsc-wjcu960y/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-wjcu960y/config.headers/conftest.c" 2
# 1 "/tmp/petsc-wjcu960y/config.headers/conffix.h" 1
# 3 "/tmp/petsc-wjcu960y/config.headers/conftest.c" 2
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: dos.h: No such file or directory
#include <dos.h>
compilation terminated.
Source:
#include <dos.h>
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: dos.h: No such file or directory
#include <dos.h>
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: dos.h: No such file or directory #include <dos.h> ^~~~~~~compilation terminated.:
Checking for header: endian.h
Defined "HAVE_ENDIAN_H" to "1"
Checking for header: fcntl.h
Defined "HAVE_FCNTL_H" to "1"
Checking for header: float.h
Defined "HAVE_FLOAT_H" to "1"
Checking for header: io.h
stdout:
# 1 "<built-in>"
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: io.h: No such file or directory
#include <io.h>
Source:
#include <io.h>
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: io.h: No such file or directory
#include <io.h>
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: io.h: No such file or directory #include <io.h> ^~~~~~compilation terminated.:
Checking for header: limits.h
Defined "HAVE_LIMITS_H" to "1"
Checking for header: malloc.h
Defined "HAVE_MALLOC_H" to "1"
Checking for header: pwd.h
Defined "HAVE_PWD_H" to "1"
Checking for header: search.h
Defined "HAVE_SEARCH_H" to "1"
Checking for header: strings.h
Defined "HAVE_STRINGS_H" to "1"
Checking for header: unistd.h
Defined "HAVE_UNISTD_H" to "1"
Checking for header: sys/sysinfo.h
Defined "HAVE_SYS_SYSINFO_H" to "1"
Checking for header: machine/endian.h
stdout:
# 1 "<built-in>"
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: machine/endian.h: No such file or directory
#include <machine/endian.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: machine/endian.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: machine/endian.h: No such file or directory #include <machine/endian.h> ^~~~~~~~~~~~~~~~~~compilation terminated.:
Checking for header: sys/param.h
Defined "HAVE_SYS_PARAM_H" to "1"
Checking for header: sys/procfs.h
Defined "HAVE_SYS_PROCFS_H" to "1"
Checking for header: sys/resource.h
Defined "HAVE_SYS_RESOURCE_H" to "1"
Checking for header: sys/systeminfo.h
stdout:
# 1 "<built-in>"
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: sys/systeminfo.h: No such file or directory
#include <sys/systeminfo.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: sys/systeminfo.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: sys/systeminfo.h: No such file or directory #include <sys/systeminfo.h> ^~~~~~~~~~~~~~~~~~compilation terminated.:
Checking for header: sys/times.h
Defined "HAVE_SYS_TIMES_H" to "1"
Checking for header: sys/utsname.h
Defined "HAVE_SYS_UTSNAME_H" to "1"
Checking for header: string.h
Defined "HAVE_STRING_H" to "1"
Checking for header: stdlib.h
Defined "HAVE_STDLIB_H" to "1"
Checking for header: sys/socket.h
Defined "HAVE_SYS_SOCKET_H" to "1"
Checking for header: sys/wait.h
Checking for header: netinet/in.h
Defined "HAVE_NETINET_IN_H" to "1"
Checking for header: netdb.h
Defined "HAVE_NETDB_H" to "1"
Checking for header: Direct.h
stdout:
# 1 "<built-in>"
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: Direct.h: No such file or directory
#include <Direct.h>
Source:
#include <Direct.h>
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: Direct.h: No such file or directory
#include <Direct.h>
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: Direct.h: No such file or directory #include <Direct.h> ^~~~~~~~~~compilation terminated.:
Checking for header: Ws2tcpip.h
stdout:
# 1 "<built-in>"
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: Ws2tcpip.h: No such file or directory
#include <Ws2tcpip.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: Ws2tcpip.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: Ws2tcpip.h: No such file or directory #include <Ws2tcpip.h> ^~~~~~~~~~~~compilation terminated.:
Checking for header: sys/types.h
Defined "HAVE_SYS_TYPES_H" to "1"
Checking for header: WindowsX.h
stdout:
# 1 "<built-in>"
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: WindowsX.h: No such file or directory
#include <WindowsX.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: WindowsX.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: WindowsX.h: No such file or directory #include <WindowsX.h> ^~~~~~~~~~~~compilation terminated.:
Checking for header: cxxabi.h
stdout:
# 1 "<built-in>"
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: cxxabi.h: No such file or directory
#include <cxxabi.h>
Source:
#include <cxxabi.h>
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: cxxabi.h: No such file or directory
#include <cxxabi.h>
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: cxxabi.h: No such file or directory #include <cxxabi.h> ^~~~~~~~~~compilation terminated.:
Checking for header: ieeefp.h
stdout:
# 1 "<built-in>"
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: ieeefp.h: No such file or directory
#include <ieeefp.h>
Source:
#include <ieeefp.h>
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: ieeefp.h: No such file or directory
#include <ieeefp.h>
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: ieeefp.h: No such file or directory #include <ieeefp.h> ^~~~~~~~~~compilation terminated.:
Checking for header: stdint.h
Defined "HAVE_STDINT_H" to "1"
Checking for header: sched.h
Defined "HAVE_SCHED_H" to "1"
Checking for header: pthread.h
Defined "HAVE_PTHREAD_H" to "1"
Checking for header: inttypes.h
Defined "HAVE_INTTYPES_H" to "1"
Checking for header: immintrin.h
Defined "HAVE_IMMINTRIN_H" to "1"
Checking for header: zmmintrin.h
stdout:
# 1 "<built-in>"
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: zmmintrin.h: No such file or directory
#include <zmmintrin.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: zmmintrin.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: zmmintrin.h: No such file or directory #include <zmmintrin.h> ^~~~~~~~~~~~~compilation terminated.:
stdout:
# 1 "<built-in>"
stderr:
#include <dos.h>
Source:
#include <dos.h>
#include <dos.h>
stdout:
# 1 "<built-in>"
stderr:
#include <io.h>
Source:
#include <io.h>
#include <io.h>
stdout:
# 1 "<built-in>"
stderr:
Source:
stdout:
# 1 "<built-in>"
stderr:
Source:
stdout:
# 1 "<built-in>"
stderr:
#include <Direct.h>
Source:
#include <Direct.h>
#include <Direct.h>
stdout:
# 1 "<built-in>"
stderr:
Source:
stdout:
# 1 "<built-in>"
stderr:
Source:
stdout:
# 1 "<built-in>"
stderr:
#include <cxxabi.h>
Source:
#include "confdefs.h"
#include "conffix.h"
#include <cxxabi.h>
#include <cxxabi.h>
stdout:
# 1 "<built-in>"
stderr:
#include <ieeefp.h>
Source:
#include <ieeefp.h>
#include <ieeefp.h>
stdout:
# 1 "<built-in>"
stderr:
Source:
TEST checkRecursiveMacros from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:223)
TESTING: checkRecursiveMacros from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:223)
Checks that the preprocessor allows recursive macros, and if not defines HAVE_BROKEN_RECURSIVE_MACRO
Successful compile:
Source:
void a(int i, int j) {}
#define a(b) a(b,__LINE__)
int main() {
a(0);
return 0;
TEST configureCacheDetails from config.utilities.cacheDetails(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/cacheDetails.py:77)
TESTING: configureCacheDetails from config.utilities.cacheDetails(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/cacheDetails.py:77)
Try to determine the size and associativity of the cache.
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.utilities.cacheDetails
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.utilities.cacheDetails/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.utilities.cacheDetails/conftest.c
Successful compile:
Source:
#include <unistd.h>
long getconf_LEVEL1_DCACHE_SIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_SIZE); return (16 <= val && val <= 2147483647) ? val : 32768; }
int main() {
return 0;
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_SIZE()); fclose(output);;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.utilities.cacheDetails/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.utilities.cacheDetails/conftest.o -lstdc++ -ldl
Testing executable /tmp/petsc-wjcu960y/config.utilities.cacheDetails/conftest to see if it can be run
Executing: /tmp/petsc-wjcu960y/config.utilities.cacheDetails/conftest
Defined "LEVEL1_DCACHE_SIZE" to "32768"
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
long getconf_LEVEL1_DCACHE_LINESIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_LINESIZE); return (16 <= val && val <= 2147483647) ? val : 32; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_LINESIZE()); fclose(output);;
return 0;
Defined "LEVEL1_DCACHE_LINESIZE" to "64"
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
long getconf_LEVEL1_DCACHE_ASSOC() { long val = sysconf(_SC_LEVEL1_DCACHE_ASSOC); return (0 <= val && val <= 2147483647) ? val : 2; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_ASSOC()); fclose(output);;
return 0;
Defined "LEVEL1_DCACHE_ASSOC" to "8"
TEST check_struct_sigaction from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:46)
TESTING: check_struct_sigaction from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:46)
Checks if "struct sigaction" exists in signal.h. This check is for C89 check.
Checking for type: struct sigaction
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.types
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.types/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.types/conftest.c
stderr:
/tmp/petsc-wjcu960y/config.types/conftest.c: In function ���main���:
/tmp/petsc-wjcu960y/config.types/conftest.c:13:18: warning: unused variable ���a��� [-Wunused-variable]
struct sigaction a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#include<signal.h>
#endif
int main() {
return 0;
struct sigaction found
Defined "HAVE_STRUCT_SIGACTION" to "1"
TEST check__int64 from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:52)
TESTING: check__int64 from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:52)
Checks if __int64 exists. This is primarily for windows.
Checking for type: __int64
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.types/conftest.o -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.types/conftest.c
stderr:
/tmp/petsc-wjcu960y/config.types/conftest.c:13:1: error: unknown type name ���__int64���; did you mean ���__int64_t���?
__int64 a;;
__int64_t
/tmp/petsc-wjcu960y/config.types/conftest.c:13:9: warning: unused variable ���a��� [-Wunused-variable]
__int64 a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
__int64 a;;
return 0;
__int64 found
TEST checkSizeTypes from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:58)
TESTING: checkSizeTypes from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:58)
Checks for types associated with sizes, such as size_t.
Checking for type: size_t
stderr:
/tmp/petsc-wjcu960y/config.types/conftest.c:13:8: warning: unused variable ���a��� [-Wunused-variable]
size_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
size_t a;;
return 0;
size_t found
TEST checkFileTypes from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:68)
TESTING: checkFileTypes from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:68)
Checks for types associated with files, such as mode_t, off_t, etc.
Checking for type: mode_t
stderr:
mode_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
mode_t a;;
return 0;
mode_t found
Checking for type: off_t
stderr:
/tmp/petsc-wjcu960y/config.types/conftest.c:13:7: warning: unused variable ���a��� [-Wunused-variable]
off_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
off_t a;;
return 0;
off_t found
TEST checkIntegerTypes from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:63)
TESTING: checkIntegerTypes from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:63)
Checks for types associated with integers, such as int32_t.
Checking for type: int32_t
stderr:
int32_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
int32_t a;;
return 0;
int32_t found
TEST checkPID from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:74)
TESTING: checkPID from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:74)
Checks for pid_t, and defines it if necessary
Checking for type: pid_t
stderr:
pid_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
pid_t a;;
return 0;
pid_t found
TEST checkUID from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:78)
TESTING: checkUID from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:78)
Checks for uid_t and gid_t, and defines them if necessary
Source:
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.headers /tmp/petsc-wjcu960y/config.types/conftest.c
TEST checkSignal from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:85)
TESTING: checkSignal from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:85)
Checks the return type of signal() and defines RETSIGTYPE to that type name
Successful compile:
Source:
#include <signal.h>
#ifdef signal
#undef signal
#endif
#ifdef __cplusplus
extern "C" void (*signal (int, void(*)(int)))(int);
#else
void (*signal())();
#endif
int main() {
return 0;
Defined "RETSIGTYPE" to "void"
TEST checkC99Complex from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:106)
TESTING: checkC99Complex from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:106)
Check for complex numbers in in C99 std
Note that since PETSc source code uses _Complex we test specifically for that, not complex
stderr:
/tmp/petsc-wjcu960y/config.types/conftest.c:6:17: warning: variable ���x��� set but not used [-Wunused-but-set-variable]
double _Complex x;
Source:
#include <complex.h>
int main() {
double _Complex x;
x = I;
return 0;
stderr:
double _Complex x;
Source:
int main() {
double _Complex x;
x = I;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.types/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.types/conftest.o -lstdc++ -ldl
Defined "HAVE_C99_COMPLEX" to "1"
TEST checkCxxComplex from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:117)
TESTING: checkCxxComplex from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:117)
Check for complex numbers in namespace std
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.types/conftest.o -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fPIC /tmp/petsc-wjcu960y/config.types/conftest.cc
Successful compile:
Source:
#include <complex>
int main() {
std::complex<double> x;
return 0;
Executing: mpicxx -o /tmp/petsc-wjcu960y/config.types/conftest -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.types/conftest.o -lstdc++ -ldl
Defined "HAVE_CXX_COMPLEX" to "1"
TEST checkFortranKind from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:138)
TESTING: checkFortranKind from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:138)
Checks whether selected_int_kind etc work USE_FORTRANKIND
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.types/conftest.o -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.types/conftest.F90
stderr:
/tmp/petsc-wjcu960y/config.types/conftest.F90:4:43:
real(kind=selected_real_kind(10)) d
1
Warning: Unused variable ���d��� declared at (1) [-Wunused-variable]
/tmp/petsc-wjcu960y/config.types/conftest.F90:3:45:
integer(kind=selected_int_kind(10)) i
1
Warning: Unused variable ���i��� declared at (1) [-Wunused-variable]
Source:
program main
end
Defined "USE_FORTRANKIND" to "1"
TEST checkConst from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:150)
TESTING: checkConst from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:150)
Checks for working const, and if not found defines it to empty string
stderr:
/tmp/petsc-wjcu960y/config.types/conftest.c:25:5: warning: this ���if��� clause does not guard... [-Wmisleading-indentation]
if (x[0]);
/tmp/petsc-wjcu960y/config.types/conftest.c:26:5: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ���if���
{ /* SCO 3.2v4 cc rejects this. */
/tmp/petsc-wjcu960y/config.types/conftest.c:25:10: warning: ���x[0]��� is used uninitialized in this function [-Wuninitialized]
if (x[0]);
/tmp/petsc-wjcu960y/config.types/conftest.c:30:9: warning: ���t��� is used uninitialized in this function [-Wuninitialized]
*t++ = 0;
/tmp/petsc-wjcu960y/config.types/conftest.c:46:25: warning: ���b��� is used uninitialized in this function [-Wuninitialized]
struct s *b; b->j = 5;
Source:
int main() {
/* Ultrix mips cc rejects this. */
typedef int charset[2]; const charset x;
/* SunOS 4.1.1 cc rejects this. */
char const *const *ccp;
char **p;
/* NEC SVR4.0.2 mips cc rejects this. */
struct point {int x, y;};
static struct point const zero = {0,0};
/* AIX XL C 1.02.0.0 rejects this.
It does not let you subtract one const X* pointer from another in an arm
of an if-expression whose if-part is not a constant expression */
const char *g = "string";
ccp = &g + (g ? g-g : 0);
/* HPUX 7.0 cc rejects these. */
++ccp;
p = (char**) ccp;
ccp = (char const *const *) p;
/* This section avoids unused variable warnings */
if (zero.x);
if (x[0]);
char *t;
char const *s = 0 ? (char *) 0 : (char const *) 0;
*t++ = 0;
if (*s);
{ /* Someone thinks the Sun supposedly-ANSI compiler will reject this. */
int x[] = {25, 17};
const int *foo = &x[0];
++foo;
{ /* Sun SC1.0 ANSI compiler rejects this -- but not the above. */
typedef const int *iptr;
iptr p = 0;
++p;
{ /* AIX XL C 1.02.0.0 rejects this saying
"k.c", line 2.27: 1506-025 (S) Operand must be a modifiable lvalue. */
struct s { int j; const int *ap[3]; };
{ /* ULTRIX-32 V3.1 (Rev 9) vcc rejects this */
const int foo = 10;
/* Get rid of unused variable warning */
if (foo);
return 0;
TEST checkEndian from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:206)
TESTING: checkEndian from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:206)
If the machine is big endian, defines WORDS_BIGENDIAN
Successful compile:
Source:
#ifdef HAVE_SYS_PARAM_H
#include <sys/param.h>
#endif
int main() {
#if !BYTE_ORDER || !BIG_ENDIAN || !LITTLE_ENDIAN
bogus endian macros
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.types/conftest.c:11:3: error: unknown type name ���not���; did you mean ���ino_t���?
not big endian
ino_t
/tmp/petsc-wjcu960y/config.types/conftest.c:11:11: error: expected ���=���, ���,���, ���;���, ���asm��� or ���__attribute__��� before ���endian���
not big endian
Source:
#endif
int main() {
#if BYTE_ORDER != BIG_ENDIAN
not big endian
#endif
return 0;
TEST checkSizeof from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:259)
TESTING: checkSizeof from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:259)
Determines the size of type "typeName", and defines SIZEOF_"typeName" to be the size
Checking for size of type: char
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
FILE *f = fopen("conftestval", "w");
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(char));
return 0;
Testing executable /tmp/petsc-wjcu960y/config.types/conftest to see if it can be run
Executing: /tmp/petsc-wjcu960y/config.types/conftest
Defined "SIZEOF_CHAR" to "1"
Checking for size of type: void *
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(void *));
return 0;
Defined "SIZEOF_VOID_P" to "8"
Checking for size of type: short
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(short));
return 0;
Defined "SIZEOF_SHORT" to "2"
Checking for size of type: int
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(int));
return 0;
Defined "SIZEOF_INT" to "4"
Checking for size of type: long
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long));
return 0;
Defined "SIZEOF_LONG" to "8"
Checking for size of type: long long
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long long));
return 0;
Defined "SIZEOF_LONG_LONG" to "8"
Checking for size of type: float
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(float));
return 0;
Defined "SIZEOF_FLOAT" to "4"
Checking for size of type: double
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(double));
return 0;
Defined "SIZEOF_DOUBLE" to "8"
Checking for size of type: size_t
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(size_t));
return 0;
Defined "SIZEOF_SIZE_T" to "8"
TEST checkBitsPerByte from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:310)
TESTING: checkBitsPerByte from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:310)
Determine the nubmer of bits per byte and define BITS_PER_BYTE
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#endif
int main() {
char val[2];
int i = 0;
if (!f) exit(1);
val[0]='\1';
val[1]='\0';
while(val[0]) {val[0] <<= 1; i++;}
fprintf(f, "%d\n", i);
return 0;
Defined "BITS_PER_BYTE" to "8"
TEST checkVisibility from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:356)
TESTING: checkVisibility from config.types(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/types.py:356)
Successful compile:
Source:
int main() {
__attribute__((visibility ("default"))) int foo(void);;
return 0;
Defined "USE_VISIBILITY_C" to "1"
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.types/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fPIC /tmp/petsc-wjcu960y/config.types/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Defined "USE_VISIBILITY_CXX" to "1"
TEST configureMemAlign from PETSc.options.memAlign(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/memAlign.py:29)
TESTING: configureMemAlign from PETSc.options.memAlign(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/memAlign.py:29)
Choose alignment
Defined "MEMALIGN" to "16"
Memory alignment is 16
TEST check from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:154)
TESTING: check from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:154)
Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
Checking for functions [socket] in library ['socket', 'nsl'] []
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char socket();
static void _check_socket() { socket(); }
int main() {
_check_socket();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.o -lsocket -lnsl -lstdc++ -ldl
Possible ERROR while running linker: exit code 1
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: cannot find -lsocket
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: cannot find -lnsl
collect2: error: ld returned 1 exit status
Checking for functions [handle_sigfpes] in library ['fpe'] []
Successful compile:
Source:
char handle_sigfpes();
static void _check_handle_sigfpes() { handle_sigfpes(); }
int main() {
_check_handle_sigfpes();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.o -lfpe -lstdc++ -ldl
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: cannot find -lfpe
Successful compile:
Source:
char socket();
int main() {
_check_socket();;
return 0;
stderr:
Successful compile:
Source:
int main() {
return 0;
stderr:
TEST checkMath from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:261)
TESTING: checkMath from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:261)
Check for sin() in libm, the math library
Checking for functions [sin floor log10 pow] in library [''] []
Successful compile:
Source:
#include <stdio.h>
double sin(double);
static void _check_sin() { double x,y; scanf("%lf",&x); y = sin(x); printf("%f",y);
#include <stdio.h>
double floor(double);
static void _check_floor() { double x,y; scanf("%lf",&x); y = floor(x); printf("%f",y);
#include <stdio.h>
double log10(double);
static void _check_log10() { double x,y; scanf("%lf",&x); y = log10(x); printf("%f",y);
#include <stdio.h>
double pow(double, double);
static void _check_pow() { double x,y; scanf("%lf",&x); y = pow(x,x); printf("%f",y);
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.o -lstdc++ -ldl
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: undefined reference to symbol 'log10@@GLIBC_2.2.5'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /lib64/libm.so.6: error adding symbols: DSO missing from command line
Checking for functions [sin floor log10 pow] in library ['m'] []
Successful compile:
Source:
#include <stdio.h>
double sin(double);
#include <stdio.h>
#include <stdio.h>
#include <stdio.h>
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.o -lm -lstdc++ -ldl
Defined "HAVE_LIBM" to "1"
CheckMath: using math library ['libm.a']
TEST checkMathErf from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:280)
TESTING: checkMathErf from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:280)
Check for erf() in libm, the math library
Checking for functions [erf] in library ['libm.a'] []
stderr:
/tmp/petsc-wjcu960y/config.libraries/conftest.c: In function ���_check_erf���:
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5:74: warning: variable ���y��� set but not used [-Wunused-but-set-variable]
static void _check_erf() { double (*checkErf)(double) = erf;double x = 0,y; y = (*checkErf)(x); }
Source:
#include <math.h>
int main() {
_check_erf();;
return 0;
erf() found
Defined "HAVE_ERF" to "1"
TEST checkMathTgamma from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:289)
TESTING: checkMathTgamma from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:289)
Check for tgamma() in libm, the math library
Checking for functions [tgamma] in library ['libm.a'] []
stderr:
/tmp/petsc-wjcu960y/config.libraries/conftest.c: In function ���_check_tgamma���:
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5:83: warning: variable ���y��� set but not used [-Wunused-but-set-variable]
static void _check_tgamma() { double (*checkTgamma)(double) = tgamma;double x = 0,y; y = (*checkTgamma)(x); }
Source:
#include <math.h>
int main() {
_check_tgamma();;
return 0;
tgamma() found
Defined "HAVE_TGAMMA" to "1"
TEST checkMathFenv from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:298)
TESTING: checkMathFenv from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:298)
Checks if <fenv.h> can be used with FE_DFL_ENV
Checking for functions [fesetenv] in library ['libm.a'] []
Successful compile:
Source:
#include <fenv.h>
static void _check_fesetenv() { fesetenv(FE_DFL_ENV);; }
int main() {
_check_fesetenv();;
return 0;
Defined "HAVE_FENV_H" to "1"
TEST checkMathLog2 from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:306)
TESTING: checkMathLog2 from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:306)
Check for log2() in libm, the math library
Checking for functions [log2] in library ['libm.a'] []
stderr:
/tmp/petsc-wjcu960y/config.libraries/conftest.c: In function ���_check_log2���:
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5:81: warning: unused variable ���y��� [-Wunused-variable]
static void _check_log2() { double (*checkLog2)(double) = log2; double x = 2.5, y = (*checkLog2)(x); }
Source:
#include <math.h>
int main() {
_check_log2();;
return 0;
log2() found
Defined "HAVE_LOG2" to "1"
TEST checkRealtime from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:315)
TESTING: checkRealtime from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:315)
Check for presence of clock_gettime() in realtime library (POSIX Realtime extensions)
Checking for functions [clock_gettime] in library [''] []
Successful compile:
Source:
#include <time.h>
static void _check_clock_gettime() { struct timespec tp; clock_gettime(CLOCK_REALTIME,&tp);; }
int main() {
_check_clock_gettime();;
return 0;
realtime functions are linked in by default
TEST checkDynamic from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:331)
TESTING: checkDynamic from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:331)
Check for the header and libraries necessary for dynamic library manipulation
Checking for functions [dlopen] in library ['dl'] []
Successful compile:
Source:
char dlopen();
static void _check_dlopen() { dlopen(); }
int main() {
_check_dlopen();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.o -ldl -lstdc++ -ldl
Defined "HAVE_LIBDL" to "1"
Checking for header: dlfcn.h
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.headers /tmp/petsc-wjcu960y/config.headers/conftest.c
Defined "HAVE_DLFCN_H" to "1"
TEST configureLibraryOptions from PETSc.options.libraryOptions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/libraryOptions.py:37)
TESTING: configureLibraryOptions from PETSc.options.libraryOptions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/libraryOptions.py:37)
Sets PETSC_USE_DEBUG, PETSC_USE_INFO, PETSC_USE_LOG, PETSC_USE_CTABLE, PETSC_USE_FORTRAN_KERNELS, and PETSC_USE_AVX512_KERNELS
Defined "USE_LOG" to "1"
Executing: mpicc -qversion
Defined "USE_MALLOC_COALESCED" to "1"
Defined "USE_INFO" to "1"
Defined "USE_CTABLE" to "1"
Defined "USE_BACKWARD_LOOP" to "1"
**********Checking if running on BGL/IBM detected
Checking for functions [bgl_perfctr_void] in library [''] []
Successful compile:
Source:
char bgl_perfctr_void();
static void _check_bgl_perfctr_void() { bgl_perfctr_void(); }
int main() {
_check_bgl_perfctr_void();;
return 0;
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_bgl_perfctr_void':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `bgl_perfctr_void'
Checking for functions [ADIOI_BGL_Open] in library [''] []
Successful compile:
Source:
char ADIOI_BGL_Open();
static void _check_ADIOI_BGL_Open() { ADIOI_BGL_Open(); }
int main() {
_check_ADIOI_BGL_Open();;
return 0;
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_ADIOI_BGL_Open':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `ADIOI_BGL_Open'
*********BGL/IBM test failure
Defined "Alignx(a,b)" to " "
TEST configureISColorValueType from PETSc.options.libraryOptions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/libraryOptions.py:95)
TESTING: configureISColorValueType from PETSc.options.libraryOptions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/libraryOptions.py:95)
Sets PETSC_IS_COLOR_VALUE_TYPE, MPIU_COLORING_VALUE, IS_COLORING_MAX required by ISColor
Defined "MPIU_COLORING_VALUE" to "MPI_UNSIGNED_SHORT"
Defined "IS_COLORING_MAX" to "65535"
Defined "IS_COLOR_VALUE_TYPE" to "short"
Defined "IS_COLOR_VALUE_TYPE_F" to "integer2"
TEST configureCPURelax from config.atomics(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/atomics.py:17)
TESTING: configureCPURelax from config.atomics(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/atomics.py:17)
Definitions for cpu relax assembly instructions
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.atomics
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.atomics/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.atomics -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.atomics/conftest.c
Successful compile:
Source:
int main() {
__asm__ __volatile__("rep; nop" ::: "memory");;
return 0;
Defined "CPU_RELAX()" to "__asm__ __volatile__("rep; nop" ::: "memory")"
TEST configureMemoryBarriers from config.atomics(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/atomics.py:38)
TESTING: configureMemoryBarriers from config.atomics(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/atomics.py:38)
Definitions for memory barrier instructions
Successful compile:
Source:
int main() {
__asm__ __volatile__ ("mfence":::"memory");
return 0;
Defined "MEMORY_BARRIER()" to "__asm__ __volatile__ ("mfence":::"memory")"
Successful compile:
Source:
int main() {
__asm__ __volatile__ ("lfence":::"memory");
return 0;
Defined "READ_MEMORY_BARRIER()" to "__asm__ __volatile__ ("lfence":::"memory")"
Successful compile:
Source:
int main() {
__asm__ __volatile__ ("sfence":::"memory");
return 0;
Defined "WRITE_MEMORY_BARRIER()" to "__asm__ __volatile__ ("sfence":::"memory")"
stderr:
/tmp/petsc-wjcu960y/config.atomics/conftest.c: Assembler messages:
/tmp/petsc-wjcu960y/config.atomics/conftest.c:5: Error: no such instruction: `sync'
Source:
int main() {
__asm__ __volatile__ ("sync":::"memory");
return 0;
stderr:
/tmp/petsc-wjcu960y/config.atomics/conftest.c:5: Error: no such instruction: `lwsync'
Source:
int main() {
__asm__ __volatile__ ("lwsync":::"memory");
return 0;
stderr:
/tmp/petsc-wjcu960y/config.atomics/conftest.c:5: Error: no such instruction: `eieio'
Source:
int main() {
__asm__ __volatile__ ("eieio":::"memory");
return 0;
stderr:
/tmp/petsc-wjcu960y/config.atomics/conftest.c:5: Error: no such instruction: `dmb'
Source:
int main() {
__asm__ __volatile__ ("dmb":::"memory");
return 0;
stderr:
/tmp/petsc-wjcu960y/config.atomics/conftest.c:5: Error: no such instruction: `dmb ish'
Source:
int main() {
__asm__ __volatile__ ("dmb ish":::"memory");
return 0;
stderr:
/tmp/petsc-wjcu960y/config.atomics/conftest.c:5: Error: no such instruction: `dmb ishld'
Source:
int main() {
__asm__ __volatile__ ("dmb ishld":::"memory");
return 0;
stderr:
/tmp/petsc-wjcu960y/config.atomics/conftest.c:5: Error: no such instruction: `dmb ishst'
Source:
int main() {
__asm__ __volatile__ ("dmb ishst":::"memory");
return 0;
TEST checkMemcmp from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:110)
TESTING: checkMemcmp from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:110)
Check for 8-bit clean memcmp
Making executable to test memcmp()
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.functions
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.functions/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.atomics -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.functions/conftest.c
Successful compile:
Source:
#include <string.h>
void exit(int);
int main() {
char c0 = 0x40;
char c1 = (char) 0x80;
char c2 = (char) 0x81;
exit(memcmp(&c0, &c2, 1) < 0 && memcmp(&c1, &c2, 1) < 0 ? 0 : 1);
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.functions/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.functions/conftest.o -lstdc++ -ldl
Testing executable /tmp/petsc-wjcu960y/config.functions/conftest to see if it can be run
Executing: /tmp/petsc-wjcu960y/config.functions/conftest
TEST checkSysinfo from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:135)
TESTING: checkSysinfo from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:135)
Check whether sysinfo takes three arguments, and if it does define HAVE_SYSINFO_3ARG
Checking for functions [sysinfo]
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.functions/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.functions/conftest.c
Successful compile:
Source:
/* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char sysinfo();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_sysinfo) || defined (__stub___sysinfo)
sysinfo_will_always_fail_with_ENOSYS();
#else
sysinfo();
#endif
return 0;
Defined "HAVE_SYSINFO" to "1"
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:13:4: error: #error "Cannot check sysinfo without special headers"
# error "Cannot check sysinfo without special headers"
/tmp/petsc-wjcu960y/config.functions/conftest.c: In function ���main���:
/tmp/petsc-wjcu960y/config.functions/conftest.c:17:30: warning: implicit declaration of function ���sysinfo��� [-Wimplicit-function-declaration]
char buf[10]; long count=10; sysinfo(1, buf, count);
Source:
#ifdef HAVE_LINUX_KERNEL_H
# include <linux/kernel.h>
# include <linux/sys.h>
# ifdef HAVE_SYS_SYSINFO_H
# include <sys/sysinfo.h>
# endif
#elif defined(HAVE_SYS_SYSTEMINFO_H)
# include <sys/systeminfo.h>
#else
#endif
int main() {
return 0;
TEST checkVPrintf from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:158)
TESTING: checkVPrintf from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:158)
Checks whether vprintf requires a char * last argument, and if it does defines HAVE_VPRINTF_CHAR
Checking for functions [vprintf]
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ���vprintf��� [-Wbuiltin-declaration-mismatch]
char vprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vprintf) || defined (__stub___vprintf)
vprintf_will_always_fail_with_ENOSYS();
#else
vprintf();
#endif
return 0;
Defined "HAVE_VPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vprintf( "%d", Argp );
return 0;
TEST checkVFPrintf from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:165)
TESTING: checkVFPrintf from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:165)
Checks whether vfprintf requires a char * last argument, and if it does defines HAVE_VFPRINTF_CHAR
Checking for functions [vfprintf]
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ���vfprintf��� [-Wbuiltin-declaration-mismatch]
char vfprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vfprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vfprintf) || defined (__stub___vfprintf)
vfprintf_will_always_fail_with_ENOSYS();
#else
vfprintf();
#endif
return 0;
Defined "HAVE_VFPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vfprintf(stdout, "%d", Argp );
return 0;
TEST checkVSNPrintf from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:172)
TESTING: checkVSNPrintf from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:172)
Checks whether vsnprintf requires a char * last argument, and if it does defines HAVE_VSNPRINTF_CHAR
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;char str[6];
vsnprintf(str,5, "%d", Argp );
return 0;
Defined "HAVE_VSNPRINTF" to "1"
TEST checkNanosleep from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:202)
TESTING: checkNanosleep from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:202)
Check for functional nanosleep() - as time.h behaves differently for different compiler flags - like -std=c89
Successful compile:
Source:
#include <time.h>
int main() {
struct timespec tp;
tp.tv_sec = 0;
tp.tv_nsec = (long)(1e9);
nanosleep(&tp,0);
return 0;
Defined "HAVE_NANOSLEEP" to "1"
TEST checkMemmove from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:208)
TESTING: checkMemmove from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:208)
Check for functional memmove() - as MS VC requires correct includes to for this test
Successful compile:
Source:
#include <string.h>
int main() {
char c1[1], c2[1] = "c";
size_t n=1;
memmove(c1,c2,n);
return 0;
Defined "HAVE_MEMMOVE" to "1"
TEST checkSignalHandlerType from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:178)
TESTING: checkSignalHandlerType from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:178)
Checks the type of C++ signals handlers, and defines SIGNAL_CAST to the correct value
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.functions/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.functions -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fPIC /tmp/petsc-wjcu960y/config.functions/conftest.cc
Successful compile:
Source:
#include <signal.h>
static void myhandler(int sig) {}
int main() {
signal(SIGFPE,myhandler);
return 0;
Executing: mpicxx -o /tmp/petsc-wjcu960y/config.functions/conftest -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.functions/conftest.o -lstdc++ -ldl
Defined "SIGNAL_CAST" to " "
TEST checkFreeReturnType from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:188)
TESTING: checkFreeReturnType from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:188)
Checks whether free returns void or int, and defines HAVE_FREE_RETURN_INT
Possible ERROR while running compiler: exit code 1
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:6:25: error: void value not ignored as it ought to be
int ierr; void *p; ierr = free(p); return 0;
/tmp/petsc-wjcu960y/config.functions/conftest.c:6:5: warning: variable ���ierr��� set but not used [-Wunused-but-set-variable]
Source:
#include <stdlib.h>
int main() {
return 0;
TEST checkVariableArgumentLists from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:194)
TESTING: checkVariableArgumentLists from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:194)
Checks whether the variable argument list functionality is working
Successful compile:
Source:
#include <stdarg.h>
int main() {
va_list l1, l2;
va_copy(l1, l2);
return 0;
return 0;
Defined "HAVE_VA_COPY" to "1"
TEST checkClassify from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:89)
TESTING: checkClassify from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:89)
Recursive decompose to rapidly classify functions as found or missing
To confirm that a function is missing, we require a compile/link
failure with only that function in a compilation unit. In contrast,
we can confirm that many functions are present by compiling them all
together in a large compilation unit. We optimistically compile
everything together, then trim all functions that were named in the
error message and bisect the result. The trimming is only an
optimization to increase the likelihood of a big-batch compile
succeeding; we do not rely on the compiler naming missing functions.
Checking for functions [uname bzero usleep gettimeofday _sleep gethostbyname snprintf getrusage socket getdomainname _snprintf _getcwd sbreak _access _set_output_format dlclose strcasecmp gethostname sysctlbyname signal sigaction times drand48 mkstemp lseek access PXFGETARG dlopen readlink dlsym _lseek getcwd fork clock stricmp _mkdir realpath popen time rand memalign sigset sleep getwd dlerror getpagesize get_nprocs]
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:14:6: warning: conflicting types for built-in function ���bzero��� [-Wbuiltin-declaration-mismatch]
char bzero();
/tmp/petsc-wjcu960y/config.functions/conftest.c:19:6: warning: conflicting types for built-in function ���snprintf��� [-Wbuiltin-declaration-mismatch]
char snprintf();
/tmp/petsc-wjcu960y/config.functions/conftest.c:29:6: warning: conflicting types for built-in function ���strcasecmp��� [-Wbuiltin-declaration-mismatch]
char strcasecmp();
/tmp/petsc-wjcu960y/config.functions/conftest.c:45:6: warning: conflicting types for built-in function ���fork��� [-Wbuiltin-declaration-mismatch]
char fork();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char uname();
char bzero();
char usleep();
char gettimeofday();
char _sleep();
char gethostbyname();
char snprintf();
char getrusage();
char socket();
char getdomainname();
char _snprintf();
char _getcwd();
char sbreak();
char _access();
char _set_output_format();
char dlclose();
char strcasecmp();
char gethostname();
char sysctlbyname();
char signal();
char sigaction();
char times();
char drand48();
char mkstemp();
char lseek();
char access();
char PXFGETARG();
char dlopen();
char readlink();
char dlsym();
char _lseek();
char getcwd();
char fork();
char clock();
char stricmp();
char _mkdir();
char realpath();
char popen();
char time();
char rand();
char memalign();
char sigset();
char sleep();
char getwd();
char dlerror();
char getpagesize();
char get_nprocs();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_uname) || defined (__stub___uname)
uname_will_always_fail_with_ENOSYS();
#else
uname();
#endif
#if defined (__stub_bzero) || defined (__stub___bzero)
bzero_will_always_fail_with_ENOSYS();
#else
bzero();
#endif
#if defined (__stub_usleep) || defined (__stub___usleep)
usleep_will_always_fail_with_ENOSYS();
#else
usleep();
#endif
#if defined (__stub_gettimeofday) || defined (__stub___gettimeofday)
gettimeofday_will_always_fail_with_ENOSYS();
#else
gettimeofday();
#endif
#if defined (__stub__sleep) || defined (__stub____sleep)
_sleep_will_always_fail_with_ENOSYS();
#else
_sleep();
#endif
#if defined (__stub_gethostbyname) || defined (__stub___gethostbyname)
gethostbyname_will_always_fail_with_ENOSYS();
#else
gethostbyname();
#endif
#if defined (__stub_snprintf) || defined (__stub___snprintf)
snprintf_will_always_fail_with_ENOSYS();
#else
snprintf();
#endif
#if defined (__stub_getrusage) || defined (__stub___getrusage)
getrusage_will_always_fail_with_ENOSYS();
#else
getrusage();
#endif
#if defined (__stub_socket) || defined (__stub___socket)
socket_will_always_fail_with_ENOSYS();
#else
socket();
#endif
#if defined (__stub_getdomainname) || defined (__stub___getdomainname)
getdomainname_will_always_fail_with_ENOSYS();
#else
getdomainname();
#endif
#if defined (__stub__snprintf) || defined (__stub____snprintf)
_snprintf_will_always_fail_with_ENOSYS();
#else
_snprintf();
#endif
#if defined (__stub__getcwd) || defined (__stub____getcwd)
_getcwd_will_always_fail_with_ENOSYS();
#else
_getcwd();
#endif
#if defined (__stub_sbreak) || defined (__stub___sbreak)
sbreak_will_always_fail_with_ENOSYS();
#else
sbreak();
#endif
#if defined (__stub__access) || defined (__stub____access)
_access_will_always_fail_with_ENOSYS();
#else
_access();
#endif
#if defined (__stub__set_output_format) || defined (__stub____set_output_format)
_set_output_format_will_always_fail_with_ENOSYS();
#else
#endif
#if defined (__stub_dlclose) || defined (__stub___dlclose)
dlclose_will_always_fail_with_ENOSYS();
#else
dlclose();
#endif
#if defined (__stub_strcasecmp) || defined (__stub___strcasecmp)
strcasecmp_will_always_fail_with_ENOSYS();
#else
strcasecmp();
#endif
#if defined (__stub_gethostname) || defined (__stub___gethostname)
gethostname_will_always_fail_with_ENOSYS();
#else
gethostname();
#endif
#if defined (__stub_sysctlbyname) || defined (__stub___sysctlbyname)
sysctlbyname_will_always_fail_with_ENOSYS();
#else
sysctlbyname();
#endif
#if defined (__stub_signal) || defined (__stub___signal)
signal_will_always_fail_with_ENOSYS();
#else
signal();
#endif
#if defined (__stub_sigaction) || defined (__stub___sigaction)
sigaction_will_always_fail_with_ENOSYS();
#else
sigaction();
#endif
#if defined (__stub_times) || defined (__stub___times)
times_will_always_fail_with_ENOSYS();
#else
times();
#endif
#if defined (__stub_drand48) || defined (__stub___drand48)
drand48_will_always_fail_with_ENOSYS();
#else
drand48();
#endif
#if defined (__stub_mkstemp) || defined (__stub___mkstemp)
mkstemp_will_always_fail_with_ENOSYS();
#else
mkstemp();
#endif
#if defined (__stub_lseek) || defined (__stub___lseek)
lseek_will_always_fail_with_ENOSYS();
#else
lseek();
#endif
#if defined (__stub_access) || defined (__stub___access)
#else
access();
#endif
#if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
PXFGETARG_will_always_fail_with_ENOSYS();
#else
PXFGETARG();
#endif
#if defined (__stub_dlopen) || defined (__stub___dlopen)
dlopen_will_always_fail_with_ENOSYS();
#else
dlopen();
#endif
#if defined (__stub_readlink) || defined (__stub___readlink)
readlink_will_always_fail_with_ENOSYS();
#else
readlink();
#endif
#if defined (__stub_dlsym) || defined (__stub___dlsym)
dlsym_will_always_fail_with_ENOSYS();
#else
dlsym();
#endif
#if defined (__stub__lseek) || defined (__stub____lseek)
_lseek_will_always_fail_with_ENOSYS();
#else
_lseek();
#endif
#if defined (__stub_getcwd) || defined (__stub___getcwd)
#else
getcwd();
#endif
#if defined (__stub_fork) || defined (__stub___fork)
fork_will_always_fail_with_ENOSYS();
#else
fork();
#endif
#if defined (__stub_clock) || defined (__stub___clock)
clock_will_always_fail_with_ENOSYS();
#else
clock();
#endif
#if defined (__stub_stricmp) || defined (__stub___stricmp)
stricmp_will_always_fail_with_ENOSYS();
#else
stricmp();
#endif
#if defined (__stub__mkdir) || defined (__stub____mkdir)
_mkdir_will_always_fail_with_ENOSYS();
#else
_mkdir();
#endif
#if defined (__stub_realpath) || defined (__stub___realpath)
realpath_will_always_fail_with_ENOSYS();
#else
realpath();
#endif
#if defined (__stub_popen) || defined (__stub___popen)
popen_will_always_fail_with_ENOSYS();
#else
popen();
#endif
#if defined (__stub_time) || defined (__stub___time)
time_will_always_fail_with_ENOSYS();
#else
time();
#endif
#if defined (__stub_rand) || defined (__stub___rand)
rand_will_always_fail_with_ENOSYS();
#else
rand();
#endif
#if defined (__stub_memalign) || defined (__stub___memalign)
memalign_will_always_fail_with_ENOSYS();
#else
memalign();
#endif
#if defined (__stub_sigset) || defined (__stub___sigset)
sigset_will_always_fail_with_ENOSYS();
#else
sigset();
#endif
#if defined (__stub_sleep) || defined (__stub___sleep)
#else
sleep();
#endif
#if defined (__stub_getwd) || defined (__stub___getwd)
getwd_will_always_fail_with_ENOSYS();
#else
getwd();
#endif
#if defined (__stub_dlerror) || defined (__stub___dlerror)
dlerror_will_always_fail_with_ENOSYS();
#else
dlerror();
#endif
#if defined (__stub_getpagesize) || defined (__stub___getpagesize)
getpagesize_will_always_fail_with_ENOSYS();
#else
getpagesize();
#endif
#if defined (__stub_get_nprocs) || defined (__stub___get_nprocs)
get_nprocs_will_always_fail_with_ENOSYS();
#else
get_nprocs();
#endif
return 0;
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.functions/conftest.o: in function `main':
/tmp/petsc-wjcu960y/config.functions/conftest.c:328: warning: the `getwd' function is dangerous and should not be used.
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.functions/conftest.c:94: undefined reference to `_sleep'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.functions/conftest.c:130: undefined reference to `_snprintf'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.functions/conftest.c:136: undefined reference to `_getcwd'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.functions/conftest.c:142: undefined reference to `sbreak'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.functions/conftest.c:148: undefined reference to `_access'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.functions/conftest.c:154: undefined reference to `_set_output_format'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.functions/conftest.c:178: undefined reference to `sysctlbyname'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.functions/conftest.c:226: undefined reference to `PXFGETARG'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.functions/conftest.c:250: undefined reference to `_lseek'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.functions/conftest.c:274: undefined reference to `stricmp'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.functions/conftest.c:280: undefined reference to `_mkdir'
Checking for functions [uname bzero usleep gettimeofday gethostbyname getrusage socket getdomainname dlclose strcasecmp gethostname signal sigaction times drand48]
stderr:
char bzero();
/tmp/petsc-wjcu960y/config.functions/conftest.c:22:6: warning: conflicting types for built-in function ���strcasecmp��� [-Wbuiltin-declaration-mismatch]
char strcasecmp();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char uname();
char bzero();
char usleep();
char getrusage();
char socket();
char dlclose();
char strcasecmp();
char gethostname();
char signal();
char sigaction();
char times();
char drand48();
#ifdef __cplusplus
#endif
int main() {
#else
uname();
#endif
#else
bzero();
#endif
#else
usleep();
#endif
#else
gettimeofday();
#endif
#else
gethostbyname();
#endif
#else
getrusage();
#endif
#else
socket();
#endif
#else
getdomainname();
#endif
#else
dlclose();
#endif
#else
strcasecmp();
#endif
#else
gethostname();
#endif
#else
signal();
#endif
#else
sigaction();
#endif
#else
times();
#endif
#else
drand48();
#endif
return 0;
Defined "HAVE_UNAME" to "1"
Defined "HAVE_BZERO" to "1"
Defined "HAVE_USLEEP" to "1"
Defined "HAVE_GETTIMEOFDAY" to "1"
Defined "HAVE_GETHOSTBYNAME" to "1"
Defined "HAVE_GETRUSAGE" to "1"
Defined "HAVE_SOCKET" to "1"
Defined "HAVE_GETDOMAINNAME" to "1"
Defined "HAVE_DLCLOSE" to "1"
Defined "HAVE_STRCASECMP" to "1"
Defined "HAVE_GETHOSTNAME" to "1"
Defined "HAVE_SIGNAL" to "1"
Defined "HAVE_SIGACTION" to "1"
Defined "HAVE_TIMES" to "1"
Defined "HAVE_DRAND48" to "1"
Checking for functions [mkstemp dlopen readlink dlsym fork clock realpath popen time rand memalign sigset dlerror getpagesize get_nprocs]
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:17:6: warning: conflicting types for built-in function ���fork��� [-Wbuiltin-declaration-mismatch]
char fork();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char mkstemp();
char dlopen();
char readlink();
char dlsym();
char fork();
char clock();
char realpath();
char popen();
char time();
char rand();
char memalign();
char sigset();
char dlerror();
char getpagesize();
char get_nprocs();
#ifdef __cplusplus
#endif
int main() {
#else
mkstemp();
#endif
#else
dlopen();
#endif
#else
readlink();
#endif
#else
dlsym();
#endif
#else
fork();
#endif
#else
clock();
#endif
#else
realpath();
#endif
#else
popen();
#endif
#else
time();
#endif
#else
rand();
#endif
#else
memalign();
#endif
#else
sigset();
#endif
#else
dlerror();
#endif
#else
getpagesize();
#endif
#else
get_nprocs();
#endif
return 0;
Defined "HAVE_MKSTEMP" to "1"
Defined "HAVE_DLOPEN" to "1"
Defined "HAVE_READLINK" to "1"
Defined "HAVE_DLSYM" to "1"
Defined "HAVE_FORK" to "1"
Defined "HAVE_CLOCK" to "1"
Defined "HAVE_REALPATH" to "1"
Defined "HAVE_POPEN" to "1"
Defined "HAVE_TIME" to "1"
Defined "HAVE_RAND" to "1"
Defined "HAVE_MEMALIGN" to "1"
Defined "HAVE_SIGSET" to "1"
Defined "HAVE_DLERROR" to "1"
Defined "HAVE_GETPAGESIZE" to "1"
Defined "HAVE_GET_NPROCS" to "1"
Checking for functions [_sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _sleep();
#ifdef __cplusplus
#endif
int main() {
#else
_sleep();
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `_sleep'
Checking for functions [snprintf]
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ���snprintf��� [-Wbuiltin-declaration-mismatch]
char snprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
snprintf();
#endif
return 0;
Defined "HAVE_SNPRINTF" to "1"
Checking for functions [_snprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
_snprintf();
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `_snprintf'
Checking for functions [_getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
_getcwd();
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `_getcwd'
Checking for functions [sbreak]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sbreak();
#ifdef __cplusplus
#endif
int main() {
#else
sbreak();
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `sbreak'
Checking for functions [_access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
_access();
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `_access'
Checking for functions [_set_output_format]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `_set_output_format'
Checking for functions [sysctlbyname]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
sysctlbyname();
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `sysctlbyname'
Checking for functions [lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
#ifdef __cplusplus
#endif
int main() {
#else
lseek();
#endif
return 0;
Defined "HAVE_LSEEK" to "1"
Checking for functions [access]
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char access();
#ifdef __cplusplus
#endif
int main() {
#else
access();
#endif
return 0;
Defined "HAVE_ACCESS" to "1"
Checking for functions [PXFGETARG]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `PXFGETARG'
Checking for functions [_lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _lseek();
#ifdef __cplusplus
#endif
int main() {
#else
_lseek();
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `_lseek'
Checking for functions [getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
getcwd();
#endif
return 0;
Defined "HAVE_GETCWD" to "1"
Checking for functions [stricmp]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#else
stricmp();
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `stricmp'
Checking for functions [_mkdir]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _mkdir();
#ifdef __cplusplus
#endif
int main() {
#else
_mkdir();
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `_mkdir'
Checking for functions [sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sleep();
#ifdef __cplusplus
#endif
int main() {
#else
sleep();
#endif
return 0;
Defined "HAVE_SLEEP" to "1"
Checking for functions [getwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getwd();
#ifdef __cplusplus
#endif
int main() {
#else
getwd();
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: warning: the `getwd' function is dangerous and should not be used.
Defined "HAVE_GETWD" to "1"
TEST checkMmap from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:214)
TESTING: checkMmap from config.functions(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/functions.py:214)
Check for functional mmap() to allocate shared memory and define HAVE_MMAP
Successful compile:
Source:
#include <sys/mman.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
int main() {
int fd;
fd=open("/tmp/file",O_RDWR);
mmap((void*)0,100,PROT_READ|PROT_WRITE,MAP_SHARED,fd,0);
return 0;
Defined "HAVE_MMAP" to "1"
TEST configureMemorySize from config.utilities.getResidentSetSize(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/getResidentSetSize.py:31)
TESTING: configureMemorySize from config.utilities.getResidentSetSize(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/getResidentSetSize.py:31)
Try to determine how to measure the memory usage
Defined "USE_PROC_FOR_SIZE" to "1"
Using /proc for PetscMemoryGetCurrentUsage()
TEST configureFortranCommandLine from config.utilities.fortranCommandLine(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/fortranCommandLine.py:26)
TESTING: configureFortranCommandLine from config.utilities.fortranCommandLine(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/fortranCommandLine.py:26)
Check for the mechanism to retrieve command line arguments in Fortran
Defined "HAVE_FORTRAN_GET_COMMAND_ARGUMENT" to "1"
Checking for functions [] in library [''] []
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.F90
Successful compile:
Source:
program main
integer i
character*(80) arg
i = command_argument_count()
call get_command_argument(i,arg)
end
Executing: mpif90 -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.o -lstdc++ -ldl
Defined "HAVE_GFORTRAN_IARGC" to "1"
Checking for functions [get_command_argument_] in library [''] ['-lstdc++', '-ldl', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lmpifort', '-lmpi', '-lrt', '-lpthread', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7', '-L/usr/lib64/gcc/x86_64-suse-linux/7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-Wl,-rpath,/usr/x86_64-suse-linux/lib', '-L/usr/x86_64-suse-linux/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath']
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.c
Successful compile:
Source:
char get_command_argument_();
static void _check_get_command_argument_() { get_command_argument_(); }
int main() {
_check_get_command_argument_();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.o -lstdc++ -ldl -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7 -L/usr/lib64/gcc/x86_64-suse-linux/7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_get_command_argument_':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `get_command_argument_'
Checking for functions [getarg_] in library [''] ['-lstdc++', '-ldl', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lmpifort', '-lmpi', '-lrt', '-lpthread', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7', '-L/usr/lib64/gcc/x86_64-suse-linux/7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-Wl,-rpath,/usr/x86_64-suse-linux/lib', '-L/usr/x86_64-suse-linux/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath']
Successful compile:
Source:
char getarg_();
static void _check_getarg_() { getarg_(); }
int main() {
_check_getarg_();;
return 0;
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_getarg_':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `getarg_'
Checking for functions [ipxfargc_]
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.functions/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.functions/conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char ipxfargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_ipxfargc_) || defined (__stub___ipxfargc_)
ipxfargc__will_always_fail_with_ENOSYS();
#else
ipxfargc_();
#endif
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.functions/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.functions/conftest.o -lstdc++ -ldl -lstdc++ -ldl -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7 -L/usr/lib64/gcc/x86_64-suse-linux/7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lgfortran -lm -lgcc_s -lquadmath
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `ipxfargc_'
Checking for functions [f90_unix_MP_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char f90_unix_MP_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_f90_unix_MP_iargc) || defined (__stub___f90_unix_MP_iargc)
f90_unix_MP_iargc_will_always_fail_with_ENOSYS();
#else
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `f90_unix_MP_iargc'
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
return 0;
stderr:
Checking for functions [iargc_]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char iargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_iargc_) || defined (__stub___iargc_)
iargc__will_always_fail_with_ENOSYS();
#else
iargc_();
#endif
return 0;
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:24: undefined reference to `iargc_'
Checking for functions [GETARG at 16]
stderr:
/tmp/petsc-wjcu960y/config.functions/conftest.c:13:12: error: stray ���@��� in program
char GETARG at 16();
/tmp/petsc-wjcu960y/config.functions/conftest.c:13:13: error: expected ���=���, ���,���, ���;���, ���asm��� or ���__attribute__��� before numeric constant
/tmp/petsc-wjcu960y/config.functions/conftest.c:21:27: error: missing ')' after "defined"
#if defined (__stub_GETARG at 16) || defined (__stub___GETARG at 16)
/tmp/petsc-wjcu960y/config.functions/conftest.c:21:28: error: missing binary operator before token "16"
/tmp/petsc-wjcu960y/config.functions/conftest.c:24:7: error: stray ���@��� in program
GETARG at 16();
/tmp/petsc-wjcu960y/config.functions/conftest.c:24:1: error: ���GETARG��� undeclared (first use in this function)
GETARG at 16();
/tmp/petsc-wjcu960y/config.functions/conftest.c:24:1: note: each undeclared identifier is reported only once for each function it appears in
/tmp/petsc-wjcu960y/config.functions/conftest.c:24:8: error: expected ���;��� before numeric constant
GETARG at 16();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
GETARG at 16_will_always_fail_with_ENOSYS();
#else
GETARG at 16();
#endif
return 0;
Compile failed inside link
Checking for functions [_gfortran_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _gfortran_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub__gfortran_iargc) || defined (__stub____gfortran_iargc)
_gfortran_iargc_will_always_fail_with_ENOSYS();
#else
_gfortran_iargc();
#endif
return 0;
Defined "HAVE__GFORTRAN_IARGC" to "1"
TEST configureFeatureTestMacros from config.utilities.featureTestMacros(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/featureTestMacros.py:13)
TESTING: configureFeatureTestMacros from config.utilities.featureTestMacros(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/featureTestMacros.py:13)
Checks if certain feature test macros are support
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.utilities.featureTestMacros
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.utilities.featureTestMacros/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.utilities.featureTestMacros/conftest.c
stderr:
/tmp/petsc-wjcu960y/config.utilities.featureTestMacros/conftest.c:4:10: fatal error: sysctl.h: No such file or directory
#include <sysctl.h>
compilation terminated.
Source:
#define _POSIX_C_SOURCE 200112L
#include <sysctl.h>
int main() {
return 0;
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.utilities.featureTestMacros/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.utilities.featureTestMacros/conftest.c
stderr:
In file included from /usr/include/bits/libc-header-start.h:33:0,
from /usr/include/stdlib.h:25,
from /tmp/petsc-wjcu960y/config.utilities.featureTestMacros/conftest.c:4:
/usr/include/features.h:183:3: warning: #warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE" [-Wcpp]
# warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE"
Source:
#define _BSD_SOURCE
#include<stdlib.h>
int main() {
return 0;
Defined "_BSD_SOURCE" to "1"
Successful compile:
Source:
#define _DEFAULT_SOURCE
#include<stdlib.h>
int main() {
return 0;
Defined "_DEFAULT_SOURCE" to "1"
Successful compile:
Source:
#define _GNU_SOURCE
#include <sched.h>
int main() {
cpu_set_t mset;
CPU_ZERO(&mset);;
return 0;
Defined "_GNU_SOURCE" to "1"
TEST configureMissingDefines from config.utilities.missing(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/missing.py:56)
TESTING: configureMissingDefines from config.utilities.missing(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/missing.py:56)
Checks for limits
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.utilities.missing
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.utilities.missing/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.utilities.missing/conftest.c
Successful compile:
Source:
#ifdef PETSC_HAVE_LIMITS_H
#include <limits.h>
#endif
int main() {
int i=INT_MAX;
if (i);
return 0;
Successful compile:
Source:
#ifdef PETSC_HAVE_FLOAT_H
#include <float.h>
#endif
int main() {
double d=DBL_MAX;
if (d);
return 0;
TEST configureMissingUtypeTypedefs from config.utilities.missing(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/missing.py:66)
TESTING: configureMissingUtypeTypedefs from config.utilities.missing(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/missing.py:66)
Checks if u_short is undefined
stderr:
/tmp/petsc-wjcu960y/config.utilities.missing/conftest.c: In function ���main���:
/tmp/petsc-wjcu960y/config.utilities.missing/conftest.c:6:9: warning: unused variable ���foo��� [-Wunused-variable]
u_short foo;
Source:
int main() {
u_short foo;
return 0;
TEST configureMissingFunctions from config.utilities.missing(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/missing.py:72)
TESTING: configureMissingFunctions from config.utilities.missing(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/missing.py:72)
Checks for SOCKETS
TEST configureMissingSignals from config.utilities.missing(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/missing.py:92)
TESTING: configureMissingSignals from config.utilities.missing(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/missing.py:92)
Check for missing signals, and define MISSING_<signal name> if necessary
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGABRT;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGALRM;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGBUS;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCHLD;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCONT;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGFPE;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGHUP;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGILL;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGINT;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGKILL;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGPIPE;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGQUIT;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSEGV;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSTOP;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSYS;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTERM;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTRAP;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTSTP;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGURG;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR1;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR2;
if (i);
return 0;
TEST configureMissingGetdomainnamePrototype from config.utilities.missing(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/missing.py:109)
TESTING: configureMissingGetdomainnamePrototype from config.utilities.missing(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/missing.py:109)
Successful compile:
Source:
#if !defined(_BSD_SOURCE)
#define _BSD_SOURCE
#endif
#if !defined(_DEFAULT_SOURCE)
#endif
#if !defined(_GNU_SOURCE)
#define _GNU_SOURCE
#endif
#ifdef PETSC_HAVE_UNISTD_H
#include <unistd.h>
#endif
#ifdef PETSC_HAVE_NETDB_H
#include <netdb.h>
#endif
int main() {
int (*getdomainname_ptr)(char*,size_t) = getdomainname;
char test[10];
if (getdomainname_ptr(test,10)) return 1;
return 0;
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.utilities.missing/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.missing -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fPIC /tmp/petsc-wjcu960y/config.utilities.missing/conftest.cc
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
char test[10];
return 0;
Executing: mpicxx -o /tmp/petsc-wjcu960y/config.utilities.missing/conftest -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.utilities.missing/conftest.o -lstdc++ -ldl
TEST configureMissingSrandPrototype from config.utilities.missing(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/missing.py:134)
TESTING: configureMissingSrandPrototype from config.utilities.missing(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/missing.py:134)
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#ifdef PETSC_HAVE_STDLIB_H
#include <stdlib.h>
#endif
int main() {
double (*drand48_ptr)(void) = drand48;
void (*srand48_ptr)(long int) = srand48;
long int seed=10;
srand48_ptr(seed);
if (drand48_ptr() > 0.5) return 1;
return 0;
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#include <stdlib.h>
#endif
int main() {
long int seed=10;
srand48_ptr(seed);
return 0;
TEST configureFPTrap from config.utilities.FPTrap(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/FPTrap.py:27)
TESTING: configureFPTrap from config.utilities.FPTrap(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/utilities/FPTrap.py:27)
Checking the handling of floating point traps
Checking for header: sigfpe.h
Possible ERROR while running preprocessor: exit code 1
stdout:
# 1 "/tmp/petsc-wjcu960y/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "<command-line>" 2
# 1 "/tmp/petsc-wjcu960y/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-wjcu960y/config.headers/conftest.c" 2
# 1 "/tmp/petsc-wjcu960y/config.headers/conffix.h" 1
# 3 "/tmp/petsc-wjcu960y/config.headers/conftest.c" 2
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: sigfpe.h: No such file or directory
#include <sigfpe.h>
Source:
#include <sigfpe.h>
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: sigfpe.h: No such file or directory
#include <sigfpe.h>
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: sigfpe.h: No such file or directory #include <sigfpe.h> ^~~~~~~~~~compilation terminated.:
Checking for header: fpxcp.h
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.headers /tmp/petsc-wjcu960y/config.headers/conftest.c
stdout:
# 1 "<built-in>"
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: fpxcp.h: No such file or directory
#include <fpxcp.h>
Source:
#include <fpxcp.h>
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: fpxcp.h: No such file or directory
#include <fpxcp.h>
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: fpxcp.h: No such file or directory #include <fpxcp.h> ^~~~~~~~~compilation terminated.:
Checking for header: floatingpoint.h
stdout:
# 1 "<built-in>"
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: floatingpoint.h: No such file or directory
#include <floatingpoint.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: floatingpoint.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: floatingpoint.h: No such file or directory #include <floatingpoint.h> ^~~~~~~~~~~~~~~~~compilation terminated.:
TEST configureScalarType from PETSc.options.scalarTypes(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/scalarTypes.py:36)
TESTING: configureScalarType from PETSc.options.scalarTypes(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/scalarTypes.py:36)
Choose between real and complex numbers
Defined "USE_SCALAR_REAL" to "1"
Scalar type is real
All intermediate test results are stored in /tmp/petsc-wjcu960y/PETSc.options.scalarTypes
Executing: mpicc -c -o /tmp/petsc-wjcu960y/PETSc.options.scalarTypes/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/PETSc.options.scalarTypes/conftest.c
stderr:
/tmp/petsc-wjcu960y/PETSc.options.scalarTypes/conftest.c: In function ���main���:
/tmp/petsc-wjcu960y/PETSc.options.scalarTypes/conftest.c:6:21: warning: unused variable ���a��� [-Wunused-variable]
double b = 2.0; int a = isnormal(b);
Source:
#include <math.h>
int main() {
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/PETSc.options.scalarTypes/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/PETSc.options.scalarTypes/conftest.o -lstdc++ -ldl
Defined "HAVE_ISNORMAL" to "1"
stderr:
double b = 2.0; int a = isnan(b);
Source:
#include <math.h>
int main() {
return 0;
Defined "HAVE_ISNAN" to "1"
stderr:
double b = 2.0; int a = isinf(b);
Source:
#include <math.h>
int main() {
return 0;
Defined "HAVE_ISINF" to "1"
stderr:
/tmp/petsc-wjcu960y/PETSc.options.scalarTypes/conftest.c:6:24: warning: implicit declaration of function ���_isnan��� [-Wimplicit-function-declaration]
double b = 2.0;int a = _isnan(b);
/tmp/petsc-wjcu960y/PETSc.options.scalarTypes/conftest.c:6:20: warning: unused variable ���a��� [-Wunused-variable]
Source:
#include <float.h>
int main() {
return 0;
Possible ERROR while running linker: exit code 1
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/PETSc.options.scalarTypes/conftest.o: in function `main':
/tmp/petsc-wjcu960y/PETSc.options.scalarTypes/conftest.c:6: undefined reference to `_isnan'
collect2: error: ld returned 1 exit status
stderr:
/tmp/petsc-wjcu960y/PETSc.options.scalarTypes/conftest.c:6:24: warning: implicit declaration of function ���_finite��� [-Wimplicit-function-declaration]
double b = 2.0;int a = _finite(b);
Source:
#include <float.h>
int main() {
return 0;
stderr:
/tmp/petsc-wjcu960y/PETSc.options.scalarTypes/conftest.c:6: undefined reference to `_finite'
TEST configurePrecision from PETSc.options.scalarTypes(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/scalarTypes.py:78)
TESTING: configurePrecision from PETSc.options.scalarTypes(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/PETSc/options/scalarTypes.py:78)
Set the default real number precision for PETSc objects
Defined "USE_REAL_DOUBLE" to "1"
Defined make macro "PETSC_SCALAR_SIZE" to "64"
Precision is double
TEST configureMkdir from config.programs(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/programs.py:22)
TESTING: configureMkdir from config.programs(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/programs.py:22)
Make sure we can have mkdir automatically make intermediate directories
Checking for program /home/wangzl/miniconda3/bin/mkdir...not found
Checking for program /home/wangzl/projects/moose/python/peacock/mkdir...not found
Checking for program /home/wangzl/software/fftwmpi/bin/mkdir...not found
Checking for program /home/wangzl/software/byacc/bin/mkdir...not found
Checking for program /home/wangzl/software/m4/bin/mkdir...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/mkdir...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/mkdir...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/mkdir...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/mkdir...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/mkdir...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mkdir...not found
Checking for program /home/wangzl/bin/mkdir...not found
Checking for program /usr/local/bin/mkdir...not found
Checking for program /usr/bin/mkdir...found
Executing: /usr/bin/mkdir -p .conftest/tmp
Adding -p flag to /usr/bin/mkdir -p to automatically create directories
Defined make macro "MKDIR" to "/usr/bin/mkdir -p"
TEST configureAutoreconf from config.programs(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/programs.py:44)
TESTING: configureAutoreconf from config.programs(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/programs.py:44)
Check for autoreconf
Checking for program /home/wangzl/miniconda3/bin/autoreconf...not found
Checking for program /home/wangzl/projects/moose/python/peacock/autoreconf...not found
Checking for program /home/wangzl/software/fftwmpi/bin/autoreconf...not found
Checking for program /home/wangzl/software/byacc/bin/autoreconf...not found
Checking for program /home/wangzl/software/m4/bin/autoreconf...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/autoreconf...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/autoreconf...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/autoreconf...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/autoreconf...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/autoreconf...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/autoreconf...not found
Checking for program /home/wangzl/bin/autoreconf...not found
Checking for program /usr/local/bin/autoreconf...not found
Checking for program /usr/bin/autoreconf...found
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.programs
Executing: ['/usr/bin/autoreconf']
autoreconf test successful!
Checking for program /home/wangzl/miniconda3/bin/libtoolize...not found
Checking for program /home/wangzl/projects/moose/python/peacock/libtoolize...not found
Checking for program /home/wangzl/software/fftwmpi/bin/libtoolize...not found
Checking for program /home/wangzl/software/byacc/bin/libtoolize...not found
Checking for program /home/wangzl/software/m4/bin/libtoolize...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/libtoolize...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/libtoolize...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/libtoolize...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/libtoolize...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/libtoolize...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/libtoolize...not found
Checking for program /home/wangzl/bin/libtoolize...not found
Checking for program /usr/local/bin/libtoolize...not found
Checking for program /usr/bin/libtoolize...found
TEST configurePrograms from config.programs(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/programs.py:71)
TESTING: configurePrograms from config.programs(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/programs.py:71)
Check for the programs needed to build and run PETSc
Checking for program /home/wangzl/miniconda3/bin/sh...not found
Checking for program /home/wangzl/projects/moose/python/peacock/sh...not found
Checking for program /home/wangzl/software/fftwmpi/bin/sh...not found
Checking for program /home/wangzl/software/byacc/bin/sh...not found
Checking for program /home/wangzl/software/m4/bin/sh...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/sh...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/sh...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/sh...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/sh...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/sh...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/sh...not found
Checking for program /home/wangzl/bin/sh...not found
Checking for program /usr/local/bin/sh...not found
Checking for program /usr/bin/sh...found
Defined make macro "SHELL" to "/usr/bin/sh"
Checking for program /home/wangzl/miniconda3/bin/sed...not found
Checking for program /home/wangzl/projects/moose/python/peacock/sed...not found
Checking for program /home/wangzl/software/fftwmpi/bin/sed...not found
Checking for program /home/wangzl/software/byacc/bin/sed...not found
Checking for program /home/wangzl/software/m4/bin/sed...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/sed...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/sed...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/sed...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/sed...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/sed...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/sed...not found
Checking for program /home/wangzl/bin/sed...not found
Checking for program /usr/local/bin/sed...not found
Checking for program /usr/bin/sed...found
Defined make macro "SED" to "/usr/bin/sed"
Executing: /usr/bin/sed -i s/sed/sd/g "/tmp/petsc-wjcu960y/config.programs/sed1"
Adding SEDINPLACE cmd: /usr/bin/sed -i
Defined make macro "SEDINPLACE" to "/usr/bin/sed -i"
Checking for program /home/wangzl/miniconda3/bin/mv...not found
Checking for program /home/wangzl/projects/moose/python/peacock/mv...not found
Checking for program /home/wangzl/software/fftwmpi/bin/mv...not found
Checking for program /home/wangzl/software/byacc/bin/mv...not found
Checking for program /home/wangzl/software/m4/bin/mv...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/mv...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/mv...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/mv...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/mv...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/mv...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mv...not found
Checking for program /home/wangzl/bin/mv...not found
Checking for program /usr/local/bin/mv...not found
Checking for program /usr/bin/mv...found
Defined make macro "MV" to "/usr/bin/mv"
Checking for program /home/wangzl/miniconda3/bin/cp...not found
Checking for program /home/wangzl/projects/moose/python/peacock/cp...not found
Checking for program /home/wangzl/software/fftwmpi/bin/cp...not found
Checking for program /home/wangzl/software/byacc/bin/cp...not found
Checking for program /home/wangzl/software/m4/bin/cp...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/cp...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/cp...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/cp...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/cp...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/cp...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/cp...not found
Checking for program /home/wangzl/bin/cp...not found
Checking for program /usr/local/bin/cp...not found
Checking for program /usr/bin/cp...found
Defined make macro "CP" to "/usr/bin/cp"
Checking for program /home/wangzl/miniconda3/bin/grep...not found
Checking for program /home/wangzl/projects/moose/python/peacock/grep...not found
Checking for program /home/wangzl/software/fftwmpi/bin/grep...not found
Checking for program /home/wangzl/software/byacc/bin/grep...not found
Checking for program /home/wangzl/software/m4/bin/grep...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/grep...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/grep...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/grep...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/grep...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/grep...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/grep...not found
Checking for program /home/wangzl/bin/grep...not found
Checking for program /usr/local/bin/grep...not found
Checking for program /usr/bin/grep...found
Defined make macro "GREP" to "/usr/bin/grep"
Checking for program /home/wangzl/miniconda3/bin/rm...not found
Checking for program /home/wangzl/projects/moose/python/peacock/rm...not found
Checking for program /home/wangzl/software/fftwmpi/bin/rm...not found
Checking for program /home/wangzl/software/byacc/bin/rm...not found
Checking for program /home/wangzl/software/m4/bin/rm...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/rm...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/rm...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/rm...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/rm...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/rm...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/rm...not found
Checking for program /home/wangzl/bin/rm...not found
Checking for program /usr/local/bin/rm...not found
Checking for program /usr/bin/rm...found
Defined make macro "RM" to "/usr/bin/rm -f"
Checking for program /home/wangzl/miniconda3/bin/diff...not found
Checking for program /home/wangzl/projects/moose/python/peacock/diff...not found
Checking for program /home/wangzl/software/fftwmpi/bin/diff...not found
Checking for program /home/wangzl/software/byacc/bin/diff...not found
Checking for program /home/wangzl/software/m4/bin/diff...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/diff...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/diff...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/diff...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/diff...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/diff...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/diff...not found
Checking for program /home/wangzl/bin/diff...not found
Checking for program /usr/local/bin/diff...not found
Checking for program /usr/bin/diff...found
Executing: "/usr/bin/diff" -w "/tmp/petsc-wjcu960y/config.programs/diff1" "/tmp/petsc-wjcu960y/config.programs/diff2"
Defined make macro "DIFF" to "/usr/bin/diff -w"
Checking for program /usr/ucb/ps...not found
Checking for program /usr/usb/ps...not found
Checking for program /tmp/stack_temp.rFVgkc/petsc-3.11.4/lib/petsc/bin/win32fe/ps...not found
Checking for program /home/wangzl/miniconda3/bin/gzip...not found
Checking for program /home/wangzl/projects/moose/python/peacock/gzip...not found
Checking for program /home/wangzl/software/fftwmpi/bin/gzip...not found
Checking for program /home/wangzl/software/byacc/bin/gzip...not found
Checking for program /home/wangzl/software/m4/bin/gzip...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/gzip...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/gzip...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/gzip...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/gzip...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/gzip...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/gzip...not found
Checking for program /home/wangzl/bin/gzip...not found
Checking for program /usr/local/bin/gzip...not found
Checking for program /usr/bin/gzip...found
Defined make macro "GZIP" to "/usr/bin/gzip"
Defined "HAVE_GZIP" to "1"
Defined make macro "PYTHON" to "/home/wangzl/miniconda3/bin/python"
Checking for program /home/wangzl/miniconda3/bin/m4...not found
Checking for program /home/wangzl/projects/moose/python/peacock/m4...not found
Checking for program /home/wangzl/software/fftwmpi/bin/m4...not found
Checking for program /home/wangzl/software/byacc/bin/m4...not found
Checking for program /home/wangzl/software/m4/bin/m4...found
Defined make macro "M4" to "/home/wangzl/software/m4/bin/m4"
TEST configureMake from config.packages.make(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/make.py:85)
TESTING: configureMake from config.packages.make(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/make.py:85)
Check Guesses for GNU make
Executing: gmake --version
stdout:
GNU Make 4.2.1
Built for x86_64-suse-linux-gnu
Copyright (C) 1988-2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Checking for program /home/wangzl/miniconda3/bin/gmake...not found
Checking for program /home/wangzl/projects/moose/python/peacock/gmake...not found
Checking for program /home/wangzl/software/fftwmpi/bin/gmake...not found
Checking for program /home/wangzl/software/byacc/bin/gmake...not found
Checking for program /home/wangzl/software/m4/bin/gmake...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/gmake...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/gmake...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/gmake...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/gmake...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/gmake...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/gmake...not found
Checking for program /home/wangzl/bin/gmake...not found
Checking for program /usr/local/bin/gmake...not found
Checking for program /usr/bin/gmake...found
Defined make macro "MAKE" to "/usr/bin/gmake"
TEST setupGNUMake from config.packages.make(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/make.py:113)
TESTING: setupGNUMake from config.packages.make(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/make.py:113)
Setup other GNU make stuff
Executing: uname -s
stdout: Linux
Executing: uname -s
stdout: Linux
Defined make macro "MAKE_IS_GNUMAKE" to "1"
Defined make rule "libc" with dependencies "${LIBNAME}(${OBJSC})" and code []
Defined make rule "libcxx" with dependencies "${LIBNAME}(${OBJSCXX})" and code []
Defined make rule "libcu" with dependencies "${LIBNAME}(${OBJSCU})" and code []
Defined make rule "libf" with dependencies "${OBJSF}" and code -${AR} ${AR_FLAGS} ${LIBNAME} ${OBJSF}
Defined make macro "OMAKE_PRINTDIR " to "/usr/bin/gmake --print-directory"
Defined make macro "OMAKE" to "/usr/bin/gmake --no-print-directory"
Defined make macro "MAKE_PAR_OUT_FLG" to "--output-sync=recurse"
TEST configureMakeNP from config.packages.make(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/make.py:161)
TESTING: configureMakeNP from config.packages.make(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/make.py:161)
check no of cores on the build machine [perhaps to do make '-j ncores']
module multiprocessing found 20 cores: using make_np = 16
Defined make macro "MAKE_NP" to "16"
Defined make macro "MAKE_TEST_NP" to "10"
Defined make macro "MAKE_LOAD" to "30.0"
Defined make macro "NPMAX" to "20"
TEST alternateConfigureLibrary from config.packages.OpenMPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.OpenMPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
Called if --with-packagename=0; does nothing by default
Executing: uname -s
stdout: Linux
Executing: uname -s
stdout: Linux
TEST alternateConfigureLibrary from config.packages.MPICH(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.MPICH(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST checkDependencies from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TESTING: checkDependencies from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TEST configureLibrary from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:523)
TESTING: configureLibrary from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:523)
Calls the regular package configureLibrary and then does an additional test needed by MPI
Checking for a functional MPI
Checking for library in Compiler specific search MPI: []
TEST check from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:154)
TESTING: check from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:154)
Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
Checking for functions [MPI_Init MPI_Comm_create] in library [] []
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char MPI_Init();
static void _check_MPI_Init() { MPI_Init(); }
char MPI_Comm_create();
static void _check_MPI_Comm_create() { MPI_Comm_create(); }
int main() {
_check_MPI_Init();
_check_MPI_Comm_create();;
return 0;
No functions to check for in library [] []
Checking for headers Compiler specific search MPI: ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
TEST checkInclude from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:86)
Checks if a particular include file can be found along particular include paths
Checking for header files ['mpi.h'] in ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Checking include with compiler flags var CPPFLAGS ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.headers -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0 -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include /tmp/petsc-wjcu960y/config.headers/conftest.c
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Found header files ['mpi.h'] in ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
TEST configureConversion from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:251)
TESTING: configureConversion from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:251)
Check for the functions which convert communicators between C and Fortran
- Define HAVE_MPI_COMM_F2C and HAVE_MPI_COMM_C2F if they are present
- Some older MPI 1 implementations are missing these
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.packages.MPI
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.packages.MPI/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.packages.MPI/conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Comm_f2c((MPI_Fint)0));
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.packages.MPI/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.packages.MPI/conftest.o -lstdc++ -ldl
Defined "HAVE_MPI_COMM_F2C" to "1"
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.packages.MPI/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.packages.MPI -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.packages.MPI/conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Comm_c2f(MPI_COMM_WORLD));
return 0;
Defined "HAVE_MPI_COMM_C2F" to "1"
Possible ERROR while running compiler:
stderr:
/tmp/petsc-wjcu960y/config.packages.MPI/conftest.c: In function ���main���:
/tmp/petsc-wjcu960y/config.packages.MPI/conftest.c:6:10: warning: unused variable ���a��� [-Wunused-variable]
MPI_Fint a;
Source:
#include <mpi.h>
int main() {
MPI_Fint a;
return 0;
Defined "HAVE_MPI_FINT" to "1"
TEST checkMPICHorOpenMPI from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:460)
TESTING: checkMPICHorOpenMPI from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:460)
Determine if MPICH_NUMVERSION or OMPI_MAJOR_VERSION exist in mpi.h
Used for consistency checking of MPI installation at compile time
stderr:
In file included from /tmp/petsc-wjcu960y/config.packages.MPI/conftest.c:3:0:
/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/mpi.h:595:26: warning: overflow in implicit constant conversion [-Woverflow]
#define I_MPI_NUMVERSION 20190005300
/tmp/petsc-wjcu960y/config.packages.MPI/conftest.c:4:17: note: in expansion of macro ���I_MPI_NUMVERSION���
int mpich_ver = I_MPI_NUMVERSION;
Source:
#include "confdefs.h"
#include "conffix.h"
#include <mpi.h>
int main() {
return 0;
Source:
#include <mpi.h>
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.headers /tmp/petsc-wjcu960y/config.packages.MPI/conftest.c
Defined "HAVE_I_MPI_NUMVERSION" to "20190005300"
TEST configureMPI2 from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:184)
TESTING: configureMPI2 from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:184)
Check for functions added to the interface in MPI-2
Successful compile:
Source:
#include <mpi.h>
int main() {
int flag;if (MPI_Finalized(&flag));
return 0;
Defined "HAVE_MPI_FINALIZED" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Allreduce(MPI_IN_PLACE,0, 1, MPI_INT, MPI_SUM, MPI_COMM_SELF));
return 0;
Defined "HAVE_MPI_IN_PLACE" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
int count=2; int blocklens[2]={0,1}; MPI_Aint indices[2]={0,1}; MPI_Datatype old_types[2]={0,1}; MPI_Datatype *newtype = 0;
if (MPI_Type_create_struct(count, blocklens, indices, old_types, newtype));
return 0;
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Comm_errhandler_fn * p_err_fun = 0; MPI_Errhandler * p_errhandler = 0; if (MPI_Comm_create_errhandler(p_err_fun,p_errhandler));
return 0;
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Comm_set_errhandler(MPI_COMM_WORLD,MPI_ERRORS_RETURN));
return 0;
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Reduce_local(0, 0, 0, MPI_INT, MPI_SUM));;
return 0;
Defined "HAVE_MPI_REDUCE_LOCAL" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
char version[MPI_MAX_LIBRARY_VERSION_STRING];int verlen;if (MPI_Get_library_version(version,&verlen));
return 0;
Defined "HAVE_MPI_GET_LIBRARY_VERSION" to "1"
TEST configureMPI3 from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:223)
TESTING: configureMPI3 from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:223)
Check for functions added to the interface in MPI-3
Checking for functions [MPI_Win_create] in library [] []
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.c
Successful compile:
Source:
char MPI_Win_create();
static void _check_MPI_Win_create() { MPI_Win_create(); }
int main() {
_check_MPI_Win_create();;
return 0;
Defined "HAVE_MPI_WIN_CREATE" to "1"
Defined "HAVE_MPI_REPLACE" to "1"
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.packages.MPI/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.packages.MPI/conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Comm scomm; if (MPI_Comm_split_type(MPI_COMM_WORLD, MPI_COMM_TYPE_SHARED, 0, MPI_INFO_NULL, &scomm));
return 0;
Defined "HAVE_MPI_SHARED_COMM" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Win win; if (MPI_Win_allocate_shared(100,10,MPI_INFO_NULL,MPI_COMM_WORLD, 0, &win));
return 0;
Defined "HAVE_MPI_WIN_ALLOCATE_SHARED" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Win_shared_query(MPI_WIN_NULL,0,0,0,0));
return 0;
Defined "HAVE_MPI_WIN_SHARED_QUERY" to "1"
Defined "HAVE_MPI_WIN_CREATE_FEATURE" to "1"
Defined "HAVE_MPI_PROCESS_SHARED_MEMORY" to "1"
TEST configureTypes from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:271)
TESTING: configureTypes from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:271)
Checking for MPI types
Checking for size of type: MPI_Comm
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.types/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.types/conftest.c
Successful compile:
Source:
#include <sys/types.h>
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
#define MPICH_IGNORE_CXX_SEEK
#define MPICH_SKIP_MPICXX 1
#define OMPI_SKIP_MPICXX 1
#include <mpi.h>
int main() {
FILE *f = fopen("conftestval", "w");
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(MPI_Comm));
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.types/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.types/conftest.o -lstdc++ -ldl
Testing executable /tmp/petsc-wjcu960y/config.types/conftest to see if it can be run
Executing: /tmp/petsc-wjcu960y/config.types/conftest
Defined "SIZEOF_MPI_COMM" to "4"
Checking for size of type: MPI_Fint
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
#include <mpi.h>
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(MPI_Fint));
return 0;
Defined "SIZEOF_MPI_FINT" to "4"
TEST configureMPITypes from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:283)
TESTING: configureMPITypes from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:283)
Checking for MPI Datatype handles
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.packages.MPI/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.packages.MPI/conftest.c
Successful compile:
Source:
#include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_LONG_DOUBLE, &size);
if(ierr || (size == 0)) exit(1);
MPI_Finalize();
return 0;
Successful compile:
Source:
#include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
MPI_Finalize();
return 0;
Testing executable /tmp/petsc-wjcu960y/config.packages.MPI/conftest to see if it can be run
Executing: /tmp/petsc-wjcu960y/config.packages.MPI/conftest
Defined "HAVE_MPI_LONG_DOUBLE" to "1"
Successful compile:
Source:
#include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_INT64_T, &size);
MPI_Finalize();
return 0;
Successful compile:
Source:
#include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
MPI_Finalize();
return 0;
Defined "HAVE_MPI_INT64_T" to "1"
Successful compile:
Source:
#include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_C_DOUBLE_COMPLEX, &size);
MPI_Finalize();
return 0;
Successful compile:
Source:
#include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
MPI_Finalize();
return 0;
Defined "HAVE_MPI_C_DOUBLE_COMPLEX" to "1"
TEST configureMissingPrototypes from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:351)
TESTING: configureMissingPrototypes from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:351)
Checks for missing prototypes, which it adds to petscfix.h
TEST SGIMPICheck from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:370)
TESTING: SGIMPICheck from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:370)
Returns true if SGI MPI is used
Checking for functions [MPI_SGI_barrier] in library [] []
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.c
Successful compile:
Source:
char MPI_SGI_barrier();
static void _check_MPI_SGI_barrier() { MPI_SGI_barrier(); }
int main() {
_check_MPI_SGI_barrier();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.o -lstdc++ -ldl
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_MPI_SGI_barrier':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `MPI_SGI_barrier'
SGI MPI test failure
TEST CxxMPICheck from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:380)
TESTING: CxxMPICheck from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:380)
Make sure C++ can compile and link
Checking for header mpi.h
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/config.libraries -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fPIC /tmp/petsc-wjcu960y/config.libraries/conftest.cc
Successful compile:
Source:
#include <mpi.h>
int main() {
return 0;
Checking for C++ MPI_Finalize()
Checking for functions [MPI_Finalize] in library [] []
stderr:
/tmp/petsc-wjcu960y/config.libraries/conftest.cc: In function ���void _check_MPI_Finalize()���:
/tmp/petsc-wjcu960y/config.libraries/conftest.cc:5:41: warning: variable ���ierr��� set but not used [-Wunused-but-set-variable]
static void _check_MPI_Finalize() { int ierr;
Source:
#include <mpi.h>
ierr = MPI_Finalize();; }
int main() {
_check_MPI_Finalize();;
return 0;
Executing: mpicxx -o /tmp/petsc-wjcu960y/config.libraries/conftest -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.o -lstdc++ -ldl
TEST FortranMPICheck from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:398)
TESTING: FortranMPICheck from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:398)
Make sure fortran include [mpif.h] and library symbols are found
Checking for header mpif.h
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.F90
Successful compile:
Source:
program main
#include "mpif.h"
end
Checking for fortran mpi_init()
Checking for functions [] in library [] []
Successful compile:
Source:
program main
#include "mpif.h"
integer ierr
call mpi_init(ierr)
end
Executing: mpif90 -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.o -lstdc++ -ldl
Checking for mpi.mod
Successful compile:
Source:
program main
use mpi
integer ierr,rank
call mpi_init(ierr)
call mpi_comm_rank(MPI_COMM_WORLD,rank,ierr)
end
Defined "HAVE_MPI_F90MODULE" to "1"
TEST configureIO from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:423)
TESTING: configureIO from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:423)
Check for the functions in MPI/IO
- Define HAVE_MPIIO if they are present
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Aint lb, extent;
if (MPI_Type_get_extent(MPI_INT, &lb, &extent));
return 0;
stderr:
/tmp/petsc-wjcu960y/config.packages.MPI/conftest.c:9:5: warning: ���fh��� is used uninitialized in this function [-Wuninitialized]
if (MPI_File_write_all(fh, buf, 1, MPI_INT, &status));
/tmp/petsc-wjcu960y/config.packages.MPI/conftest.c:9:5: warning: ���buf��� is used uninitialized in this function [-Wuninitialized]
Source:
#include <mpi.h>
int main() {
MPI_File fh;
void *buf;
MPI_Status status;
return 0;
stderr:
if (MPI_File_read_all(fh, buf, 1, MPI_INT, &status));
Source:
#include <mpi.h>
int main() {
MPI_File fh;
void *buf;
MPI_Status status;
return 0;
stderr:
if (MPI_File_set_view(fh, disp, MPI_INT, MPI_INT, "", info));
/tmp/petsc-wjcu960y/config.packages.MPI/conftest.c:9:5: warning: ���disp��� is used uninitialized in this function [-Wuninitialized]
/tmp/petsc-wjcu960y/config.packages.MPI/conftest.c:9:5: warning: ���info��� is used uninitialized in this function [-Wuninitialized]
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Offset disp;
MPI_Info info;
return 0;
stderr:
/tmp/petsc-wjcu960y/config.packages.MPI/conftest.c:8:5: warning: ���info��� is used uninitialized in this function [-Wuninitialized]
if (MPI_File_open(MPI_COMM_SELF, "", 0, info, &fh));
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Info info;
return 0;
stderr:
/tmp/petsc-wjcu960y/config.packages.MPI/conftest.c:7:10: warning: unused variable ���info��� [-Wunused-variable]
MPI_Info info;
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Info info;
if (MPI_File_close(&fh));
return 0;
Defined "HAVE_MPIIO" to "1"
TEST findMPIInc from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:497)
TESTING: findMPIInc from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:497)
Find MPI include paths from "mpicc -show" and use with CUDAC_FLAGS
Checking for functions [MPI_Alltoallw] in library [] []
Successful compile:
Source:
char MPI_Alltoallw();
static void _check_MPI_Alltoallw() { MPI_Alltoallw(); }
int main() {
_check_MPI_Alltoallw();;
return 0;
Checking for functions [MPI_Type_create_indexed_block] in library [] []
Successful compile:
Source:
char MPI_Type_create_indexed_block();
static void _check_MPI_Type_create_indexed_block() { MPI_Type_create_indexed_block(); }
int main() {
_check_MPI_Type_create_indexed_block();;
return 0;
Defined "HAVE_MPI_ALLTOALLW" to "1"
Checking for functions [MPI_Comm_spawn MPI_Type_get_envelope MPI_Type_get_extent MPI_Type_dup MPI_Init_thread MPI_Iallreduce MPI_Ibarrier MPI_Finalized MPI_Exscan MPI_Reduce_scatter MPI_Reduce_scatter_block] in library [] []
Successful compile:
Source:
char MPI_Comm_spawn();
static void _check_MPI_Comm_spawn() { MPI_Comm_spawn(); }
char MPI_Type_get_envelope();
static void _check_MPI_Type_get_envelope() { MPI_Type_get_envelope(); }
char MPI_Type_get_extent();
static void _check_MPI_Type_get_extent() { MPI_Type_get_extent(); }
char MPI_Type_dup();
static void _check_MPI_Type_dup() { MPI_Type_dup(); }
char MPI_Init_thread();
static void _check_MPI_Init_thread() { MPI_Init_thread(); }
char MPI_Iallreduce();
static void _check_MPI_Iallreduce() { MPI_Iallreduce(); }
char MPI_Ibarrier();
static void _check_MPI_Ibarrier() { MPI_Ibarrier(); }
char MPI_Finalized();
static void _check_MPI_Finalized() { MPI_Finalized(); }
char MPI_Exscan();
static void _check_MPI_Exscan() { MPI_Exscan(); }
char MPI_Reduce_scatter();
static void _check_MPI_Reduce_scatter() { MPI_Reduce_scatter(); }
char MPI_Reduce_scatter_block();
static void _check_MPI_Reduce_scatter_block() { MPI_Reduce_scatter_block(); }
int main() {
_check_MPI_Comm_spawn();
_check_MPI_Type_get_envelope();
_check_MPI_Type_get_extent();
_check_MPI_Type_dup();
_check_MPI_Init_thread();
_check_MPI_Iallreduce();
_check_MPI_Ibarrier();
_check_MPI_Finalized();
_check_MPI_Exscan();
_check_MPI_Reduce_scatter();
_check_MPI_Reduce_scatter_block();;
return 0;
Defined "HAVE_MPI_COMM_SPAWN" to "1"
Defined "HAVE_MPI_TYPE_GET_ENVELOPE" to "1"
Defined "HAVE_MPI_TYPE_GET_EXTENT" to "1"
Defined "HAVE_MPI_TYPE_DUP" to "1"
Defined "HAVE_MPI_INIT_THREAD" to "1"
Defined "HAVE_MPI_IALLREDUCE" to "1"
Defined "HAVE_MPI_IBARRIER" to "1"
Defined "HAVE_MPI_EXSCAN" to "1"
Defined "HAVE_MPI_REDUCE_SCATTER" to "1"
Defined "HAVE_MPI_REDUCE_SCATTER_BLOCK" to "1"
Checking for functions [MPIX_Iallreduce] in library [] []
Successful compile:
Source:
char MPIX_Iallreduce();
static void _check_MPIX_Iallreduce() { MPIX_Iallreduce(); }
int main() {
_check_MPIX_Iallreduce();;
return 0;
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_MPIX_Iallreduce':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `MPIX_Iallreduce'
Checking for functions [MPIX_Ibarrier] in library [] []
Successful compile:
Source:
char MPIX_Ibarrier();
static void _check_MPIX_Ibarrier() { MPIX_Ibarrier(); }
int main() {
_check_MPIX_Ibarrier();;
return 0;
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_MPIX_Ibarrier':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `MPIX_Ibarrier'
stderr:
/tmp/petsc-wjcu960y/config.packages.MPI/conftest.c:6:5: warning: unused variable ���combiner��� [-Wunused-variable]
int combiner = MPI_COMBINER_DUP;;
Source:
#include <mpi.h>
int main() {
return 0;
Defined "HAVE_MPI_COMBINER_DUP" to "1"
stderr:
int combiner = MPI_COMBINER_CONTIGUOUS;;
Source:
#include <mpi.h>
int main() {
return 0;
Defined "HAVE_MPI_COMBINER_CONTIGUOUS" to "1"
stderr:
int combiner = MPI_COMBINER_NAMED;;
Source:
#include <mpi.h>
int main() {
return 0;
Defined "HAVE_MPI_COMBINER_NAMED" to "1"
Checking for functions [MPIDI_CH3I_sock_set] in library [] []
Successful compile:
Source:
char MPIDI_CH3I_sock_set();
static void _check_MPIDI_CH3I_sock_set() { MPIDI_CH3I_sock_set(); }
int main() {
_check_MPIDI_CH3I_sock_set();;
return 0;
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_MPIDI_CH3I_sock_set':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `MPIDI_CH3I_sock_set'
Checking for functions [MPIDI_CH3I_sock_fixed_nbc_progress] in library [] []
Successful compile:
Source:
char MPIDI_CH3I_sock_fixed_nbc_progress();
static void _check_MPIDI_CH3I_sock_fixed_nbc_progress() { MPIDI_CH3I_sock_fixed_nbc_progress(); }
int main() {
_check_MPIDI_CH3I_sock_fixed_nbc_progress();;
return 0;
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_MPIDI_CH3I_sock_fixed_nbc_progress':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `MPIDI_CH3I_sock_fixed_nbc_progress'
TEST checkSharedLibrary from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:132)
TESTING: checkSharedLibrary from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:132)
Sets flag indicating if MPI libraries are shared or not and
determines if MPI libraries CANNOT be used by shared libraries
TEST configureMPIEXEC from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:145)
TESTING: configureMPIEXEC from config.packages.MPI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/MPI.py:145)
Checking for mpiexec
Checking for program /home/wangzl/miniconda3/bin/mpiexec...not found
Checking for program /home/wangzl/miniconda3/bin/mpirun...not found
Checking for program /home/wangzl/miniconda3/bin/mprun...not found
Checking for program /home/wangzl/projects/moose/python/peacock/mpiexec...not found
Checking for program /home/wangzl/projects/moose/python/peacock/mpirun...not found
Checking for program /home/wangzl/projects/moose/python/peacock/mprun...not found
Checking for program /home/wangzl/software/fftwmpi/bin/mpiexec...not found
Checking for program /home/wangzl/software/fftwmpi/bin/mpirun...not found
Checking for program /home/wangzl/software/fftwmpi/bin/mprun...not found
Checking for program /home/wangzl/software/byacc/bin/mpiexec...not found
Checking for program /home/wangzl/software/byacc/bin/mpirun...not found
Checking for program /home/wangzl/software/byacc/bin/mprun...not found
Checking for program /home/wangzl/software/m4/bin/mpiexec...not found
Checking for program /home/wangzl/software/m4/bin/mpirun...not found
Checking for program /home/wangzl/software/m4/bin/mprun...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/mpiexec...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/mpirun...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/mprun...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/mpiexec...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/mpirun...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/mprun...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/mpiexec...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/mpirun...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/mprun...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/mpiexec...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/mpirun...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/mprun...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/mpiexec...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/mpirun...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/mprun...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpiexec...found
Defined make macro "MPIEXEC" to "mpiexec"
Successful compile:
Source:
#include <mpi.h>
#ifdef __cplusplus
extern "C"
#endif
int init(int argc, char *argv[]) {
int isInitialized;
MPI_Init(&argc, &argv);
MPI_Initialized(&isInitialized);
return (int) isInitialized;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.packages.MPI/libconftest.so -shared -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.packages.MPI/conftest.o -lstdc++ -ldl
Successful compile:
Source:
#include <mpi.h>
#ifdef __cplusplus
extern "C"
#endif
int checkInit(void) {
int isInitialized;
if (isInitialized) MPI_Finalize();
Successful compile:
Source:
#include <stdio.h>
#include <stdlib.h>
#ifdef PETSC_HAVE_DLFCN_H
#include <dlfcn.h>
#endif
int main() {
int argc = 1;
char *argv[2] = {(char *) "conftest", NULL};
void *lib;
int (*init)(int, char **);
int (*checkInit)(void);
lib = dlopen("/tmp/petsc-wjcu960y/config.libraries/lib1.so", RTLD_LAZY);
if (!lib) {
fprintf(stderr, "Could not open lib1.so: %s\n", dlerror());
exit(1);
init = (int (*)(int, char **)) dlsym(lib, "init");
if (!init) {
fprintf(stderr, "Could not find initialization function\n");
exit(1);
if (!(*init)(argc, argv)) {
fprintf(stderr, "Could not initialize library\n");
exit(1);
lib = dlopen("/tmp/petsc-wjcu960y/config.libraries/lib2.so", RTLD_LAZY);
if (!lib) {
fprintf(stderr, "Could not open lib2.so: %s\n", dlerror());
exit(1);
checkInit = (int (*)(void)) dlsym(lib, "checkInit");
if (!checkInit) {
fprintf(stderr, "Could not find initialization check function\n");
exit(1);
if (!(*checkInit)()) {
fprintf(stderr, "Did not link with shared library\n");
exit(2);
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.libraries/conftest.o -lstdc++ -ldl -ldl
Testing executable /tmp/petsc-wjcu960y/config.libraries/conftest to see if it can be run
Executing: mpiexec /tmp/petsc-wjcu960y/config.libraries/conftest
ERROR while running executable: Could not execute "['mpiexec /tmp/petsc-wjcu960y/config.libraries/conftest']":
Library was not shared
TEST alternateConfigureLibrary from config.packages.yaml(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.yaml(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST configureLibrary from config.packages.valgrind(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
TESTING: configureLibrary from config.packages.valgrind(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
Find an installation and check if it can work with PETSc
Checking for a functional valgrind
Not checking for library in Compiler specific search VALGRIND: [] because no functions given to check for
Checking for headers Compiler specific search VALGRIND: ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Checking for header files ['valgrind/valgrind.h'] in ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.headers -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0 -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include /tmp/petsc-wjcu960y/config.headers/conftest.c
Possible ERROR while running preprocessor: exit code 1
stdout:
# 1 "/tmp/petsc-wjcu960y/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "<command-line>" 2
# 1 "/tmp/petsc-wjcu960y/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-wjcu960y/config.headers/conftest.c" 2
# 1 "/tmp/petsc-wjcu960y/config.headers/conffix.h" 1
# 3 "/tmp/petsc-wjcu960y/config.headers/conftest.c" 2
stderr:
/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: valgrind/valgrind.h: No such file or directory
#include <valgrind/valgrind.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: valgrind/valgrind.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-wjcu960y/config.headers/conftest.c:3:10: fatal error: valgrind/valgrind.h: No such file or directory #include <valgrind/valgrind.h> ^~~~~~~~~~~~~~~~~~~~~compilation terminated.:
Not checking for library in Package specific search directory VALGRIND: [] because no functions given to check for
Checking for headers Package specific search directory VALGRIND: ['/usr/local/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Checking for header files ['valgrind/valgrind.h'] in ['/usr/local/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Checking include with compiler flags var CPPFLAGS ['/usr/local/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.headers -I/usr/local/include -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0 -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include /tmp/petsc-wjcu960y/config.headers/conftest.c
stdout:
# 1 "<built-in>"
stderr:
Source:
stdout:
# 1 "<built-in>"
stderr:
Source:
VALGRIND: SearchDir DirPath not found.. skipping: /opt/local
Executing: uname -s
stdout: Linux
It appears you do not have valgrind installed on your system.
We HIGHLY recommend you install it from www.valgrind.org
Or install valgrind-devel or equivalent using your package manager.
Then rerun ./configure
TEST alternateConfigureLibrary from config.packages.ssl(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.ssl(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.sprng(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.sprng(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
Not checking sowing on user request of --with-sowing=0
TEST checkDependencies from config.packages.slepc(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TESTING: checkDependencies from config.packages.slepc(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TEST configureLibrary from config.packages.slepc(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
TESTING: configureLibrary from config.packages.slepc(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
Checking for a functional slepc
Looking for SLEPC at git.slepc, hg.slepc or a directory starting with ['slepc']
Could not locate an existing copy of SLEPC:
Downloading slepc
Trying to download git:///home/wangzl/packages/slepc for SLEPC
Executing: git clone /home/wangzl/packages/slepc /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/git.slepc
Found a copy of SLEPC in git.slepc
Executing: ['git', 'rev-parse', '--git-dir']
stdout: .git
Executing: ['git', 'cat-file', '-e', 'v3.11^{commit}']
Executing: ['git', 'rev-parse', 'v3.11']
stdout: 02e3715d9a6a29d28a09436b62760459488011a8
Executing: ['git', '-c', 'user.name=petsc-configure', '-c', 'user.email=petsc at configure', 'stash']
stdout: No local changes to save
Executing: ['git', 'clean', '-f', '-d', '-x']
Executing: ['git', 'checkout', '-f', '02e3715d9a6a29d28a09436b62760459488011a8']
Defined "HAVE_SLEPC" to "1"
Defined make macro "SLEPC" to "yes"
Defined make rule "slepcbuild" with dependencies "" and code ['@echo "*** Building slepc ***"', '@${RM} -f ${PETSC_ARCH}/lib/petsc/conf/slepc.errorflg', '@(cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/git.slepc && \\\n SLEPC_DIR=/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/git.slepc PETSC_DIR=/home/wangzl/moose-compilers/petsc-3.11.4 PETSC_ARCH="" ./configure --prefix=/home/wangzl/moose-compilers/petsc-3.11.4 && \\\n SLEPC_DIR=/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/git.slepc PETSC_DIR=/home/wangzl/moose-compilers/petsc-3.11.4 PETSC_ARCH=installed-arch-linux-c-opt ${OMAKE} SLEPC_DIR=/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/git.slepc PETSC_DIR=/home/wangzl/moose-compilers/petsc-3.11.4 PETSC_ARCH=installed-arch-linux-c-opt ) > ${PETSC_ARCH}/lib/petsc/conf/slepc.log 2>&1 || \\\n (echo "**************************ERROR*************************************" && \\\n echo "Error building slepc. Check ${PETSC_ARCH}/lib/petsc/conf/slepc.log" && \\\n echo "********************************************************************" && \\\n touch ${PETSC_ARCH}/lib/petsc/conf/slepc.errorflg && \\\n exit 1)']
Defined make rule "slepcinstall" with dependencies "" and code ['@echo "*** Installing slepc ***"', '@(cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/git.slepc && \\\n SLEPC_DIR=/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/git.slepc PETSC_DIR=/home/wangzl/moose-compilers/petsc-3.11.4 PETSC_ARCH=installed-arch-linux-c-opt ${OMAKE} install SLEPC_DIR=/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/git.slepc PETSC_DIR=/home/wangzl/moose-compilers/petsc-3.11.4 PETSC_ARCH=installed-arch-linux-c-opt ) >> ${PETSC_ARCH}/lib/petsc/conf/slepc.log 2>&1 || \\\n (echo "**************************ERROR*************************************" && \\\n echo "Error building slepc. Check ${PETSC_ARCH}/lib/petsc/conf/slepc.log" && \\\n echo "********************************************************************" && \\\n exit 1)']
Defined make rule "slepc-build" with dependencies "" and code []
Defined make rule "slepc-install" with dependencies "slepcbuild slepcinstall" and code []
Slepc examples are available at ${PETSC_DIR}/linux-opt/externalpackages/git.slepc
export SLEPC_DIR=/home/wangzl/moose-compilers/petsc-3.11.4
TEST checkSharedLibrary from config.packages.slepc(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TESTING: checkSharedLibrary from config.packages.slepc(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
By default we don't care about checking if the library is shared
TEST alternateConfigureLibrary from config.packages.revolve(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.revolve(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.radau5(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.radau5(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.pami(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.pami(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.opengles(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.opengles(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.opencl(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.opencl(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.muparser(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.muparser(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
Defined "PYTHON_EXE" to ""/home/wangzl/miniconda3/bin/python""
Executing: /home/wangzl/miniconda3/bin/python -c "import Cython"
Executing: /home/wangzl/miniconda3/bin/python -c "import numpy"
TEST alternateConfigureLibrary from config.packages.petsc4py(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/petsc4py.py:96)
TESTING: alternateConfigureLibrary from config.packages.petsc4py(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/petsc4py.py:96)
Defined make rule "petsc4py-build" with dependencies "" and code []
Defined make rule "petsc4py-install" with dependencies "" and code []
TEST alternateConfigureLibrary from config.packages.mpi4py(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/mpi4py.py:73)
TESTING: alternateConfigureLibrary from config.packages.mpi4py(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/mpi4py.py:73)
Defined make rule "mpi4py-build" with dependencies "" and code []
Defined make rule "mpi4py-install" with dependencies "" and code []
TEST alternateConfigureLibrary from config.packages.mpe(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.mpe(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.memkind(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.memkind(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.libmesh(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/libmesh.py:76)
TESTING: alternateConfigureLibrary from config.packages.libmesh(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/libmesh.py:76)
Defined make rule "libmesh-build" with dependencies "" and code []
Defined make rule "libmesh-install" with dependencies "" and code []
TEST alternateConfigureLibrary from config.packages.moose(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.moose(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.libjpeg(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.libjpeg(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.libceed(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.libceed(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
Not a clone of PETSc, don't need Lgrind
TEST alternateConfigureLibrary from config.packages.gmp(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.gmp(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.mpfr(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.mpfr(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.giflib(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.giflib(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.cuda(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.cuda(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.ctetgen(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.ctetgen(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.concurrencykit(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.concurrencykit(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST locateC2html from config.packages.c2html(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/c2html.py:32)
TESTING: locateC2html from config.packages.c2html(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/c2html.py:32)
Looking for default C2html executable
Checking for program /home/wangzl/miniconda3/bin/c2html...not found
Checking for program /home/wangzl/projects/moose/python/peacock/c2html...not found
Checking for program /home/wangzl/software/fftwmpi/bin/c2html...not found
Checking for program /home/wangzl/software/byacc/bin/c2html...not found
Checking for program /home/wangzl/software/m4/bin/c2html...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/c2html...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/c2html...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/c2html...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/c2html...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/c2html...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/c2html...not found
Checking for program /home/wangzl/bin/c2html...not found
Checking for program /usr/local/bin/c2html...not found
Checking for program /usr/bin/c2html...not found
Checking for program /bin/c2html...not found
Checking for program /opt/pbs/bin/c2html...not found
Checking for program /home/apps/c2html...not found
Checking for program /tmp/stack_temp.rFVgkc/petsc-3.11.4/lib/petsc/bin/win32fe/c2html...not found
TEST alternateConfigureLibrary from config.packages.boost(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.boost(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.silo(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.silo(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.Random123(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.Random123(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.PARTY(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.PARTY(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.Matlab(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.Matlab(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.MatlabEngine(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.MatlabEngine(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.Mathematica(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.Mathematica(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.hwloc(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.hwloc(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST checkDependencies from config.packages.pthread(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TESTING: checkDependencies from config.packages.pthread(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TEST configureLibrary from config.packages.pthread(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/pthread.py:19)
TESTING: configureLibrary from config.packages.pthread(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/pthread.py:19)
Checks for pthread_barrier_t, cpu_set_t, and sys/sysctl.h
Checking for a functional pthread
Checking for library in Compiler specific search PTHREAD: []
Checking for functions [pthread_create] in library [] []
Successful compile:
Source:
char pthread_create();
static void _check_pthread_create() { pthread_create(); }
int main() {
_check_pthread_create();;
return 0;
Checking for headers Compiler specific search PTHREAD: ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Checking for header files ['pthread.h'] in ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Found header files ['pthread.h'] in ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.packages.pthread
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.packages.pthread/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.packages.pthread/conftest.c
stderr:
/tmp/petsc-wjcu960y/config.packages.pthread/conftest.c: In function ���main���:
/tmp/petsc-wjcu960y/config.packages.pthread/conftest.c:6:20: warning: unused variable ���a��� [-Wunused-variable]
pthread_barrier_t *a;
Source:
#include <pthread.h>
int main() {
return 0;
Defined "HAVE_PTHREAD_BARRIER_T" to "1"
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.packages.pthread/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.packages.pthread -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /tmp/petsc-wjcu960y/config.packages.pthread/conftest.c
stderr:
/tmp/petsc-wjcu960y/config.packages.pthread/conftest.c:6:12: warning: unused variable ���a��� [-Wunused-variable]
cpu_set_t *a;
Source:
#include <sched.h>
int main() {
cpu_set_t *a;
return 0;
Defined "HAVE_SCHED_CPU_SET_T" to "1"
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.headers /tmp/petsc-wjcu960y/config.packages.pthread/conftest.c
Defined "HAVE_SYS_SYSCTL_H" to "1"
TEST checkSharedLibrary from config.packages.pthread(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TESTING: checkSharedLibrary from config.packages.pthread(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TEST checkDependencies from config.packages.openmp(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TESTING: checkDependencies from config.packages.openmp(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TEST configureLibrary from config.packages.openmp(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/openmp.py:19)
TESTING: configureLibrary from config.packages.openmp(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/openmp.py:19)
Checks for -fopenmp compiler flag
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag -fopenmp
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O -fopenmp /tmp/petsc-wjcu960y/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Added FC compiler flag -fopenmp
Executing: mpicxx -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp -fPIC /tmp/petsc-wjcu960y/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag -fopenmp
Checking for a functional openmp
Not checking for library in Compiler specific search OPENMP: [] because no functions given to check for
TEST check from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:154)
TESTING: check from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:154)
Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
Checking for headers Compiler specific search OPENMP: ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Checking for header files ['omp.h'] in ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.headers -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0 -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include /tmp/petsc-wjcu960y/config.headers/conftest.c
Found header files ['omp.h'] in ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
TEST checkSharedLibrary from config.packages.openmp(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TESTING: checkSharedLibrary from config.packages.openmp(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TEST alternateConfigureLibrary from config.packages.viennacl(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.viennacl(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.opengl(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.opengl(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.glut(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.glut(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST checkDependencies from config.packages.X(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TESTING: checkDependencies from config.packages.X(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TEST configureLibrary from config.packages.X(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
TESTING: configureLibrary from config.packages.X(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
Checking for a functional X
Checking for library in Compiler specific search X: []
Checking for functions [XSetWMName] in library [] []
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char XSetWMName();
static void _check_XSetWMName() { XSetWMName(); }
int main() {
_check_XSetWMName();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.o -lstdc++ -ldl
Possible ERROR while running linker: exit code 1
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_XSetWMName':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `XSetWMName'
collect2: error: ld returned 1 exit status
Checking for library in Compiler specific search X: ['libX11.a']
Checking for functions [XSetWMName] in library ['libX11.a'] []
Successful compile:
Source:
char XSetWMName();
int main() {
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.o -lX11 -lstdc++ -ldl
Defined "HAVE_LIBX11" to "1"
No functions to check for in library ['libX11.a'] []
Checking for headers Compiler specific search X: ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
TEST checkInclude from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:86)
Checks if a particular include file can be found along particular include paths
Checking for header files ['X11/Xlib.h'] in ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Checking include with compiler flags var CPPFLAGS ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Found header files ['X11/Xlib.h'] in ['/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
TEST checkSharedLibrary from config.packages.X(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TESTING: checkSharedLibrary from config.packages.X(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TEST alternateConfigureLibrary from config.packages.GLVis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.GLVis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.ColPack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.ColPack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.CoDiPack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.CoDiPack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.adblaslapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.adblaslapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.ADOLC(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.ADOLC(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.szlib(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.szlib(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.zlib(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.zlib(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST locateCMake from config.packages.cmake(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/cmake.py:36)
TESTING: locateCMake from config.packages.cmake(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/cmake.py:36)
Looking for default CMake executable
Checking for program /home/wangzl/miniconda3/bin/cmake...not found
Checking for program /home/wangzl/projects/moose/python/peacock/cmake...not found
Checking for program /home/wangzl/software/fftwmpi/bin/cmake...not found
Checking for program /home/wangzl/software/byacc/bin/cmake...not found
Checking for program /home/wangzl/software/m4/bin/cmake...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/cmake...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/cmake...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/cmake...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/cmake...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/cmake...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/cmake...not found
Checking for program /home/wangzl/bin/cmake...not found
Checking for program /usr/local/bin/cmake...not found
Checking for program /usr/bin/cmake...found
Defined make macro "CMAKE" to "/usr/bin/cmake"
Looking for default CTest executable
Checking for program /home/wangzl/miniconda3/bin/ctest...not found
Checking for program /home/wangzl/projects/moose/python/peacock/ctest...not found
Checking for program /home/wangzl/software/fftwmpi/bin/ctest...not found
Checking for program /home/wangzl/software/byacc/bin/ctest...not found
Checking for program /home/wangzl/software/m4/bin/ctest...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/ctest...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/ctest...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/ctest...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/ctest...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/ctest...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/ctest...not found
Checking for program /home/wangzl/bin/ctest...not found
Checking for program /usr/local/bin/ctest...not found
Checking for program /usr/bin/ctest...found
Defined make macro "CTEST" to "/usr/bin/ctest"
TEST alternateConfigureLibrary from config.packages.googletest(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.googletest(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.unittestcpp(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.unittestcpp(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.eigen(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.eigen(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.tetgen(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.tetgen(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.tchem(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.tchem(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.saws(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.saws(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.libpng(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.libpng(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.combblas(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.combblas(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.Triangle(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.Triangle(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST checkDependencies from config.packages.PTScotch(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TESTING: checkDependencies from config.packages.PTScotch(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TEST configureLibrary from config.packages.PTScotch(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
TESTING: configureLibrary from config.packages.PTScotch(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
Checking for a functional PTScotch
Looking for PTSCOTCH at git.ptscotch, hg.ptscotch or a directory starting with ['scotch', 'petsc-pkg-scotch']
Could not locate an existing copy of PTSCOTCH:
['git.slepc']
Downloading PTScotch
Trying to download file:///home/wangzl/packages/petsc-pkg-scotch-c15036faac5f.tar.gz for PTSCOTCH
Downloading file:///home/wangzl/packages/petsc-pkg-scotch-c15036faac5f.tar.gz to /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/_d_petsc-pkg-scotch-c15036faac5f.tar.gz
Extracting /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/_d_petsc-pkg-scotch-c15036faac5f.tar.gz
Executing: cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages; chmod -R a+r petsc-pkg-scotch-c15036faac5f;find petsc-pkg-scotch-c15036faac5f -type d -name "*" -exec chmod a+rx {} \;
Found a copy of PTSCOTCH in petsc-pkg-scotch-c15036faac5f
Creating PTScotch /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/Makefile.inc
Checking for program /home/wangzl/miniconda3/bin/bison...not found
Checking for program /home/wangzl/projects/moose/python/peacock/bison...not found
Checking for program /home/wangzl/software/fftwmpi/bin/bison...not found
Checking for program /home/wangzl/software/byacc/bin/bison...not found
Checking for program /home/wangzl/software/m4/bin/bison...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/bison...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/bison...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/bison...not found
Checking for program /opt/intel/debugger_2019/gdb/intel64/bin/bison...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/bin/bison...not found
Checking for program /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/bison...not found
Checking for program /home/wangzl/bin/bison...not found
Checking for program /usr/local/bin/bison...not found
Checking for program /usr/bin/bison...found
Defined make macro "BISON" to "/usr/bin/bison"
Checking for program /home/wangzl/miniconda3/bin/flex...not found
Checking for program /home/wangzl/projects/moose/python/peacock/flex...not found
Checking for program /home/wangzl/software/fftwmpi/bin/flex...not found
Checking for program /home/wangzl/software/byacc/bin/flex...not found
Checking for program /home/wangzl/software/m4/bin/flex...not found
Checking for program /home/wangzl/software/flex-2.6.4/bin/flex...found
Defined make macro "FLEX" to "/home/wangzl/software/flex-2.6.4/bin/flex"
Checking for functions [gzwrite] in library ['-lz'] []
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
char gzwrite();
static void _check_gzwrite() { gzwrite(); }
int main() {
_check_gzwrite();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.o -lz -lstdc++ -ldl
Defined "HAVE_LIBZ" to "1"
Adding ['-lz'] to LIBS
Checking for functions [pthread_barrier_destroy] in library ['-lpthread'] []
Successful compile:
Source:
char pthread_barrier_destroy();
static void _check_pthread_barrier_destroy() { pthread_barrier_destroy(); }
int main() {
_check_pthread_barrier_destroy();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.o -lpthread -lz -lstdc++ -ldl
Defined "HAVE_LIBPTHREAD" to "1"
Adding ['-lpthread'] to LIBS
Checking for functions [sin] in library ['-lm'] []
Possible ERROR while running compiler:
stderr:
/tmp/petsc-wjcu960y/config.libraries/conftest.c:4:6: warning: conflicting types for built-in function ���sin��� [-Wbuiltin-declaration-mismatch]
char sin();
Source:
char sin();
static void _check_sin() { sin(); }
int main() {
_check_sin();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.o -lm -lpthread -lz -lstdc++ -ldl
Defined "HAVE_LIBM" to "1"
Adding ['-lm'] to LIBS
Checking for functions [timer_create] in library ['-lrt'] []
Successful compile:
Source:
char timer_create();
static void _check_timer_create() { timer_create(); }
int main() {
_check_timer_create();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.o -lrt -lm -lpthread -lz -lstdc++ -ldl
Defined "HAVE_LIBRT" to "1"
Adding ['-lrt'] to LIBS
Executing: uname -s
stdout: Linux
Have to rebuild PTSCOTCH, /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/Makefile.inc != /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/lib/petsc/conf/pkg.conf.ptscotch
Compiling PTScotch; this may take several minutes
Executing: cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src && make clean ptesmumps esmumps
stdout:
/usr/bin/mkdir -p ../bin
/usr/bin/mkdir -p ../include
/usr/bin/mkdir -p ../lib
(cd libscotch ; make clean)
make[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/libscotch'
rm -f *~ *.o lib*.a parser_yy.c parser_ly.h parser_ll.c *scotch.h *scotchf.h y.output *dummysizes
make[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/libscotch'
(cd scotch ; make clean)
make[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/scotch'
rm -f *~ *.o acpl amk_ccc amk_fft2 amk_grf amk_hy amk_m2 amk_p2 atst gbase gcv *ggath *gmap gmk_hy gmk_m2 gmk_m3 gmk_msh gmk_ub2 gmtst *gord gotst gout *gpart *gscat *gtst mcv mmk_m2 mmk_m3 mord mtst
make[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/scotch'
(cd libscotchmetis ; make clean)
make[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/libscotchmetis'
rm -f *~ *.o lib*.a metis.h parmetis.h
make[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/libscotchmetis'
(cd check ; make clean)
make[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/check'
rm -f *~ *.o
make[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/check'
(cd esmumps ; make clean)
make[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/esmumps'
rm -f *~ common.h *.o lib*.a main_esmumps
make[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/esmumps'
(cd libscotch ; make VERSION=6 RELEASE=0 PATCHLEVEL=6 scotch && make install)
make CC="mpicc" CCD="mpicc" \
scotch.h \
scotchf.h \
libscotch.a \
libscotcherr.a \
libscotcherrexit.a
make[2]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/libscotch'
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch.c -o arch.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6 dummysizes.c -o dummysizes -lz -lpthread -lm -lrt
./dummysizes "-s" library.h scotch.h
./dummysizes "-s" library_f.h scotchf.h
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_build.c -o arch_build.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_build2.c -o arch_build2.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_cmplt.c -o arch_cmplt.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_cmpltw.c -o arch_cmpltw.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_deco.c -o arch_deco.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_deco2.c -o arch_deco2.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_dist.c -o arch_dist.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_hcub.c -o arch_hcub.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_mesh.c -o arch_mesh.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_sub.c -o arch_sub.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_tleaf.c -o arch_tleaf.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_torus.c -o arch_torus.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_vcmplt.c -o arch_vcmplt.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c arch_vhcub.c -o arch_vhcub.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c bgraph.c -o bgraph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c bgraph_bipart_bd.c -o bgraph_bipart_bd.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c bgraph_bipart_df.c -o bgraph_bipart_df.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c bgraph_bipart_ex.c -o bgraph_bipart_ex.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c bgraph_bipart_fm.c -o bgraph_bipart_fm.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c bgraph_bipart_gg.c -o bgraph_bipart_gg.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c bgraph_bipart_gp.c -o bgraph_bipart_gp.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c bgraph_bipart_ml.c -o bgraph_bipart_ml.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c bgraph_bipart_st.c -o bgraph_bipart_st.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c bgraph_bipart_zr.c -o bgraph_bipart_zr.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c bgraph_check.c -o bgraph_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c bgraph_store.c -o bgraph_store.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c common.c -DSCOTCH_COMMON_RENAME -o common.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c common_file.c -DSCOTCH_COMMON_RENAME -o common_file.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c common_file_compress.c -DSCOTCH_COMMON_RENAME -o common_file_compress.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c common_file_decompress.c -DSCOTCH_COMMON_RENAME -o common_file_decompress.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c common_integer.c -DSCOTCH_COMMON_RENAME -o common_integer.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c common_memory.c -DSCOTCH_COMMON_RENAME -o common_memory.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c common_string.c -DSCOTCH_COMMON_RENAME -o common_string.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c common_stub.c -DSCOTCH_COMMON_RENAME -o common_stub.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c common_thread.c -DSCOTCH_COMMON_RENAME -o common_thread.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c fibo.c -o fibo.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c gain.c -o gain.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c geom.c -o geom.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph.c -o graph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_base.c -o graph_base.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_band.c -o graph_band.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_check.c -o graph_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_clone.c -o graph_clone.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_coarsen.c -o graph_coarsen.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_diam.c -o graph_diam.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_ielo.c -o graph_ielo.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_induce.c -o graph_induce.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_io.c -o graph_io.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_io_chac.c -o graph_io_chac.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_io_habo.c -o graph_io_habo.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_io_mmkt.c -o graph_io_mmkt.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_io_scot.c -o graph_io_scot.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_list.c -o graph_list.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c graph_match.c -o graph_match.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hall_order_hd.c -o hall_order_hd.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hall_order_hf.c -o hall_order_hf.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hall_order_hx.c -o hall_order_hx.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph.c -o hgraph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph_check.c -o hgraph_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph_induce.c -o hgraph_induce.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph_order_bl.c -o hgraph_order_bl.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph_order_cc.c -o hgraph_order_cc.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph_order_cp.c -o hgraph_order_cp.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph_order_gp.c -o hgraph_order_gp.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph_order_hd.c -o hgraph_order_hd.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph_order_hf.c -o hgraph_order_hf.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph_order_hx.c -o hgraph_order_hx.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph_order_kp.c -o hgraph_order_kp.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph_order_nd.c -o hgraph_order_nd.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph_order_si.c -o hgraph_order_si.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hgraph_order_st.c -o hgraph_order_st.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh.c -o hmesh.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_check.c -o hmesh_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_hgraph.c -o hmesh_hgraph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_induce.c -o hmesh_induce.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_mesh.c -o hmesh_mesh.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_order_bl.c -o hmesh_order_bl.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_order_cp.c -o hmesh_order_cp.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_order_gr.c -o hmesh_order_gr.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_order_gp.c -o hmesh_order_gp.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_order_hd.c -o hmesh_order_hd.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_order_hf.c -o hmesh_order_hf.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_order_hx.c -o hmesh_order_hx.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_order_nd.c -o hmesh_order_nd.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_order_si.c -o hmesh_order_si.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c hmesh_order_st.c -o hmesh_order_st.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph.c -o kgraph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph_band.c -o kgraph_band.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph_check.c -o kgraph_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph_map_bd.c -o kgraph_map_bd.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph_map_cp.c -o kgraph_map_cp.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph_map_df.c -o kgraph_map_df.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph_map_ex.c -o kgraph_map_ex.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph_map_fm.c -o kgraph_map_fm.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph_map_ml.c -o kgraph_map_ml.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph_map_rb.c -o kgraph_map_rb.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph_map_rb_map.c -o kgraph_map_rb_map.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph_map_rb_part.c -o kgraph_map_rb_part.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph_map_st.c -o kgraph_map_st.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c kgraph_store.c -o kgraph_store.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_arch.c -o library_arch.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_arch_f.c -o library_arch_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_arch_build.c -o library_arch_build.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_arch_build_f.c -o library_arch_build_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_common_f.c -o library_common_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_geom.c -o library_geom.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_geom_f.c -o library_geom_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph.c -o library_graph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_f.c -o library_graph_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_base.c -o library_graph_base.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_base_f.c -o library_graph_base_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_check.c -o library_graph_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_check_f.c -o library_graph_check_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_coarsen.c -o library_graph_coarsen.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_coarsen_f.c -o library_graph_coarsen_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_color.c -o library_graph_color.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_color_f.c -o library_graph_color_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_diam.c -o library_graph_diam.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_diam_f.c -o library_graph_diam_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_induce.c -o library_graph_induce.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_induce_f.c -o library_graph_induce_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_io_chac.c -o library_graph_io_chac.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_io_chac_f.c -o library_graph_io_chac_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_io_habo.c -o library_graph_io_habo.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_io_habo_f.c -o library_graph_io_habo_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_io_mmkt.c -o library_graph_io_mmkt.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_io_mmkt_f.c -o library_graph_io_mmkt_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_io_scot.c -o library_graph_io_scot.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_io_scot_f.c -o library_graph_io_scot_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_map.c -o library_graph_map.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_map_f.c -o library_graph_map_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_map_io.c -o library_graph_map_io.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_map_io_f.c -o library_graph_map_io_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_map_view.c -o library_graph_map_view.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_map_view_f.c -o library_graph_map_view_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_order.c -o library_graph_order.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_order_f.c -o library_graph_order_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_part_ovl.c -o library_graph_part_ovl.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_graph_part_ovl_f.c -o library_graph_part_ovl_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_mapping.c -o library_mapping.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_memory.c -o library_memory.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_memory_f.c -o library_memory_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_mesh.c -o library_mesh.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_mesh_f.c -o library_mesh_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_mesh_graph.c -o library_mesh_graph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_mesh_graph_f.c -o library_mesh_graph_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_mesh_io_habo.c -o library_mesh_io_habo.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_mesh_io_habo_f.c -o library_mesh_io_habo_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_mesh_io_scot.c -o library_mesh_io_scot.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_mesh_io_scot_f.c -o library_mesh_io_scot_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_mesh_order.c -o library_mesh_order.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_mesh_order_f.c -o library_mesh_order_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_order.c -o library_order.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_parser.c -o library_parser.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_parser_f.c -o library_parser_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_random.c -o library_random.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_random_f.c -o library_random_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_strat.c -o library_strat.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_version.c -o library_version.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_version_f.c -o library_version_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c mapping.c -o mapping.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c mapping_io.c -o mapping_io.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c mesh.c -o mesh.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c mesh_check.c -o mesh_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c mesh_coarsen.c -o mesh_coarsen.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c mesh_graph.c -o mesh_graph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c mesh_induce_sepa.c -o mesh_induce_sepa.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c mesh_io.c -o mesh_io.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c mesh_io_habo.c -o mesh_io_habo.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c mesh_io_scot.c -o mesh_io_scot.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c order.c -o order.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c order_check.c -o order_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c order_io.c -o order_io.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c parser.c -o parser.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
(/usr/bin/bison -y -d -v parser_yy.y && \
/usr/bin/mv y.tab.c parser_yy.c && \
/usr/bin/mv y.tab.h parser_ly.h) || \
/usr/bin/cp last_resort/parser_ly.h last_resort/parser_yy.c .
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c parser_yy.c -o parser_yy.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
(/home/wangzl/software/flex-2.6.4/bin/flex parser_ll.l && \
/usr/bin/mv lex.yy.c parser_ll.c) || \
/usr/bin/cp last_resort/parser_ll.c .
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c parser_ll.c -o parser_ll.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph.c -o vgraph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph_check.c -o vgraph_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph_separate_bd.c -o vgraph_separate_bd.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph_separate_df.c -o vgraph_separate_df.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph_separate_es.c -o vgraph_separate_es.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph_separate_fm.c -o vgraph_separate_fm.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph_separate_gg.c -o vgraph_separate_gg.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph_separate_gp.c -o vgraph_separate_gp.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph_separate_ml.c -o vgraph_separate_ml.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph_separate_st.c -o vgraph_separate_st.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph_separate_th.c -o vgraph_separate_th.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph_separate_vw.c -o vgraph_separate_vw.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph_separate_zr.c -o vgraph_separate_zr.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vgraph_store.c -o vgraph_store.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vmesh.c -o vmesh.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vmesh_check.c -o vmesh_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vmesh_separate_fm.c -o vmesh_separate_fm.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vmesh_separate_gg.c -o vmesh_separate_gg.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vmesh_separate_gr.c -o vmesh_separate_gr.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vmesh_separate_ml.c -o vmesh_separate_ml.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vmesh_separate_zr.c -o vmesh_separate_zr.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vmesh_separate_st.c -o vmesh_separate_st.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c vmesh_store.c -o vmesh_store.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c wgraph.c -o wgraph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c wgraph_check.c -o wgraph_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c wgraph_part_fm.c -o wgraph_part_fm.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c wgraph_part_gg.c -o wgraph_part_gg.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c wgraph_part_gp.c -o wgraph_part_gp.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c wgraph_part_ml.c -o wgraph_part_ml.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c wgraph_part_rb.c -o wgraph_part_rb.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c wgraph_part_st.c -o wgraph_part_st.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c wgraph_part_zr.c -o wgraph_part_zr.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c wgraph_store.c -o wgraph_store.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
/usr/bin/ar cr libscotch.a arch.o arch_build.o arch_build2.o arch_cmplt.o arch_cmpltw.o arch_deco.o arch_deco2.o arch_dist.o arch_hcub.o arch_mesh.o arch_sub.o arch_tleaf.o arch_torus.o arch_vcmplt.o arch_vhcub.o bgraph.o bgraph_bipart_bd.o bgraph_bipart_df.o bgraph_bipart_ex.o bgraph_bipart_fm.o bgraph_bipart_gg.o bgraph_bipart_gp.o bgraph_bipart_ml.o bgraph_bipart_st.o bgraph_bipart_zr.o bgraph_check.o bgraph_store.o common.o common_file.o common_file_compress.o common_file_decompress.o common_integer.o common_memory.o common_string.o common_stub.o common_thread.o fibo.o gain.o geom.o graph.o graph_base.o graph_band.o graph_check.o graph_clone.o graph_coarsen.o graph_diam.o graph_ielo.o graph_induce.o graph_io.o graph_io_chac.o graph_io_habo.o graph_io_mmkt.o graph_io_scot.o graph_list.o graph_match.o hall_order_hd.o hall_order_hf.o hall_order_hx.o hgraph.o hgraph_check.o hgraph_induce.o hgraph_order_bl.o hgraph_order_cc.o hgraph_order_cp.o hgraph_order_gp.o hgraph_order_hd.o hgraph_order_hf.o hgraph_order_hx.o hgraph_order_kp.o hgraph_order_nd.o hgraph_order_si.o hgraph_order_st.o hmesh.o hmesh_check.o hmesh_hgraph.o hmesh_induce.o hmesh_mesh.o hmesh_order_bl.o hmesh_order_cp.o hmesh_order_gr.o hmesh_order_gp.o hmesh_order_hd.o hmesh_order_hf.o hmesh_order_hx.o hmesh_order_nd.o hmesh_order_si.o hmesh_order_st.o kgraph.o kgraph_band.o kgraph_check.o kgraph_map_bd.o kgraph_map_cp.o kgraph_map_df.o kgraph_map_ex.o kgraph_map_fm.o kgraph_map_ml.o kgraph_map_rb.o kgraph_map_rb_map.o kgraph_map_rb_part.o kgraph_map_st.o kgraph_store.o library_arch.o library_arch_f.o library_arch_build.o library_arch_build_f.o library_common_f.o library_geom.o library_geom_f.o library_graph.o library_graph_f.o library_graph_base.o library_graph_base_f.o library_graph_check.o library_graph_check_f.o library_graph_coarsen.o library_graph_coarsen_f.o library_graph_color.o library_graph_color_f.o library_graph_diam.o library_graph_diam_f.o library_graph_induce.o library_graph_induce_f.o library_graph_io_chac.o library_graph_io_chac_f.o library_graph_io_habo.o library_graph_io_habo_f.o library_graph_io_mmkt.o library_graph_io_mmkt_f.o library_graph_io_scot.o library_graph_io_scot_f.o library_graph_map.o library_graph_map_f.o library_graph_map_io.o library_graph_map_io_f.o library_graph_map_view.o library_graph_map_view_f.o library_graph_order.o library_graph_order_f.o library_graph_part_ovl.o library_graph_part_ovl_f.o library_mapping.o library_memory.o library_memory_f.o library_mesh.o library_mesh_f.o library_mesh_graph.o library_mesh_graph_f.o library_mesh_io_habo.o library_mesh_io_habo_f.o library_mesh_io_scot.o library_mesh_io_scot_f.o library_mesh_order.o library_mesh_order_f.o library_order.o library_parser.o library_parser_f.o library_random.o library_random_f.o library_strat.o library_version.o library_version_f.o mapping.o mapping_io.o mesh.o mesh_check.o mesh_coarsen.o mesh_graph.o mesh_induce_sepa.o mesh_io.o mesh_io_habo.o mesh_io_scot.o order.o order_check.o order_io.o parser.o parser_ll.o parser_yy.o vgraph.o vgraph_check.o vgraph_separate_bd.o vgraph_separate_df.o vgraph_separate_es.o vgraph_separate_fm.o vgraph_separate_gg.o vgraph_separate_gp.o vgraph_separate_ml.o vgraph_separate_st.o vgraph_separate_th.o vgraph_separate_vw.o vgraph_separate_zr.o vgraph_store.o vmesh.o vmesh_check.o vmesh_separate_fm.o vmesh_separate_gg.o vmesh_separate_gr.o vmesh_separate_ml.o vmesh_separate_zr.o vmesh_separate_st.o vmesh_store.o wgraph.o wgraph_check.o wgraph_part_fm.o wgraph_part_gg.o wgraph_part_gp.o wgraph_part_ml.o wgraph_part_rb.o wgraph_part_st.o wgraph_part_zr.o wgraph_store.o
/usr/bin/ranlib libscotch.a
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_error.c -o library_error.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
/usr/bin/ar cr libscotcherr.a library_error.o
/usr/bin/ranlib libscotcherr.a
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -c library_error_exit.c -o library_error_exit.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
/usr/bin/ar cr libscotcherrexit.a library_error_exit.o
/usr/bin/ranlib libscotcherrexit.a
make[2]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/libscotch'
make[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/libscotch'
make[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/libscotch'
/usr/bin/cp scotch.h ../../include
/usr/bin/cp scotchf.h ../../include
/usr/bin/cp libscotch.a libscotcherr*.a ../../lib
(cd scotch ; make VERSION=6 RELEASE=0 PATCHLEVEL=6 scotch && make install)
make[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/scotch'
make CC="mpicc" SCOTCHLIB=scotch \
acpl \
amk_ccc \
amk_fft2 \
amk_grf \
amk_hy \
amk_m2 \
amk_p2 \
atst \
gbase \
gcv \
gmap \
gmk_hy \
gmk_m2 \
gmk_m3 \
gmk_msh \
gmk_ub2 \
gmtst \
gord \
gotst \
gout \
gpart \
gscat \
gtst \
mcv \
mmk_m2 \
mmk_m3 \
mord \
mtst
make[2]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/scotch'
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch acpl.c -o acpl -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch amk_ccc.c -o amk_ccc -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch amk_fft2.c -o amk_fft2 -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch amk_grf.c -o amk_grf -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch amk_hy.c -o amk_hy -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch amk_m2.c -o amk_m2 -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch amk_p2.c -o amk_p2 -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch atst.c -o atst -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gbase.c -o gbase -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gcv.c -o gcv -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gmap.c -o gmap -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gmk_hy.c -o gmk_hy -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gmk_m2.c -o gmk_m2 -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gmk_m3.c -o gmk_m3 -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gmk_msh.c -o gmk_msh -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gmk_ub2.c -o gmk_ub2 -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gmtst.c -o gmtst -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gord.c -o gord -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gotst.c -o gotst -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../libscotch -I../../include gout_c.c gout_o.c -o gout -L../../lib -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gmap.c -DSCOTCH_COMPILE_PART -o gpart -L../../lib -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gscat.c -o gscat -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch gtst.c -o gtst -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch mcv.c -o mcv -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch mmk_m2.c -o mmk_m2 -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch mmk_m3.c -o mmk_m3 -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch mord.c -o mord -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch mtst.c -o mtst -L../../lib -lscotch -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
make[2]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/scotch'
make[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/scotch'
acpl \
amk_ccc \
amk_fft2 \
amk_grf \
amk_hy \
amk_m2 \
amk_p2 \
atst \
gbase \
gcv \
gmap \
gmk_hy \
gmk_m2 \
gmk_m3 \
gmk_msh \
gmk_ub2 \
gmtst \
gord \
gotst \
gout \
gpart \
gscat \
gtst \
mcv \
mmk_m2 \
mmk_m3 \
mord \
mtst
make[2]: 'acpl' is up to date.
make[2]: 'amk_ccc' is up to date.
make[2]: 'amk_fft2' is up to date.
make[2]: 'amk_grf' is up to date.
make[2]: 'amk_hy' is up to date.
make[2]: 'amk_m2' is up to date.
make[2]: 'amk_p2' is up to date.
make[2]: 'atst' is up to date.
make[2]: 'gbase' is up to date.
make[2]: 'gcv' is up to date.
make[2]: 'gmap' is up to date.
make[2]: 'gmk_hy' is up to date.
make[2]: 'gmk_m2' is up to date.
make[2]: 'gmk_m3' is up to date.
make[2]: 'gmk_msh' is up to date.
make[2]: 'gmk_ub2' is up to date.
make[2]: 'gmtst' is up to date.
make[2]: 'gord' is up to date.
make[2]: 'gotst' is up to date.
make[2]: 'gout' is up to date.
make[2]: 'gpart' is up to date.
make[2]: 'gscat' is up to date.
make[2]: 'gtst' is up to date.
make[2]: 'mcv' is up to date.
make[2]: 'mmk_m2' is up to date.
make[2]: 'mmk_m3' is up to date.
make[2]: 'mord' is up to date.
make[2]: 'mtst' is up to date.
/usr/bin/cp acpl amk_ccc amk_fft2 amk_grf amk_hy amk_m2 amk_p2 atst gbase gcv gmap gmk_hy gmk_m2 gmk_m3 gmk_msh gmk_ub2 gmtst gord gotst gout gpart *gtst gscat mcv mmk_m2 mmk_m3 mord mtst ../../bin
(cd libscotchmetis ; make scotch && make install)
make[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/libscotchmetis'
make CC="mpicc" SCOTCHLIB=ptscotch \
metis.h \
libscotchmetis.a
make[2]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/libscotchmetis'
../libscotch/dummysizes library_metis.h metis.h
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch -c metis_graph_order.c -o metis_graph_order.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch -c metis_graph_order_f.c -o metis_graph_order_f.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch -c metis_graph_part.c -o metis_graph_part.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch -c metis_graph_part_f.c -o metis_graph_part_f.o
/usr/bin/ar cr libscotchmetis.a metis_graph_order.o metis_graph_order_f.o metis_graph_part.o metis_graph_part_f.o
/usr/bin/ranlib libscotchmetis.a
make[2]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/libscotchmetis'
make[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/libscotchmetis'
metis.h \
libscotchmetis.a
make[2]: 'metis.h' is up to date.
make[2]: 'libscotchmetis.a' is up to date.
/usr/bin/cp metis.h ../../include
/usr/bin/cp libscotchmetis.a ../../lib
(cd libscotch ; make VERSION=6 RELEASE=0 PATCHLEVEL=6 ptscotch && make ptinstall)
make CC="mpicc" CCD="mpicc" \
scotch.h \
scotchf.h \
libscotch.a \
libscotcherr.a \
libscotcherrexit.a
make[2]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/libscotch'
make[2]: 'scotch.h' is up to date.
make[2]: 'scotchf.h' is up to date.
make[2]: 'libscotch.a' is up to date.
make[2]: 'libscotcherr.a' is up to date.
make[2]: 'libscotcherrexit.a' is up to date.
make CFLAGS="-fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH" CC="mpicc" \
ptscotch.h \
ptscotchf.h \
libptscotch.a \
libptscotcherr.a \
libptscotcherrexit.a
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6 dummysizes.c -o ptdummysizes -lz -lpthread -lm -lrt
./ptdummysizes "-s" library_pt.h ptscotch.h
./ptdummysizes "-s" library_pt_f.h ptscotchf.h
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c bdgraph.c -o bdgraph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c bdgraph_bipart_bd.c -o bdgraph_bipart_bd.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c bdgraph_bipart_df.c -o bdgraph_bipart_df.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c bdgraph_bipart_ex.c -o bdgraph_bipart_ex.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c bdgraph_bipart_ml.c -o bdgraph_bipart_ml.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c bdgraph_bipart_sq.c -o bdgraph_bipart_sq.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c bdgraph_bipart_st.c -o bdgraph_bipart_st.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c bdgraph_bipart_zr.c -o bdgraph_bipart_zr.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c bdgraph_check.c -o bdgraph_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c bdgraph_gather_all.c -o bdgraph_gather_all.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c bdgraph_store.c -o bdgraph_store.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c comm.c -o comm.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph.c -o dgraph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_allreduce.c -o dgraph_allreduce.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_band.c -o dgraph_band.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_build.c -o dgraph_build.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_build_grid3d.c -o dgraph_build_grid3d.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_build_hcub.c -o dgraph_build_hcub.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_check.c -o dgraph_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_coarsen.c -o dgraph_coarsen.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_fold.c -o dgraph_fold.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_fold_comm.c -o dgraph_fold_comm.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_fold_dup.c -o dgraph_fold_dup.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_gather.c -o dgraph_gather.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_gather_all.c -o dgraph_gather_all.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_ghst.c -o dgraph_ghst.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_halo.c -o dgraph_halo.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_induce.c -o dgraph_induce.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_io_load.c -o dgraph_io_load.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_io_save.c -o dgraph_io_save.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_match.c -o dgraph_match.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_match_sync_coll.c -o dgraph_match_sync_coll.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_match_sync_ptop.c -o dgraph_match_sync_ptop.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_match_check.c -o dgraph_match_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_redist.c -o dgraph_redist.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_scatter.c -o dgraph_scatter.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dgraph_view.c -o dgraph_view.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dmapping.c -o dmapping.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dmapping_io.c -o dmapping_io.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dorder.c -o dorder.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dorder_gather.c -o dorder_gather.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dorder_io.c -o dorder_io.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dorder_io_block.c -o dorder_io_block.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dorder_io_tree.c -o dorder_io_tree.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dorder_perm.c -o dorder_perm.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c dorder_tree_dist.c -o dorder_tree_dist.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c hdgraph.c -o hdgraph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c hdgraph_check.c -o hdgraph_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c hdgraph_fold.c -o hdgraph_fold.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c hdgraph_gather.c -o hdgraph_gather.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c hdgraph_induce.c -o hdgraph_induce.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c hdgraph_order_nd.c -o hdgraph_order_nd.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c hdgraph_order_si.c -o hdgraph_order_si.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c hdgraph_order_sq.c -o hdgraph_order_sq.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c hdgraph_order_st.c -o hdgraph_order_st.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c kdgraph.c -o kdgraph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c kdgraph_gather.c -o kdgraph_gather.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c kdgraph_map_rb.c -o kdgraph_map_rb.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c kdgraph_map_rb_map.c -o kdgraph_map_rb_map.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c kdgraph_map_rb_part.c -o kdgraph_map_rb_part.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c kdgraph_map_st.c -o kdgraph_map_st.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph.c -o library_dgraph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_f.c -o library_dgraph_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_band.c -o library_dgraph_band.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_band_f.c -o library_dgraph_band_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_build.c -o library_dgraph_build.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_build_f.c -o library_dgraph_build_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_build_grid3d.c -o library_dgraph_build_grid3d.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_build_grid3d_f.c -o library_dgraph_build_grid3d_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_check.c -o library_dgraph_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_check_f.c -o library_dgraph_check_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_coarsen.c -o library_dgraph_coarsen.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_coarsen_f.c -o library_dgraph_coarsen_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_gather.c -o library_dgraph_gather.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_gather_f.c -o library_dgraph_gather_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_grow.c -o library_dgraph_grow.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_halo.c -o library_dgraph_halo.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_halo_f.c -o library_dgraph_halo_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_induce.c -o library_dgraph_induce.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_induce_f.c -o library_dgraph_induce_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_io_load.c -o library_dgraph_io_load.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_io_load_f.c -o library_dgraph_io_load_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_io_save.c -o library_dgraph_io_save.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_io_save_f.c -o library_dgraph_io_save_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_map.c -o library_dgraph_map.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_map_f.c -o library_dgraph_map_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_map_view.c -o library_dgraph_map_view.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_map_view_f.c -o library_dgraph_map_view_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_order.c -o library_dgraph_order.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_order_f.c -o library_dgraph_order_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_order_gather.c -o library_dgraph_order_gather.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_order_gather_f.c -o library_dgraph_order_gather_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_order_io.c -o library_dgraph_order_io.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_order_io_f.c -o library_dgraph_order_io_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_order_io_block.c -o library_dgraph_order_io_block.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_order_io_block_f.c -o library_dgraph_order_io_block_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_order_perm.c -o library_dgraph_order_perm.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_order_perm_f.c -o library_dgraph_order_perm_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_order_tree_dist.c -o library_dgraph_order_tree_dist.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_order_tree_dist_f.c -o library_dgraph_order_tree_dist_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_redist.c -o library_dgraph_redist.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_redist_f.c -o library_dgraph_redist_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_scatter.c -o library_dgraph_scatter.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_scatter_f.c -o library_dgraph_scatter_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_stat.c -o library_dgraph_stat.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dgraph_stat_f.c -o library_dgraph_stat_f.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dmapping.c -o library_dmapping.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_dorder.c -o library_dorder.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c vdgraph.c -o vdgraph.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c vdgraph_check.c -o vdgraph_check.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c vdgraph_gather_all.c -o vdgraph_gather_all.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c vdgraph_separate_bd.c -o vdgraph_separate_bd.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c vdgraph_separate_df.c -o vdgraph_separate_df.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c vdgraph_separate_ml.c -o vdgraph_separate_ml.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c vdgraph_separate_sq.c -o vdgraph_separate_sq.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c vdgraph_separate_st.c -o vdgraph_separate_st.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c vdgraph_separate_zr.c -o vdgraph_separate_zr.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c vdgraph_store.c -o vdgraph_store.o -DSCOTCH_VERSION_NUM=6 -DSCOTCH_RELEASE_NUM=0 -DSCOTCH_PATCHLEVEL_NUM=6
/usr/bin/ar cr libptscotch.a bdgraph.o bdgraph_bipart_bd.o bdgraph_bipart_df.o bdgraph_bipart_ex.o bdgraph_bipart_ml.o bdgraph_bipart_sq.o bdgraph_bipart_st.o bdgraph_bipart_zr.o bdgraph_check.o bdgraph_gather_all.o bdgraph_store.o comm.o dgraph.o dgraph_allreduce.o dgraph_band.o dgraph_build.o dgraph_build_grid3d.o dgraph_build_hcub.o dgraph_check.o dgraph_coarsen.o dgraph_fold.o dgraph_fold_comm.o dgraph_fold_dup.o dgraph_gather.o dgraph_gather_all.o dgraph_ghst.o dgraph_halo.o dgraph_induce.o dgraph_io_load.o dgraph_io_save.o dgraph_match.o dgraph_match_sync_coll.o dgraph_match_sync_ptop.o dgraph_match_check.o dgraph_redist.o dgraph_scatter.o dgraph_view.o dmapping.o dmapping_io.o dorder.o dorder_gather.o dorder_io.o dorder_io_block.o dorder_io_tree.o dorder_perm.o dorder_tree_dist.o hdgraph.o hdgraph_check.o hdgraph_fold.o hdgraph_gather.o hdgraph_induce.o hdgraph_order_nd.o hdgraph_order_si.o hdgraph_order_sq.o hdgraph_order_st.o kdgraph.o kdgraph_gather.o kdgraph_map_rb.o kdgraph_map_rb_map.o kdgraph_map_rb_part.o kdgraph_map_st.o library_dgraph.o library_dgraph_f.o library_dgraph_band.o library_dgraph_band_f.o library_dgraph_build.o library_dgraph_build_f.o library_dgraph_build_grid3d.o library_dgraph_build_grid3d_f.o library_dgraph_check.o library_dgraph_check_f.o library_dgraph_coarsen.o library_dgraph_coarsen_f.o library_dgraph_gather.o library_dgraph_gather_f.o library_dgraph_grow.o library_dgraph_halo.o library_dgraph_halo_f.o library_dgraph_induce.o library_dgraph_induce_f.o library_dgraph_io_load.o library_dgraph_io_load_f.o library_dgraph_io_save.o library_dgraph_io_save_f.o library_dgraph_map.o library_dgraph_map_f.o library_dgraph_map_view.o library_dgraph_map_view_f.o library_dgraph_order.o library_dgraph_order_f.o library_dgraph_order_gather.o library_dgraph_order_gather_f.o library_dgraph_order_io.o library_dgraph_order_io_f.o library_dgraph_order_io_block.o library_dgraph_order_io_block_f.o library_dgraph_order_perm.o library_dgraph_order_perm_f.o library_dgraph_order_tree_dist.o library_dgraph_order_tree_dist_f.o library_dgraph_redist.o library_dgraph_redist_f.o library_dgraph_scatter.o library_dgraph_scatter_f.o library_dgraph_stat.o library_dgraph_stat_f.o library_dmapping.o library_dorder.o vdgraph.o vdgraph_check.o vdgraph_gather_all.o vdgraph_separate_bd.o vdgraph_separate_df.o vdgraph_separate_ml.o vdgraph_separate_sq.o vdgraph_separate_st.o vdgraph_separate_zr.o vdgraph_store.o
/usr/bin/ranlib libptscotch.a
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_error.c -o library_error_pt.o
/usr/bin/ar cr libptscotcherr.a library_error_pt.o
/usr/bin/ranlib libptscotcherr.a
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -c library_error_exit.c -o library_error_exit_pt.o
/usr/bin/ar cr libptscotcherrexit.a library_error_exit_pt.o
/usr/bin/ranlib libptscotcherrexit.a
/usr/bin/cp ptscotch.h ../../include
/usr/bin/cp ptscotchf.h ../../include
/usr/bin/cp libptscotch.a libptscotcherr*.a ../../lib
(cd scotch ; make VERSION=6 RELEASE=0 PATCHLEVEL=6 ptscotch && make ptinstall)
dggath \
dgmap \
dgord \
dgpart \
dgscat \
dgtst
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch dggath.c -o dggath -L../../lib -lptscotch -lscotch -lptscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch dgmap.c -o dgmap -L../../lib -lptscotch -lscotch -lptscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch dgord.c -o dgord -L../../lib -lptscotch -lscotch -lptscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch dgmap.c -DSCOTCH_COMPILE_PART -o dgpart -L../../lib -lptscotch -lscotch -lptscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch dgscat.c -o dgscat -L../../lib -lptscotch -lscotch -lptscotcherrexit -lz -lpthread -lm -lrt
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -I../libscotch dgtst.c -o dgtst -L../../lib -lptscotch -lscotch -lptscotcherrexit -lz -lpthread -lm -lrt
dggath \
dgmap \
dgord \
dgpart \
dgscat \
dgtst
make[2]: 'dggath' is up to date.
make[2]: 'dgmap' is up to date.
make[2]: 'dgord' is up to date.
make[2]: 'dgpart' is up to date.
make[2]: 'dgscat' is up to date.
make[2]: 'dgtst' is up to date.
/usr/bin/cp dggath dgmap dgord dgpart dgscat dgtst ../../bin
(cd libscotchmetis ; make ptscotch && make ptinstall)
make CFLAGS="-fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH" CC="mpicc" SCOTCHLIB=ptscotch \
parmetis.h \
libptscotchparmetis.a
../libscotch/dummysizes library_parmetis.h parmetis.h
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -I../../include -I../libscotch -c parmetis_dgraph_order.c -o parmetis_dgraph_order.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -I../../include -I../libscotch -c parmetis_dgraph_order_f.c -o parmetis_dgraph_order_f.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -I../../include -I../libscotch -c parmetis_dgraph_part.c -o parmetis_dgraph_part.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict= -DINTSIZE32 -DSCOTCH_METIS_PREFIX -DSCOTCH_PTSCOTCH -I../../include -I../libscotch -c parmetis_dgraph_part_f.c -o parmetis_dgraph_part_f.o
/usr/bin/ar cr libptscotchparmetis.a parmetis_dgraph_order.o parmetis_dgraph_order_f.o parmetis_dgraph_part.o parmetis_dgraph_part_f.o
/usr/bin/ranlib libptscotchparmetis.a
parmetis.h \
make[2]: 'parmetis.h' is up to date.
make[2]: 'libptscotchparmetis.a' is up to date.
/usr/bin/cp parmetis.h ../../include
/usr/bin/cp libptscotchparmetis.a ../../lib
(cd esmumps ; make ptscotch && make ptinstall)
make[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/esmumps'
rm -f *~ common.h *.o lib*.a main_esmumps
libesmumps.a \
main_esmumps
make[2]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/esmumps'
cat module.h ../libscotch/common.h > common.h
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -c graph_graph.c -o graph_graph.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -c order.c -o order.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -c order_scotch_graph.c -o order_scotch_graph.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -c dof.c -o dof.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -c symbol.c -o symbol.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -c symbol_fax_graph.c -o symbol_fax_graph.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -c esmumps.c -o esmumps.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -c esmumps_f.c -o esmumps_f.o
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include -c esmumps_strats.c -o esmumps_strats.o
/usr/bin/ar cr libesmumps.a graph_graph.o order.o order_scotch_graph.o dof.o symbol.o symbol_fax_graph.o esmumps.o esmumps_f.o esmumps_strats.o
/usr/bin/ranlib libesmumps.a
mpicc -fPIC -fstack-protector -g -O -fopenmp -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict="" -DINTSIZE32 -DSCOTCH_METIS_PREFIX -I../../include main_esmumps.c -o main_esmumps -L. -lesmumps -L../../lib -lscotch -lscotcherrexit -lz -lpthread -lm -lrt
make[2]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/esmumps'
make[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f/src/esmumps'
libesmumps.a \
main_esmumps
/usr/bin/cp esmumps.h ../../include
/usr/bin/cp libesmumps.a ../../lib/libptesmumps.a
(cd esmumps ; make scotch && make install)
libesmumps.a \
main_esmumps
libesmumps.a \
main_esmumps
Installing PTScotch; this may take several minutes
Executing: mkdir -p /home/wangzl/moose-compilers/petsc-3.11.4/include && mkdir -p /home/wangzl/moose-compilers/petsc-3.11.4/lib && cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-scotch-c15036faac5f && cp -f lib/*.a /home/wangzl/moose-compilers/petsc-3.11.4/lib/. && cp -f include/*.h /home/wangzl/moose-compilers/petsc-3.11.4/include/.
********Output of running make on PTSCOTCH follows *******
********End of Output of running make on PTSCOTCH *******
Checking for library in Download PTSCOTCH: ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libptesmumps.a', 'libptscotchparmetis.a', 'libptscotch.a', 'libptscotcherr.a', 'libesmumps.a', 'libscotch.a', 'libscotcherr.a']
Contents: ['include', 'lib', 'share']
TEST check from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:154)
TESTING: check from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:154)
Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
Checking for functions [SCOTCH_archBuild] in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libptesmumps.a', 'libptscotchparmetis.a', 'libptscotch.a', 'libptscotcherr.a', 'libesmumps.a', 'libscotch.a', 'libscotcherr.a'] ['libm.a']
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
char SCOTCH_archBuild();
static void _check_SCOTCH_archBuild() { SCOTCH_archBuild(); }
int main() {
_check_SCOTCH_archBuild();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.o -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -lptesmumps -lptscotchparmetis -lptscotch -lptscotcherr -lesmumps -lscotch -lscotcherr -lm -lrt -lm -lpthread -lz -lstdc++ -ldl
Defined "HAVE_LIBPTESMUMPS" to "1"
Defined "HAVE_LIBPTSCOTCHPARMETIS" to "1"
Defined "HAVE_LIBPTSCOTCH" to "1"
Defined "HAVE_LIBPTSCOTCHERR" to "1"
Defined "HAVE_LIBESMUMPS" to "1"
Defined "HAVE_LIBSCOTCH" to "1"
Defined "HAVE_LIBSCOTCHERR" to "1"
Checking for functions [SCOTCH_ParMETIS_V3_NodeND] in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libptesmumps.a', 'libptscotchparmetis.a', 'libptscotch.a', 'libptscotcherr.a', 'libesmumps.a', 'libscotch.a', 'libscotcherr.a'] ['libm.a']
Successful compile:
Source:
char SCOTCH_ParMETIS_V3_NodeND();
static void _check_SCOTCH_ParMETIS_V3_NodeND() { SCOTCH_ParMETIS_V3_NodeND(); }
int main() {
_check_SCOTCH_ParMETIS_V3_NodeND();;
return 0;
Defined "HAVE_SCOTCH_PARMETIS_V3_NODEND" to "1"
Checking for headers Download PTSCOTCH: ['/home/wangzl/moose-compilers/petsc-3.11.4/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
TEST checkInclude from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:86)
Checks if a particular include file can be found along particular include paths
Checking for header files ['ptscotch.h'] in ['/home/wangzl/moose-compilers/petsc-3.11.4/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Checking include with compiler flags var CPPFLAGS ['/home/wangzl/moose-compilers/petsc-3.11.4/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0 -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include /tmp/petsc-wjcu960y/config.headers/conftest.c
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Found header files ['ptscotch.h'] in ['/home/wangzl/moose-compilers/petsc-3.11.4/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
TEST checkSharedLibrary from config.packages.PTScotch(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TESTING: checkSharedLibrary from config.packages.PTScotch(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
By default we don't care about checking if the library is shared
TEST checkDependencies from config.packages.metis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TESTING: checkDependencies from config.packages.metis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TEST configureLibrary from config.packages.metis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/metis.py:47)
TESTING: configureLibrary from config.packages.metis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/metis.py:47)
Checking for a functional metis
Looking for METIS at git.metis, hg.metis or a directory starting with ['petsc-pkg-metis']
Could not locate an existing copy of METIS:
['git.slepc', 'petsc-pkg-scotch-c15036faac5f']
Downloading metis
Trying to download file:///home/wangzl/packages/petsc-pkg-metis-49e61501c498.tar.gz for METIS
Downloading file:///home/wangzl/packages/petsc-pkg-metis-49e61501c498.tar.gz to /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/_d_petsc-pkg-metis-49e61501c498.tar.gz
Extracting /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/_d_petsc-pkg-metis-49e61501c498.tar.gz
Executing: cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages; chmod -R a+r petsc-pkg-metis-49e61501c498;find petsc-pkg-metis-49e61501c498 -type d -name "*" -exec chmod a+rx {} \;
Found a copy of METIS in petsc-pkg-metis-49e61501c498
Have to rebuild METIS, /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/metis.petscconf != /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/lib/petsc/conf/pkg.conf.metis
Configuring METIS with cmake, this may take several minutes
Executing: /usr/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/home/wangzl/moose-compilers/petsc-3.11.4 -DCMAKE_VERBOSE_MAKEFILE=1 -DCMAKE_C_COMPILER="mpicc" -DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib -DCMAKE_C_FLAGS:STRING="-fPIC -fstack-protector -g -O -fopenmp" -DCMAKE_C_FLAGS_DEBUG:STRING="-fPIC -fstack-protector -g -O -fopenmp" -DCMAKE_C_FLAGS_RELEASE:STRING="-fPIC -fstack-protector -g -O -fopenmp" -DCMAKE_CXX_COMPILER="mpicxx" -DCMAKE_CXX_FLAGS:STRING="-fstack-protector -g -O -fopenmp -fPIC" -DCMAKE_CXX_FLAGS_DEBUG:STRING="-fstack-protector -g -O -fopenmp -fPIC" -DCMAKE_CXX_FLAGS_RELEASE:STRING="-fstack-protector -g -O -fopenmp -fPIC" -DCMAKE_Fortran_COMPILER="mpif90" -DCMAKE_Fortran_FLAGS:STRING="-fPIC -ffree-line-length-0 -g -O -fopenmp" -DCMAKE_Fortran_FLAGS_DEBUG:STRING="-fPIC -ffree-line-length-0 -g -O -fopenmp" -DCMAKE_Fortran_FLAGS_RELEASE:STRING="-fPIC -ffree-line-length-0 -g -O -fopenmp" -DBUILD_SHARED_LIBS=on -DGKLIB_PATH=../GKlib -DGKRAND=1 -DSHARED=1 -DMATH_LIB="-lm"
stdout:
-- The C compiler identification is GNU 7.5.0
-- Check for working C compiler: /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc
-- Check for working C compiler: /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc - works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Looking for execinfo.h
-- Looking for execinfo.h - found
-- Looking for getline
-- Looking for getline - found
-- Configuring done
-- Generating done
-- Build files have been written to: /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build
Compiling and installing METIS; this may take several minutes
Executing: /usr/bin/gmake -j16 -l30.0
stdout:
/usr/bin/cmake -S/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498 -B/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build --check-build-system CMakeFiles/Makefile.cmake 0
/usr/bin/cmake -E cmake_progress_start /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/CMakeFiles /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/CMakeFiles/progress.marks
/usr/bin/gmake -f CMakeFiles/Makefile2 all
gmake[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build'
/usr/bin/gmake -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/depend
gmake[2]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build'
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498 /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis/CMakeFiles/metis.dir/DependInfo.cmake --color=
Scanning dependencies of target metis
gmake[2]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build'
/usr/bin/gmake -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/build
[ 1%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/b64.c.o
[ 3%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/error.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/b64.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/b64.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/error.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/error.c
[ 6%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/fs.c.o
[ 6%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/blas.c.o
[ 9%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/csr.c.o
[ 9%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/gkregex.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/blas.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/blas.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/fs.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/fs.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/csr.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/csr.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/gkregex.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/gkregex.c
[ 12%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/evaluate.c.o
[ 12%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/getopt.c.o
[ 14%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/getopt.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/getopt.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/evaluate.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/evaluate.c
[ 16%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/itemsets.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/fkvkselect.c
[ 17%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/io.c.o
[ 19%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/memory.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/itemsets.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/itemsets.c
[ 22%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/htable.c.o
[ 22%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/omp.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/io.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/io.c
[ 24%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/graph.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/memory.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/memory.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/omp.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/omp.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/htable.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/htable.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/graph.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/graph.c
[ 25%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/mcore.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/mcore.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/mcore.c
[ 27%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/pdb.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/pdb.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pdb.c
[ 29%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/pqueue.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/pqueue.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c
[ 30%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/random.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/random.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/random.c
[ 32%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/rw.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/rw.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/rw.c
[ 33%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/seq.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/seq.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/seq.c
[ 35%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/sort.c.o
[ 37%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/string.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/sort.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/sort.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/string.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/string.c
[ 38%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/timers.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/timers.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/timers.c
[ 40%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/tokenizer.c
[ 41%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/util.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/util.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/util.c
[ 43%] Building C object libmetis/CMakeFiles/metis.dir/auxapi.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/auxapi.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/auxapi.c
[ 45%] Building C object libmetis/CMakeFiles/metis.dir/balance.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/balance.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/balance.c
[ 46%] Building C object libmetis/CMakeFiles/metis.dir/bucketsort.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/bucketsort.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/bucketsort.c
[ 48%] Building C object libmetis/CMakeFiles/metis.dir/checkgraph.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/checkgraph.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/checkgraph.c
[ 50%] Building C object libmetis/CMakeFiles/metis.dir/coarsen.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/coarsen.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/coarsen.c
[ 51%] Building C object libmetis/CMakeFiles/metis.dir/compress.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/compress.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/compress.c
[ 53%] Building C object libmetis/CMakeFiles/metis.dir/contig.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/contig.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/contig.c
[ 54%] Building C object libmetis/CMakeFiles/metis.dir/debug.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/debug.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c
[ 56%] Building C object libmetis/CMakeFiles/metis.dir/fm.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/fm.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/fm.c
[ 58%] Building C object libmetis/CMakeFiles/metis.dir/fortran.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/fortran.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/fortran.c
[ 59%] Building C object libmetis/CMakeFiles/metis.dir/frename.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/frename.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/frename.c
[ 61%] Building C object libmetis/CMakeFiles/metis.dir/gklib.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/gklib.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/gklib.c
[ 62%] Building C object libmetis/CMakeFiles/metis.dir/graph.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/graph.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/graph.c
[ 64%] Building C object libmetis/CMakeFiles/metis.dir/initpart.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/initpart.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/initpart.c
[ 66%] Building C object libmetis/CMakeFiles/metis.dir/kmetis.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/kmetis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kmetis.c
[ 67%] Building C object libmetis/CMakeFiles/metis.dir/kwayfm.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/kwayfm.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayfm.c
[ 69%] Building C object libmetis/CMakeFiles/metis.dir/kwayrefine.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/kwayrefine.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayrefine.c
[ 70%] Building C object libmetis/CMakeFiles/metis.dir/mcutil.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/mcutil.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/mcutil.c
[ 72%] Building C object libmetis/CMakeFiles/metis.dir/mesh.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/mesh.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/mesh.c
[ 74%] Building C object libmetis/CMakeFiles/metis.dir/meshpart.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/meshpart.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/meshpart.c
[ 75%] Building C object libmetis/CMakeFiles/metis.dir/minconn.c.o
[ 77%] Building C object libmetis/CMakeFiles/metis.dir/mincover.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/minconn.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/minconn.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/mincover.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/mincover.c
[ 79%] Building C object libmetis/CMakeFiles/metis.dir/mmd.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/mmd.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/mmd.c
[ 80%] Building C object libmetis/CMakeFiles/metis.dir/ometis.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/ometis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/ometis.c
[ 82%] Building C object libmetis/CMakeFiles/metis.dir/options.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/options.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/options.c
[ 83%] Building C object libmetis/CMakeFiles/metis.dir/parmetis.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/parmetis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/parmetis.c
[ 85%] Building C object libmetis/CMakeFiles/metis.dir/pmetis.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/pmetis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/pmetis.c
[ 87%] Building C object libmetis/CMakeFiles/metis.dir/refine.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/refine.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/refine.c
[ 88%] Building C object libmetis/CMakeFiles/metis.dir/separator.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/separator.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/separator.c
[ 90%] Building C object libmetis/CMakeFiles/metis.dir/sfm.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/sfm.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/sfm.c
[ 91%] Building C object libmetis/CMakeFiles/metis.dir/srefine.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/srefine.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/srefine.c
[ 93%] Building C object libmetis/CMakeFiles/metis.dir/stat.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/stat.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/stat.c
[ 95%] Building C object libmetis/CMakeFiles/metis.dir/timing.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/timing.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/timing.c
[ 96%] Building C object libmetis/CMakeFiles/metis.dir/util.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/util.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/util.c
[ 98%] Building C object libmetis/CMakeFiles/metis.dir/wspace.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/wspace.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/wspace.c
[100%] Linking C shared library libmetis.so
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /usr/bin/cmake -E cmake_link_script CMakeFiles/metis.dir/link.txt --verbose=1
/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -fPIC -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -shared -Wl,-soname,libmetis.so -o libmetis.so CMakeFiles/metis.dir/__/GKlib/b64.c.o CMakeFiles/metis.dir/__/GKlib/blas.c.o CMakeFiles/metis.dir/__/GKlib/csr.c.o CMakeFiles/metis.dir/__/GKlib/error.c.o CMakeFiles/metis.dir/__/GKlib/evaluate.c.o CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o CMakeFiles/metis.dir/__/GKlib/fs.c.o CMakeFiles/metis.dir/__/GKlib/getopt.c.o CMakeFiles/metis.dir/__/GKlib/gkregex.c.o CMakeFiles/metis.dir/__/GKlib/graph.c.o CMakeFiles/metis.dir/__/GKlib/htable.c.o CMakeFiles/metis.dir/__/GKlib/io.c.o CMakeFiles/metis.dir/__/GKlib/itemsets.c.o CMakeFiles/metis.dir/__/GKlib/mcore.c.o CMakeFiles/metis.dir/__/GKlib/memory.c.o CMakeFiles/metis.dir/__/GKlib/omp.c.o CMakeFiles/metis.dir/__/GKlib/pdb.c.o CMakeFiles/metis.dir/__/GKlib/pqueue.c.o CMakeFiles/metis.dir/__/GKlib/random.c.o CMakeFiles/metis.dir/__/GKlib/rw.c.o CMakeFiles/metis.dir/__/GKlib/seq.c.o CMakeFiles/metis.dir/__/GKlib/sort.c.o CMakeFiles/metis.dir/__/GKlib/string.c.o CMakeFiles/metis.dir/__/GKlib/timers.c.o CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o CMakeFiles/metis.dir/__/GKlib/util.c.o CMakeFiles/metis.dir/auxapi.c.o CMakeFiles/metis.dir/balance.c.o CMakeFiles/metis.dir/bucketsort.c.o CMakeFiles/metis.dir/checkgraph.c.o CMakeFiles/metis.dir/coarsen.c.o CMakeFiles/metis.dir/compress.c.o CMakeFiles/metis.dir/contig.c.o CMakeFiles/metis.dir/debug.c.o CMakeFiles/metis.dir/fm.c.o CMakeFiles/metis.dir/fortran.c.o CMakeFiles/metis.dir/frename.c.o CMakeFiles/metis.dir/gklib.c.o CMakeFiles/metis.dir/graph.c.o CMakeFiles/metis.dir/initpart.c.o CMakeFiles/metis.dir/kmetis.c.o CMakeFiles/metis.dir/kwayfm.c.o CMakeFiles/metis.dir/kwayrefine.c.o CMakeFiles/metis.dir/mcutil.c.o CMakeFiles/metis.dir/mesh.c.o CMakeFiles/metis.dir/meshpart.c.o CMakeFiles/metis.dir/minconn.c.o CMakeFiles/metis.dir/mincover.c.o CMakeFiles/metis.dir/mmd.c.o CMakeFiles/metis.dir/ometis.c.o CMakeFiles/metis.dir/options.c.o CMakeFiles/metis.dir/parmetis.c.o CMakeFiles/metis.dir/pmetis.c.o CMakeFiles/metis.dir/refine.c.o CMakeFiles/metis.dir/separator.c.o CMakeFiles/metis.dir/sfm.c.o CMakeFiles/metis.dir/srefine.c.o CMakeFiles/metis.dir/stat.c.o CMakeFiles/metis.dir/timing.c.o CMakeFiles/metis.dir/util.c.o CMakeFiles/metis.dir/wspace.c.o -lm
gmake[2]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build'
[100%] Built target metis
gmake[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build'
/usr/bin/cmake -E cmake_progress_start /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/CMakeFiles 0
Executing: /usr/bin/gmake install
stdout:
/usr/bin/cmake -S/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498 -B/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build --check-build-system CMakeFiles/Makefile.cmake 0
/usr/bin/cmake -E cmake_progress_start /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/CMakeFiles /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/CMakeFiles/progress.marks
/usr/bin/gmake -f CMakeFiles/Makefile2 all
gmake[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build'
/usr/bin/gmake -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/depend
gmake[2]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build'
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498 /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis/CMakeFiles/metis.dir/DependInfo.cmake --color=
/usr/bin/gmake -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/build
gmake[2]: Nothing to be done for 'libmetis/CMakeFiles/metis.dir/build'.
/usr/bin/gmake -f CMakeFiles/Makefile2 preinstall
gmake[1]: Nothing to be done for 'preinstall'.
Install the project...
/usr/bin/cmake -P cmake_install.cmake
-- Install configuration: ""
-- Installing: /home/wangzl/moose-compilers/petsc-3.11.4/include/metis.h
-- Installing: /home/wangzl/moose-compilers/petsc-3.11.4/include/gklib_tls.h
-- Installing: /home/wangzl/moose-compilers/petsc-3.11.4/lib/libmetis.so
-- Up-to-date: /home/wangzl/moose-compilers/petsc-3.11.4/include/gklib_defs.h
-- Up-to-date: /home/wangzl/moose-compilers/petsc-3.11.4/include/gklib_rename.h
********Output of running make on METIS follows *******
-- The C compiler identification is GNU 7.5.0
-- Check for working C compiler: /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc
-- Check for working C compiler: /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc - works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Looking for execinfo.h
-- Looking for execinfo.h - found
-- Looking for getline
-- Looking for getline - found
-- Configuring done
-- Generating done
-- Build files have been written to: /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-buildCMake Warning:
Manually-specified variables were not used by the project:
CMAKE_CXX_COMPILER
CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS_DEBUG
CMAKE_CXX_FLAGS_RELEASE
CMAKE_C_FLAGS_DEBUG
CMAKE_C_FLAGS_RELEASE
CMAKE_Fortran_COMPILER
CMAKE_Fortran_FLAGS
CMAKE_Fortran_FLAGS_DEBUG
CMAKE_Fortran_FLAGS_RELEASE
Scanning dependencies of target metis
[ 1%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/b64.c.o
[ 3%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/error.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/b64.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/b64.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/error.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/error.c
[ 6%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/fs.c.o
[ 6%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/blas.c.o
[ 9%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/csr.c.o
[ 9%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/gkregex.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/blas.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/blas.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/fs.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/fs.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/csr.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/csr.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/gkregex.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/gkregex.c
[ 12%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/evaluate.c.o
[ 12%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/getopt.c.o
[ 14%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/getopt.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/getopt.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/evaluate.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/evaluate.c
[ 16%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/itemsets.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/fkvkselect.c
[ 17%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/io.c.o
[ 19%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/memory.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/itemsets.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/itemsets.c
[ 22%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/htable.c.o
[ 22%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/omp.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/io.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/io.c
[ 24%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/graph.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/memory.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/memory.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/omp.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/omp.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/htable.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/htable.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/graph.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/graph.c
[ 25%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/mcore.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/mcore.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/mcore.c
[ 27%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/pdb.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/pdb.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pdb.c
[ 29%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/pqueue.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/pqueue.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c
[ 30%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/random.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/random.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/random.c
[ 32%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/rw.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/rw.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/rw.c
[ 33%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/seq.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/seq.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/seq.c
[ 35%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/sort.c.o
[ 37%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/string.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/sort.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/sort.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/string.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/string.c
[ 38%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/timers.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/timers.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/timers.c
[ 40%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/tokenizer.c
[ 41%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/util.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/__/GKlib/util.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/util.c
[ 43%] Building C object libmetis/CMakeFiles/metis.dir/auxapi.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/auxapi.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/auxapi.c
[ 45%] Building C object libmetis/CMakeFiles/metis.dir/balance.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/balance.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/balance.c
[ 46%] Building C object libmetis/CMakeFiles/metis.dir/bucketsort.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/bucketsort.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/bucketsort.c
[ 48%] Building C object libmetis/CMakeFiles/metis.dir/checkgraph.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/checkgraph.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/checkgraph.c
[ 50%] Building C object libmetis/CMakeFiles/metis.dir/coarsen.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/coarsen.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/coarsen.c
[ 51%] Building C object libmetis/CMakeFiles/metis.dir/compress.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/compress.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/compress.c
[ 53%] Building C object libmetis/CMakeFiles/metis.dir/contig.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/contig.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/contig.c
[ 54%] Building C object libmetis/CMakeFiles/metis.dir/debug.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/debug.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c
[ 56%] Building C object libmetis/CMakeFiles/metis.dir/fm.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/fm.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/fm.c
[ 58%] Building C object libmetis/CMakeFiles/metis.dir/fortran.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/fortran.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/fortran.c
[ 59%] Building C object libmetis/CMakeFiles/metis.dir/frename.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/frename.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/frename.c
[ 61%] Building C object libmetis/CMakeFiles/metis.dir/gklib.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/gklib.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/gklib.c
[ 62%] Building C object libmetis/CMakeFiles/metis.dir/graph.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/graph.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/graph.c
[ 64%] Building C object libmetis/CMakeFiles/metis.dir/initpart.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/initpart.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/initpart.c
[ 66%] Building C object libmetis/CMakeFiles/metis.dir/kmetis.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/kmetis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kmetis.c
[ 67%] Building C object libmetis/CMakeFiles/metis.dir/kwayfm.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/kwayfm.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayfm.c
[ 69%] Building C object libmetis/CMakeFiles/metis.dir/kwayrefine.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/kwayrefine.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayrefine.c
[ 70%] Building C object libmetis/CMakeFiles/metis.dir/mcutil.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/mcutil.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/mcutil.c
[ 72%] Building C object libmetis/CMakeFiles/metis.dir/mesh.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/mesh.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/mesh.c
[ 74%] Building C object libmetis/CMakeFiles/metis.dir/meshpart.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/meshpart.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/meshpart.c
[ 75%] Building C object libmetis/CMakeFiles/metis.dir/minconn.c.o
[ 77%] Building C object libmetis/CMakeFiles/metis.dir/mincover.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/minconn.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/minconn.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/mincover.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/mincover.c
[ 79%] Building C object libmetis/CMakeFiles/metis.dir/mmd.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/mmd.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/mmd.c
[ 80%] Building C object libmetis/CMakeFiles/metis.dir/ometis.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/ometis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/ometis.c
[ 82%] Building C object libmetis/CMakeFiles/metis.dir/options.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/options.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/options.c
[ 83%] Building C object libmetis/CMakeFiles/metis.dir/parmetis.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/parmetis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/parmetis.c
[ 85%] Building C object libmetis/CMakeFiles/metis.dir/pmetis.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/pmetis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/pmetis.c
[ 87%] Building C object libmetis/CMakeFiles/metis.dir/refine.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/refine.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/refine.c
[ 88%] Building C object libmetis/CMakeFiles/metis.dir/separator.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/separator.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/separator.c
[ 90%] Building C object libmetis/CMakeFiles/metis.dir/sfm.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/sfm.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/sfm.c
[ 91%] Building C object libmetis/CMakeFiles/metis.dir/srefine.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/srefine.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/srefine.c
[ 93%] Building C object libmetis/CMakeFiles/metis.dir/stat.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/stat.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/stat.c
[ 95%] Building C object libmetis/CMakeFiles/metis.dir/timing.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/timing.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/timing.c
[ 96%] Building C object libmetis/CMakeFiles/metis.dir/util.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/util.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/util.c
[ 98%] Building C object libmetis/CMakeFiles/metis.dir/wspace.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/. -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/include -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -fPIC -o CMakeFiles/metis.dir/wspace.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/wspace.c
[100%] Linking C shared library libmetis.so
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis && /usr/bin/cmake -E cmake_link_script CMakeFiles/metis.dir/link.txt --verbose=1
/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -fPIC -fPIC -fstack-protector -g -O -fopenmp -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -shared -Wl,-soname,libmetis.so -o libmetis.so CMakeFiles/metis.dir/__/GKlib/b64.c.o CMakeFiles/metis.dir/__/GKlib/blas.c.o CMakeFiles/metis.dir/__/GKlib/csr.c.o CMakeFiles/metis.dir/__/GKlib/error.c.o CMakeFiles/metis.dir/__/GKlib/evaluate.c.o CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o CMakeFiles/metis.dir/__/GKlib/fs.c.o CMakeFiles/metis.dir/__/GKlib/getopt.c.o CMakeFiles/metis.dir/__/GKlib/gkregex.c.o CMakeFiles/metis.dir/__/GKlib/graph.c.o CMakeFiles/metis.dir/__/GKlib/htable.c.o CMakeFiles/metis.dir/__/GKlib/io.c.o CMakeFiles/metis.dir/__/GKlib/itemsets.c.o CMakeFiles/metis.dir/__/GKlib/mcore.c.o CMakeFiles/metis.dir/__/GKlib/memory.c.o CMakeFiles/metis.dir/__/GKlib/omp.c.o CMakeFiles/metis.dir/__/GKlib/pdb.c.o CMakeFiles/metis.dir/__/GKlib/pqueue.c.o CMakeFiles/metis.dir/__/GKlib/random.c.o CMakeFiles/metis.dir/__/GKlib/rw.c.o CMakeFiles/metis.dir/__/GKlib/seq.c.o CMakeFiles/metis.dir/__/GKlib/sort.c.o CMakeFiles/metis.dir/__/GKlib/string.c.o CMakeFiles/metis.dir/__/GKlib/timers.c.o CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o CMakeFiles/metis.dir/__/GKlib/util.c.o CMakeFiles/metis.dir/auxapi.c.o CMakeFiles/metis.dir/balance.c.o CMakeFiles/metis.dir/bucketsort.c.o CMakeFiles/metis.dir/checkgraph.c.o CMakeFiles/metis.dir/coarsen.c.o CMakeFiles/metis.dir/compress.c.o CMakeFiles/metis.dir/contig.c.o CMakeFiles/metis.dir/debug.c.o CMakeFiles/metis.dir/fm.c.o CMakeFiles/metis.dir/fortran.c.o CMakeFiles/metis.dir/frename.c.o CMakeFiles/metis.dir/gklib.c.o CMakeFiles/metis.dir/graph.c.o CMakeFiles/metis.dir/initpart.c.o CMakeFiles/metis.dir/kmetis.c.o CMakeFiles/metis.dir/kwayfm.c.o CMakeFiles/metis.dir/kwayrefine.c.o CMakeFiles/metis.dir/mcutil.c.o CMakeFiles/metis.dir/mesh.c.o CMakeFiles/metis.dir/meshpart.c.o CMakeFiles/metis.dir/minconn.c.o CMakeFiles/metis.dir/mincover.c.o CMakeFiles/metis.dir/mmd.c.o CMakeFiles/metis.dir/ometis.c.o CMakeFiles/metis.dir/options.c.o CMakeFiles/metis.dir/parmetis.c.o CMakeFiles/metis.dir/pmetis.c.o CMakeFiles/metis.dir/refine.c.o CMakeFiles/metis.dir/separator.c.o CMakeFiles/metis.dir/sfm.c.o CMakeFiles/metis.dir/srefine.c.o CMakeFiles/metis.dir/stat.c.o CMakeFiles/metis.dir/timing.c.o CMakeFiles/metis.dir/util.c.o CMakeFiles/metis.dir/wspace.c.o -lm
gmake[2]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build'
[100%] Built target metis
gmake[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build'
/usr/bin/cmake -E cmake_progress_start /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/CMakeFiles 0/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/error.c: In function ���gk_strerror���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/error.c:183:3: warning: implicit declaration of function ���strerror_r���; did you mean ���strerror���? [-Wimplicit-function-declaration]
strerror_r(errnum, buf, 1024);
strerror
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/getopt.c: In function ���gk_getopt_internal���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/getopt.c:343:5: warning: this ���if��� clause does not guard... [-Wmisleading-indentation]
if (gk_optind == 0)
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/getopt.c:345:7: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ���if���
optstring = gk_getopt_initialize (argc, argv, optstring);
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/getopt.c:700:2: warning: this ���else��� clause does not guard... [-Wmisleading-indentation]
else
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/getopt.c:703:4: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ���else���
nextchar = NULL;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/csr.c: In function ���gk_csr_Normalize���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/csr.c:1344:9: warning: this ���if��� clause does not guard... [-Wmisleading-indentation]
else if (norm == 1)
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/csr.c:1346:11: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ���if���
for (j=ptr[i]; j<ptr[i+1]; j++)
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/csr.c:1371:9: warning: this ���if��� clause does not guard... [-Wmisleading-indentation]
else if (norm == 1)
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/csr.c:1373:11: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ���if���
In file included from /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/GKlib.h:74:0,
from /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c:12:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c: In function ���gk_ipqCheckHeap���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/gk_mkpqueue.h:386:8: warning: variable ���heap��� set but not used [-Wunused-but-set-variable]
KVT *heap;\
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c:19:1: note: in expansion of macro ���GK_MKPQUEUE���
GK_MKPQUEUE(gk_ipq, gk_ipq_t, gk_ikv_t, int, gk_idx_t, gk_ikvmalloc, INT_MAX, key_gt)
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c: In function ���gk_i32pqCheckHeap���:
KVT *heap;\
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c:20:1: note: in expansion of macro ���GK_MKPQUEUE���
GK_MKPQUEUE(gk_i32pq, gk_i32pq_t, gk_i32kv_t, int32_t, gk_idx_t, gk_i32kvmalloc, INT32_MAX, key_gt)
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c: In function ���gk_i64pqCheckHeap���:
KVT *heap;\
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c:21:1: note: in expansion of macro ���GK_MKPQUEUE���
GK_MKPQUEUE(gk_i64pq, gk_i64pq_t, gk_i64kv_t, int64_t, gk_idx_t, gk_i64kvmalloc, INT64_MAX, key_gt)
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c: In function ���gk_fpqCheckHeap���:
KVT *heap;\
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c:22:1: note: in expansion of macro ���GK_MKPQUEUE���
GK_MKPQUEUE(gk_fpq, gk_fpq_t, gk_fkv_t, float, gk_idx_t, gk_fkvmalloc, FLT_MAX, key_gt)
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c: In function ���gk_dpqCheckHeap���:
KVT *heap;\
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c:23:1: note: in expansion of macro ���GK_MKPQUEUE���
GK_MKPQUEUE(gk_dpq, gk_dpq_t, gk_dkv_t, double, gk_idx_t, gk_dkvmalloc, DBL_MAX, key_gt)
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c: In function ���gk_idxpqCheckHeap���:
KVT *heap;\
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/GKlib/pqueue.c:24:1: note: in expansion of macro ���GK_MKPQUEUE���
GK_MKPQUEUE(gk_idxpq, gk_idxpq_t, gk_idxkv_t, gk_idx_t, gk_idx_t, gk_idxkvmalloc, GK_IDX_MAX, key_gt)
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/coarsen.c: In function ���libmetis__Match_RM���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/coarsen.c:152:33: warning: variable ���adjwgt��� set but not used [-Wunused-but-set-variable]
idx_t *xadj, *vwgt, *adjncy, *adjwgt, *maxvwgt;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/contig.c: In function ���libmetis__EliminateComponents���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/contig.c:345:11: warning: variable ���tpwgts��� set but not used [-Wunused-but-set-variable]
real_t *tpwgts;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c: In function ���libmetis__CheckBnd���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c:124:43: warning: variable ���bndind��� set but not used [-Wunused-but-set-variable]
idx_t *xadj, *adjncy, *where, *bndptr, *bndind;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c:124:34: warning: variable ���bndptr��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c: In function ���libmetis__CheckBnd2���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c:161:43: warning: variable ���bndind��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c:161:34: warning: variable ���bndptr��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c: In function ���libmetis__CheckNodeBnd���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c:198:43: warning: variable ���bndind��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c:198:34: warning: variable ���bndptr��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c:198:17: warning: variable ���adjncy��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c:198:10: warning: variable ���xadj��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/contig.c: In function ���libmetis__MoveGroupContigForCut���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c: In function ���libmetis__CheckRInfo���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c:235:11: warning: variable ���nbrs��� set but not used [-Wunused-but-set-variable]
cnbr_t *nbrs;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/contig.c:534:34: warning: variable ���nvtxs��� set but not used [-Wunused-but-set-variable]
idx_t i, ii, iii, j, jj, k, l, nvtxs, nbnd, from, me;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c: In function ���libmetis__CheckNodePartitionParams���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c:258:26: warning: variable ���adjwgt��� set but not used [-Wunused-but-set-variable]
idx_t *xadj, *adjncy, *adjwgt, *vwgt, *where;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c: In function ���libmetis__IsSeparable���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c:312:17: warning: variable ���adjncy��� set but not used [-Wunused-but-set-variable]
idx_t *xadj, *adjncy, *where;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/debug.c:311:22: warning: variable ���other��� set but not used [-Wunused-but-set-variable]
idx_t i, j, nvtxs, other;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/contig.c: In function ���libmetis__MoveGroupContigForVol���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/contig.c:605:34: warning: variable ���nvtxs��� set but not used [-Wunused-but-set-variable]
idx_t i, ii, iii, j, jj, k, l, nvtxs, from, me, other, xgain;
from /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/metislib.h:17,
from /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/gklib.c:12:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/gklib.c: In function ���libmetis__ipqCheckHeap���:
KVT *heap;\
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/gklib.c:33:1: note: in expansion of macro ���GK_MKPQUEUE���
GK_MKPQUEUE(ipq, ipq_t, ikv_t, idx_t, idx_t, ikvmalloc, IDX_MAX, key_gt)
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/gklib.c: In function ���libmetis__rpqCheckHeap���:
KVT *heap;\
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/gklib.c:34:1: note: in expansion of macro ���GK_MKPQUEUE���
GK_MKPQUEUE(rpq, rpq_t, rkv_t, real_t, idx_t, rkvmalloc, REAL_MAX, key_gt)
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/initpart.c: In function ���libmetis__RandomBisection���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/initpart.c:119:33: warning: variable ���adjwgt��� set but not used [-Wunused-but-set-variable]
idx_t *xadj, *vwgt, *adjncy, *adjwgt, *where;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/initpart.c:119:24: warning: variable ���adjncy��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/initpart.c:119:10: warning: variable ���xadj��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/initpart.c: In function ���libmetis__GrowBisection���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/initpart.c:195:33: warning: variable ���adjwgt��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/initpart.c: In function ���libmetis__GrowBisectionNode���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/initpart.c:438:33: warning: variable ���adjwgt��� set but not used [-Wunused-but-set-variable]
idx_t *xadj, *vwgt, *adjncy, *adjwgt, *where, *bndind;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayfm.c: In function ���libmetis__Greedy_KWayCutOptimize���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayfm.c:69:74: warning: variable ���adwgts��� set but not used [-Wunused-but-set-variable]
idx_t maxndoms, *safetos=NULL, *nads=NULL, *doms=NULL, **adids=NULL, **adwgts=NULL;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayfm.c: In function ���libmetis__Greedy_KWayVolOptimize���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayfm.c:379:74: warning: variable ���adwgts��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayfm.c:377:33: warning: variable ���bndptr��� set but not used [-Wunused-but-set-variable]
idx_t *where, *pwgts, *perm, *bndptr, *bndind, *minwgt, *maxwgt, *itpwgts;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayrefine.c: In function ���libmetis__ComputeKWayVolGains���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayrefine.c:565:34: warning: variable ���adjwgt��� set but not used [-Wunused-but-set-variable]
idx_t *xadj, *vsize, *adjncy, *adjwgt, *where,
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayfm.c: In function ���libmetis__Greedy_McKWayCutOptimize���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayfm.c:693:74: warning: variable ���adwgts��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayfm.c: In function ���libmetis__Greedy_McKWayVolOptimize���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayfm.c:1035:74: warning: variable ���adwgts��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/kwayfm.c:1033:33: warning: variable ���bndptr��� set but not used [-Wunused-but-set-variable]
idx_t *where, *pwgts, *perm, *bndptr, *bndind, *minwgt, *maxwgt;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/minconn.c: In function ���libmetis__ComputeSubDomainGraph���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/minconn.c:21:26: warning: variable ���adjwgt��� set but not used [-Wunused-but-set-variable]
idx_t *xadj, *adjncy, *adjwgt, *where;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/minconn.c:21:17: warning: variable ���adjncy��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/minconn.c:21:10: warning: variable ���xadj��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/minconn.c: In function ���libmetis__MoveGroupMinConnForCut���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/minconn.c:480:29: warning: variable ���nvtxs��� set but not used [-Wunused-but-set-variable]
idx_t i, ii, j, jj, k, l, nvtxs, nbnd, from, me;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/minconn.c: In function ���libmetis__MoveGroupMinConnForVol���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/minconn.c:564:29: warning: variable ���nvtxs��� set but not used [-Wunused-but-set-variable]
idx_t i, ii, j, jj, k, l, nvtxs, from, me, other, xgain, ewgt;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/ometis.c: In function ���libmetis__MlevelNestedDissection���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/ometis.c:186:15: warning: variable ���nvtxs��� set but not used [-Wunused-but-set-variable]
idx_t i, j, nvtxs, nbnd;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/ometis.c: In function ���libmetis__SplitGraphOrder���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/ometis.c:426:33: warning: variable ���adjwgt��� set but not used [-Wunused-but-set-variable]
idx_t *xadj, *vwgt, *adjncy, *adjwgt, *label, *where, *bndptr, *bndind;
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/ometis.c: In function ���libmetis__SplitGraphOrderCC���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/ometis.c:556:33: warning: variable ���adjwgt��� set but not used [-Wunused-but-set-variable]
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/separator.c: In function ���libmetis__ConstructMinCoverSeparator���:
/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis/separator.c:73:27: warning: variable ���bndptr��� set but not used [-Wunused-but-set-variable]
idx_t *where, *bndind, *bndptr, *vmap, *ivmap, *cover;
/usr/bin/cmake -S/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498 -B/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build --check-build-system CMakeFiles/Makefile.cmake 0
/usr/bin/cmake -E cmake_progress_start /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/CMakeFiles /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/CMakeFiles/progress.marks
/usr/bin/gmake -f CMakeFiles/Makefile2 all
gmake[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build'
/usr/bin/gmake -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/depend
gmake[2]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build'
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498 /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/libmetis /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-metis-49e61501c498/petsc-build/libmetis/CMakeFiles/metis.dir/DependInfo.cmake --color=
/usr/bin/gmake -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/build
gmake[2]: Nothing to be done for 'libmetis/CMakeFiles/metis.dir/build'.
/usr/bin/gmake -f CMakeFiles/Makefile2 preinstall
gmake[1]: Nothing to be done for 'preinstall'.
Install the project...
/usr/bin/cmake -P cmake_install.cmake
-- Install configuration: ""
-- Installing: /home/wangzl/moose-compilers/petsc-3.11.4/include/metis.h
-- Installing: /home/wangzl/moose-compilers/petsc-3.11.4/include/gklib_tls.h
-- Installing: /home/wangzl/moose-compilers/petsc-3.11.4/lib/libmetis.so
-- Up-to-date: /home/wangzl/moose-compilers/petsc-3.11.4/include/gklib_defs.h
-- Up-to-date: /home/wangzl/moose-compilers/petsc-3.11.4/include/gklib_rename.h********End of Output of running make on METIS *******
Checking for library in Download METIS: ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libmetis.a']
Contents: ['include', 'lib', 'share']
TEST check from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:154)
TESTING: check from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:154)
Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
Checking for functions [METIS_PartGraphKway] in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libmetis.a'] ['libm.a']
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
char METIS_PartGraphKway();
static void _check_METIS_PartGraphKway() { METIS_PartGraphKway(); }
int main() {
_check_METIS_PartGraphKway();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.o -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -lmetis -lm -lrt -lm -lpthread -lz -lstdc++ -ldl
Defined "HAVE_LIBMETIS" to "1"
No functions to check for in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libmetis.a'] ['libm.a']
Checking for headers Download METIS: ['/home/wangzl/moose-compilers/petsc-3.11.4/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
TEST checkInclude from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/headers.py:86)
Checks if a particular include file can be found along particular include paths
Checking for header files ['metis.h'] in ['/home/wangzl/moose-compilers/petsc-3.11.4/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Checking include with compiler flags var CPPFLAGS ['/home/wangzl/moose-compilers/petsc-3.11.4/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0 -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include /tmp/petsc-wjcu960y/config.headers/conftest.c
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Found header files ['metis.h'] in ['/home/wangzl/moose-compilers/petsc-3.11.4/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
All intermediate test results are stored in /tmp/petsc-wjcu960y/config.packages.metis
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.packages.metis/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.packages.metis -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp -I/home/wangzl/moose-compilers/petsc-3.11.4/include /tmp/petsc-wjcu960y/config.packages.metis/conftest.c
Possible ERROR while running compiler:
stderr:
/tmp/petsc-wjcu960y/config.packages.metis/conftest.c: In function ���main���:
/tmp/petsc-wjcu960y/config.packages.metis/conftest.c:8:7: warning: extra tokens at end of #endif directive [-Wendif-labels]
#endif;
Source:
#include "metis.h"
int main() {
#if (IDXTYPEWIDTH != 32)
#error incompatible IDXTYPEWIDTH
#endif;
return 0;
TEST checkSharedLibrary from config.packages.metis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TESTING: checkSharedLibrary from config.packages.metis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
By default we don't care about checking if the library is shared
TEST alternateConfigureLibrary from config.packages.pragmatic(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.pragmatic(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
Called if --with-packagename=0; does nothing by default
TEST checkDependencies from config.packages.parmetis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TESTING: checkDependencies from config.packages.parmetis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TEST configureLibrary from config.packages.parmetis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/parmetis.py:39)
TESTING: configureLibrary from config.packages.parmetis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/parmetis.py:39)
Checking for a functional parmetis
Looking for PARMETIS at git.parmetis, hg.parmetis or a directory starting with ['petsc-pkg-parmetis']
Could not locate an existing copy of PARMETIS:
['git.slepc', 'petsc-pkg-scotch-c15036faac5f', 'petsc-pkg-metis-49e61501c498']
Downloading parmetis
Trying to download file:///home/wangzl/packages/petsc-pkg-parmetis-73dab469aa36.tar.gz for PARMETIS
Downloading file:///home/wangzl/packages/petsc-pkg-parmetis-73dab469aa36.tar.gz to /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/_d_petsc-pkg-parmetis-73dab469aa36.tar.gz
Extracting /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/_d_petsc-pkg-parmetis-73dab469aa36.tar.gz
Executing: cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages; chmod -R a+r petsc-pkg-parmetis-73dab469aa36;find petsc-pkg-parmetis-73dab469aa36 -type d -name "*" -exec chmod a+rx {} \;
Found a copy of PARMETIS in petsc-pkg-parmetis-73dab469aa36
Have to rebuild PARMETIS, /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/parmetis.petscconf != /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/lib/petsc/conf/pkg.conf.parmetis
Configuring PARMETIS with cmake, this may take several minutes
Executing: /usr/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/home/wangzl/moose-compilers/petsc-3.11.4 -DCMAKE_VERBOSE_MAKEFILE=1 -DCMAKE_C_COMPILER="mpicc" -DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib -DCMAKE_C_FLAGS:STRING="-fPIC -fstack-protector -g -O -fopenmp" -DCMAKE_C_FLAGS_DEBUG:STRING="-fPIC -fstack-protector -g -O -fopenmp" -DCMAKE_C_FLAGS_RELEASE:STRING="-fPIC -fstack-protector -g -O -fopenmp" -DCMAKE_CXX_COMPILER="mpicxx" -DCMAKE_CXX_FLAGS:STRING="-fstack-protector -g -O -fopenmp -fPIC" -DCMAKE_CXX_FLAGS_DEBUG:STRING="-fstack-protector -g -O -fopenmp -fPIC" -DCMAKE_CXX_FLAGS_RELEASE:STRING="-fstack-protector -g -O -fopenmp -fPIC" -DCMAKE_Fortran_COMPILER="mpif90" -DCMAKE_Fortran_FLAGS:STRING="-fPIC -ffree-line-length-0 -g -O -fopenmp" -DCMAKE_Fortran_FLAGS_DEBUG:STRING="-fPIC -ffree-line-length-0 -g -O -fopenmp" -DCMAKE_Fortran_FLAGS_RELEASE:STRING="-fPIC -ffree-line-length-0 -g -O -fopenmp" -DBUILD_SHARED_LIBS=on -DGKLIB_PATH=../headers -DMETIS_PATH=/home/wangzl/moose-compilers/petsc-3.11.4 -DSHARED=1 -DCMAKE_INSTALL_RPATH_USE_LINK_PATH:BOOL=ON
stdout:
-- The C compiler identification is GNU 7.5.0
-- Check for working C compiler: /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc
-- Check for working C compiler: /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc - works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Configuring done
-- Generating done
-- Build files have been written to: /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build
Compiling and installing PARMETIS; this may take several minutes
Executing: /usr/bin/gmake -j16 -l30.0
stdout:
/usr/bin/cmake -S/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36 -B/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build --check-build-system CMakeFiles/Makefile.cmake 0
/usr/bin/cmake -E cmake_progress_start /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/CMakeFiles /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/CMakeFiles/progress.marks
gmake[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build'
/usr/bin/gmake -f libparmetis/CMakeFiles/parmetis.dir/build.make libparmetis/CMakeFiles/parmetis.dir/depend
gmake[2]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build'
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36 /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis/CMakeFiles/parmetis.dir/DependInfo.cmake --color=
Scanning dependencies of target parmetis
gmake[2]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build'
/usr/bin/gmake -f libparmetis/CMakeFiles/parmetis.dir/build.make libparmetis/CMakeFiles/parmetis.dir/build
[ 7%] Building C object libparmetis/CMakeFiles/parmetis.dir/akwayfm.c.o
[ 7%] Building C object libparmetis/CMakeFiles/parmetis.dir/ComputeVertexSeparator.c.o
[ 9%] Building C object libparmetis/CMakeFiles/parmetis.dir/balancemylink.c.o
[ 9%] Building C object libparmetis/CMakeFiles/parmetis.dir/comm.c.o
[ 12%] Building C object libparmetis/CMakeFiles/parmetis.dir/ctrl.c.o
[ 14%] Building C object libparmetis/CMakeFiles/parmetis.dir/ametis.c.o
[ 17%] Building C object libparmetis/CMakeFiles/parmetis.dir/debug.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/ComputeVertexSeparator.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/ComputeVertexSeparator.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/akwayfm.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/akwayfm.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/balancemylink.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/balancemylink.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/comm.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/comm.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/ctrl.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/ctrl.c
[ 19%] Building C object libparmetis/CMakeFiles/parmetis.dir/csrmatch.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/ametis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/ametis.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/debug.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/debug.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/csrmatch.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/csrmatch.c
[ 31%] Building C object libparmetis/CMakeFiles/parmetis.dir/gkmetis.c.o
[ 31%] Building C object libparmetis/CMakeFiles/parmetis.dir/initmsection.c.o
[ 31%] Building C object libparmetis/CMakeFiles/parmetis.dir/graph.c.o
[ 31%] Building C object libparmetis/CMakeFiles/parmetis.dir/initbalance.c.o
[ 31%] Building C object libparmetis/CMakeFiles/parmetis.dir/initpart.c.o
[ 34%] Building C object libparmetis/CMakeFiles/parmetis.dir/frename.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/graph.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/graph.c
[ 36%] Building C object libparmetis/CMakeFiles/parmetis.dir/diffutil.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/gkmetis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/gkmetis.c
[ 39%] Building C object libparmetis/CMakeFiles/parmetis.dir/gkmpi.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/initbalance.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/initbalance.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/frename.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/frename.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/initmsection.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/initmsection.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/initpart.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/initpart.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/diffutil.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/diffutil.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/gkmpi.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/gkmpi.c
[ 41%] Building C object libparmetis/CMakeFiles/parmetis.dir/kmetis.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/kmetis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/kmetis.c
[ 43%] Building C object libparmetis/CMakeFiles/parmetis.dir/kwayrefine.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/kwayrefine.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/kwayrefine.c
[ 46%] Building C object libparmetis/CMakeFiles/parmetis.dir/match.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/match.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/match.c
[ 48%] Building C object libparmetis/CMakeFiles/parmetis.dir/mdiffusion.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/mdiffusion.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/mdiffusion.c
[ 51%] Building C object libparmetis/CMakeFiles/parmetis.dir/mesh.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/mesh.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/mesh.c
[ 53%] Building C object libparmetis/CMakeFiles/parmetis.dir/mmetis.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/mmetis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/mmetis.c
[ 56%] Building C object libparmetis/CMakeFiles/parmetis.dir/move.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/move.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/move.c
[ 58%] Building C object libparmetis/CMakeFiles/parmetis.dir/msetup.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/msetup.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/msetup.c
[ 60%] Building C object libparmetis/CMakeFiles/parmetis.dir/node_refine.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/node_refine.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/node_refine.c
[ 63%] Building C object libparmetis/CMakeFiles/parmetis.dir/ometis.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/ometis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/ometis.c
[ 65%] Building C object libparmetis/CMakeFiles/parmetis.dir/pspases.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/pspases.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/pspases.c
[ 68%] Building C object libparmetis/CMakeFiles/parmetis.dir/redomylink.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/redomylink.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/redomylink.c
[ 70%] Building C object libparmetis/CMakeFiles/parmetis.dir/remap.c.o
[ 73%] Building C object libparmetis/CMakeFiles/parmetis.dir/renumber.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/remap.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/remap.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/renumber.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/renumber.c
[ 75%] Building C object libparmetis/CMakeFiles/parmetis.dir/rmetis.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/rmetis.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/rmetis.c
[ 78%] Building C object libparmetis/CMakeFiles/parmetis.dir/selectq.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/selectq.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/selectq.c
[ 80%] Building C object libparmetis/CMakeFiles/parmetis.dir/serial.c.o
[ 82%] Building C object libparmetis/CMakeFiles/parmetis.dir/stat.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/serial.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/serial.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/stat.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/stat.c
[ 85%] Building C object libparmetis/CMakeFiles/parmetis.dir/timer.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/timer.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/timer.c
[ 87%] Building C object libparmetis/CMakeFiles/parmetis.dir/util.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/util.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/util.c
[ 92%] Building C object libparmetis/CMakeFiles/parmetis.dir/wave.c.o
[ 92%] Building C object libparmetis/CMakeFiles/parmetis.dir/weird.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/weird.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/weird.c
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/wave.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/wave.c
[ 95%] Building C object libparmetis/CMakeFiles/parmetis.dir/wspace.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/wspace.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/wspace.c
[ 97%] Building C object libparmetis/CMakeFiles/parmetis.dir/xyzpart.c.o
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -Dparmetis_EXPORTS -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/. -fPIC -fstack-protector -g -O -fopenmp -fPIC -o CMakeFiles/parmetis.dir/xyzpart.c.o -c /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/libparmetis/xyzpart.c
[100%] Linking C shared library libparmetis.so
cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/libparmetis && /usr/bin/cmake -E cmake_link_script CMakeFiles/parmetis.dir/link.txt --verbose=1
/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpicc -fPIC -fPIC -fstack-protector -g -O -fopenmp -shared -Wl,-soname,libparmetis.so -o libparmetis.so CMakeFiles/parmetis.dir/ComputeVertexSeparator.c.o CMakeFiles/parmetis.dir/akwayfm.c.o CMakeFiles/parmetis.dir/ametis.c.o CMakeFiles/parmetis.dir/balancemylink.c.o CMakeFiles/parmetis.dir/comm.c.o CMakeFiles/parmetis.dir/csrmatch.c.o CMakeFiles/parmetis.dir/ctrl.c.o CMakeFiles/parmetis.dir/debug.c.o CMakeFiles/parmetis.dir/diffutil.c.o CMakeFiles/parmetis.dir/frename.c.o CMakeFiles/parmetis.dir/gkmetis.c.o CMakeFiles/parmetis.dir/gkmpi.c.o CMakeFiles/parmetis.dir/graph.c.o CMakeFiles/parmetis.dir/initbalance.c.o CMakeFiles/parmetis.dir/initmsection.c.o CMakeFiles/parmetis.dir/initpart.c.o CMakeFiles/parmetis.dir/kmetis.c.o CMakeFiles/parmetis.dir/kwayrefine.c.o CMakeFiles/parmetis.dir/match.c.o CMakeFiles/parmetis.dir/mdiffusion.c.o CMakeFiles/parmetis.dir/mesh.c.o CMakeFiles/parmetis.dir/mmetis.c.o CMakeFiles/parmetis.dir/move.c.o CMakeFiles/parmetis.dir/msetup.c.o CMakeFiles/parmetis.dir/node_refine.c.o CMakeFiles/parmetis.dir/ometis.c.o CMakeFiles/parmetis.dir/pspases.c.o CMakeFiles/parmetis.dir/redomylink.c.o CMakeFiles/parmetis.dir/remap.c.o CMakeFiles/parmetis.dir/renumber.c.o CMakeFiles/parmetis.dir/rmetis.c.o CMakeFiles/parmetis.dir/selectq.c.o CMakeFiles/parmetis.dir/serial.c.o CMakeFiles/parmetis.dir/stat.c.o CMakeFiles/parmetis.dir/timer.c.o CMakeFiles/parmetis.dir/util.c.o CMakeFiles/parmetis.dir/wave.c.o CMakeFiles/parmetis.dir/weird.c.o CMakeFiles/parmetis.dir/wspace.c.o CMakeFiles/parmetis.dir/xyzpart.c.o -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib: -lmetis
[100%] Built target parmetis
gmake[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build'
/usr/bin/cmake -E cmake_progress_start /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/CMakeFiles 0
Executing: /usr/bin/gmake install
stdout:
gmake[2]: Nothing to be done for 'libparmetis/CMakeFiles/parmetis.dir/build'.
-- Up-to-date: /home/wangzl/moose-compilers/petsc-3.11.4/include/parmetis.h
-- Installing: /home/wangzl/moose-compilers/petsc-3.11.4/lib/libparmetis.so
-- Set runtime path of "/home/wangzl/moose-compilers/petsc-3.11.4/lib/libparmetis.so" to "/home/wangzl/moose-compilers/petsc-3.11.4/lib"
********Output of running make on PARMETIS follows *******
-- Configuring done
-- Generating done
-- Build files have been written to: /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-buildCMake Warning:
Manually-specified variables were not used by the project:
CMAKE_CXX_COMPILER
CMAKE_CXX_FLAGS
CMAKE_C_FLAGS_DEBUG
CMAKE_Fortran_FLAGS
/usr/bin/cmake -E cmake_progress_start /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build/CMakeFiles 0/usr/bin/cmake -S/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36 -B/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/petsc-pkg-parmetis-73dab469aa36/petsc-build --check-build-system CMakeFiles/Makefile.cmake 0
-- Set runtime path of "/home/wangzl/moose-compilers/petsc-3.11.4/lib/libparmetis.so" to "/home/wangzl/moose-compilers/petsc-3.11.4/lib"********End of Output of running make on PARMETIS *******
Checking for library in Download PARMETIS: ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libparmetis.a']
Checking for functions [ParMETIS_V3_PartKway] in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libparmetis.a'] ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libmetis.a', 'libm.a']
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.packages.metis -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.c
Successful compile:
Source:
char ParMETIS_V3_PartKway();
static void _check_ParMETIS_V3_PartKway() { ParMETIS_V3_PartKway(); }
int main() {
_check_ParMETIS_V3_PartKway();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.o -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -lparmetis -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -lmetis -lm -lrt -lm -lpthread -lz -lstdc++ -ldl
Defined "HAVE_LIBPARMETIS" to "1"
No functions to check for in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libparmetis.a'] ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libmetis.a', 'libm.a']
Checking for headers Download PARMETIS: ['/home/wangzl/moose-compilers/petsc-3.11.4/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Checking for header files ['parmetis.h'] in ['/home/wangzl/moose-compilers/petsc-3.11.4/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Checking include with compiler flags var CPPFLAGS ['/home/wangzl/moose-compilers/petsc-3.11.4/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include', '/home/wangzl/moose-compilers/petsc-3.11.4/include']
Executing: mpicc -E -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.headers -I/home/wangzl/moose-compilers/petsc-3.11.4/include -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0 -I/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include -I/home/wangzl/moose-compilers/petsc-3.11.4/include /tmp/petsc-wjcu960y/config.headers/conftest.c
Found header files ['parmetis.h'] in ['/home/wangzl/moose-compilers/petsc-3.11.4/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
Checking for functions [ParMETIS_ComputeVertexSeparator] in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libparmetis.a'] ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libmetis.a', 'libm.a']
Successful compile:
Source:
char ParMETIS_ComputeVertexSeparator();
static void _check_ParMETIS_ComputeVertexSeparator() { ParMETIS_ComputeVertexSeparator(); }
int main() {
_check_ParMETIS_ComputeVertexSeparator();;
return 0;
TEST checkSharedLibrary from config.packages.parmetis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TESTING: checkSharedLibrary from config.packages.parmetis(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TEST alternateConfigureLibrary from config.packages.Zoltan(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.Zoltan(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.Chaco(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.Chaco(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.hdf5(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.hdf5(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.med(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.med(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.cgns(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.cgns(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.ascem-io(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.ascem-io(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.pflotran(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.pflotran(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.alquimia(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.alquimia(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.SAMRAI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.SAMRAI(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.ADIOS2(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.ADIOS2(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.pnetcdf(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.pnetcdf(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.netcdf(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.netcdf(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.exodusii(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.exodusii(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.ADIOS(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.ADIOS(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.openblas(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.openblas(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST checkDependencies from config.packages.fblaslapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TESTING: checkDependencies from config.packages.fblaslapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TEST configureLibrary from config.packages.fblaslapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
TESTING: configureLibrary from config.packages.fblaslapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
Find an installation and check if it can work with PETSc
Checking for a functional fblaslapack
Looking for FBLASLAPACK at git.fblaslapack, hg.fblaslapack or a directory starting with ['fblaslapack']
Could not locate an existing copy of FBLASLAPACK:
['git.slepc', 'petsc-pkg-scotch-c15036faac5f', 'petsc-pkg-metis-49e61501c498', 'petsc-pkg-parmetis-73dab469aa36']
Downloading fblaslapack
Trying to download file:///home/wangzl/packages/fblaslapack-3.4.2.tar.gz for FBLASLAPACK
Downloading file:///home/wangzl/packages/fblaslapack-3.4.2.tar.gz to /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/_d_fblaslapack-3.4.2.tar.gz
Extracting /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/_d_fblaslapack-3.4.2.tar.gz
Executing: cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages; chmod -R a+r fblaslapack-3.4.2;find fblaslapack-3.4.2 -type d -name "*" -exec chmod a+rx {} \;
Found a copy of FBLASLAPACK in fblaslapack-3.4.2
Executing: mpif90 -V
Executing: mpif90 -qversion
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O -fopenmp -O0 /tmp/petsc-wjcu960y/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Executing: mpif90 -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.libraries -I/tmp/petsc-wjcu960y/config.setCompilers -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O -fopenmp -mfp16-format=ieee /tmp/petsc-wjcu960y/config.setCompilers/conftest.F90
Possible ERROR while running compiler: exit code 1
stderr:
gfortran: error: unrecognized command line option ���-mfp16-format=ieee���
Source:
program main
end
Rejecting compiler flag -mfp16-format=ieee due to nonzero status from link
PETSc Error: No output file produced
Have to rebuild FBLASLAPACK, /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/fblaslapack-3.4.2/tmpmakefile != /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/lib/petsc/conf/pkg.conf.fblaslapack
Compiling FBLASLAPACK; this may take several minutes
Executing: cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/fblaslapack-3.4.2 && make -f tmpmakefile cleanblaslapck cleanlib && make -f tmpmakefile
stdout:
/usr/bin/rm -f */*.o
/usr/bin/rm -f ./*.a ./*.lib
cd blas; make lib FC="mpif90" FOPTFLAGS="-fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O -fopenmp " FNOOPT="-O0 -fPIC " AR="/usr/bin/ar" AR_FLAGS="cr" RM="/usr/bin/rm -f" LIBNAME="libfblas.a"
make[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/fblaslapack-3.4.2/blas'
mpif90 -c -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O -fopenmp caxpy.f ccopy.f cdotc.f cdotu.f cgbmv.f cgemm.f cgemv.f cgerc.f cgeru.f chbmv.f chemm.f chemv.f cher2.f cher2k.f cher.f cherk.f chpmv.f chpr2.f chpr.f crotg.f cscal.f csrot.f csscal.f cswap.f csymm.f csyr2k.f csyrk.f ctbmv.f ctbsv.f ctpmv.f ctpsv.f ctrmm.f ctrmv.f ctrsm.f ctrsv.f dasum.f daxpy.f dcabs1.f dcopy.f ddot.f dgbmv.f dgemm.f dgemv.f dger.f dnrm2.f drot.f drotg.f drotm.f drotmg.f dsbmv.f dscal.f dsdot.f dspmv.f dspr2.f dspr.f dswap.f dsymm.f dsymv.f dsyr2.f dsyr2k.f dsyr.f dsyrk.f dtbmv.f dtbsv.f dtpmv.f dtpsv.f dtrmm.f dtrmv.f dtrsm.f dtrsv.f dzasum.f dznrm2.f icamax.f idamax.f isamax.f izamax.f lsame.f sasum.f saxpy.f scabs1.f scasum.f scnrm2.f scopy.f sdot.f sdsdot.f sgbmv.f sgemm.f sgemv.f sger.f snrm2.f srot.f srotg.f srotm.f srotmg.f ssbmv.f sscal.f sspmv.f sspr2.f sspr.f sswap.f ssymm.f ssymv.f ssyr2.f ssyr2k.f ssyr.f ssyrk.f stbmv.f stbsv.f stpmv.f stpsv.f strmm.f strmv.f strsm.f strsv.f xerbla_array.f xerbla.f zaxpy.f zcopy.f zdotc.f zdotu.f zdrot.f zdscal.f zgbmv.f zgemm.f zgemv.f zgerc.f zgeru.f zhbmv.f zhemm.f zhemv.f zher2.f zher2k.f zher.f zherk.f zhpmv.f zhpr2.f zhpr.f zrotg.f zscal.f zswap.f zsymm.f zsyr2k.f zsyrk.f ztbmv.f ztbsv.f ztpmv.f ztpsv.f ztrmm.f ztrmv.f ztrsm.f ztrsv.f
/usr/bin/ar cr ../libfblas.a caxpy.o ccopy.o cdotc.o cdotu.o cgbmv.o cgemm.o cgemv.o cgerc.o cgeru.o chbmv.o chemm.o chemv.o cher2.o cher2k.o cher.o cherk.o chpmv.o chpr2.o chpr.o crotg.o cscal.o csrot.o csscal.o cswap.o csymm.o csyr2k.o csyrk.o ctbmv.o ctbsv.o ctpmv.o ctpsv.o ctrmm.o ctrmv.o ctrsm.o ctrsv.o dasum.o daxpy.o dcabs1.o dcopy.o ddot.o dgbmv.o dgemm.o dgemv.o dger.o dnrm2.o drot.o drotg.o drotm.o drotmg.o dsbmv.o dscal.o dsdot.o dspmv.o dspr2.o dspr.o dswap.o dsymm.o dsymv.o dsyr2.o dsyr2k.o dsyr.o dsyrk.o dtbmv.o dtbsv.o dtpmv.o dtpsv.o dtrmm.o dtrmv.o dtrsm.o dtrsv.o dzasum.o dznrm2.o icamax.o idamax.o isamax.o izamax.o lsame.o sasum.o saxpy.o scabs1.o scasum.o scnrm2.o scopy.o sdot.o sdsdot.o sgbmv.o sgemm.o sgemv.o sger.o snrm2.o srot.o srotg.o srotm.o srotmg.o ssbmv.o sscal.o sspmv.o sspr2.o sspr.o sswap.o ssymm.o ssymv.o ssyr2.o ssyr2k.o ssyr.o ssyrk.o stbmv.o stbsv.o stpmv.o stpsv.o strmm.o strmv.o strsm.o strsv.o xerbla_array.o xerbla.o zaxpy.o zcopy.o zdotc.o zdotu.o zdrot.o zdscal.o zgbmv.o zgemm.o zgemv.o zgerc.o zgeru.o zhbmv.o zhemm.o zhemv.o zher2.o zher2k.o zher.o zherk.o zhpmv.o zhpr2.o zhpr.o zrotg.o zscal.o zswap.o zsymm.o zsyr2k.o zsyrk.o ztbmv.o ztbsv.o ztpmv.o ztpsv.o ztrmm.o ztrmv.o ztrsm.o ztrsv.o
/usr/bin/rm -f caxpy.o ccopy.o cdotc.o cdotu.o cgbmv.o cgemm.o cgemv.o cgerc.o cgeru.o chbmv.o chemm.o chemv.o cher2.o cher2k.o cher.o cherk.o chpmv.o chpr2.o chpr.o crotg.o cscal.o csrot.o csscal.o cswap.o csymm.o csyr2k.o csyrk.o ctbmv.o ctbsv.o ctpmv.o ctpsv.o ctrmm.o ctrmv.o ctrsm.o ctrsv.o dasum.o daxpy.o dcabs1.o dcopy.o ddot.o dgbmv.o dgemm.o dgemv.o dger.o dnrm2.o drot.o drotg.o drotm.o drotmg.o dsbmv.o dscal.o dsdot.o dspmv.o dspr2.o dspr.o dswap.o dsymm.o dsymv.o dsyr2.o dsyr2k.o dsyr.o dsyrk.o dtbmv.o dtbsv.o dtpmv.o dtpsv.o dtrmm.o dtrmv.o dtrsm.o dtrsv.o dzasum.o dznrm2.o icamax.o idamax.o isamax.o izamax.o lsame.o sasum.o saxpy.o scabs1.o scasum.o scnrm2.o scopy.o sdot.o sdsdot.o sgbmv.o sgemm.o sgemv.o sger.o snrm2.o srot.o srotg.o srotm.o srotmg.o ssbmv.o sscal.o sspmv.o sspr2.o sspr.o sswap.o ssymm.o ssymv.o ssyr2.o ssyr2k.o ssyr.o ssyrk.o stbmv.o stbsv.o stpmv.o stpsv.o strmm.o strmv.o strsm.o strsv.o xerbla_array.o xerbla.o zaxpy.o zcopy.o zdotc.o zdotu.o zdrot.o zdscal.o zgbmv.o zgemm.o zgemv.o zgerc.o zgeru.o zhbmv.o zhemm.o zhemv.o zher2.o zher2k.o zher.o zherk.o zhpmv.o zhpr2.o zhpr.o zrotg.o zscal.o zswap.o zsymm.o zsyr2k.o zsyrk.o ztbmv.o ztbsv.o ztpmv.o ztpsv.o ztrmm.o ztrmv.o ztrsm.o ztrsv.o
make[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/fblaslapack-3.4.2/blas'
/usr/bin/ranlib libfblas.a
cd lapack; make lib FC="mpif90" FOPTFLAGS="-fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O -fopenmp " FNOOPT="-O0 -fPIC " AR="/usr/bin/ar" AR_FLAGS="cr" RM="/usr/bin/rm -f" LIBNAME="libflapack.a"
make[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/fblaslapack-3.4.2/lapack'
mpif90 -c -O0 -fPIC slaruv.f dlaruv.f
mpif90 -c -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O -fopenmp cbbcsd.f cbdsqr.f cgbbrd.f cgbcon.f cgbequb.f cgbequ.f cgbrfs.f cgbrfsx.f cgbsv.f cgbsvx.f cgbsvxx.f cgbtf2.f cgbtrf.f cgbtrs.f cgebak.f cgebal.f cgebd2.f cgebrd.f cgecon.f cgeequb.f cgeequ.f cgees.f cgeesx.f cgeev.f cgeevx.f cgegs.f cgegv.f cgehd2.f cgehrd.f cgelq2.f cgelqf.f cgelsd.f cgels.f cgelss.f cgelsx.f cgelsy.f cgemqrt.f cgeql2.f cgeqlf.f cgeqp3.f cgeqpf.f cgeqr2.f cgeqr2p.f cgeqrf.f cgeqrfp.f cgeqrt2.f cgeqrt3.f cgeqrt.f cgerfs.f cgerfsx.f cgerq2.f cgerqf.f cgesc2.f cgesdd.f cgesvd.f cgesv.f cgesvx.f cgesvxx.f cgetc2.f cgetf2.f cgetrf.f cgetri.f cgetrs.f cggbak.f cggbal.f cgges.f cggesx.f cggev.f cggevx.f cggglm.f cgghrd.f cgglse.f cggqrf.f cggrqf.f cggsvd.f cggsvp.f cgtcon.f cgtrfs.f cgtsv.f cgtsvx.f cgttrf.f cgttrs.f cgtts2.f chbevd.f chbev.f chbevx.f chbgst.f chbgvd.f chbgv.f chbgvx.f chbtrd.f checon.f checon_rook.f cheequb.f cheevd.f cheev.f cheevr.f cheevx.f chegs2.f chegst.f chegvd.f chegv.f chegvx.f cherfs.f cherfsx.f chesv.f chesv_rook.f chesvx.f chesvxx.f cheswapr.f chetd2.f chetf2.f chetf2_rook.f chetrd.f chetrf.f chetrf_rook.f chetri2.f chetri2x.f chetri.f chetri_rook.f chetrs2.f chetrs.f chetrs_rook.f chfrk.f chgeqz.f chla_transtype.f chpcon.f chpevd.f chpev.f chpevx.f chpgst.f chpgvd.f chpgv.f chpgvx.f chprfs.f chpsv.f chpsvx.f chptrd.f chptrf.f chptri.f chptrs.f chsein.f chseqr.f clabrd.f clacgv.f clacn2.f clacon.f clacp2.f clacpy.f clacrm.f clacrt.f cladiv.f claed0.f claed7.f claed8.f claein.f claesy.f claev2.f clag2z.f cla_gbamv.f cla_gbrcond_c.f cla_gbrcond_x.f cla_gbrfsx_extended.f cla_gbrpvgrw.f cla_geamv.f cla_gercond_c.f cla_gercond_x.f cla_gerfsx_extended.f cla_gerpvgrw.f clags2.f clagtm.f cla_heamv.f clahef.f clahef_rook.f cla_hercond_c.f cla_hercond_x.f cla_herfsx_extended.f cla_herpvgrw.f clahqr.f clahr2.f clahrd.f claic1.f cla_lin_berr.f clals0.f clalsa.f clalsd.f clangb.f clange.f clangt.f clanhb.f clanhe.f clanhf.f clanhp.f clanhs.f clanht.f clansb.f clansp.f clansy.f clantb.f clantp.f clantr.f clapll.f clapmr.f clapmt.f cla_porcond_c.f cla_porcond_x.f cla_porfsx_extended.f cla_porpvgrw.f claqgb.f claqge.f claqhb.f claqhe.f claqhp.f claqp2.f claqps.f claqr0.f claqr1.f claqr2.f claqr3.f claqr4.f claqr5.f claqsb.f claqsp.f claqsy.f clar1v.f clar2v.f clarcm.f clarfb.f clarf.f clarfg.f clarfgp.f clarft.f clarfx.f clargv.f clarnv.f clarrv.f clarscl2.f clartg.f clartv.f clarzb.f clarz.f clarzt.f clascl2.f clascl.f claset.f clasr.f classq.f claswp.f cla_syamv.f clasyf.f clasyf_rook.f cla_syrcond_c.f cla_syrcond_x.f cla_syrfsx_extended.f cla_syrpvgrw.f clatbs.f clatdf.f clatps.f clatrd.f clatrs.f clatrz.f clatzm.f clauu2.f clauum.f cla_wwaddw.f cpbcon.f cpbequ.f cpbrfs.f cpbstf.f cpbsv.f cpbsvx.f cpbtf2.f cpbtrf.f cpbtrs.f cpftrf.f cpftri.f cpftrs.f cpocon.f cpoequb.f cpoequ.f cporfs.f cporfsx.f cposv.f cposvx.f cposvxx.f cpotf2.f cpotrf.f cpotri.f cpotrs.f cppcon.f cppequ.f cpprfs.f cppsv.f cppsvx.f cpptrf.f cpptri.f cpptrs.f cpstf2.f cpstrf.f cptcon.f cpteqr.f cptrfs.f cptsv.f cptsvx.f cpttrf.f cpttrs.f cptts2.f crot.f cspcon.f cspmv.f cspr.f csprfs.f cspsv.f cspsvx.f csptrf.f csptri.f csptrs.f csrscl.f cstedc.f cstegr.f cstein.f cstemr.f csteqr.f csycon.f csycon_rook.f csyconv.f csyequb.f csymv.f csyr.f csyrfs.f csyrfsx.f csysv.f csysv_rook.f csysvx.f csysvxx.f csyswapr.f csytf2.f csytf2_rook.f csytrf.f csytrf_rook.f csytri2.f csytri2x.f csytri.f csytri_rook.f csytrs2.f csytrs.f csytrs_rook.f ctbcon.f ctbrfs.f ctbtrs.f ctfsm.f ctftri.f ctfttp.f ctfttr.f ctgevc.f ctgex2.f ctgexc.f ctgsen.f ctgsja.f ctgsna.f ctgsy2.f ctgsyl.f ctpcon.f ctpmqrt.f ctpqrt2.f ctpqrt.f ctprfb.f ctprfs.f ctptri.f ctptrs.f ctpttf.f ctpttr.f ctrcon.f ctrevc.f ctrexc.f ctrrfs.f ctrsen.f ctrsna.f ctrsyl.f ctrti2.f ctrtri.f ctrtrs.f ctrttf.f ctrttp.f ctzrqf.f ctzrzf.f cunbdb1.f cunbdb2.f cunbdb3.f cunbdb4.f cunbdb5.f cunbdb6.f cunbdb.f cuncsd2by1.f cuncsd.f cung2l.f cung2r.f cungbr.f cunghr.f cungl2.f cunglq.f cungql.f cungqr.f cungr2.f cungrq.f cungtr.f cunm2l.f cunm2r.f cunmbr.f cunmhr.f cunml2.f cunmlq.f cunmql.f cunmqr.f cunmr2.f cunmr3.f cunmrq.f cunmrz.f cunmtr.f cupgtr.f cupmtr.f dbbcsd.f dbdsdc.f dbdsqr.f ddisna.f dgbbrd.f dgbcon.f dgbequb.f dgbequ.f dgbrfs.f dgbrfsx.f dgbsv.f dgbsvx.f dgbsvxx.f dgbtf2.f dgbtrf.f dgbtrs.f dgebak.f dgebal.f dgebd2.f dgebrd.f dgecon.f dgeequb.f dgeequ.f dgees.f dgeesx.f dgeev.f dgeevx.f dgegs.f dgegv.f dgehd2.f dgehrd.f dgejsv.f dgelq2.f dgelqf.f dgelsd.f dgels.f dgelss.f dgelsx.f dgelsy.f dgemqrt.f dgeql2.f dgeqlf.f dgeqp3.f dgeqpf.f dgeqr2.f dgeqr2p.f dgeqrf.f dgeqrfp.f dgeqrt2.f dgeqrt3.f dgeqrt.f dgerfs.f dgerfsx.f dgerq2.f dgerqf.f dgesc2.f dgesdd.f dgesvd.f dgesv.f dgesvj.f dgesvx.f dgesvxx.f dgetc2.f dgetf2.f dgetrf.f dgetri.f dgetrs.f dggbak.f dggbal.f dgges.f dggesx.f dggev.f dggevx.f dggglm.f dgghrd.f dgglse.f dggqrf.f dggrqf.f dggsvd.f dggsvp.f dgsvj0.f dgsvj1.f dgtcon.f dgtrfs.f dgtsv.f dgtsvx.f dgttrf.f dgttrs.f dgtts2.f dhgeqz.f dhsein.f dhseqr.f disnan.f dlabad.f dlabrd.f dlacn2.f dlacon.f dlacpy.f dladiv.f dlae2.f dlaebz.f dlaed0.f dlaed1.f dlaed2.f dlaed3.f dlaed4.f dlaed5.f dlaed6.f dlaed7.f dlaed8.f dlaed9.f dlaeda.f dlaein.f dlaev2.f dlaexc.f dlag2.f dlag2s.f dla_gbamv.f dla_gbrcond.f dla_gbrfsx_extended.f dla_gbrpvgrw.f dla_geamv.f dla_gercond.f dla_gerfsx_extended.f dla_gerpvgrw.f dlags2.f dlagtf.f dlagtm.f dlagts.f dlagv2.f dlahqr.f dlahr2.f dlahrd.f dlaic1.f dlaisnan.f dla_lin_berr.f dlaln2.f dlals0.f dlalsa.f dlalsd.f dlamrg.f dlaneg.f dlangb.f dlange.f dlangt.f dlanhs.f dlansb.f dlansf.f dlansp.f dlanst.f dlansy.f dlantb.f dlantp.f dlantr.f dlanv2.f dlapll.f dlapmr.f dlapmt.f dla_porcond.f dla_porfsx_extended.f dla_porpvgrw.f dlapy2.f dlapy3.f dlaqgb.f dlaqge.f dlaqp2.f dlaqps.f dlaqr0.f dlaqr1.f dlaqr2.f dlaqr3.f dlaqr4.f dlaqr5.f dlaqsb.f dlaqsp.f dlaqsy.f dlaqtr.f dlar1v.f dlar2v.f dlarfb.f dlarf.f dlarfg.f dlarfgp.f dlarft.f dlarfx.f dlargv.f dlarnv.f dlarra.f dlarrb.f dlarrc.f dlarrd.f dlarre.f dlarrf.f dlarrj.f dlarrk.f dlarrr.f dlarrv.f dlarscl2.f dlartg.f dlartgp.f dlartgs.f dlartv.f dlaruv.f dlarzb.f dlarz.f dlarzt.f dlas2.f dlascl2.f dlascl.f dlasd0.f dlasd1.f dlasd2.f dlasd3.f dlasd4.f dlasd5.f dlasd6.f dlasd7.f dlasd8.f dlasda.f dlasdq.f dlasdt.f dlaset.f dlasq1.f dlasq2.f dlasq3.f dlasq4.f dlasq5.f dlasq6.f dlasr.f dlasrt.f dlassq.f dlasv2.f dlaswp.f dlasy2.f dla_syamv.f dlasyf.f dlasyf_rook.f dla_syrcond.f dla_syrfsx_extended.f dla_syrpvgrw.f dlat2s.f dlatbs.f dlatdf.f dlatps.f dlatrd.f dlatrs.f dlatrz.f dlatzm.f dlauu2.f dlauum.f dla_wwaddw.f dlazq3.f dlazq4.f dopgtr.f dopmtr.f dorbdb1.f dorbdb2.f dorbdb3.f dorbdb4.f dorbdb5.f dorbdb6.f dorbdb.f dorcsd2by1.f dorcsd.f dorg2l.f dorg2r.f dorgbr.f dorghr.f dorgl2.f dorglq.f dorgql.f dorgqr.f dorgr2.f dorgrq.f dorgtr.f dorm2l.f dorm2r.f dormbr.f dormhr.f dorml2.f dormlq.f dormql.f dormqr.f dormr2.f dormr3.f dormrq.f dormrz.f dormtr.f dpbcon.f dpbequ.f dpbrfs.f dpbstf.f dpbsv.f dpbsvx.f dpbtf2.f dpbtrf.f dpbtrs.f dpftrf.f dpftri.f dpftrs.f dpocon.f dpoequb.f dpoequ.f dporfs.f dporfsx.f dposv.f dposvx.f dposvxx.f dpotf2.f dpotrf.f dpotri.f dpotrs.f dppcon.f dppequ.f dpprfs.f dppsv.f dppsvx.f dpptrf.f dpptri.f dpptrs.f dpstf2.f dpstrf.f dptcon.f dpteqr.f dptrfs.f dptsv.f dptsvx.f dpttrf.f dpttrs.f dptts2.f drscl.f dsbevd.f dsbev.f dsbevx.f dsbgst.f dsbgvd.f dsbgv.f dsbgvx.f dsbtrd.f dsfrk.f dsgesv.f dspcon.f dspevd.f dspev.f dspevx.f dspgst.f dspgvd.f dspgv.f dspgvx.f dsposv.f dsprfs.f dspsv.f dspsvx.f dsptrd.f dsptrf.f dsptri.f dsptrs.f dstebz.f dstedc.f dstegr.f dstein.f dstemr.f dsteqr.f dsterf.f dstevd.f dstev.f dstevr.f dstevx.f dsycon.f dsycon_rook.f dsyconv.f dsyequb.f dsyevd.f dsyev.f dsyevr.f dsyevx.f dsygs2.f dsygst.f dsygvd.f dsygv.f dsygvx.f dsyrfs.f dsyrfsx.f dsysv.f dsysv_rook.f dsysvx.f dsysvxx.f dsyswapr.f dsytd2.f dsytf2.f dsytf2_rook.f dsytrd.f dsytrf.f dsytrf_rook.f dsytri2.f dsytri2x.f dsytri.f dsytri_rook.f dsytrs2.f dsytrs.f dsytrs_rook.f dtbcon.f dtbrfs.f dtbtrs.f dtfsm.f dtftri.f dtfttp.f dtfttr.f dtgevc.f dtgex2.f dtgexc.f dtgsen.f dtgsja.f dtgsna.f dtgsy2.f dtgsyl.f dtpcon.f dtpmqrt.f dtpqrt2.f dtpqrt.f dtprfb.f dtprfs.f dtptri.f dtptrs.f dtpttf.f dtpttr.f dtrcon.f dtrevc.f dtrexc.f dtrrfs.f dtrsen.f dtrsna.f dtrsyl.f dtrti2.f dtrtri.f dtrtrs.f dtrttf.f dtrttp.f dtzrqf.f dtzrzf.f dzsum1.f icmax1.f ieeeck.f ilaclc.f ilaclr.f iladiag.f iladlc.f iladlr.f ilaenv.f ilaprec.f ilaslc.f ilaslr.f ilatrans.f ilauplo.f ilaver.f ilazlc.f ilazlr.f iparmq.f izmax1.f lsamen.f sbbcsd.f sbdsdc.f sbdsqr.f scsum1.f sdisna.f sgbbrd.f sgbcon.f sgbequb.f sgbequ.f sgbrfs.f sgbrfsx.f sgbsv.f sgbsvx.f sgbsvxx.f sgbtf2.f sgbtrf.f sgbtrs.f sgebak.f sgebal.f sgebd2.f sgebrd.f sgecon.f sgeequb.f sgeequ.f sgees.f sgeesx.f sgeev.f sgeevx.f sgegs.f sgegv.f sgehd2.f sgehrd.f sgejsv.f sgelq2.f sgelqf.f sgelsd.f sgels.f sgelss.f sgelsx.f sgelsy.f sgemqrt.f sgeql2.f sgeqlf.f sgeqp3.f sgeqpf.f sgeqr2.f sgeqr2p.f sgeqrf.f sgeqrfp.f sgeqrt2.f sgeqrt3.f sgeqrt.f sgerfs.f sgerfsx.f sgerq2.f sgerqf.f sgesc2.f sgesdd.f sgesvd.f sgesv.f sgesvj.f sgesvx.f sgesvxx.f sgetc2.f sgetf2.f sgetrf.f sgetri.f sgetrs.f sggbak.f sggbal.f sgges.f sggesx.f sggev.f sggevx.f sggglm.f sgghrd.f sgglse.f sggqrf.f sggrqf.f sggsvd.f sggsvp.f sgsvj0.f sgsvj1.f sgtcon.f sgtrfs.f sgtsv.f sgtsvx.f sgttrf.f sgttrs.f sgtts2.f shgeqz.f shsein.f shseqr.f sisnan.f slabad.f slabrd.f slacn2.f slacon.f slacpy.f sladiv.f slae2.f slaebz.f slaed0.f slaed1.f slaed2.f slaed3.f slaed4.f slaed5.f slaed6.f slaed7.f slaed8.f slaed9.f slaeda.f slaein.f slaev2.f slaexc.f slag2d.f slag2.f sla_gbamv.f sla_gbrcond.f sla_gbrfsx_extended.f sla_gbrpvgrw.f sla_geamv.f sla_gercond.f sla_gerfsx_extended.f sla_gerpvgrw.f slags2.f slagtf.f slagtm.f slagts.f slagv2.f slahqr.f slahr2.f slahrd.f slaic1.f slaisnan.f sla_lin_berr.f slaln2.f slals0.f slalsa.f slalsd.f slamrg.f slaneg.f slangb.f slange.f slangt.f slanhs.f slansb.f slansf.f slansp.f slanst.f slansy.f slantb.f slantp.f slantr.f slanv2.f slapll.f slapmr.f slapmt.f sla_porcond.f sla_porfsx_extended.f sla_porpvgrw.f slapy2.f slapy3.f slaqgb.f slaqge.f slaqp2.f slaqps.f slaqr0.f slaqr1.f slaqr2.f slaqr3.f slaqr4.f slaqr5.f slaqsb.f slaqsp.f slaqsy.f slaqtr.f slar1v.f slar2v.f slarfb.f slarf.f slarfg.f slarfgp.f slarft.f slarfx.f slargv.f slarnv.f slarra.f slarrb.f slarrc.f slarrd.f slarre.f slarrf.f slarrj.f slarrk.f slarrr.f slarrv.f slarscl2.f slartg.f slartgp.f slartgs.f slartv.f slaruv.f slarzb.f slarz.f slarzt.f slas2.f slascl2.f slascl.f slasd0.f slasd1.f slasd2.f slasd3.f slasd4.f slasd5.f slasd6.f slasd7.f slasd8.f slasda.f slasdq.f slasdt.f slaset.f slasq1.f slasq2.f slasq3.f slasq4.f slasq5.f slasq6.f slasr.f slasrt.f slassq.f slasv2.f slaswp.f slasy2.f sla_syamv.f slasyf.f slasyf_rook.f sla_syrcond.f sla_syrfsx_extended.f sla_syrpvgrw.f slatbs.f slatdf.f slatps.f slatrd.f slatrs.f slatrz.f slatzm.f slauu2.f slauum.f sla_wwaddw.f slazq3.f slazq4.f sopgtr.f sopmtr.f sorbdb1.f sorbdb2.f sorbdb3.f sorbdb4.f sorbdb5.f sorbdb6.f sorbdb.f sorcsd2by1.f sorcsd.f sorg2l.f sorg2r.f sorgbr.f sorghr.f sorgl2.f sorglq.f sorgql.f sorgqr.f sorgr2.f sorgrq.f sorgtr.f sorm2l.f sorm2r.f sormbr.f sormhr.f sorml2.f sormlq.f sormql.f sormqr.f sormr2.f sormr3.f sormrq.f sormrz.f sormtr.f spbcon.f spbequ.f spbrfs.f spbstf.f spbsv.f spbsvx.f spbtf2.f spbtrf.f spbtrs.f spftrf.f spftri.f spftrs.f spocon.f spoequb.f spoequ.f sporfs.f sporfsx.f sposv.f sposvx.f sposvxx.f spotf2.f spotrf.f spotri.f spotrs.f sppcon.f sppequ.f spprfs.f sppsv.f sppsvx.f spptrf.f spptri.f spptrs.f spstf2.f spstrf.f sptcon.f spteqr.f sptrfs.f sptsv.f sptsvx.f spttrf.f spttrs.f sptts2.f srscl.f ssbevd.f ssbev.f ssbevx.f ssbgst.f ssbgvd.f ssbgv.f ssbgvx.f ssbtrd.f ssfrk.f sspcon.f sspevd.f sspev.f sspevx.f sspgst.f sspgvd.f sspgv.f sspgvx.f ssprfs.f sspsv.f sspsvx.f ssptrd.f ssptrf.f ssptri.f ssptrs.f sstebz.f sstedc.f sstegr.f sstein.f sstemr.f ssteqr.f ssterf.f sstevd.f sstev.f sstevr.f sstevx.f ssycon.f ssycon_rook.f ssyconv.f ssyequb.f ssyevd.f ssyev.f ssyevr.f ssyevx.f ssygs2.f ssygst.f ssygvd.f ssygv.f ssygvx.f ssyrfs.f ssyrfsx.f ssysv.f ssysv_rook.f ssysvx.f ssysvxx.f ssyswapr.f ssytd2.f ssytf2.f ssytf2_rook.f ssytrd.f ssytrf.f ssytrf_rook.f ssytri2.f ssytri2x.f ssytri.f ssytri_rook.f ssytrs2.f ssytrs.f ssytrs_rook.f stbcon.f stbrfs.f stbtrs.f stfsm.f stftri.f stfttp.f stfttr.f stgevc.f stgex2.f stgexc.f stgsen.f stgsja.f stgsna.f stgsy2.f stgsyl.f stpcon.f stpmqrt.f stpqrt2.f stpqrt.f stprfb.f stprfs.f stptri.f stptrs.f stpttf.f stpttr.f strcon.f strevc.f strexc.f strrfs.f strsen.f strsna.f strsyl.f strti2.f strtri.f strtrs.f strttf.f strttp.f stzrqf.f stzrzf.f zbbcsd.f zbdsqr.f zcgesv.f zcposv.f zdrscl.f zgbbrd.f zgbcon.f zgbequb.f zgbequ.f zgbrfs.f zgbrfsx.f zgbsv.f zgbsvx.f zgbsvxx.f zgbtf2.f zgbtrf.f zgbtrs.f zgebak.f zgebal.f zgebd2.f zgebrd.f zgecon.f zgeequb.f zgeequ.f zgees.f zgeesx.f zgeev.f zgeevx.f zgegs.f zgegv.f zgehd2.f zgehrd.f zgelq2.f zgelqf.f zgelsd.f zgels.f zgelss.f zgelsx.f zgelsy.f zgemqrt.f zgeql2.f zgeqlf.f zgeqp3.f zgeqpf.f zgeqr2.f zgeqr2p.f zgeqrf.f zgeqrfp.f zgeqrt2.f zgeqrt3.f zgeqrt.f zgerfs.f zgerfsx.f zgerq2.f zgerqf.f zgesc2.f zgesdd.f zgesvd.f zgesv.f zgesvx.f zgesvxx.f zgetc2.f zgetf2.f zgetrf.f zgetri.f zgetrs.f zggbak.f zggbal.f zgges.f zggesx.f zggev.f zggevx.f zggglm.f zgghrd.f zgglse.f zggqrf.f zggrqf.f zggsvd.f zggsvp.f zgtcon.f zgtrfs.f zgtsv.f zgtsvx.f zgttrf.f zgttrs.f zgtts2.f zhbevd.f zhbev.f zhbevx.f zhbgst.f zhbgvd.f zhbgv.f zhbgvx.f zhbtrd.f zhecon.f zhecon_rook.f zheequb.f zheevd.f zheev.f zheevr.f zheevx.f zhegs2.f zhegst.f zhegvd.f zhegv.f zhegvx.f zherfs.f zherfsx.f zhesv.f zhesv_rook.f zhesvx.f zhesvxx.f zheswapr.f zhetd2.f zhetf2.f zhetf2_rook.f zhetrd.f zhetrf.f zhetrf_rook.f zhetri2.f zhetri2x.f zhetri.f zhetri_rook.f zhetrs2.f zhetrs.f zhetrs_rook.f zhfrk.f zhgeqz.f zhpcon.f zhpevd.f zhpev.f zhpevx.f zhpgst.f zhpgvd.f zhpgv.f zhpgvx.f zhprfs.f zhpsv.f zhpsvx.f zhptrd.f zhptrf.f zhptri.f zhptrs.f zhsein.f zhseqr.f zlabrd.f zlacgv.f zlacn2.f zlacon.f zlacp2.f zlacpy.f zlacrm.f zlacrt.f zladiv.f zlaed0.f zlaed7.f zlaed8.f zlaein.f zlaesy.f zlaev2.f zlag2c.f zla_gbamv.f zla_gbrcond_c.f zla_gbrcond_x.f zla_gbrfsx_extended.f zla_gbrpvgrw.f zla_geamv.f zla_gercond_c.f zla_gercond_x.f zla_gerfsx_extended.f zla_gerpvgrw.f zlags2.f zlagtm.f zla_heamv.f zlahef.f zlahef_rook.f zla_hercond_c.f zla_hercond_x.f zla_herfsx_extended.f zla_herpvgrw.f zlahqr.f zlahr2.f zlahrd.f zlaic1.f zla_lin_berr.f zlals0.f zlalsa.f zlalsd.f zlangb.f zlange.f zlangt.f zlanhb.f zlanhe.f zlanhf.f zlanhp.f zlanhs.f zlanht.f zlansb.f zlansp.f zlansy.f zlantb.f zlantp.f zlantr.f zlapll.f zlapmr.f zlapmt.f zla_porcond_c.f zla_porcond_x.f zla_porfsx_extended.f zla_porpvgrw.f zlaqgb.f zlaqge.f zlaqhb.f zlaqhe.f zlaqhp.f zlaqp2.f zlaqps.f zlaqr0.f zlaqr1.f zlaqr2.f zlaqr3.f zlaqr4.f zlaqr5.f zlaqsb.f zlaqsp.f zlaqsy.f zlar1v.f zlar2v.f zlarcm.f zlarfb.f zlarf.f zlarfg.f zlarfgp.f zlarft.f zlarfx.f zlargv.f zlarnv.f zlarrv.f zlarscl2.f zlartg.f zlartv.f zlarzb.f zlarz.f zlarzt.f zlascl2.f zlascl.f zlaset.f zlasr.f zlassq.f zlaswp.f zla_syamv.f zlasyf.f zlasyf_rook.f zla_syrcond_c.f zla_syrcond_x.f zla_syrfsx_extended.f zla_syrpvgrw.f zlat2c.f zlatbs.f zlatdf.f zlatps.f zlatrd.f zlatrs.f zlatrz.f zlatzm.f zlauu2.f zlauum.f zla_wwaddw.f zpbcon.f zpbequ.f zpbrfs.f zpbstf.f zpbsv.f zpbsvx.f zpbtf2.f zpbtrf.f zpbtrs.f zpftrf.f zpftri.f zpftrs.f zpocon.f zpoequb.f zpoequ.f zporfs.f zporfsx.f zposv.f zposvx.f zposvxx.f zpotf2.f zpotrf.f zpotri.f zpotrs.f zppcon.f zppequ.f zpprfs.f zppsv.f zppsvx.f zpptrf.f zpptri.f zpptrs.f zpstf2.f zpstrf.f zptcon.f zpteqr.f zptrfs.f zptsv.f zptsvx.f zpttrf.f zpttrs.f zptts2.f zrot.f zspcon.f zspmv.f zspr.f zsprfs.f zspsv.f zspsvx.f zsptrf.f zsptri.f zsptrs.f zstedc.f zstegr.f zstein.f zstemr.f zsteqr.f zsycon.f zsycon_rook.f zsyconv.f zsyequb.f zsymv.f zsyr.f zsyrfs.f zsyrfsx.f zsysv.f zsysv_rook.f zsysvx.f zsysvxx.f zsyswapr.f zsytf2.f zsytf2_rook.f zsytrf.f zsytrf_rook.f zsytri2.f zsytri2x.f zsytri.f zsytri_rook.f zsytrs2.f zsytrs.f zsytrs_rook.f ztbcon.f ztbrfs.f ztbtrs.f ztfsm.f ztftri.f ztfttp.f ztfttr.f ztgevc.f ztgex2.f ztgexc.f ztgsen.f ztgsja.f ztgsna.f ztgsy2.f ztgsyl.f ztpcon.f ztpmqrt.f ztpqrt2.f ztpqrt.f ztprfb.f ztprfs.f ztptri.f ztptrs.f ztpttf.f ztpttr.f ztrcon.f ztrevc.f ztrexc.f ztrrfs.f ztrsen.f ztrsna.f ztrsyl.f ztrti2.f ztrtri.f ztrtrs.f ztrttf.f ztrttp.f ztzrqf.f ztzrzf.f zunbdb1.f zunbdb2.f zunbdb3.f zunbdb4.f zunbdb5.f zunbdb6.f zunbdb.f zuncsd2by1.f zuncsd.f zung2l.f zung2r.f zungbr.f zunghr.f zungl2.f zunglq.f zungql.f zungqr.f zungr2.f zungrq.f zungtr.f zunm2l.f zunm2r.f zunmbr.f zunmhr.f zunml2.f zunmlq.f zunmql.f zunmqr.f zunmr2.f zunmr3.f zunmrq.f zunmrz.f zunmtr.f zupgtr.f zupmtr.f
/usr/bin/ar cr ../libflapack.a slaruv.o dlaruv.o cbbcsd.o cbdsqr.o cgbbrd.o cgbcon.o cgbequb.o cgbequ.o cgbrfs.o cgbrfsx.o cgbsv.o cgbsvx.o cgbsvxx.o cgbtf2.o cgbtrf.o cgbtrs.o cgebak.o cgebal.o cgebd2.o cgebrd.o cgecon.o cgeequb.o cgeequ.o cgees.o cgeesx.o cgeev.o cgeevx.o cgegs.o cgegv.o cgehd2.o cgehrd.o cgelq2.o cgelqf.o cgelsd.o cgels.o cgelss.o cgelsx.o cgelsy.o cgemqrt.o cgeql2.o cgeqlf.o cgeqp3.o cgeqpf.o cgeqr2.o cgeqr2p.o cgeqrf.o cgeqrfp.o cgeqrt2.o cgeqrt3.o cgeqrt.o cgerfs.o cgerfsx.o cgerq2.o cgerqf.o cgesc2.o cgesdd.o cgesvd.o cgesv.o cgesvx.o cgesvxx.o cgetc2.o cgetf2.o cgetrf.o cgetri.o cgetrs.o cggbak.o cggbal.o cgges.o cggesx.o cggev.o cggevx.o cggglm.o cgghrd.o cgglse.o cggqrf.o cggrqf.o cggsvd.o cggsvp.o cgtcon.o cgtrfs.o cgtsv.o cgtsvx.o cgttrf.o cgttrs.o cgtts2.o chbevd.o chbev.o chbevx.o chbgst.o chbgvd.o chbgv.o chbgvx.o chbtrd.o checon.o checon_rook.o cheequb.o cheevd.o cheev.o cheevr.o cheevx.o chegs2.o chegst.o chegvd.o chegv.o chegvx.o cherfs.o cherfsx.o chesv.o chesv_rook.o chesvx.o chesvxx.o cheswapr.o chetd2.o chetf2.o chetf2_rook.o chetrd.o chetrf.o chetrf_rook.o chetri2.o chetri2x.o chetri.o chetri_rook.o chetrs2.o chetrs.o chetrs_rook.o chfrk.o chgeqz.o chla_transtype.o chpcon.o chpevd.o chpev.o chpevx.o chpgst.o chpgvd.o chpgv.o chpgvx.o chprfs.o chpsv.o chpsvx.o chptrd.o chptrf.o chptri.o chptrs.o chsein.o chseqr.o clabrd.o clacgv.o clacn2.o clacon.o clacp2.o clacpy.o clacrm.o clacrt.o cladiv.o claed0.o claed7.o claed8.o claein.o claesy.o claev2.o clag2z.o cla_gbamv.o cla_gbrcond_c.o cla_gbrcond_x.o cla_gbrfsx_extended.o cla_gbrpvgrw.o cla_geamv.o cla_gercond_c.o cla_gercond_x.o cla_gerfsx_extended.o cla_gerpvgrw.o clags2.o clagtm.o cla_heamv.o clahef.o clahef_rook.o cla_hercond_c.o cla_hercond_x.o cla_herfsx_extended.o cla_herpvgrw.o clahqr.o clahr2.o clahrd.o claic1.o cla_lin_berr.o clals0.o clalsa.o clalsd.o clangb.o clange.o clangt.o clanhb.o clanhe.o clanhf.o clanhp.o clanhs.o clanht.o clansb.o clansp.o clansy.o clantb.o clantp.o clantr.o clapll.o clapmr.o clapmt.o cla_porcond_c.o cla_porcond_x.o cla_porfsx_extended.o cla_porpvgrw.o claqgb.o claqge.o claqhb.o claqhe.o claqhp.o claqp2.o claqps.o claqr0.o claqr1.o claqr2.o claqr3.o claqr4.o claqr5.o claqsb.o claqsp.o claqsy.o clar1v.o clar2v.o clarcm.o clarfb.o clarf.o clarfg.o clarfgp.o clarft.o clarfx.o clargv.o clarnv.o clarrv.o clarscl2.o clartg.o clartv.o clarzb.o clarz.o clarzt.o clascl2.o clascl.o claset.o clasr.o classq.o claswp.o cla_syamv.o clasyf.o clasyf_rook.o cla_syrcond_c.o cla_syrcond_x.o cla_syrfsx_extended.o cla_syrpvgrw.o clatbs.o clatdf.o clatps.o clatrd.o clatrs.o clatrz.o clatzm.o clauu2.o clauum.o cla_wwaddw.o cpbcon.o cpbequ.o cpbrfs.o cpbstf.o cpbsv.o cpbsvx.o cpbtf2.o cpbtrf.o cpbtrs.o cpftrf.o cpftri.o cpftrs.o cpocon.o cpoequb.o cpoequ.o cporfs.o cporfsx.o cposv.o cposvx.o cposvxx.o cpotf2.o cpotrf.o cpotri.o cpotrs.o cppcon.o cppequ.o cpprfs.o cppsv.o cppsvx.o cpptrf.o cpptri.o cpptrs.o cpstf2.o cpstrf.o cptcon.o cpteqr.o cptrfs.o cptsv.o cptsvx.o cpttrf.o cpttrs.o cptts2.o crot.o cspcon.o cspmv.o cspr.o csprfs.o cspsv.o cspsvx.o csptrf.o csptri.o csptrs.o csrscl.o cstedc.o cstegr.o cstein.o cstemr.o csteqr.o csycon.o csycon_rook.o csyconv.o csyequb.o csymv.o csyr.o csyrfs.o csyrfsx.o csysv.o csysv_rook.o csysvx.o csysvxx.o csyswapr.o csytf2.o csytf2_rook.o csytrf.o csytrf_rook.o csytri2.o csytri2x.o csytri.o csytri_rook.o csytrs2.o csytrs.o csytrs_rook.o ctbcon.o ctbrfs.o ctbtrs.o ctfsm.o ctftri.o ctfttp.o ctfttr.o ctgevc.o ctgex2.o ctgexc.o ctgsen.o ctgsja.o ctgsna.o ctgsy2.o ctgsyl.o ctpcon.o ctpmqrt.o ctpqrt2.o ctpqrt.o ctprfb.o ctprfs.o ctptri.o ctptrs.o ctpttf.o ctpttr.o ctrcon.o ctrevc.o ctrexc.o ctrrfs.o ctrsen.o ctrsna.o ctrsyl.o ctrti2.o ctrtri.o ctrtrs.o ctrttf.o ctrttp.o ctzrqf.o ctzrzf.o cunbdb1.o cunbdb2.o cunbdb3.o cunbdb4.o cunbdb5.o cunbdb6.o cunbdb.o cuncsd2by1.o cuncsd.o cung2l.o cung2r.o cungbr.o cunghr.o cungl2.o cunglq.o cungql.o cungqr.o cungr2.o cungrq.o cungtr.o cunm2l.o cunm2r.o cunmbr.o cunmhr.o cunml2.o cunmlq.o cunmql.o cunmqr.o cunmr2.o cunmr3.o cunmrq.o cunmrz.o cunmtr.o cupgtr.o cupmtr.o dbbcsd.o dbdsdc.o dbdsqr.o ddisna.o dgbbrd.o dgbcon.o dgbequb.o dgbequ.o dgbrfs.o dgbrfsx.o dgbsv.o dgbsvx.o dgbsvxx.o dgbtf2.o dgbtrf.o dgbtrs.o dgebak.o dgebal.o dgebd2.o dgebrd.o dgecon.o dgeequb.o dgeequ.o dgees.o dgeesx.o dgeev.o dgeevx.o dgegs.o dgegv.o dgehd2.o dgehrd.o dgejsv.o dgelq2.o dgelqf.o dgelsd.o dgels.o dgelss.o dgelsx.o dgelsy.o dgemqrt.o dgeql2.o dgeqlf.o dgeqp3.o dgeqpf.o dgeqr2.o dgeqr2p.o dgeqrf.o dgeqrfp.o dgeqrt2.o dgeqrt3.o dgeqrt.o dgerfs.o dgerfsx.o dgerq2.o dgerqf.o dgesc2.o dgesdd.o dgesvd.o dgesv.o dgesvj.o dgesvx.o dgesvxx.o dgetc2.o dgetf2.o dgetrf.o dgetri.o dgetrs.o dggbak.o dggbal.o dgges.o dggesx.o dggev.o dggevx.o dggglm.o dgghrd.o dgglse.o dggqrf.o dggrqf.o dggsvd.o dggsvp.o dgsvj0.o dgsvj1.o dgtcon.o dgtrfs.o dgtsv.o dgtsvx.o dgttrf.o dgttrs.o dgtts2.o dhgeqz.o dhsein.o dhseqr.o disnan.o dlabad.o dlabrd.o dlacn2.o dlacon.o dlacpy.o dladiv.o dlae2.o dlaebz.o dlaed0.o dlaed1.o dlaed2.o dlaed3.o dlaed4.o dlaed5.o dlaed6.o dlaed7.o dlaed8.o dlaed9.o dlaeda.o dlaein.o dlaev2.o dlaexc.o dlag2.o dlag2s.o dla_gbamv.o dla_gbrcond.o dla_gbrfsx_extended.o dla_gbrpvgrw.o dla_geamv.o dla_gercond.o dla_gerfsx_extended.o dla_gerpvgrw.o dlags2.o dlagtf.o dlagtm.o dlagts.o dlagv2.o dlahqr.o dlahr2.o dlahrd.o dlaic1.o dlaisnan.o dla_lin_berr.o dlaln2.o dlals0.o dlalsa.o dlalsd.o dlamrg.o dlaneg.o dlangb.o dlange.o dlangt.o dlanhs.o dlansb.o dlansf.o dlansp.o dlanst.o dlansy.o dlantb.o dlantp.o dlantr.o dlanv2.o dlapll.o dlapmr.o dlapmt.o dla_porcond.o dla_porfsx_extended.o dla_porpvgrw.o dlapy2.o dlapy3.o dlaqgb.o dlaqge.o dlaqp2.o dlaqps.o dlaqr0.o dlaqr1.o dlaqr2.o dlaqr3.o dlaqr4.o dlaqr5.o dlaqsb.o dlaqsp.o dlaqsy.o dlaqtr.o dlar1v.o dlar2v.o dlarfb.o dlarf.o dlarfg.o dlarfgp.o dlarft.o dlarfx.o dlargv.o dlarnv.o dlarra.o dlarrb.o dlarrc.o dlarrd.o dlarre.o dlarrf.o dlarrj.o dlarrk.o dlarrr.o dlarrv.o dlarscl2.o dlartg.o dlartgp.o dlartgs.o dlartv.o dlaruv.o dlarzb.o dlarz.o dlarzt.o dlas2.o dlascl2.o dlascl.o dlasd0.o dlasd1.o dlasd2.o dlasd3.o dlasd4.o dlasd5.o dlasd6.o dlasd7.o dlasd8.o dlasda.o dlasdq.o dlasdt.o dlaset.o dlasq1.o dlasq2.o dlasq3.o dlasq4.o dlasq5.o dlasq6.o dlasr.o dlasrt.o dlassq.o dlasv2.o dlaswp.o dlasy2.o dla_syamv.o dlasyf.o dlasyf_rook.o dla_syrcond.o dla_syrfsx_extended.o dla_syrpvgrw.o dlat2s.o dlatbs.o dlatdf.o dlatps.o dlatrd.o dlatrs.o dlatrz.o dlatzm.o dlauu2.o dlauum.o dla_wwaddw.o dlazq3.o dlazq4.o dopgtr.o dopmtr.o dorbdb1.o dorbdb2.o dorbdb3.o dorbdb4.o dorbdb5.o dorbdb6.o dorbdb.o dorcsd2by1.o dorcsd.o dorg2l.o dorg2r.o dorgbr.o dorghr.o dorgl2.o dorglq.o dorgql.o dorgqr.o dorgr2.o dorgrq.o dorgtr.o dorm2l.o dorm2r.o dormbr.o dormhr.o dorml2.o dormlq.o dormql.o dormqr.o dormr2.o dormr3.o dormrq.o dormrz.o dormtr.o dpbcon.o dpbequ.o dpbrfs.o dpbstf.o dpbsv.o dpbsvx.o dpbtf2.o dpbtrf.o dpbtrs.o dpftrf.o dpftri.o dpftrs.o dpocon.o dpoequb.o dpoequ.o dporfs.o dporfsx.o dposv.o dposvx.o dposvxx.o dpotf2.o dpotrf.o dpotri.o dpotrs.o dppcon.o dppequ.o dpprfs.o dppsv.o dppsvx.o dpptrf.o dpptri.o dpptrs.o dpstf2.o dpstrf.o dptcon.o dpteqr.o dptrfs.o dptsv.o dptsvx.o dpttrf.o dpttrs.o dptts2.o drscl.o dsbevd.o dsbev.o dsbevx.o dsbgst.o dsbgvd.o dsbgv.o dsbgvx.o dsbtrd.o dsfrk.o dsgesv.o dspcon.o dspevd.o dspev.o dspevx.o dspgst.o dspgvd.o dspgv.o dspgvx.o dsposv.o dsprfs.o dspsv.o dspsvx.o dsptrd.o dsptrf.o dsptri.o dsptrs.o dstebz.o dstedc.o dstegr.o dstein.o dstemr.o dsteqr.o dsterf.o dstevd.o dstev.o dstevr.o dstevx.o dsycon.o dsycon_rook.o dsyconv.o dsyequb.o dsyevd.o dsyev.o dsyevr.o dsyevx.o dsygs2.o dsygst.o dsygvd.o dsygv.o dsygvx.o dsyrfs.o dsyrfsx.o dsysv.o dsysv_rook.o dsysvx.o dsysvxx.o dsyswapr.o dsytd2.o dsytf2.o dsytf2_rook.o dsytrd.o dsytrf.o dsytrf_rook.o dsytri2.o dsytri2x.o dsytri.o dsytri_rook.o dsytrs2.o dsytrs.o dsytrs_rook.o dtbcon.o dtbrfs.o dtbtrs.o dtfsm.o dtftri.o dtfttp.o dtfttr.o dtgevc.o dtgex2.o dtgexc.o dtgsen.o dtgsja.o dtgsna.o dtgsy2.o dtgsyl.o dtpcon.o dtpmqrt.o dtpqrt2.o dtpqrt.o dtprfb.o dtprfs.o dtptri.o dtptrs.o dtpttf.o dtpttr.o dtrcon.o dtrevc.o dtrexc.o dtrrfs.o dtrsen.o dtrsna.o dtrsyl.o dtrti2.o dtrtri.o dtrtrs.o dtrttf.o dtrttp.o dtzrqf.o dtzrzf.o dzsum1.o icmax1.o ieeeck.o ilaclc.o ilaclr.o iladiag.o iladlc.o iladlr.o ilaenv.o ilaprec.o ilaslc.o ilaslr.o ilatrans.o ilauplo.o ilaver.o ilazlc.o ilazlr.o iparmq.o izmax1.o lsamen.o sbbcsd.o sbdsdc.o sbdsqr.o scsum1.o sdisna.o sgbbrd.o sgbcon.o sgbequb.o sgbequ.o sgbrfs.o sgbrfsx.o sgbsv.o sgbsvx.o sgbsvxx.o sgbtf2.o sgbtrf.o sgbtrs.o sgebak.o sgebal.o sgebd2.o sgebrd.o sgecon.o sgeequb.o sgeequ.o sgees.o sgeesx.o sgeev.o sgeevx.o sgegs.o sgegv.o sgehd2.o sgehrd.o sgejsv.o sgelq2.o sgelqf.o sgelsd.o sgels.o sgelss.o sgelsx.o sgelsy.o sgemqrt.o sgeql2.o sgeqlf.o sgeqp3.o sgeqpf.o sgeqr2.o sgeqr2p.o sgeqrf.o sgeqrfp.o sgeqrt2.o sgeqrt3.o sgeqrt.o sgerfs.o sgerfsx.o sgerq2.o sgerqf.o sgesc2.o sgesdd.o sgesvd.o sgesv.o sgesvj.o sgesvx.o sgesvxx.o sgetc2.o sgetf2.o sgetrf.o sgetri.o sgetrs.o sggbak.o sggbal.o sgges.o sggesx.o sggev.o sggevx.o sggglm.o sgghrd.o sgglse.o sggqrf.o sggrqf.o sggsvd.o sggsvp.o sgsvj0.o sgsvj1.o sgtcon.o sgtrfs.o sgtsv.o sgtsvx.o sgttrf.o sgttrs.o sgtts2.o shgeqz.o shsein.o shseqr.o sisnan.o slabad.o slabrd.o slacn2.o slacon.o slacpy.o sladiv.o slae2.o slaebz.o slaed0.o slaed1.o slaed2.o slaed3.o slaed4.o slaed5.o slaed6.o slaed7.o slaed8.o slaed9.o slaeda.o slaein.o slaev2.o slaexc.o slag2d.o slag2.o sla_gbamv.o sla_gbrcond.o sla_gbrfsx_extended.o sla_gbrpvgrw.o sla_geamv.o sla_gercond.o sla_gerfsx_extended.o sla_gerpvgrw.o slags2.o slagtf.o slagtm.o slagts.o slagv2.o slahqr.o slahr2.o slahrd.o slaic1.o slaisnan.o sla_lin_berr.o slaln2.o slals0.o slalsa.o slalsd.o slamrg.o slaneg.o slangb.o slange.o slangt.o slanhs.o slansb.o slansf.o slansp.o slanst.o slansy.o slantb.o slantp.o slantr.o slanv2.o slapll.o slapmr.o slapmt.o sla_porcond.o sla_porfsx_extended.o sla_porpvgrw.o slapy2.o slapy3.o slaqgb.o slaqge.o slaqp2.o slaqps.o slaqr0.o slaqr1.o slaqr2.o slaqr3.o slaqr4.o slaqr5.o slaqsb.o slaqsp.o slaqsy.o slaqtr.o slar1v.o slar2v.o slarfb.o slarf.o slarfg.o slarfgp.o slarft.o slarfx.o slargv.o slarnv.o slarra.o slarrb.o slarrc.o slarrd.o slarre.o slarrf.o slarrj.o slarrk.o slarrr.o slarrv.o slarscl2.o slartg.o slartgp.o slartgs.o slartv.o slaruv.o slarzb.o slarz.o slarzt.o slas2.o slascl2.o slascl.o slasd0.o slasd1.o slasd2.o slasd3.o slasd4.o slasd5.o slasd6.o slasd7.o slasd8.o slasda.o slasdq.o slasdt.o slaset.o slasq1.o slasq2.o slasq3.o slasq4.o slasq5.o slasq6.o slasr.o slasrt.o slassq.o slasv2.o slaswp.o slasy2.o sla_syamv.o slasyf.o slasyf_rook.o sla_syrcond.o sla_syrfsx_extended.o sla_syrpvgrw.o slatbs.o slatdf.o slatps.o slatrd.o slatrs.o slatrz.o slatzm.o slauu2.o slauum.o sla_wwaddw.o slazq3.o slazq4.o sopgtr.o sopmtr.o sorbdb1.o sorbdb2.o sorbdb3.o sorbdb4.o sorbdb5.o sorbdb6.o sorbdb.o sorcsd2by1.o sorcsd.o sorg2l.o sorg2r.o sorgbr.o sorghr.o sorgl2.o sorglq.o sorgql.o sorgqr.o sorgr2.o sorgrq.o sorgtr.o sorm2l.o sorm2r.o sormbr.o sormhr.o sorml2.o sormlq.o sormql.o sormqr.o sormr2.o sormr3.o sormrq.o sormrz.o sormtr.o spbcon.o spbequ.o spbrfs.o spbstf.o spbsv.o spbsvx.o spbtf2.o spbtrf.o spbtrs.o spftrf.o spftri.o spftrs.o spocon.o spoequb.o spoequ.o sporfs.o sporfsx.o sposv.o sposvx.o sposvxx.o spotf2.o spotrf.o spotri.o spotrs.o sppcon.o sppequ.o spprfs.o sppsv.o sppsvx.o spptrf.o spptri.o spptrs.o spstf2.o spstrf.o sptcon.o spteqr.o sptrfs.o sptsv.o sptsvx.o spttrf.o spttrs.o sptts2.o srscl.o ssbevd.o ssbev.o ssbevx.o ssbgst.o ssbgvd.o ssbgv.o ssbgvx.o ssbtrd.o ssfrk.o sspcon.o sspevd.o sspev.o sspevx.o sspgst.o sspgvd.o sspgv.o sspgvx.o ssprfs.o sspsv.o sspsvx.o ssptrd.o ssptrf.o ssptri.o ssptrs.o sstebz.o sstedc.o sstegr.o sstein.o sstemr.o ssteqr.o ssterf.o sstevd.o sstev.o sstevr.o sstevx.o ssycon.o ssycon_rook.o ssyconv.o ssyequb.o ssyevd.o ssyev.o ssyevr.o ssyevx.o ssygs2.o ssygst.o ssygvd.o ssygv.o ssygvx.o ssyrfs.o ssyrfsx.o ssysv.o ssysv_rook.o ssysvx.o ssysvxx.o ssyswapr.o ssytd2.o ssytf2.o ssytf2_rook.o ssytrd.o ssytrf.o ssytrf_rook.o ssytri2.o ssytri2x.o ssytri.o ssytri_rook.o ssytrs2.o ssytrs.o ssytrs_rook.o stbcon.o stbrfs.o stbtrs.o stfsm.o stftri.o stfttp.o stfttr.o stgevc.o stgex2.o stgexc.o stgsen.o stgsja.o stgsna.o stgsy2.o stgsyl.o stpcon.o stpmqrt.o stpqrt2.o stpqrt.o stprfb.o stprfs.o stptri.o stptrs.o stpttf.o stpttr.o strcon.o strevc.o strexc.o strrfs.o strsen.o strsna.o strsyl.o strti2.o strtri.o strtrs.o strttf.o strttp.o stzrqf.o stzrzf.o zbbcsd.o zbdsqr.o zcgesv.o zcposv.o zdrscl.o zgbbrd.o zgbcon.o zgbequb.o zgbequ.o zgbrfs.o zgbrfsx.o zgbsv.o zgbsvx.o zgbsvxx.o zgbtf2.o zgbtrf.o zgbtrs.o zgebak.o zgebal.o zgebd2.o zgebrd.o zgecon.o zgeequb.o zgeequ.o zgees.o zgeesx.o zgeev.o zgeevx.o zgegs.o zgegv.o zgehd2.o zgehrd.o zgelq2.o zgelqf.o zgelsd.o zgels.o zgelss.o zgelsx.o zgelsy.o zgemqrt.o zgeql2.o zgeqlf.o zgeqp3.o zgeqpf.o zgeqr2.o zgeqr2p.o zgeqrf.o zgeqrfp.o zgeqrt2.o zgeqrt3.o zgeqrt.o zgerfs.o zgerfsx.o zgerq2.o zgerqf.o zgesc2.o zgesdd.o zgesvd.o zgesv.o zgesvx.o zgesvxx.o zgetc2.o zgetf2.o zgetrf.o zgetri.o zgetrs.o zggbak.o zggbal.o zgges.o zggesx.o zggev.o zggevx.o zggglm.o zgghrd.o zgglse.o zggqrf.o zggrqf.o zggsvd.o zggsvp.o zgtcon.o zgtrfs.o zgtsv.o zgtsvx.o zgttrf.o zgttrs.o zgtts2.o zhbevd.o zhbev.o zhbevx.o zhbgst.o zhbgvd.o zhbgv.o zhbgvx.o zhbtrd.o zhecon.o zhecon_rook.o zheequb.o zheevd.o zheev.o zheevr.o zheevx.o zhegs2.o zhegst.o zhegvd.o zhegv.o zhegvx.o zherfs.o zherfsx.o zhesv.o zhesv_rook.o zhesvx.o zhesvxx.o zheswapr.o zhetd2.o zhetf2.o zhetf2_rook.o zhetrd.o zhetrf.o zhetrf_rook.o zhetri2.o zhetri2x.o zhetri.o zhetri_rook.o zhetrs2.o zhetrs.o zhetrs_rook.o zhfrk.o zhgeqz.o zhpcon.o zhpevd.o zhpev.o zhpevx.o zhpgst.o zhpgvd.o zhpgv.o zhpgvx.o zhprfs.o zhpsv.o zhpsvx.o zhptrd.o zhptrf.o zhptri.o zhptrs.o zhsein.o zhseqr.o zlabrd.o zlacgv.o zlacn2.o zlacon.o zlacp2.o zlacpy.o zlacrm.o zlacrt.o zladiv.o zlaed0.o zlaed7.o zlaed8.o zlaein.o zlaesy.o zlaev2.o zlag2c.o zla_gbamv.o zla_gbrcond_c.o zla_gbrcond_x.o zla_gbrfsx_extended.o zla_gbrpvgrw.o zla_geamv.o zla_gercond_c.o zla_gercond_x.o zla_gerfsx_extended.o zla_gerpvgrw.o zlags2.o zlagtm.o zla_heamv.o zlahef.o zlahef_rook.o zla_hercond_c.o zla_hercond_x.o zla_herfsx_extended.o zla_herpvgrw.o zlahqr.o zlahr2.o zlahrd.o zlaic1.o zla_lin_berr.o zlals0.o zlalsa.o zlalsd.o zlangb.o zlange.o zlangt.o zlanhb.o zlanhe.o zlanhf.o zlanhp.o zlanhs.o zlanht.o zlansb.o zlansp.o zlansy.o zlantb.o zlantp.o zlantr.o zlapll.o zlapmr.o zlapmt.o zla_porcond_c.o zla_porcond_x.o zla_porfsx_extended.o zla_porpvgrw.o zlaqgb.o zlaqge.o zlaqhb.o zlaqhe.o zlaqhp.o zlaqp2.o zlaqps.o zlaqr0.o zlaqr1.o zlaqr2.o zlaqr3.o zlaqr4.o zlaqr5.o zlaqsb.o zlaqsp.o zlaqsy.o zlar1v.o zlar2v.o zlarcm.o zlarfb.o zlarf.o zlarfg.o zlarfgp.o zlarft.o zlarfx.o zlargv.o zlarnv.o zlarrv.o zlarscl2.o zlartg.o zlartv.o zlarzb.o zlarz.o zlarzt.o zlascl2.o zlascl.o zlaset.o zlasr.o zlassq.o zlaswp.o zla_syamv.o zlasyf.o zlasyf_rook.o zla_syrcond_c.o zla_syrcond_x.o zla_syrfsx_extended.o zla_syrpvgrw.o zlat2c.o zlatbs.o zlatdf.o zlatps.o zlatrd.o zlatrs.o zlatrz.o zlatzm.o zlauu2.o zlauum.o zla_wwaddw.o zpbcon.o zpbequ.o zpbrfs.o zpbstf.o zpbsv.o zpbsvx.o zpbtf2.o zpbtrf.o zpbtrs.o zpftrf.o zpftri.o zpftrs.o zpocon.o zpoequb.o zpoequ.o zporfs.o zporfsx.o zposv.o zposvx.o zposvxx.o zpotf2.o zpotrf.o zpotri.o zpotrs.o zppcon.o zppequ.o zpprfs.o zppsv.o zppsvx.o zpptrf.o zpptri.o zpptrs.o zpstf2.o zpstrf.o zptcon.o zpteqr.o zptrfs.o zptsv.o zptsvx.o zpttrf.o zpttrs.o zptts2.o zrot.o zspcon.o zspmv.o zspr.o zsprfs.o zspsv.o zspsvx.o zsptrf.o zsptri.o zsptrs.o zstedc.o zstegr.o zstein.o zstemr.o zsteqr.o zsycon.o zsycon_rook.o zsyconv.o zsyequb.o zsymv.o zsyr.o zsyrfs.o zsyrfsx.o zsysv.o zsysv_rook.o zsysvx.o zsysvxx.o zsyswapr.o zsytf2.o zsytf2_rook.o zsytrf.o zsytrf_rook.o zsytri2.o zsytri2x.o zsytri.o zsytri_rook.o zsytrs2.o zsytrs.o zsytrs_rook.o ztbcon.o ztbrfs.o ztbtrs.o ztfsm.o ztftri.o ztfttp.o ztfttr.o ztgevc.o ztgex2.o ztgexc.o ztgsen.o ztgsja.o ztgsna.o ztgsy2.o ztgsyl.o ztpcon.o ztpmqrt.o ztpqrt2.o ztpqrt.o ztprfb.o ztprfs.o ztptri.o ztptrs.o ztpttf.o ztpttr.o ztrcon.o ztrevc.o ztrexc.o ztrrfs.o ztrsen.o ztrsna.o ztrsyl.o ztrti2.o ztrtri.o ztrtrs.o ztrttf.o ztrttp.o ztzrqf.o ztzrzf.o zunbdb1.o zunbdb2.o zunbdb3.o zunbdb4.o zunbdb5.o zunbdb6.o zunbdb.o zuncsd2by1.o zuncsd.o zung2l.o zung2r.o zungbr.o zunghr.o zungl2.o zunglq.o zungql.o zungqr.o zungr2.o zungrq.o zungtr.o zunm2l.o zunm2r.o zunmbr.o zunmhr.o zunml2.o zunmlq.o zunmql.o zunmqr.o zunmr2.o zunmr3.o zunmrq.o zunmrz.o zunmtr.o zupgtr.o zupmtr.o
/usr/bin/rm -f slaruv.o dlaruv.o cbbcsd.o cbdsqr.o cgbbrd.o cgbcon.o cgbequb.o cgbequ.o cgbrfs.o cgbrfsx.o cgbsv.o cgbsvx.o cgbsvxx.o cgbtf2.o cgbtrf.o cgbtrs.o cgebak.o cgebal.o cgebd2.o cgebrd.o cgecon.o cgeequb.o cgeequ.o cgees.o cgeesx.o cgeev.o cgeevx.o cgegs.o cgegv.o cgehd2.o cgehrd.o cgelq2.o cgelqf.o cgelsd.o cgels.o cgelss.o cgelsx.o cgelsy.o cgemqrt.o cgeql2.o cgeqlf.o cgeqp3.o cgeqpf.o cgeqr2.o cgeqr2p.o cgeqrf.o cgeqrfp.o cgeqrt2.o cgeqrt3.o cgeqrt.o cgerfs.o cgerfsx.o cgerq2.o cgerqf.o cgesc2.o cgesdd.o cgesvd.o cgesv.o cgesvx.o cgesvxx.o cgetc2.o cgetf2.o cgetrf.o cgetri.o cgetrs.o cggbak.o cggbal.o cgges.o cggesx.o cggev.o cggevx.o cggglm.o cgghrd.o cgglse.o cggqrf.o cggrqf.o cggsvd.o cggsvp.o cgtcon.o cgtrfs.o cgtsv.o cgtsvx.o cgttrf.o cgttrs.o cgtts2.o chbevd.o chbev.o chbevx.o chbgst.o chbgvd.o chbgv.o chbgvx.o chbtrd.o checon.o checon_rook.o cheequb.o cheevd.o cheev.o cheevr.o cheevx.o chegs2.o chegst.o chegvd.o chegv.o chegvx.o cherfs.o cherfsx.o chesv.o chesv_rook.o chesvx.o chesvxx.o cheswapr.o chetd2.o chetf2.o chetf2_rook.o chetrd.o chetrf.o chetrf_rook.o chetri2.o chetri2x.o chetri.o chetri_rook.o chetrs2.o chetrs.o chetrs_rook.o chfrk.o chgeqz.o chla_transtype.o chpcon.o chpevd.o chpev.o chpevx.o chpgst.o chpgvd.o chpgv.o chpgvx.o chprfs.o chpsv.o chpsvx.o chptrd.o chptrf.o chptri.o chptrs.o chsein.o chseqr.o clabrd.o clacgv.o clacn2.o clacon.o clacp2.o clacpy.o clacrm.o clacrt.o cladiv.o claed0.o claed7.o claed8.o claein.o claesy.o claev2.o clag2z.o cla_gbamv.o cla_gbrcond_c.o cla_gbrcond_x.o cla_gbrfsx_extended.o cla_gbrpvgrw.o cla_geamv.o cla_gercond_c.o cla_gercond_x.o cla_gerfsx_extended.o cla_gerpvgrw.o clags2.o clagtm.o cla_heamv.o clahef.o clahef_rook.o cla_hercond_c.o cla_hercond_x.o cla_herfsx_extended.o cla_herpvgrw.o clahqr.o clahr2.o clahrd.o claic1.o cla_lin_berr.o clals0.o clalsa.o clalsd.o clangb.o clange.o clangt.o clanhb.o clanhe.o clanhf.o clanhp.o clanhs.o clanht.o clansb.o clansp.o clansy.o clantb.o clantp.o clantr.o clapll.o clapmr.o clapmt.o cla_porcond_c.o cla_porcond_x.o cla_porfsx_extended.o cla_porpvgrw.o claqgb.o claqge.o claqhb.o claqhe.o claqhp.o claqp2.o claqps.o claqr0.o claqr1.o claqr2.o claqr3.o claqr4.o claqr5.o claqsb.o claqsp.o claqsy.o clar1v.o clar2v.o clarcm.o clarfb.o clarf.o clarfg.o clarfgp.o clarft.o clarfx.o clargv.o clarnv.o clarrv.o clarscl2.o clartg.o clartv.o clarzb.o clarz.o clarzt.o clascl2.o clascl.o claset.o clasr.o classq.o claswp.o cla_syamv.o clasyf.o clasyf_rook.o cla_syrcond_c.o cla_syrcond_x.o cla_syrfsx_extended.o cla_syrpvgrw.o clatbs.o clatdf.o clatps.o clatrd.o clatrs.o clatrz.o clatzm.o clauu2.o clauum.o cla_wwaddw.o cpbcon.o cpbequ.o cpbrfs.o cpbstf.o cpbsv.o cpbsvx.o cpbtf2.o cpbtrf.o cpbtrs.o cpftrf.o cpftri.o cpftrs.o cpocon.o cpoequb.o cpoequ.o cporfs.o cporfsx.o cposv.o cposvx.o cposvxx.o cpotf2.o cpotrf.o cpotri.o cpotrs.o cppcon.o cppequ.o cpprfs.o cppsv.o cppsvx.o cpptrf.o cpptri.o cpptrs.o cpstf2.o cpstrf.o cptcon.o cpteqr.o cptrfs.o cptsv.o cptsvx.o cpttrf.o cpttrs.o cptts2.o crot.o cspcon.o cspmv.o cspr.o csprfs.o cspsv.o cspsvx.o csptrf.o csptri.o csptrs.o csrscl.o cstedc.o cstegr.o cstein.o cstemr.o csteqr.o csycon.o csycon_rook.o csyconv.o csyequb.o csymv.o csyr.o csyrfs.o csyrfsx.o csysv.o csysv_rook.o csysvx.o csysvxx.o csyswapr.o csytf2.o csytf2_rook.o csytrf.o csytrf_rook.o csytri2.o csytri2x.o csytri.o csytri_rook.o csytrs2.o csytrs.o csytrs_rook.o ctbcon.o ctbrfs.o ctbtrs.o ctfsm.o ctftri.o ctfttp.o ctfttr.o ctgevc.o ctgex2.o ctgexc.o ctgsen.o ctgsja.o ctgsna.o ctgsy2.o ctgsyl.o ctpcon.o ctpmqrt.o ctpqrt2.o ctpqrt.o ctprfb.o ctprfs.o ctptri.o ctptrs.o ctpttf.o ctpttr.o ctrcon.o ctrevc.o ctrexc.o ctrrfs.o ctrsen.o ctrsna.o ctrsyl.o ctrti2.o ctrtri.o ctrtrs.o ctrttf.o ctrttp.o ctzrqf.o ctzrzf.o cunbdb1.o cunbdb2.o cunbdb3.o cunbdb4.o cunbdb5.o cunbdb6.o cunbdb.o cuncsd2by1.o cuncsd.o cung2l.o cung2r.o cungbr.o cunghr.o cungl2.o cunglq.o cungql.o cungqr.o cungr2.o cungrq.o cungtr.o cunm2l.o cunm2r.o cunmbr.o cunmhr.o cunml2.o cunmlq.o cunmql.o cunmqr.o cunmr2.o cunmr3.o cunmrq.o cunmrz.o cunmtr.o cupgtr.o cupmtr.o dbbcsd.o dbdsdc.o dbdsqr.o ddisna.o dgbbrd.o dgbcon.o dgbequb.o dgbequ.o dgbrfs.o dgbrfsx.o dgbsv.o dgbsvx.o dgbsvxx.o dgbtf2.o dgbtrf.o dgbtrs.o dgebak.o dgebal.o dgebd2.o dgebrd.o dgecon.o dgeequb.o dgeequ.o dgees.o dgeesx.o dgeev.o dgeevx.o dgegs.o dgegv.o dgehd2.o dgehrd.o dgejsv.o dgelq2.o dgelqf.o dgelsd.o dgels.o dgelss.o dgelsx.o dgelsy.o dgemqrt.o dgeql2.o dgeqlf.o dgeqp3.o dgeqpf.o dgeqr2.o dgeqr2p.o dgeqrf.o dgeqrfp.o dgeqrt2.o dgeqrt3.o dgeqrt.o dgerfs.o dgerfsx.o dgerq2.o dgerqf.o dgesc2.o dgesdd.o dgesvd.o dgesv.o dgesvj.o dgesvx.o dgesvxx.o dgetc2.o dgetf2.o dgetrf.o dgetri.o dgetrs.o dggbak.o dggbal.o dgges.o dggesx.o dggev.o dggevx.o dggglm.o dgghrd.o dgglse.o dggqrf.o dggrqf.o dggsvd.o dggsvp.o dgsvj0.o dgsvj1.o dgtcon.o dgtrfs.o dgtsv.o dgtsvx.o dgttrf.o dgttrs.o dgtts2.o dhgeqz.o dhsein.o dhseqr.o disnan.o dlabad.o dlabrd.o dlacn2.o dlacon.o dlacpy.o dladiv.o dlae2.o dlaebz.o dlaed0.o dlaed1.o dlaed2.o dlaed3.o dlaed4.o dlaed5.o dlaed6.o dlaed7.o dlaed8.o dlaed9.o dlaeda.o dlaein.o dlaev2.o dlaexc.o dlag2.o dlag2s.o dla_gbamv.o dla_gbrcond.o dla_gbrfsx_extended.o dla_gbrpvgrw.o dla_geamv.o dla_gercond.o dla_gerfsx_extended.o dla_gerpvgrw.o dlags2.o dlagtf.o dlagtm.o dlagts.o dlagv2.o dlahqr.o dlahr2.o dlahrd.o dlaic1.o dlaisnan.o dla_lin_berr.o dlaln2.o dlals0.o dlalsa.o dlalsd.o dlamrg.o dlaneg.o dlangb.o dlange.o dlangt.o dlanhs.o dlansb.o dlansf.o dlansp.o dlanst.o dlansy.o dlantb.o dlantp.o dlantr.o dlanv2.o dlapll.o dlapmr.o dlapmt.o dla_porcond.o dla_porfsx_extended.o dla_porpvgrw.o dlapy2.o dlapy3.o dlaqgb.o dlaqge.o dlaqp2.o dlaqps.o dlaqr0.o dlaqr1.o dlaqr2.o dlaqr3.o dlaqr4.o dlaqr5.o dlaqsb.o dlaqsp.o dlaqsy.o dlaqtr.o dlar1v.o dlar2v.o dlarfb.o dlarf.o dlarfg.o dlarfgp.o dlarft.o dlarfx.o dlargv.o dlarnv.o dlarra.o dlarrb.o dlarrc.o dlarrd.o dlarre.o dlarrf.o dlarrj.o dlarrk.o dlarrr.o dlarrv.o dlarscl2.o dlartg.o dlartgp.o dlartgs.o dlartv.o dlaruv.o dlarzb.o dlarz.o dlarzt.o dlas2.o dlascl2.o dlascl.o dlasd0.o dlasd1.o dlasd2.o dlasd3.o dlasd4.o dlasd5.o dlasd6.o dlasd7.o dlasd8.o dlasda.o dlasdq.o dlasdt.o dlaset.o dlasq1.o dlasq2.o dlasq3.o dlasq4.o dlasq5.o dlasq6.o dlasr.o dlasrt.o dlassq.o dlasv2.o dlaswp.o dlasy2.o dla_syamv.o dlasyf.o dlasyf_rook.o dla_syrcond.o dla_syrfsx_extended.o dla_syrpvgrw.o dlat2s.o dlatbs.o dlatdf.o dlatps.o dlatrd.o dlatrs.o dlatrz.o dlatzm.o dlauu2.o dlauum.o dla_wwaddw.o dlazq3.o dlazq4.o dopgtr.o dopmtr.o dorbdb1.o dorbdb2.o dorbdb3.o dorbdb4.o dorbdb5.o dorbdb6.o dorbdb.o dorcsd2by1.o dorcsd.o dorg2l.o dorg2r.o dorgbr.o dorghr.o dorgl2.o dorglq.o dorgql.o dorgqr.o dorgr2.o dorgrq.o dorgtr.o dorm2l.o dorm2r.o dormbr.o dormhr.o dorml2.o dormlq.o dormql.o dormqr.o dormr2.o dormr3.o dormrq.o dormrz.o dormtr.o dpbcon.o dpbequ.o dpbrfs.o dpbstf.o dpbsv.o dpbsvx.o dpbtf2.o dpbtrf.o dpbtrs.o dpftrf.o dpftri.o dpftrs.o dpocon.o dpoequb.o dpoequ.o dporfs.o dporfsx.o dposv.o dposvx.o dposvxx.o dpotf2.o dpotrf.o dpotri.o dpotrs.o dppcon.o dppequ.o dpprfs.o dppsv.o dppsvx.o dpptrf.o dpptri.o dpptrs.o dpstf2.o dpstrf.o dptcon.o dpteqr.o dptrfs.o dptsv.o dptsvx.o dpttrf.o dpttrs.o dptts2.o drscl.o dsbevd.o dsbev.o dsbevx.o dsbgst.o dsbgvd.o dsbgv.o dsbgvx.o dsbtrd.o dsfrk.o dsgesv.o dspcon.o dspevd.o dspev.o dspevx.o dspgst.o dspgvd.o dspgv.o dspgvx.o dsposv.o dsprfs.o dspsv.o dspsvx.o dsptrd.o dsptrf.o dsptri.o dsptrs.o dstebz.o dstedc.o dstegr.o dstein.o dstemr.o dsteqr.o dsterf.o dstevd.o dstev.o dstevr.o dstevx.o dsycon.o dsycon_rook.o dsyconv.o dsyequb.o dsyevd.o dsyev.o dsyevr.o dsyevx.o dsygs2.o dsygst.o dsygvd.o dsygv.o dsygvx.o dsyrfs.o dsyrfsx.o dsysv.o dsysv_rook.o dsysvx.o dsysvxx.o dsyswapr.o dsytd2.o dsytf2.o dsytf2_rook.o dsytrd.o dsytrf.o dsytrf_rook.o dsytri2.o dsytri2x.o dsytri.o dsytri_rook.o dsytrs2.o dsytrs.o dsytrs_rook.o dtbcon.o dtbrfs.o dtbtrs.o dtfsm.o dtftri.o dtfttp.o dtfttr.o dtgevc.o dtgex2.o dtgexc.o dtgsen.o dtgsja.o dtgsna.o dtgsy2.o dtgsyl.o dtpcon.o dtpmqrt.o dtpqrt2.o dtpqrt.o dtprfb.o dtprfs.o dtptri.o dtptrs.o dtpttf.o dtpttr.o dtrcon.o dtrevc.o dtrexc.o dtrrfs.o dtrsen.o dtrsna.o dtrsyl.o dtrti2.o dtrtri.o dtrtrs.o dtrttf.o dtrttp.o dtzrqf.o dtzrzf.o dzsum1.o icmax1.o ieeeck.o ilaclc.o ilaclr.o iladiag.o iladlc.o iladlr.o ilaenv.o ilaprec.o ilaslc.o ilaslr.o ilatrans.o ilauplo.o ilaver.o ilazlc.o ilazlr.o iparmq.o izmax1.o lsamen.o sbbcsd.o sbdsdc.o sbdsqr.o scsum1.o sdisna.o sgbbrd.o sgbcon.o sgbequb.o sgbequ.o sgbrfs.o sgbrfsx.o sgbsv.o sgbsvx.o sgbsvxx.o sgbtf2.o sgbtrf.o sgbtrs.o sgebak.o sgebal.o sgebd2.o sgebrd.o sgecon.o sgeequb.o sgeequ.o sgees.o sgeesx.o sgeev.o sgeevx.o sgegs.o sgegv.o sgehd2.o sgehrd.o sgejsv.o sgelq2.o sgelqf.o sgelsd.o sgels.o sgelss.o sgelsx.o sgelsy.o sgemqrt.o sgeql2.o sgeqlf.o sgeqp3.o sgeqpf.o sgeqr2.o sgeqr2p.o sgeqrf.o sgeqrfp.o sgeqrt2.o sgeqrt3.o sgeqrt.o sgerfs.o sgerfsx.o sgerq2.o sgerqf.o sgesc2.o sgesdd.o sgesvd.o sgesv.o sgesvj.o sgesvx.o sgesvxx.o sgetc2.o sgetf2.o sgetrf.o sgetri.o sgetrs.o sggbak.o sggbal.o sgges.o sggesx.o sggev.o sggevx.o sggglm.o sgghrd.o sgglse.o sggqrf.o sggrqf.o sggsvd.o sggsvp.o sgsvj0.o sgsvj1.o sgtcon.o sgtrfs.o sgtsv.o sgtsvx.o sgttrf.o sgttrs.o sgtts2.o shgeqz.o shsein.o shseqr.o sisnan.o slabad.o slabrd.o slacn2.o slacon.o slacpy.o sladiv.o slae2.o slaebz.o slaed0.o slaed1.o slaed2.o slaed3.o slaed4.o slaed5.o slaed6.o slaed7.o slaed8.o slaed9.o slaeda.o slaein.o slaev2.o slaexc.o slag2d.o slag2.o sla_gbamv.o sla_gbrcond.o sla_gbrfsx_extended.o sla_gbrpvgrw.o sla_geamv.o sla_gercond.o sla_gerfsx_extended.o sla_gerpvgrw.o slags2.o slagtf.o slagtm.o slagts.o slagv2.o slahqr.o slahr2.o slahrd.o slaic1.o slaisnan.o sla_lin_berr.o slaln2.o slals0.o slalsa.o slalsd.o slamrg.o slaneg.o slangb.o slange.o slangt.o slanhs.o slansb.o slansf.o slansp.o slanst.o slansy.o slantb.o slantp.o slantr.o slanv2.o slapll.o slapmr.o slapmt.o sla_porcond.o sla_porfsx_extended.o sla_porpvgrw.o slapy2.o slapy3.o slaqgb.o slaqge.o slaqp2.o slaqps.o slaqr0.o slaqr1.o slaqr2.o slaqr3.o slaqr4.o slaqr5.o slaqsb.o slaqsp.o slaqsy.o slaqtr.o slar1v.o slar2v.o slarfb.o slarf.o slarfg.o slarfgp.o slarft.o slarfx.o slargv.o slarnv.o slarra.o slarrb.o slarrc.o slarrd.o slarre.o slarrf.o slarrj.o slarrk.o slarrr.o slarrv.o slarscl2.o slartg.o slartgp.o slartgs.o slartv.o slaruv.o slarzb.o slarz.o slarzt.o slas2.o slascl2.o slascl.o slasd0.o slasd1.o slasd2.o slasd3.o slasd4.o slasd5.o slasd6.o slasd7.o slasd8.o slasda.o slasdq.o slasdt.o slaset.o slasq1.o slasq2.o slasq3.o slasq4.o slasq5.o slasq6.o slasr.o slasrt.o slassq.o slasv2.o slaswp.o slasy2.o sla_syamv.o slasyf.o slasyf_rook.o sla_syrcond.o sla_syrfsx_extended.o sla_syrpvgrw.o slatbs.o slatdf.o slatps.o slatrd.o slatrs.o slatrz.o slatzm.o slauu2.o slauum.o sla_wwaddw.o slazq3.o slazq4.o sopgtr.o sopmtr.o sorbdb1.o sorbdb2.o sorbdb3.o sorbdb4.o sorbdb5.o sorbdb6.o sorbdb.o sorcsd2by1.o sorcsd.o sorg2l.o sorg2r.o sorgbr.o sorghr.o sorgl2.o sorglq.o sorgql.o sorgqr.o sorgr2.o sorgrq.o sorgtr.o sorm2l.o sorm2r.o sormbr.o sormhr.o sorml2.o sormlq.o sormql.o sormqr.o sormr2.o sormr3.o sormrq.o sormrz.o sormtr.o spbcon.o spbequ.o spbrfs.o spbstf.o spbsv.o spbsvx.o spbtf2.o spbtrf.o spbtrs.o spftrf.o spftri.o spftrs.o spocon.o spoequb.o spoequ.o sporfs.o sporfsx.o sposv.o sposvx.o sposvxx.o spotf2.o spotrf.o spotri.o spotrs.o sppcon.o sppequ.o spprfs.o sppsv.o sppsvx.o spptrf.o spptri.o spptrs.o spstf2.o spstrf.o sptcon.o spteqr.o sptrfs.o sptsv.o sptsvx.o spttrf.o spttrs.o sptts2.o srscl.o ssbevd.o ssbev.o ssbevx.o ssbgst.o ssbgvd.o ssbgv.o ssbgvx.o ssbtrd.o ssfrk.o sspcon.o sspevd.o sspev.o sspevx.o sspgst.o sspgvd.o sspgv.o sspgvx.o ssprfs.o sspsv.o sspsvx.o ssptrd.o ssptrf.o ssptri.o ssptrs.o sstebz.o sstedc.o sstegr.o sstein.o sstemr.o ssteqr.o ssterf.o sstevd.o sstev.o sstevr.o sstevx.o ssycon.o ssycon_rook.o ssyconv.o ssyequb.o ssyevd.o ssyev.o ssyevr.o ssyevx.o ssygs2.o ssygst.o ssygvd.o ssygv.o ssygvx.o ssyrfs.o ssyrfsx.o ssysv.o ssysv_rook.o ssysvx.o ssysvxx.o ssyswapr.o ssytd2.o ssytf2.o ssytf2_rook.o ssytrd.o ssytrf.o ssytrf_rook.o ssytri2.o ssytri2x.o ssytri.o ssytri_rook.o ssytrs2.o ssytrs.o ssytrs_rook.o stbcon.o stbrfs.o stbtrs.o stfsm.o stftri.o stfttp.o stfttr.o stgevc.o stgex2.o stgexc.o stgsen.o stgsja.o stgsna.o stgsy2.o stgsyl.o stpcon.o stpmqrt.o stpqrt2.o stpqrt.o stprfb.o stprfs.o stptri.o stptrs.o stpttf.o stpttr.o strcon.o strevc.o strexc.o strrfs.o strsen.o strsna.o strsyl.o strti2.o strtri.o strtrs.o strttf.o strttp.o stzrqf.o stzrzf.o zbbcsd.o zbdsqr.o zcgesv.o zcposv.o zdrscl.o zgbbrd.o zgbcon.o zgbequb.o zgbequ.o zgbrfs.o zgbrfsx.o zgbsv.o zgbsvx.o zgbsvxx.o zgbtf2.o zgbtrf.o zgbtrs.o zgebak.o zgebal.o zgebd2.o zgebrd.o zgecon.o zgeequb.o zgeequ.o zgees.o zgeesx.o zgeev.o zgeevx.o zgegs.o zgegv.o zgehd2.o zgehrd.o zgelq2.o zgelqf.o zgelsd.o zgels.o zgelss.o zgelsx.o zgelsy.o zgemqrt.o zgeql2.o zgeqlf.o zgeqp3.o zgeqpf.o zgeqr2.o zgeqr2p.o zgeqrf.o zgeqrfp.o zgeqrt2.o zgeqrt3.o zgeqrt.o zgerfs.o zgerfsx.o zgerq2.o zgerqf.o zgesc2.o zgesdd.o zgesvd.o zgesv.o zgesvx.o zgesvxx.o zgetc2.o zgetf2.o zgetrf.o zgetri.o zgetrs.o zggbak.o zggbal.o zgges.o zggesx.o zggev.o zggevx.o zggglm.o zgghrd.o zgglse.o zggqrf.o zggrqf.o zggsvd.o zggsvp.o zgtcon.o zgtrfs.o zgtsv.o zgtsvx.o zgttrf.o zgttrs.o zgtts2.o zhbevd.o zhbev.o zhbevx.o zhbgst.o zhbgvd.o zhbgv.o zhbgvx.o zhbtrd.o zhecon.o zhecon_rook.o zheequb.o zheevd.o zheev.o zheevr.o zheevx.o zhegs2.o zhegst.o zhegvd.o zhegv.o zhegvx.o zherfs.o zherfsx.o zhesv.o zhesv_rook.o zhesvx.o zhesvxx.o zheswapr.o zhetd2.o zhetf2.o zhetf2_rook.o zhetrd.o zhetrf.o zhetrf_rook.o zhetri2.o zhetri2x.o zhetri.o zhetri_rook.o zhetrs2.o zhetrs.o zhetrs_rook.o zhfrk.o zhgeqz.o zhpcon.o zhpevd.o zhpev.o zhpevx.o zhpgst.o zhpgvd.o zhpgv.o zhpgvx.o zhprfs.o zhpsv.o zhpsvx.o zhptrd.o zhptrf.o zhptri.o zhptrs.o zhsein.o zhseqr.o zlabrd.o zlacgv.o zlacn2.o zlacon.o zlacp2.o zlacpy.o zlacrm.o zlacrt.o zladiv.o zlaed0.o zlaed7.o zlaed8.o zlaein.o zlaesy.o zlaev2.o zlag2c.o zla_gbamv.o zla_gbrcond_c.o zla_gbrcond_x.o zla_gbrfsx_extended.o zla_gbrpvgrw.o zla_geamv.o zla_gercond_c.o zla_gercond_x.o zla_gerfsx_extended.o zla_gerpvgrw.o zlags2.o zlagtm.o zla_heamv.o zlahef.o zlahef_rook.o zla_hercond_c.o zla_hercond_x.o zla_herfsx_extended.o zla_herpvgrw.o zlahqr.o zlahr2.o zlahrd.o zlaic1.o zla_lin_berr.o zlals0.o zlalsa.o zlalsd.o zlangb.o zlange.o zlangt.o zlanhb.o zlanhe.o zlanhf.o zlanhp.o zlanhs.o zlanht.o zlansb.o zlansp.o zlansy.o zlantb.o zlantp.o zlantr.o zlapll.o zlapmr.o zlapmt.o zla_porcond_c.o zla_porcond_x.o zla_porfsx_extended.o zla_porpvgrw.o zlaqgb.o zlaqge.o zlaqhb.o zlaqhe.o zlaqhp.o zlaqp2.o zlaqps.o zlaqr0.o zlaqr1.o zlaqr2.o zlaqr3.o zlaqr4.o zlaqr5.o zlaqsb.o zlaqsp.o zlaqsy.o zlar1v.o zlar2v.o zlarcm.o zlarfb.o zlarf.o zlarfg.o zlarfgp.o zlarft.o zlarfx.o zlargv.o zlarnv.o zlarrv.o zlarscl2.o zlartg.o zlartv.o zlarzb.o zlarz.o zlarzt.o zlascl2.o zlascl.o zlaset.o zlasr.o zlassq.o zlaswp.o zla_syamv.o zlasyf.o zlasyf_rook.o zla_syrcond_c.o zla_syrcond_x.o zla_syrfsx_extended.o zla_syrpvgrw.o zlat2c.o zlatbs.o zlatdf.o zlatps.o zlatrd.o zlatrs.o zlatrz.o zlatzm.o zlauu2.o zlauum.o zla_wwaddw.o zpbcon.o zpbequ.o zpbrfs.o zpbstf.o zpbsv.o zpbsvx.o zpbtf2.o zpbtrf.o zpbtrs.o zpftrf.o zpftri.o zpftrs.o zpocon.o zpoequb.o zpoequ.o zporfs.o zporfsx.o zposv.o zposvx.o zposvxx.o zpotf2.o zpotrf.o zpotri.o zpotrs.o zppcon.o zppequ.o zpprfs.o zppsv.o zppsvx.o zpptrf.o zpptri.o zpptrs.o zpstf2.o zpstrf.o zptcon.o zpteqr.o zptrfs.o zptsv.o zptsvx.o zpttrf.o zpttrs.o zptts2.o zrot.o zspcon.o zspmv.o zspr.o zsprfs.o zspsv.o zspsvx.o zsptrf.o zsptri.o zsptrs.o zstedc.o zstegr.o zstein.o zstemr.o zsteqr.o zsycon.o zsycon_rook.o zsyconv.o zsyequb.o zsymv.o zsyr.o zsyrfs.o zsyrfsx.o zsysv.o zsysv_rook.o zsysvx.o zsysvxx.o zsyswapr.o zsytf2.o zsytf2_rook.o zsytrf.o zsytrf_rook.o zsytri2.o zsytri2x.o zsytri.o zsytri_rook.o zsytrs2.o zsytrs.o zsytrs_rook.o ztbcon.o ztbrfs.o ztbtrs.o ztfsm.o ztftri.o ztfttp.o ztfttr.o ztgevc.o ztgex2.o ztgexc.o ztgsen.o ztgsja.o ztgsna.o ztgsy2.o ztgsyl.o ztpcon.o ztpmqrt.o ztpqrt2.o ztpqrt.o ztprfb.o ztprfs.o ztptri.o ztptrs.o ztpttf.o ztpttr.o ztrcon.o ztrevc.o ztrexc.o ztrrfs.o ztrsen.o ztrsna.o ztrsyl.o ztrti2.o ztrtri.o ztrtrs.o ztrttf.o ztrttp.o ztzrqf.o ztzrzf.o zunbdb1.o zunbdb2.o zunbdb3.o zunbdb4.o zunbdb5.o zunbdb6.o zunbdb.o zuncsd2by1.o zuncsd.o zung2l.o zung2r.o zungbr.o zunghr.o zungl2.o zunglq.o zungql.o zungqr.o zungr2.o zungrq.o zungtr.o zunm2l.o zunm2r.o zunmbr.o zunmhr.o zunml2.o zunmlq.o zunmql.o zunmqr.o zunmr2.o zunmr3.o zunmrq.o zunmrz.o zunmtr.o zupgtr.o zupmtr.o
make[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/fblaslapack-3.4.2/lapack'
cd lapack-extra; make lib FC="mpif90" FOPTFLAGS="-fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O -fopenmp " FNOOPT="-O0 -fPIC " AR="/usr/bin/ar" AR_FLAGS="cr" RM="/usr/bin/rm -f" LIBNAME="libflapack.a"
make[1]: Entering directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/fblaslapack-3.4.2/lapack-extra'
mpif90 -c -O0 -fPIC slamch.f dlamch.f
mpif90 -c -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O -fopenmp ilaver.f
/usr/bin/ar cr ../libflapack.a slamch.o dlamch.o ilaver.o
/usr/bin/rm -f slamch.o dlamch.o ilaver.o
make[1]: Leaving directory '/tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/fblaslapack-3.4.2/lapack-extra'
/usr/bin/ranlib libflapack.a
Executing: cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/fblaslapack-3.4.2 && mkdir -p /home/wangzl/moose-compilers/petsc-3.11.4/lib && cp -f libfblas.a libflapack.a /home/wangzl/moose-compilers/petsc-3.11.4/lib
********Output of running make on FBLASLAPACK follows *******
/usr/bin/ranlib libflapack.acher2.f:257:0:
IY = KY
Warning: ���ky��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cher2.f:256:0:
IX = KX
Warning: ���kx��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cher2.f:175:0:
INTEGER I,INFO,IX,IY,J,JX,JY,KX,KY
Warning: ���jy��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cher2.f:175:0: Warning: ���jx��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cher.f:227:0:
IX = KX
cherk.f:358:30:
RTEMP = RTEMP + CONJG(A(L,J))*A(L,J)
1
Warning: Possible change of value in conversion from COMPLEX(4) to REAL(4) at (1) [-Wconversion]
cherk.f:370:30:
1
chpr2.f:253:0:
IY = KY
chpr2.f:252:0:
IX = KX
chpr2.f:170:0:
INTEGER I,INFO,IX,IY,J,JX,JY,K,KK,KX,KY
chpr2.f:170:0: Warning: ���jx��� may be used uninitialized in this function [-Wmaybe-uninitialized]
chpr.f:223:0:
IX = KX
ctbmv.f:314:0:
KX = KX + (N-1)*INCX
ctbsv.f:288:0:
ctpmv.f:270:0:
ctpsv.f:241:0:
JX = KX + (N-1)*INCX
ctrmv.f:268:0:
ctrsv.f:173:0:
INTEGER I,INFO,IX,J,JX,KX
drotmg.f:225:0:
DH22 = DH22*GAM
Warning: ���dh22��� may be used uninitialized in this function [-Wmaybe-uninitialized]
drotmg.f:224:0:
DH21 = DH21*GAM
Warning: ���dh21��� may be used uninitialized in this function [-Wmaybe-uninitialized]
drotmg.f:202:0:
DH12 = DH12*GAM
Warning: ���dh12��� may be used uninitialized in this function [-Wmaybe-uninitialized]
drotmg.f:201:0:
DH11 = DH11*GAM
Warning: ���dh11��� may be used uninitialized in this function [-Wmaybe-uninitialized]
drotmg.f:184:0:
IF (DFLAG.EQ.ZERO) THEN
Warning: ���dflag��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dspr2.f:245:0:
AP(K) = AP(K) + X(IX)*TEMP1 + Y(IY)*TEMP2
dspr2.f:245:0: Warning: ���kx��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dspr2.f:240:0:
TEMP1 = ALPHA*Y(JY)
dspr2.f:239:0:
IF ((X(JX).NE.ZERO) .OR. (Y(JY).NE.ZERO)) THEN
dspr.f:220:0:
JX = JX + INCX
dsyr2.f:252:0:
A(I,J) = A(I,J) + X(IX)*TEMP1 + Y(IY)*TEMP2
dsyr2.f:252:0: Warning: ���kx��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dsyr2.f:246:0:
dsyr2.f:246:0: Warning: ���jx��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dsyr.f:223:0:
dtbmv.f:313:0:
dtbsv.f:287:0:
dtpmv.f:266:0:
dtpsv.f:305:0:
TEMP = X(JX)
dtrmv.f:267:0:
dtrsv.f:167:0:
sdsdot.f:228:18:
SDSDOT = DSDOT
1
Warning: Possible change of value in conversion from REAL(8) to REAL(4) at (1) [-Wconversion]
sdsdot.f:253:15:
SDSDOT = DSDOT
1
srotmg.f:225:0:
SH22 = SH22*GAM
Warning: ���sh22��� may be used uninitialized in this function [-Wmaybe-uninitialized]
srotmg.f:224:0:
SH21 = SH21*GAM
Warning: ���sh21��� may be used uninitialized in this function [-Wmaybe-uninitialized]
srotmg.f:202:0:
SH12 = SH12*GAM
Warning: ���sh12��� may be used uninitialized in this function [-Wmaybe-uninitialized]
srotmg.f:201:0:
SH11 = SH11*GAM
Warning: ���sh11��� may be used uninitialized in this function [-Wmaybe-uninitialized]
srotmg.f:184:0:
IF (SFLAG.EQ.ZERO) THEN
Warning: ���sflag��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sspr2.f:245:0:
sspr2.f:245:0: Warning: ���kx��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sspr2.f:240:0:
TEMP1 = ALPHA*Y(JY)
sspr2.f:239:0:
sspr.f:220:0:
JX = JX + INCX
ssyr2.f:252:0:
ssyr2.f:252:0: Warning: ���kx��� may be used uninitialized in this function [-Wmaybe-uninitialized]
ssyr2.f:246:0:
ssyr2.f:246:0: Warning: ���jx��� may be used uninitialized in this function [-Wmaybe-uninitialized]
ssyr.f:223:0:
stbmv.f:313:0:
stbsv.f:287:0:
stpmv.f:266:0:
stpsv.f:305:0:
TEMP = X(JX)
strmv.f:267:0:
strsv.f:173:0:
zher2.f:257:0:
IY = KY
zher2.f:256:0:
IX = KX
zher2.f:175:0:
zher2.f:175:0: Warning: ���jx��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zher.f:227:0:
IX = KX
zherk.f:358:30:
RTEMP = RTEMP + DCONJG(A(L,J))*A(L,J)
1
Warning: Possible change of value in conversion from COMPLEX(8) to REAL(8) at (1) [-Wconversion]
zherk.f:370:30:
1
zhpr2.f:253:0:
IY = KY
zhpr2.f:252:0:
IX = KX
zhpr2.f:170:0:
zhpr2.f:170:0: Warning: ���jx��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zhpr.f:223:0:
IX = KX
ztbmv.f:314:0:
ztbsv.f:288:0:
ztpmv.f:270:0:
ztpsv.f:241:0:
ztrmv.f:268:0:
ztrsv.f:173:0:
cgbrfsx.f:519:23:
REF_TYPE = PARAMS( LA_LINRX_ITREF_I )
1
Warning: Possible change of value in conversion from REAL(4) to INTEGER(4) at (1) [-Wconversion]
cgbsvx.f:485:0:
COLCND = MAX( RCMIN, SMLNUM ) / MIN( RCMAX, BIGNUM )
Warning: ���smlnum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cgbsvx.f:485:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cgebak.f:244:19:
K = SCALE( I )
1
cgebak.f:258:19:
K = SCALE( I )
1
cgebd2.f:251:21:
D( I ) = ALPHA
1
cgebd2.f:270:24:
E( I ) = ALPHA
1
cgebd2.f:295:21:
D( I ) = ALPHA
1
cgebd2.f:314:24:
E( I ) = ALPHA
1
cgees.f:288:21:
HSWORK = WORK( 1 )
1
Warning: Possible change of value in conversion from COMPLEX(4) to INTEGER(4) at (1) [-Wconversion]
cgeesx.f:343:21:
HSWORK = WORK( 1 )
1
cgeesx.f:272:0:
$ ITAU, IWRK, LWRK, MAXWRK, MINWRK
Warning: ���maxwrk��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cgeev.f:281:21:
HSWORK = WORK( 1 )
1
cgeevx.f:404:21:
HSWORK = WORK( 1 )
1
cgegv.f:693:20:
SBETA = ( SCALE*BETA( JC ) )*BNRM
1
cgehrd.f:300:0:
DO 40 I = ILO, IHI - 1 - NX, NB
Warning: ���nx��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cgelsd.f:530:0:
ELSE IF( N.GE.MNTHR .AND. LWORK.GE.4*M+M*M+
Warning: ���mnthr��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cgels.f:499:0:
WORK( 1 ) = REAL( WSIZE )
Warning: ���wsize��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cgels.f:358:0:
IF( .NOT.TPSD ) THEN
Warning: ���tpsd��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cgelss.f:272:28:
LWORK_CGEQRF=DUM(1)
1
cgelss.f:276:28:
LWORK_CUNMQR=DUM(1)
1
cgelss.f:290:28:
LWORK_CGEBRD=DUM(1)
1
cgelss.f:294:28:
LWORK_CUNMBR=DUM(1)
1
cgelss.f:298:28:
LWORK_CUNGBR=DUM(1)
1
cgelss.f:316:31:
LWORK_CGELQF=DUM(1)
1
cgelss.f:320:31:
LWORK_CGEBRD=DUM(1)
1
cgelss.f:324:31:
LWORK_CUNMBR=DUM(1)
1
cgelss.f:328:31:
LWORK_CUNGBR=DUM(1)
1
cgelss.f:332:31:
LWORK_CUNMLQ=DUM(1)
1
cgelss.f:351:31:
LWORK_CGEBRD=DUM(1)
1
cgelss.f:355:31:
LWORK_CUNMBR=DUM(1)
1
cgelss.f:359:31:
LWORK_CUNGBR=DUM(1)
1
cgelss.f:551:0:
ELSE IF( N.GE.MNTHR .AND. LWORK.GE.3*M+M*M+MAX( M, NRHS, N-2*M ) )
cgeqlf.f:215:0:
IF( NB.GT.1 .AND. NB.LT.K ) THEN
Warning: ���nb��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cgerfsx.f:496:23:
1
cgerqf.f:215:0:
cgesvd.f:325:25:
LWORK_CGEQRF=DUM(1)
1
cgesvd.f:328:27:
LWORK_CUNGQR_N=DUM(1)
1
cgesvd.f:330:27:
LWORK_CUNGQR_M=DUM(1)
1
cgesvd.f:334:25:
LWORK_CGEBRD=DUM(1)
1
cgesvd.f:338:27:
LWORK_CUNGBR_P=DUM(1)
1
cgesvd.f:341:27:
LWORK_CUNGBR_Q=DUM(1)
1
cgesvd.f:449:28:
LWORK_CGEBRD=DUM(1)
1
cgesvd.f:454:33:
1
cgesvd.f:460:33:
1
cgesvd.f:475:25:
LWORK_CGELQF=DUM(1)
1
cgesvd.f:478:27:
LWORK_CUNGLQ_N=DUM(1)
1
cgesvd.f:480:27:
LWORK_CUNGLQ_M=DUM(1)
1
cgesvd.f:484:25:
LWORK_CGEBRD=DUM(1)
1
cgesvd.f:488:27:
1
cgesvd.f:492:27:
1
cgesvd.f:598:28:
LWORK_CGEBRD=DUM(1)
1
cgesvd.f:604:32:
1
cgesvd.f:610:32:
1
cgesvd.f:3395:0:
IF( LWORK.GE.WRKBL+LDA*M ) THEN
Warning: ���wrkbl��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cgesvd.f:2166:0:
IF( N.GE.MNTHR ) THEN
cgesvx.f:458:0:
cgesvx.f:458:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cgetc2.f:204:0:
A( N, N ) = CMPLX( SMIN, ZERO )
Warning: ���smin��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cgetc2.f:186:0:
$ CALL CSWAP( N, A( 1, JPV ), 1, A( 1, I ), 1 )
Warning: ���jpv��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cgetc2.f:180:0:
$ CALL CSWAP( N, A( IPV, 1 ), LDA, A( I, 1 ), LDA )
Warning: ���ipv��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cggbak.f:259:19:
K = RSCALE( I )
1
cggbak.f:269:19:
K = RSCALE( I )
1
cggbak.f:283:19:
K = LSCALE( I )
1
cggbak.f:293:19:
K = LSCALE( I )
1
cggbal.f:541:14:
IR = LSCALE( I ) + SIGN( HALF, LSCALE( I ) )
1
cggbal.f:549:14:
JC = RSCALE( I ) + SIGN( HALF, RSCALE( I ) )
1
cggglm.f:288:13:
LOPT = WORK( M+NP+1 )
1
cgglse.f:282:13:
LOPT = WORK( P+MN+1 )
1
cggqrf.f:282:13:
LOPT = WORK( 1 )
1
cggrqf.f:281:13:
LOPT = WORK( 1 )
1
chbevd.f:326:18:
W( 1 ) = AB( 1, 1 )
1
chbev.f:226:21:
W( 1 ) = AB( 1, 1 )
1
chbev.f:228:21:
W( 1 ) = AB( KD+1, 1 )
1
chbevx.f:378:21:
W( 1 ) = CTMP1
1
chbgst.f:602:0:
DO 240 J = N - 1, J2 + KA, -1
Warning: ���j2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
chbtrd.f:462:21:
D( I ) = AB( KD1, I )
1
chbtrd.f:669:21:
D( I ) = AB( 1, I )
1
cheequb.f:263:16:
AVG = AVG + S( I )*WORK( I )
1
cheequb.f:280:15:
C1 = ( N-2 ) * ( WORK( I ) - T*SI )
1
cheequb.f:281:15:
C0 = -(T*SI)*SI + 2*WORK( I )*SI - N*AVG
1
cheequb.f:315:16:
AVG = AVG + ( U + WORK( I ) ) * D / N
1
cheevd.f:320:18:
W( 1 ) = A( 1, 1 )
1
cheev.f:227:18:
W( 1 ) = A( 1, 1 )
1
cheevx.f:377:21:
W( 1 ) = A( 1, 1 )
1
cheevx.f:382:24:
W( 1 ) = A( 1, 1 )
1
cheevx.f:551:0:
WORK( 1 ) = LWKOPT
Warning: ���lwkopt��� may be used uninitialized in this function [-Wmaybe-uninitialized]
chegs2.f:199:21:
AKK = A( K, K )
1
chegs2.f:200:21:
BKK = B( K, K )
1
chegs2.f:229:21:
AKK = A( K, K )
1
chegs2.f:230:21:
BKK = B( K, K )
1
chegs2.f:254:21:
AKK = A( K, K )
1
chegs2.f:255:21:
BKK = B( K, K )
1
chegs2.f:274:21:
AKK = A( K, K )
1
chegs2.f:275:21:
BKK = B( K, K )
1
chegvd.f:366:13:
LOPT = MAX( REAL( LOPT ), REAL( WORK( 1 ) ) )
1
chegvd.f:367:14:
LROPT = MAX( REAL( LROPT ), REAL( RWORK( 1 ) ) )
1
chegvd.f:368:14:
LIOPT = MAX( REAL( LIOPT ), REAL( IWORK( 1 ) ) )
1
cherfsx.f:481:23:
1
chetd2.f:251:21:
E( I ) = ALPHA
1
chetd2.f:279:23:
D( I+1 ) = A( I+1, I+1 )
1
chetd2.f:282:18:
D( 1 ) = A( 1, 1 )
1
chetd2.f:295:21:
E( I ) = ALPHA
1
chetd2.f:324:21:
D( I ) = A( I, I )
1
chetd2.f:327:18:
D( N ) = A( N, N )
1
chetf2.f:529:0:
IF( KP.LT.N )
Warning: ���imax��� may be used uninitialized in this function [-Wmaybe-uninitialized]
chetf2_rook.f:534:24:
D11 = A( K, K ) / D
1
chetf2_rook.f:535:24:
D22 = A( K-1, K-1 ) / D
1
chetf2_rook.f:691:0:
ELSE IF( ( P.EQ.JMAX ) .OR. ( ROWMAX.LE.COLMAX ) )
Warning: ���jmax��� may be used uninitialized in this function [-Wmaybe-uninitialized]
chetrd.f:331:24:
D( J ) = A( J, J )
1
chetrd.f:363:24:
D( J ) = A( J, J )
1
chgeqz.f:854:0:
IF( ILZ )
Warning: ���ilz��� may be used uninitialized in this function [-Wmaybe-uninitialized]
chgeqz.f:796:0:
IF( ILQ ) THEN
Warning: ���ilq��� may be used uninitialized in this function [-Wmaybe-uninitialized]
chgeqz.f:688:0:
IF( .NOT.ILSCHR ) THEN
Warning: ���ilschr��� may be used uninitialized in this function [-Wmaybe-uninitialized]
chpevd.f:306:18:
W( 1 ) = AP( 1 )
1
chpev.f:209:18:
W( 1 ) = AP( 1 )
1
chpevx.f:331:21:
W( 1 ) = AP( 1 )
1
chpevx.f:335:24:
W( 1 ) = AP( 1 )
1
chpgst.f:188:21:
BJJ = BP( JJ )
1
chpgst.f:209:21:
AKK = AP( KK )
1
chpgst.f:210:21:
BKK = BP( KK )
1
chpgst.f:240:21:
AKK = AP( KK )
1
chpgst.f:241:21:
BKK = BP( KK )
1
chpgst.f:264:21:
AJJ = AP( JJ )
1
chpgst.f:265:21:
BJJ = BP( JJ )
1
chpgvd.f:341:14:
LWMIN = MAX( REAL( LWMIN ), REAL( WORK( 1 ) ) )
1
chpgvd.f:342:15:
LRWMIN = MAX( REAL( LRWMIN ), REAL( RWORK( 1 ) ) )
1
chpgvd.f:343:15:
LIWMIN = MAX( REAL( LIWMIN ), REAL( IWORK( 1 ) ) )
1
chptrd.f:227:21:
E( I ) = ALPHA
1
chptrd.f:252:23:
D( I+1 ) = AP( I1+I )
1
chptrd.f:256:18:
D( 1 ) = AP( 1 )
1
chptrd.f:272:21:
E( I ) = ALPHA
1
chptrd.f:299:21:
D( I ) = AP( II )
1
chptrd.f:303:18:
D( N ) = AP( II )
1
chptrf.f:529:0:
IF( KP.LT.N )
chptrf.f:328:0:
CALL CSWAP( KP-1, AP( KNC ), 1, AP( KPC ), 1 )
Warning: ���kpc��� may be used uninitialized in this function [-Wmaybe-uninitialized]
clabrd.f:273:21:
D( I ) = ALPHA
1
clabrd.f:313:24:
E( I ) = ALPHA
1
clabrd.f:357:21:
D( I ) = ALPHA
1
clabrd.f:391:24:
E( I ) = ALPHA
1
claed8.f:455:0:
W( K ) = Z( JLAM )
Warning: ���jlam��� may be used uninitialized in this function [-Wmaybe-uninitialized]
clahef.f:695:0:
JMAX = IMAX + ICAMAX( N-IMAX, W( IMAX+1, K+1 ), 1 )
clahef_rook.f:860:0:
clahr2.f:307:0:
A( K+NB, NB ) = EI
Warning: ���IMAGPART_EXPR <ei>��� may be used uninitialized in this function [-Wmaybe-uninitialized]
clahr2.f:307:0: Warning: ���REALPART_EXPR <ei>��� may be used uninitialized in this function [-Wmaybe-uninitialized]
claic1.f:197:21:
TMP = SQRT( S*CONJG( S )+C*CONJG( C ) )
1
claic1.f:251:19:
T = C / ( B+SQRT( B*B+C ) )
1
claic1.f:253:19:
T = SQRT( B*B+C ) - B
1
claic1.f:258:18:
TMP = SQRT( SINE*CONJG( SINE )+COSINE*CONJG( COSINE ) )
1
claic1.f:283:18:
1
claic1.f:341:19:
T = C / ( B+SQRT( ABS( B*B-C ) ) )
1
claic1.f:352:22:
T = -C / ( B+SQRT( B*B+C ) )
1
claic1.f:354:22:
T = B - SQRT( B*B+C )
1
claic1.f:360:18:
1
cla_lin_berr.f:151:21:
TMP = (SAFE1 + CABS1(RES(I,J)))/AYB(I,J)
1
clals0.f:413:0:
$ DIFRJ ) / ( POLES( I, 2 )+DJ )
Warning: ���difrj��� may be used uninitialized in this function [-Wmaybe-uninitialized]
clangb.f:150:0:
REAL SCALE, SUM, VALUE, TEMP
Warning: ���value��� may be used uninitialized in this function [-Wmaybe-uninitialized]
clange.f:140:0:
clangt.f:130:0:
REAL ANORM, SCALE, SUM, TEMP
Warning: ���anorm��� may be used uninitialized in this function [-Wmaybe-uninitialized]
clanhb.f:157:0:
REAL ABSA, SCALE, SUM, VALUE
clanhe.f:149:0:
clanhp.f:142:0:
clanhs.f:134:0:
clanht.f:126:0:
clansb.f:155:0:
clansp.f:140:0:
clansy.f:148:0:
clantb.f:167:0:
clantp.f:151:0:
clantr.f:168:0:
clarfgp.f:241:25:
BETA = -SAVEALPHA
1
clasyf_rook.f:706:0:
clatrd.f:274:26:
E( I-1 ) = ALPHA
1
clatrd.f:328:24:
E( I ) = ALPHA
1
clauu2.f:168:18:
AII = A( I, I )
1
clauu2.f:187:18:
AII = A( I, I )
1
cpbsvx.f:430:0:
SCOND = MAX( SMIN, SMLNUM ) / MIN( SMAX, BIGNUM )
cpbsvx.f:430:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cpoequb.f:180:15:
S( 1 ) = A( 1, 1 )
1
cpoequb.f:184:18:
S( I ) = A( I, I )
1
cporfsx.f:473:23:
1
cposvx.f:392:0:
cposvx.f:392:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cpotf2.f:180:18:
AJJ = REAL( A( J, J ) ) - CDOTC( J-1, A( 1, J ), 1,
1
cpotf2.f:207:18:
AJJ = REAL( A( J, J ) ) - CDOTC( J-1, A( J, 1 ), LDA,
1
cppsvx.f:393:0:
cppsvx.f:393:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cpptrf.f:195:18:
AJJ = REAL( AP( JJ ) ) - CDOTC( J-1, AP( JC ), 1, AP( JC ),
1
cpptri.f:167:18:
AJJ = AP( JJ )
1
cspr.f:220:0:
JX = KX
csptrf.f:602:0:
IPIV( K ) = -KP
csptrf.f:322:0:
cstedc.f:484:0:
WORK( 1 ) = LWMIN
Warning: ���lwmin��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cstedc.f:485:0:
RWORK( 1 ) = LRWMIN
Warning: ���lrwmin��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cstedc.f:486:0:
IWORK( 1 ) = LIWMIN
Warning: ���liwmin��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cstein.f:352:0:
$ XJ = XJM + PERTOL
Warning: ���xjm��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cstein.f:425:0:
IF( NRM.LT.STPCRT )
Warning: ���stpcrt��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cstein.f:400:0:
IF( ABS( XJ-XJM ).GT.ORTOL )
Warning: ���ortol��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cstein.f:386:0:
$ SASUM( BLKSIZ, WORK( INDRV1+1 ), 1 )
Warning: ���onenrm��� may be used uninitialized in this function [-Wmaybe-uninitialized]
csyequb.f:275:16:
1
csyequb.f:292:15:
1
csyequb.f:293:15:
1
csyequb.f:327:16:
1
csyr.f:226:0:
IX = KX
csyrfsx.f:483:23:
1
csysv.f:229:21:
LWKOPT = WORK(1)
1
csysv_rook.f:262:21:
LWKOPT = WORK(1)
1
csytf2.f:595:0:
IPIV( K ) = -KP
csytf2_rook.f:638:0:
ELSE IF( ( P.EQ.JMAX ).OR.( ROWMAX.LE.COLMAX ) ) THEN
csytf2_rook.f:416:0:
IF( KP.NE.KK ) THEN
ctfttr.f:459:0:
IJ = IJ - NP1X2
Warning: ���np1x2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
ctfttr.f:356:0:
IJ = IJ - NX2
Warning: ���nx2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
ctgsyl.f:609:0:
SCALE = SCALE2
Warning: ���scale2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
ctptri.f:230:0:
$ AP( JCLAST ), AP( JC+1 ), 1 )
Warning: ���jclast��� may be used uninitialized in this function [-Wmaybe-uninitialized]
ctrsen.f:450:0:
WORK( 1 ) = LWMIN
ctrttf.f:458:0:
IJ = IJ - NP1X2
ctrttf.f:355:0:
IJ = IJ - NX2
ctzrzf.f:251:0:
IWS = LDWORK*NB
cuncsd2by1.f:520:0:
$ WORK(ITAUQ1), WORK(IORBDB), LORBDB, CHILDINFO )
Warning: ���itauq1��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd2by1.f:520:0: Warning: ���itaup2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd2by1.f:532:0:
$ WORK(IORGQR), LORGQR, CHILDINFO )
Warning: ���iorgqr��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd2by1.f:507:0:
LORGLQ = LWORK-IORGLQ+1
Warning: ���iorglq��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd2by1.f:705:0:
CALL CCOPY( M-P, WORK(IORBDB+P), 1, U2, 1 )
Warning: ���iorbdb��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd2by1.f:553:0:
$ CHILDINFO )
Warning: ���ibbcsd��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd2by1.f:553:0: Warning: ���ib22e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd2by1.f:553:0: Warning: ���ib22d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd2by1.f:553:0: Warning: ���ib21e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd2by1.f:553:0: Warning: ���ib21d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd2by1.f:553:0: Warning: ���ib12e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd2by1.f:553:0: Warning: ���ib12d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd2by1.f:553:0: Warning: ���ib11e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd2by1.f:553:0: Warning: ���ib11d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd.f:526:0:
$ WORK(IORBDB), LORBDBWORK, CHILDINFO )
Warning: ���itauq2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd.f:526:0: Warning: ���itauq1��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd.f:526:0: Warning: ���itaup2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd.f:579:0:
$ WORK(IORGQR), LORGQRWORK, INFO )
cuncsd.f:550:0:
$ WORK(IORGLQ), LORGLQWORK, INFO )
cuncsd.f:526:0:
cuncsd.f:597:0:
$ LBBCSDWORK, INFO )
cuncsd.f:597:0: Warning: ���ib22e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd.f:597:0: Warning: ���ib22d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd.f:597:0: Warning: ���ib21e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd.f:597:0: Warning: ���ib21d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd.f:597:0: Warning: ���ib12e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd.f:597:0: Warning: ���ib12d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd.f:597:0: Warning: ���ib11e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cuncsd.f:597:0: Warning: ���ib11d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
cungbr.f:240:18:
LWKOPT = WORK( 1 )
1
cungql.f:210:0:
cungrq.f:210:0:
cunmql.f:281:0:
IWS = NW*NB
cunmrq.f:282:0:
IWS = NW*NB
dbdsdc.f:461:0:
$ WORK( WSTART ), IWORK, INFO )
Warning: ���z��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dbdsdc.f:461:0: Warning: ���poles��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dbdsdc.f:461:0: Warning: ���ivt��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dbdsdc.f:461:0: Warning: ���is��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dbdsdc.f:461:0: Warning: ���ic��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dbdsdc.f:461:0: Warning: ���givnum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dbdsdc.f:461:0: Warning: ���givcol��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dbdsdc.f:461:0: Warning: ���difr��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dbdsdc.f:461:0: Warning: ���difl��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dgbrfsx.f:523:23:
1
Warning: Possible change of value in conversion from REAL(8) to INTEGER(4) at (1) [-Wconversion]
dgbsvx.f:480:0:
dgbsvx.f:480:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dgebak.f:242:19:
K = SCALE( I )
1
dgebak.f:256:19:
K = SCALE( I )
1
dgees.f:308:21:
HSWORK = WORK( 1 )
1
dgeesx.f:388:21:
HSWORK = WORK( 1 )
1
dgeesx.f:316:0:
$ MAXWRK, MINWRK
dgeev.f:283:24:
HSWORK = WORK( 1 )
1
dgeev.f:292:24:
HSWORK = WORK( 1 )
1
dgeev.f:299:24:
HSWORK = WORK( 1 )
1
dgeevx.f:423:21:
HSWORK = WORK( 1 )
1
dgehrd.f:300:0:
dgels.f:498:0:
WORK( 1 ) = DBLE( WSIZE )
dgels.f:357:0:
dgelss.f:260:28:
LWORK_DGEQRF=DUM(1)
1
dgelss.f:264:28:
LWORK_DORMQR=DUM(1)
1
dgelss.f:279:28:
LWORK_DGEBRD=DUM(1)
1
dgelss.f:283:28:
LWORK_DORMBR=DUM(1)
1
dgelss.f:287:28:
LWORK_DORGBR=DUM(1)
1
dgelss.f:311:31:
LWORK_DGELQF=DUM(1)
1
dgelss.f:315:31:
LWORK_DGEBRD=DUM(1)
1
dgelss.f:319:31:
LWORK_DORMBR=DUM(1)
1
dgelss.f:323:31:
LWORK_DORGBR=DUM(1)
1
dgelss.f:327:31:
LWORK_DORMLQ=DUM(1)
1
dgelss.f:347:31:
LWORK_DGEBRD=DUM(1)
1
dgelss.f:351:31:
LWORK_DORMBR=DUM(1)
1
dgelss.f:355:31:
LWORK_DORGBR=DUM(1)
1
dgelss.f:540:0:
dgeqlf.f:215:0:
dgerfsx.f:496:23:
1
dgerqf.f:215:0:
dgesdd.f:1349:0:
$ WORK( IL ), M )
Warning: ���il��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dgesdd.f:921:0:
$ WORK( IR ), LDWRKR )
Warning: ���ir��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dgesdd.f:988:0:
dgesdd.f:609:0:
LDWRKR = ( LWORK-N*N-3*N-BDSPAC ) / N
Warning: ���bdspac��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dgesvd.f:317:25:
LWORK_DGEQRF=DUM(1)
1
dgesvd.f:320:27:
LWORK_DORGQR_N=DUM(1)
1
dgesvd.f:322:27:
LWORK_DORGQR_M=DUM(1)
1
dgesvd.f:326:25:
LWORK_DGEBRD=DUM(1)
1
dgesvd.f:330:27:
LWORK_DORGBR_P=DUM(1)
1
dgesvd.f:334:27:
LWORK_DORGBR_Q=DUM(1)
1
dgesvd.f:450:28:
LWORK_DGEBRD=DUM(1)
1
dgesvd.f:455:33:
1
dgesvd.f:461:33:
1
dgesvd.f:478:25:
LWORK_DGELQF=DUM(1)
1
dgesvd.f:481:27:
LWORK_DORGLQ_N=DUM(1)
1
dgesvd.f:483:27:
LWORK_DORGLQ_M=DUM(1)
1
dgesvd.f:487:25:
LWORK_DGEBRD=DUM(1)
1
dgesvd.f:491:27:
1
dgesvd.f:495:27:
1
dgesvd.f:610:28:
LWORK_DGEBRD=DUM(1)
1
dgesvd.f:616:32:
1
dgesvd.f:622:32:
1
dgesvd.f:3461:0:
IF( IE.LT.2 ) THEN
Warning: ���ie��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dgesvd.f:3201:0:
dgesvd.f:2063:0:
dgesvd.f:237:0:
INTEGER BDSPAC, BLK, CHUNK, I, IE, IERR, IR, ISCL,
dgesvx.f:456:0:
dgesvx.f:456:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dgetc2.f:204:0:
A( N, N ) = SMIN
dgetc2.f:186:0:
$ CALL DSWAP( N, A( 1, JPV ), 1, A( 1, I ), 1 )
dgetc2.f:180:0:
$ CALL DSWAP( N, A( IPV, 1 ), LDA, A( I, 1 ), LDA )
dggbak.f:258:19:
K = RSCALE( I )
1
dggbak.f:268:19:
K = RSCALE( I )
1
dggbak.f:282:19:
K = LSCALE( I )
1
dggbak.f:292:19:
K = LSCALE( I )
1
dggbal.f:528:14:
1
dggbal.f:536:14:
1
dggglm.f:287:13:
1
dgglse.f:282:13:
1
dggqrf.f:282:13:
LOPT = WORK( 1 )
1
dggrqf.f:281:13:
LOPT = WORK( 1 )
1
dhgeqz.f:1344:0:
IF( ILZ ) THEN
dhgeqz.f:835:0:
IF( ILQ ) THEN
dhgeqz.f:713:0:
dlaed0.f:386:0:
$ IWORK( SUBPBS+1 ), INFO )
Warning: ���iwrem��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlaed0.f:386:0: Warning: ���iqptr��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlaed0.f:386:0: Warning: ���iq��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlaed0.f:386:0: Warning: ���iprmpt��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlaed0.f:386:0: Warning: ���iperm��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlaed0.f:386:0: Warning: ���igivpt��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlaed0.f:386:0: Warning: ���igivcl��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlaed2.f:439:0:
DLAMDA( K ) = D( PJ )
Warning: ���pj��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlaed6.f:404:0:
$ TAU = TAU*SCLINV
Warning: ���sclinv��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlaed8.f:481:0:
W( K ) = Z( JLAM )
dlag2s.f:143:25:
SA( I, J ) = A( I, J )
1
dlahqr.f:590:0:
$ CS, SN )
Warning: ���i2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlahr2.f:305:0:
A( K+NB, NB ) = EI
Warning: ���ei��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlahrd.f:282:0:
A( K+NB, NB ) = EI
dlals0.f:410:0:
dlangb.f:149:0:
DOUBLE PRECISION SCALE, SUM, VALUE, TEMP
dlange.f:138:0:
dlangt.f:130:0:
DOUBLE PRECISION ANORM, SCALE, SUM, TEMP
dlanhs.f:132:0:
dlansb.f:153:0:
DOUBLE PRECISION ABSA, SCALE, SUM, VALUE
dlansf.f:233:0:
DOUBLE PRECISION SCALE, S, VALUE, AA, TEMP
dlansp.f:138:0:
dlanst.f:124:0:
dlansy.f:146:0:
dlantb.f:165:0:
dlantp.f:149:0:
dlantr.f:166:0:
dlarrd.f:737:0:
IF( W( JE ).GE.WUL .AND. IDISCU.GT.0 ) THEN
Warning: ���wul��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlarrd.f:720:0:
IF( W( JE ).LE.WLU .AND. IDISCL.GT.0 ) THEN
Warning: ���wlu��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlarre.f:390:0:
$ ((IRANGE.EQ.VALRNG).AND.(D(1).GT.VL).AND.(D(1).LE.VU)).OR.
Warning: ���irange��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlaruv.f:441:0:
ISEED( 4 ) = IT4
Warning: ���it4��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlaruv.f:440:0:
ISEED( 3 ) = IT3
Warning: ���it3��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlaruv.f:439:0:
ISEED( 2 ) = IT2
Warning: ���it2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlaruv.f:438:0:
ISEED( 1 ) = IT1
Warning: ���it1��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlasd2.f:443:0:
J = J + 1
Warning: ���jprev��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlasd7.f:447:0:
J = J + 1
dlasd8.f:325:0:
$ / ( DSIGMA( I )+DJ )
dlasq4.f:420:0:
TAU = S
Warning: ���s��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlasv2.f:319:0:
SSMAX = SIGN( SSMAX, TSIGN )
Warning: ���tsign��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlasy2.f:427:0:
$ CALL DSWAP( 4, T16( 1, JPSV ), 1, T16( 1, I ), 1 )
Warning: ���jpsv��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlasy2.f:421:0:
CALL DSWAP( 4, T16( IPSV, 1 ), 4, T16( I, 1 ), 4 )
Warning: ���ipsv��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlasyf_rook.f:698:0:
dlat2s.f:152:28:
1
dlat2s.f:163:28:
1
dlatbs.f:794:0:
X( J ) = X( J ) / TJJS - SUMJ
Warning: ���tjjs��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dlatps.f:775:0:
dlatrs.f:769:0:
dlazq4.f:325:0:
TAU = S
dorcsd2by1.f:478:0:
dorcsd2by1.f:478:0: Warning: ���itaup2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd2by1.f:478:0: Warning: ���itaup1��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd2by1.f:490:0:
dorcsd2by1.f:465:0:
dorcsd2by1.f:663:0:
CALL DCOPY( M-P, WORK(IORBDB+P), 1, U2, 1 )
dorcsd2by1.f:511:0:
$ CHILDINFO )
dorcsd2by1.f:511:0: Warning: ���ib22e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd2by1.f:511:0: Warning: ���ib22d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd2by1.f:511:0: Warning: ���ib21e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd2by1.f:511:0: Warning: ���ib21d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd2by1.f:511:0: Warning: ���ib12e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd2by1.f:511:0: Warning: ���ib12d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd2by1.f:511:0: Warning: ���ib11e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd2by1.f:511:0: Warning: ���ib11d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd.f:489:0:
dorcsd.f:489:0: Warning: ���itauq1��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd.f:489:0: Warning: ���itaup2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd.f:489:0: Warning: ���itaup1��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd.f:542:0:
dorcsd.f:513:0:
dorcsd.f:489:0:
dorcsd.f:559:0:
$ WORK(IB22E), WORK(IBBCSD), LBBCSDWORK, INFO )
dorcsd.f:559:0: Warning: ���ib22e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd.f:559:0: Warning: ���ib22d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd.f:559:0: Warning: ���ib21e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd.f:559:0: Warning: ���ib21d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd.f:559:0: Warning: ���ib12e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd.f:559:0: Warning: ���ib12d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd.f:559:0: Warning: ���ib11e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorcsd.f:559:0: Warning: ���ib11d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dorgbr.f:239:18:
LWKOPT = WORK( 1 )
1
dorgql.f:210:0:
dorgrq.f:210:0:
dormql.f:279:0:
IWS = NW*NB
dormrq.f:280:0:
IWS = NW*NB
dormrz.f:304:0:
IWS = NW*NB
dpbsvx.f:432:0:
dpbsvx.f:432:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dporfsx.f:475:23:
1
dposvx.f:394:0:
dposvx.f:394:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dppsvx.f:394:0:
dppsvx.f:394:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dspgvd.f:313:14:
LWMIN = MAX( DBLE( LWMIN ), DBLE( WORK( 1 ) ) )
1
dspgvd.f:314:15:
LIWMIN = MAX( DBLE( LIWMIN ), DBLE( IWORK( 1 ) ) )
1
dsptrf.f:599:0:
IPIV( K ) = -KP
dsptrf.f:315:0:
CALL DSWAP( KP-1, AP( KNC ), 1, AP( KPC ), 1 )
dstedc.f:482:0:
WORK( 1 ) = LWMIN
dstedc.f:483:0:
IWORK( 1 ) = LIWMIN
dstein.f:341:0:
$ XJ = XJM + PERTOL
dstein.f:389:0:
dstein.f:375:0:
$ DASUM( BLKSIZ, WORK( INDRV1+1 ), 1 )
dstein.f:392:0:
DO 80 I = GPIND, J - 1
Warning: ���gpind��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dstein.f:409:0:
IF( NRM.LT.DTPCRT )
Warning: ���dtpcrt��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dsyevx.f:541:0:
WORK( 1 ) = LWKOPT
dsygvd.f:336:13:
LOPT = MAX( DBLE( LOPT ), DBLE( WORK( 1 ) ) )
1
dsygvd.f:337:14:
LIOPT = MAX( DBLE( LIOPT ), DBLE( IWORK( 1 ) ) )
1
dsyrfsx.f:482:23:
1
dsysv.f:229:21:
LWKOPT = WORK(1)
1
dsysv_rook.f:262:21:
LWKOPT = WORK(1)
1
dsytf2.f:593:0:
IPIV( K ) = -KP
dsytf2_rook.f:630:0:
dsytf2_rook.f:408:0:
IF( KP.NE.KK ) THEN
dtfttr.f:422:0:
IJ = IJ - NP1X2
dtfttr.f:327:0:
IJ = IJ - NX2
dtgsna.f:673:0:
DIF( KS ) = COND
Warning: ���cond��� may be used uninitialized in this function [-Wmaybe-uninitialized]
dtgsyl.f:606:0:
SCALE = SCALE2
dtptri.f:229:0:
dtrsen.f:563:0:
WORK( 1 ) = LWMIN
dtrsen.f:564:0:
IWORK( 1 ) = LIWMIN
dtrttf.f:419:0:
IJ = IJ - NP1X2
dtrttf.f:324:0:
IJ = IJ - NX2
dtzrzf.f:251:0:
IWS = LDWORK*NB
iparmq.f:296:0:
IPARMQ = 3*NS / 2
Warning: ���ns��� may be used uninitialized in this function [-Wmaybe-uninitialized]
iparmq.f:293:0:
IF( NH.LE.KNWSWP ) THEN
Warning: ���nh��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sbdsdc.f:461:0:
sbdsdc.f:461:0: Warning: ���poles��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sbdsdc.f:461:0: Warning: ���ivt��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sbdsdc.f:461:0: Warning: ���is��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sbdsdc.f:461:0: Warning: ���ic��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sbdsdc.f:461:0: Warning: ���givnum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sbdsdc.f:461:0: Warning: ���givcol��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sbdsdc.f:461:0: Warning: ���difr��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sbdsdc.f:461:0: Warning: ���difl��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sgbrfsx.f:523:23:
1
sgbsvx.f:482:0:
sgbsvx.f:482:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sgebak.f:242:19:
K = SCALE( I )
1
sgebak.f:256:19:
K = SCALE( I )
1
sgees.f:308:21:
HSWORK = WORK( 1 )
1
sgeesx.f:388:21:
HSWORK = WORK( 1 )
1
sgeesx.f:316:0:
$ MAXWRK, MINWRK
sgeev.f:283:24:
HSWORK = WORK( 1 )
1
sgeev.f:292:24:
HSWORK = WORK( 1 )
1
sgeev.f:299:24:
HSWORK = WORK( 1 )
1
sgeevx.f:422:21:
HSWORK = WORK( 1 )
1
sgehrd.f:300:0:
sgelsd.f:511:0:
IF( LWORK.GE.MAX( 4*M+M*LDA+MAX( M, 2*M-4, NRHS, N-3*M ),
Warning: ���wlalsd��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sgelsd.f:504:0:
sgels.f:498:0:
sgels.f:357:0:
sgelss.f:259:28:
LWORK_SGEQRF=DUM(1)
1
sgelss.f:263:28:
LWORK_SORMQR=DUM(1)
1
sgelss.f:278:28:
LWORK_SGEBRD=DUM(1)
1
sgelss.f:282:28:
LWORK_SORMBR=DUM(1)
1
sgelss.f:286:28:
LWORK_SORGBR=DUM(1)
1
sgelss.f:310:31:
LWORK_SGEBRD=DUM(1)
1
sgelss.f:314:31:
LWORK_SORMBR=DUM(1)
1
sgelss.f:318:31:
LWORK_SORGBR=DUM(1)
1
sgelss.f:322:31:
LWORK_SORMLQ=DUM(1)
1
sgelss.f:343:31:
LWORK_SGEBRD=DUM(1)
1
sgelss.f:347:31:
LWORK_SORMBR=DUM(1)
1
sgelss.f:351:31:
LWORK_SORGBR=DUM(1)
1
sgelss.f:536:0:
sgeqlf.f:215:0:
sgerfsx.f:496:23:
1
sgerqf.f:218:0:
sgesdd.f:1349:0:
$ WORK( IL ), M )
sgesdd.f:921:0:
sgesdd.f:988:0:
sgesdd.f:609:0:
sgesvd.f:317:25:
LWORK_SGEQRF=DUM(1)
1
sgesvd.f:320:27:
LWORK_SORGQR_N=DUM(1)
1
sgesvd.f:322:27:
LWORK_SORGQR_M=DUM(1)
1
sgesvd.f:326:25:
LWORK_SGEBRD=DUM(1)
1
sgesvd.f:330:27:
LWORK_SORGBR_P=DUM(1)
1
sgesvd.f:334:27:
LWORK_SORGBR_Q=DUM(1)
1
sgesvd.f:450:28:
LWORK_SGEBRD=DUM(1)
1
sgesvd.f:455:33:
1
sgesvd.f:461:33:
1
sgesvd.f:478:25:
LWORK_SGELQF=DUM(1)
1
sgesvd.f:481:27:
LWORK_SORGLQ_N=DUM(1)
1
sgesvd.f:483:27:
LWORK_SORGLQ_M=DUM(1)
1
sgesvd.f:487:25:
LWORK_SGEBRD=DUM(1)
1
sgesvd.f:491:27:
1
sgesvd.f:495:27:
1
sgesvd.f:611:28:
LWORK_SGEBRD=DUM(1)
1
sgesvd.f:617:32:
1
sgesvd.f:623:32:
1
sgesvd.f:3462:0:
IF( IE.LT.2 ) THEN
sgesvd.f:3202:0:
sgesvd.f:2064:0:
sgesvd.f:237:0:
sgesvx.f:456:0:
sgesvx.f:456:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sgetc2.f:204:0:
A( N, N ) = SMIN
sgetc2.f:186:0:
$ CALL SSWAP( N, A( 1, JPV ), 1, A( 1, I ), 1 )
sgetc2.f:180:0:
$ CALL SSWAP( N, A( IPV, 1 ), LDA, A( I, 1 ), LDA )
sggbak.f:258:19:
K = RSCALE( I )
1
sggbak.f:268:19:
K = RSCALE( I )
1
sggbak.f:282:19:
K = LSCALE( I )
1
sggbak.f:292:19:
K = LSCALE( I )
1
sggbal.f:528:14:
1
sggbal.f:536:14:
1
sggglm.f:287:13:
1
sgglse.f:282:13:
1
sggqrf.f:282:13:
LOPT = WORK( 1 )
1
sggrqf.f:281:13:
LOPT = WORK( 1 )
1
shgeqz.f:1344:0:
IF( ILZ ) THEN
shgeqz.f:835:0:
IF( ILQ ) THEN
shgeqz.f:713:0:
slaed0.f:386:0:
slaed0.f:386:0: Warning: ���iqptr��� may be used uninitialized in this function [-Wmaybe-uninitialized]
slaed0.f:386:0: Warning: ���iq��� may be used uninitialized in this function [-Wmaybe-uninitialized]
slaed0.f:386:0: Warning: ���iprmpt��� may be used uninitialized in this function [-Wmaybe-uninitialized]
slaed0.f:386:0: Warning: ���iperm��� may be used uninitialized in this function [-Wmaybe-uninitialized]
slaed0.f:386:0: Warning: ���igivpt��� may be used uninitialized in this function [-Wmaybe-uninitialized]
slaed0.f:386:0: Warning: ���igivcl��� may be used uninitialized in this function [-Wmaybe-uninitialized]
slaed2.f:439:0:
slaed6.f:404:0:
$ TAU = TAU*SCLINV
slaed8.f:481:0:
W( K ) = Z( JLAM )
slahqr.f:590:0:
$ CS, SN )
slahr2.f:305:0:
A( K+NB, NB ) = EI
slahrd.f:282:0:
A( K+NB, NB ) = EI
slals0.f:410:0:
slangb.f:149:0:
slange.f:138:0:
slangt.f:130:0:
slanhs.f:132:0:
slansb.f:153:0:
slansf.f:234:0:
REAL SCALE, S, VALUE, AA, TEMP
slansp.f:138:0:
slanst.f:124:0:
slansy.f:146:0:
slantb.f:165:0:
slantp.f:149:0:
slantr.f:166:0:
slarrd.f:737:0:
slarrd.f:720:0:
slarre.f:394:0:
slaruv.f:442:0:
ISEED( 4 ) = IT4
slaruv.f:441:0:
ISEED( 3 ) = IT3
slaruv.f:440:0:
ISEED( 2 ) = IT2
slaruv.f:439:0:
ISEED( 1 ) = IT1
slasd2.f:443:0:
J = J + 1
slasd7.f:447:0:
J = J + 1
slasd8.f:325:0:
slasq4.f:420:0:
TAU = S
slasv2.f:319:0:
slasy2.f:427:0:
$ CALL SSWAP( 4, T16( 1, JPSV ), 1, T16( 1, I ), 1 )
slasy2.f:421:0:
CALL SSWAP( 4, T16( IPSV, 1 ), 4, T16( I, 1 ), 4 )
slasyf_rook.f:698:0:
slatbs.f:794:0:
slatps.f:775:0:
slatrs.f:769:0:
slazq4.f:325:0:
TAU = S
sorcsd2by1.f:474:0:
sorcsd2by1.f:474:0: Warning: ���itaup2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd2by1.f:474:0: Warning: ���itaup1��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd2by1.f:486:0:
sorcsd2by1.f:461:0:
sorcsd2by1.f:659:0:
CALL SCOPY( M-P, WORK(IORBDB+P), 1, U2, 1 )
sorcsd2by1.f:507:0:
$ CHILDINFO )
sorcsd2by1.f:507:0: Warning: ���ib22e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd2by1.f:507:0: Warning: ���ib22d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd2by1.f:507:0: Warning: ���ib21e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd2by1.f:507:0: Warning: ���ib21d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd2by1.f:507:0: Warning: ���ib12e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd2by1.f:507:0: Warning: ���ib12d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd2by1.f:507:0: Warning: ���ib11e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd2by1.f:507:0: Warning: ���ib11d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd.f:493:0:
sorcsd.f:493:0: Warning: ���itauq1��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd.f:493:0: Warning: ���itaup2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd.f:493:0: Warning: ���itaup1��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd.f:546:0:
sorcsd.f:517:0:
sorcsd.f:493:0:
sorcsd.f:563:0:
sorcsd.f:563:0: Warning: ���ib22e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd.f:563:0: Warning: ���ib22d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd.f:563:0: Warning: ���ib21e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd.f:563:0: Warning: ���ib21d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd.f:563:0: Warning: ���ib12e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd.f:563:0: Warning: ���ib12d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd.f:563:0: Warning: ���ib11e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorcsd.f:563:0: Warning: ���ib11d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sorgbr.f:239:18:
LWKOPT = WORK( 1 )
1
sorgql.f:210:0:
sorgrq.f:210:0:
sormql.f:282:0:
IWS = NW*NB
sormrq.f:282:0:
IWS = NW*NB
sormrz.f:303:0:
IWS = NW*NB
spbsvx.f:432:0:
spbsvx.f:432:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sporfsx.f:475:23:
1
sposvx.f:394:0:
sposvx.f:394:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sppsvx.f:394:0:
sppsvx.f:394:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
sspgvd.f:313:14:
1
sspgvd.f:314:15:
1
ssptrf.f:597:0:
IPIV( K ) = -KP
ssptrf.f:313:0:
CALL SSWAP( KP-1, AP( KNC ), 1, AP( KPC ), 1 )
sstedc.f:481:0:
WORK( 1 ) = LWMIN
sstedc.f:482:0:
IWORK( 1 ) = LIWMIN
sstein.f:341:0:
$ XJ = XJM + PERTOL
sstein.f:409:0:
IF( NRM.LT.STPCRT )
sstein.f:389:0:
sstein.f:375:0:
sstein.f:392:0:
ssyevx.f:541:0:
WORK( 1 ) = LWKOPT
ssygvd.f:336:13:
1
ssygvd.f:337:14:
1
ssyrfsx.f:482:23:
1
ssysv.f:229:21:
LWKOPT = WORK(1)
1
ssysv_rook.f:262:21:
LWKOPT = WORK(1)
1
ssytf2.f:594:0:
IPIV( K ) = -KP
ssytf2_rook.f:630:0:
ssytf2_rook.f:408:0:
IF( KP.NE.KK ) THEN
stfttr.f:422:0:
IJ = IJ - NP1X2
stfttr.f:327:0:
IJ = IJ - NX2
stgsna.f:673:0:
DIF( KS ) = COND
stgsyl.f:606:0:
SCALE = SCALE2
stptri.f:229:0:
strsen.f:564:0:
WORK( 1 ) = LWMIN
strsen.f:565:0:
IWORK( 1 ) = LIWMIN
strttf.f:419:0:
IJ = IJ - NP1X2
strttf.f:324:0:
IJ = IJ - NX2
stzrzf.f:251:0:
IWS = LDWORK*NB
zgbrfsx.f:519:23:
1
zgbsvx.f:485:0:
zgbsvx.f:485:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zgebak.f:244:19:
K = SCALE( I )
1
zgebak.f:258:19:
K = SCALE( I )
1
zgebd2.f:250:21:
D( I ) = ALPHA
1
zgebd2.f:269:24:
E( I ) = ALPHA
1
zgebd2.f:294:21:
D( I ) = ALPHA
1
zgebd2.f:313:24:
E( I ) = ALPHA
1
zgees.f:288:21:
HSWORK = WORK( 1 )
1
Warning: Possible change of value in conversion from COMPLEX(8) to INTEGER(4) at (1) [-Wconversion]
zgeesx.f:343:21:
HSWORK = WORK( 1 )
1
zgeesx.f:272:0:
zgeev.f:280:21:
HSWORK = WORK( 1 )
1
zgeevx.f:404:21:
HSWORK = WORK( 1 )
1
zgegv.f:693:20:
1
zgehrd.f:300:0:
zgelsd.f:529:0:
zgels.f:499:0:
zgels.f:358:0:
zgelss.f:272:28:
LWORK_ZGEQRF=DUM(1)
1
zgelss.f:276:28:
LWORK_ZUNMQR=DUM(1)
1
zgelss.f:290:28:
LWORK_ZGEBRD=DUM(1)
1
zgelss.f:294:28:
LWORK_ZUNMBR=DUM(1)
1
zgelss.f:298:28:
LWORK_ZUNGBR=DUM(1)
1
zgelss.f:316:31:
LWORK_ZGELQF=DUM(1)
1
zgelss.f:320:31:
LWORK_ZGEBRD=DUM(1)
1
zgelss.f:324:31:
LWORK_ZUNMBR=DUM(1)
1
zgelss.f:328:31:
LWORK_ZUNGBR=DUM(1)
1
zgelss.f:332:31:
LWORK_ZUNMLQ=DUM(1)
1
zgelss.f:351:31:
LWORK_ZGEBRD=DUM(1)
1
zgelss.f:355:31:
LWORK_ZUNMBR=DUM(1)
1
zgelss.f:359:31:
LWORK_ZUNGBR=DUM(1)
1
zgelss.f:551:0:
zgeqlf.f:215:0:
zgerfsx.f:496:23:
1
zgerqf.f:215:0:
zgesvd.f:325:25:
LWORK_ZGEQRF=DUM(1)
1
zgesvd.f:328:27:
LWORK_ZUNGQR_N=DUM(1)
1
zgesvd.f:330:27:
LWORK_ZUNGQR_M=DUM(1)
1
zgesvd.f:334:25:
LWORK_ZGEBRD=DUM(1)
1
zgesvd.f:338:27:
LWORK_ZUNGBR_P=DUM(1)
1
zgesvd.f:341:27:
LWORK_ZUNGBR_Q=DUM(1)
1
zgesvd.f:448:28:
LWORK_ZGEBRD=DUM(1)
1
zgesvd.f:453:33:
1
zgesvd.f:459:33:
1
zgesvd.f:474:25:
LWORK_ZGELQF=DUM(1)
1
zgesvd.f:477:27:
LWORK_ZUNGLQ_N=DUM(1)
1
zgesvd.f:479:27:
LWORK_ZUNGLQ_M=DUM(1)
1
zgesvd.f:483:25:
LWORK_ZGEBRD=DUM(1)
1
zgesvd.f:487:27:
1
zgesvd.f:491:27:
1
zgesvd.f:597:28:
LWORK_ZGEBRD=DUM(1)
1
zgesvd.f:603:32:
1
zgesvd.f:609:32:
1
zgesvd.f:3394:0:
zgesvd.f:2165:0:
zgesvx.f:458:0:
zgesvx.f:458:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zgetc2.f:204:0:
A( N, N ) = DCMPLX( SMIN, ZERO )
zgetc2.f:186:0:
$ CALL ZSWAP( N, A( 1, JPV ), 1, A( 1, I ), 1 )
zgetc2.f:180:0:
$ CALL ZSWAP( N, A( IPV, 1 ), LDA, A( I, 1 ), LDA )
zggbak.f:259:19:
K = RSCALE( I )
1
zggbak.f:269:19:
K = RSCALE( I )
1
zggbak.f:283:19:
K = LSCALE( I )
1
zggbak.f:293:19:
K = LSCALE( I )
1
zggbal.f:541:14:
1
zggbal.f:549:14:
1
zggglm.f:288:13:
1
zgglse.f:282:13:
1
zggqrf.f:282:13:
LOPT = WORK( 1 )
1
zggrqf.f:281:13:
LOPT = WORK( 1 )
1
zhbevd.f:326:18:
W( 1 ) = AB( 1, 1 )
1
zhbev.f:226:21:
W( 1 ) = AB( 1, 1 )
1
zhbev.f:228:21:
1
zhbevx.f:378:21:
W( 1 ) = CTMP1
1
zhbgst.f:602:0:
zhbtrd.f:462:21:
1
zhbtrd.f:669:21:
D( I ) = AB( 1, I )
1
zheequb.f:263:16:
1
zheequb.f:280:15:
1
zheequb.f:281:15:
1
zheequb.f:315:16:
1
zheevd.f:320:18:
W( 1 ) = A( 1, 1 )
1
zheev.f:227:18:
W( 1 ) = A( 1, 1 )
1
zheevx.f:377:21:
W( 1 ) = A( 1, 1 )
1
zheevx.f:382:24:
W( 1 ) = A( 1, 1 )
1
zheevx.f:551:0:
WORK( 1 ) = LWKOPT
zhegs2.f:199:21:
AKK = A( K, K )
1
zhegs2.f:200:21:
BKK = B( K, K )
1
zhegs2.f:229:21:
AKK = A( K, K )
1
zhegs2.f:230:21:
BKK = B( K, K )
1
zhegs2.f:254:21:
AKK = A( K, K )
1
zhegs2.f:255:21:
BKK = B( K, K )
1
zhegs2.f:274:21:
AKK = A( K, K )
1
zhegs2.f:275:21:
BKK = B( K, K )
1
zhegvd.f:366:13:
1
zhegvd.f:367:14:
LROPT = MAX( DBLE( LROPT ), DBLE( RWORK( 1 ) ) )
1
zhegvd.f:368:14:
1
zherfsx.f:481:23:
1
zhetd2.f:251:21:
E( I ) = ALPHA
1
zhetd2.f:279:23:
1
zhetd2.f:282:18:
D( 1 ) = A( 1, 1 )
1
zhetd2.f:295:21:
E( I ) = ALPHA
1
zhetd2.f:324:21:
D( I ) = A( I, I )
1
zhetd2.f:327:18:
D( N ) = A( N, N )
1
zhetf2.f:555:0:
IF( KP.LT.N )
zhetf2_rook.f:534:24:
D11 = A( K, K ) / D
1
zhetf2_rook.f:535:24:
1
zhetf2_rook.f:691:0:
zhetrd.f:331:24:
D( J ) = A( J, J )
1
zhetrd.f:363:24:
D( J ) = A( J, J )
1
zhgeqz.f:855:0:
IF( ILZ )
zhgeqz.f:797:0:
IF( ILQ ) THEN
zhgeqz.f:689:0:
zhpevd.f:307:18:
W( 1 ) = AP( 1 )
1
zhpev.f:209:18:
W( 1 ) = AP( 1 )
1
zhpevx.f:331:21:
W( 1 ) = AP( 1 )
1
zhpevx.f:335:24:
W( 1 ) = AP( 1 )
1
zhpgst.f:188:21:
BJJ = BP( JJ )
1
zhpgst.f:209:21:
AKK = AP( KK )
1
zhpgst.f:210:21:
BKK = BP( KK )
1
zhpgst.f:240:21:
AKK = AP( KK )
1
zhpgst.f:241:21:
BKK = BP( KK )
1
zhpgst.f:264:21:
AJJ = AP( JJ )
1
zhpgst.f:265:21:
BJJ = BP( JJ )
1
zhpgvd.f:341:14:
1
zhpgvd.f:342:15:
LRWMIN = MAX( DBLE( LRWMIN ), DBLE( RWORK( 1 ) ) )
1
zhpgvd.f:343:15:
1
zhptrd.f:227:21:
E( I ) = ALPHA
1
zhptrd.f:252:23:
1
zhptrd.f:256:18:
D( 1 ) = AP( 1 )
1
zhptrd.f:272:21:
E( I ) = ALPHA
1
zhptrd.f:299:21:
D( I ) = AP( II )
1
zhptrd.f:303:18:
D( N ) = AP( II )
1
zhptrf.f:529:0:
IF( KP.LT.N )
zhptrf.f:328:0:
CALL ZSWAP( KP-1, AP( KNC ), 1, AP( KPC ), 1 )
zlabrd.f:273:21:
D( I ) = ALPHA
1
zlabrd.f:313:24:
E( I ) = ALPHA
1
zlabrd.f:357:21:
D( I ) = ALPHA
1
zlabrd.f:391:24:
E( I ) = ALPHA
1
zlaed8.f:455:0:
W( K ) = Z( JLAM )
zlag2c.f:148:25:
1
Warning: Possible change of value in conversion from COMPLEX(8) to COMPLEX(4) at (1) [-Wconversion]
zlahef.f:694:0:
JMAX = IMAX + IZAMAX( N-IMAX, W( IMAX+1, K+1 ), 1 )
zlahef_rook.f:860:0:
zlahr2.f:307:0:
A( K+NB, NB ) = EI
zlahr2.f:307:0: Warning: ���REALPART_EXPR <ei>��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zlaic1.f:197:21:
TMP = SQRT( S*DCONJG( S )+C*DCONJG( C ) )
1
zlaic1.f:251:19:
1
zlaic1.f:253:19:
1
zlaic1.f:258:18:
TMP = SQRT( SINE*DCONJG( SINE )+COSINE*DCONJG( COSINE ) )
1
zlaic1.f:283:18:
1
zlaic1.f:341:19:
1
zlaic1.f:352:22:
1
zlaic1.f:354:22:
1
zlaic1.f:360:18:
1
zla_lin_berr.f:151:21:
1
zlals0.f:413:0:
zlangb.f:150:0:
zlange.f:140:0:
zlangt.f:130:0:
zlanhb.f:157:0:
zlanhe.f:149:0:
zlanhp.f:142:0:
zlanhs.f:134:0:
zlanht.f:126:0:
zlansb.f:155:0:
zlansp.f:140:0:
zlansy.f:148:0:
zlantb.f:167:0:
zlantp.f:151:0:
zlantr.f:168:0:
zlarfgp.f:241:25:
BETA = -SAVEALPHA
1
zlasyf_rook.f:706:0:
zlat2c.f:157:28:
1
zlat2c.f:170:28:
1
zlatrd.f:274:26:
E( I-1 ) = ALPHA
1
zlatrd.f:328:24:
E( I ) = ALPHA
1
zlauu2.f:168:18:
AII = A( I, I )
1
zlauu2.f:187:18:
AII = A( I, I )
1
zpbsvx.f:430:0:
zpbsvx.f:430:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zpoequb.f:180:15:
S( 1 ) = A( 1, 1 )
1
zpoequb.f:184:18:
S( I ) = A( I, I )
1
zporfsx.f:473:23:
1
zposvx.f:392:0:
zposvx.f:392:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zpotf2.f:180:18:
AJJ = DBLE( A( J, J ) ) - ZDOTC( J-1, A( 1, J ), 1,
1
zpotf2.f:207:18:
AJJ = DBLE( A( J, J ) ) - ZDOTC( J-1, A( J, 1 ), LDA,
1
zppsvx.f:393:0:
zppsvx.f:393:0: Warning: ���bignum��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zpptrf.f:195:18:
AJJ = DBLE( AP( JJ ) ) - ZDOTC( J-1, AP( JC ), 1, AP( JC ),
1
zpptri.f:167:18:
AJJ = AP( JJ )
1
zspr.f:220:0:
JX = KX
zsptrf.f:602:0:
IPIV( K ) = -KP
zsptrf.f:322:0:
zstedc.f:485:0:
WORK( 1 ) = LWMIN
zstedc.f:486:0:
RWORK( 1 ) = LRWMIN
zstedc.f:487:0:
IWORK( 1 ) = LIWMIN
zstein.f:352:0:
$ XJ = XJM + PERTOL
zstein.f:400:0:
zstein.f:386:0:
zstein.f:425:0:
IF( NRM.LT.DTPCRT )
zsyequb.f:275:16:
1
zsyequb.f:292:15:
1
zsyequb.f:293:15:
1
zsyequb.f:327:16:
1
zsyr.f:226:0:
IX = KX
zsyrfsx.f:483:23:
1
zsysv.f:229:21:
LWKOPT = WORK(1)
1
zsysv_rook.f:262:21:
LWKOPT = WORK(1)
1
zsytf2.f:595:0:
IPIV( K ) = -KP
zsytf2_rook.f:638:0:
zsytf2_rook.f:416:0:
IF( KP.NE.KK ) THEN
ztfttr.f:459:0:
IJ = IJ - NP1X2
ztfttr.f:356:0:
IJ = IJ - NX2
ztgsyl.f:611:0:
SCALE = SCALE2
ztptri.f:230:0:
ztrsen.f:450:0:
WORK( 1 ) = LWMIN
ztrttf.f:458:0:
IJ = IJ - NP1X2
ztrttf.f:355:0:
IJ = IJ - NX2
ztzrzf.f:251:0:
IWS = LDWORK*NB
zuncsd2by1.f:519:0:
zuncsd2by1.f:519:0: Warning: ���itaup2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd2by1.f:531:0:
zuncsd2by1.f:506:0:
zuncsd2by1.f:704:0:
CALL ZCOPY( M-P, WORK(IORBDB+P), 1, U2, 1 )
zuncsd2by1.f:552:0:
$ CHILDINFO )
zuncsd2by1.f:552:0: Warning: ���ib22e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd2by1.f:552:0: Warning: ���ib22d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd2by1.f:552:0: Warning: ���ib21e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd2by1.f:552:0: Warning: ���ib21d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd2by1.f:552:0: Warning: ���ib12e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd2by1.f:552:0: Warning: ���ib12d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd2by1.f:552:0: Warning: ���ib11e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd2by1.f:552:0: Warning: ���ib11d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd.f:526:0:
zuncsd.f:526:0: Warning: ���itauq1��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd.f:526:0: Warning: ���itaup2��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd.f:579:0:
zuncsd.f:550:0:
zuncsd.f:526:0:
zuncsd.f:597:0:
zuncsd.f:597:0: Warning: ���ib22e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd.f:597:0: Warning: ���ib22d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd.f:597:0: Warning: ���ib21e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd.f:597:0: Warning: ���ib21d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd.f:597:0: Warning: ���ib12e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd.f:597:0: Warning: ���ib12d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd.f:597:0: Warning: ���ib11e��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zuncsd.f:597:0: Warning: ���ib11d��� may be used uninitialized in this function [-Wmaybe-uninitialized]
zungbr.f:240:18:
LWKOPT = WORK( 1 )
1
zungql.f:210:0:
zungrq.f:210:0:
zunmql.f:279:0:
IWS = NW*NB
zunmrq.f:280:0:
IWS = NW*NB
********End of Output of running make on FBLASLAPACK *******
Not checking for library in Download FBLASLAPACK: [] because no functions given to check for
TEST check from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:154)
TESTING: check from config.libraries(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/libraries.py:154)
Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
No functions to check for in library [] []
Checking for headers Download FBLASLAPACK: ['/home/wangzl/moose-compilers/petsc-3.11.4/include', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include/gfortran/7.1.0', '/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/include']
TEST checkSharedLibrary from config.packages.fblaslapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TESTING: checkSharedLibrary from config.packages.fblaslapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
By default we don't care about checking if the library is shared
TEST alternateConfigureLibrary from config.packages.f2cblaslapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.f2cblaslapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
Called if --with-packagename=0; does nothing by default
TEST checkDependencies from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TESTING: checkDependencies from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TEST configureLibrary from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:356)
TESTING: configureLibrary from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:356)
Checking for a functional BLAS and LAPACK in fblaslapack
TEST checkLib from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:112)
TESTING: checkLib from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:112)
Checking for BLAS and LAPACK symbols
Checking for functions [ddot_] in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libfblas.a'] ['libm.a', '-lstdc++', '-ldl', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lmpifort', '-lmpi', '-lrt', '-lpthread', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7', '-L/usr/lib64/gcc/x86_64-suse-linux/7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-Wl,-rpath,/usr/x86_64-suse-linux/lib', '-L/usr/x86_64-suse-linux/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath']
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.packages.metis -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
char ddot_();
static void _check_ddot_() { ddot_(); }
int main() {
_check_ddot_();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.o -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -lfblas -lm -lstdc++ -ldl -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7 -L/usr/lib64/gcc/x86_64-suse-linux/7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lgfortran -lm -lgcc_s -lquadmath -lrt -lm -lpthread -lz -lstdc++ -ldl
Defined "HAVE_LIBFBLAS" to "1"
Checking for functions [dgetrs_] in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libflapack.a'] ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libfblas.a', 'libm.a', '-lstdc++', '-ldl', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lmpifort', '-lmpi', '-lrt', '-lpthread', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7', '-L/usr/lib64/gcc/x86_64-suse-linux/7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-Wl,-rpath,/usr/x86_64-suse-linux/lib', '-L/usr/x86_64-suse-linux/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath']
Successful compile:
Source:
char dgetrs_();
static void _check_dgetrs_() { dgetrs_(); }
int main() {
_check_dgetrs_();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.o -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -lflapack -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -lfblas -lm -lstdc++ -ldl -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7 -L/usr/lib64/gcc/x86_64-suse-linux/7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lgfortran -lm -lgcc_s -lquadmath -lrt -lm -lpthread -lz -lstdc++ -ldl
Defined "HAVE_LIBFLAPACK" to "1"
Checking for functions [dgeev_] in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libflapack.a'] ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libfblas.a', 'libm.a', '-lstdc++', '-ldl', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lmpifort', '-lmpi', '-lrt', '-lpthread', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7', '-L/usr/lib64/gcc/x86_64-suse-linux/7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-Wl,-rpath,/usr/x86_64-suse-linux/lib', '-L/usr/x86_64-suse-linux/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath']
Successful compile:
Source:
char dgeev_();
static void _check_dgeev_() { dgeev_(); }
int main() {
_check_dgeev_();;
return 0;
Found Fortran mangling on BLAS/LAPACK which is underscore
Defined "BLASLAPACK_UNDERSCORE" to "1"
TEST checkESSL from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:436)
TESTING: checkESSL from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:436)
Check for the IBM ESSL library
Checking for functions [iessl] in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libflapack.a', '/home/wangzl/moose-compilers/petsc-3.11.4/lib/libfblas.a', 'libm.a', '-lstdc++', '-ldl', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lmpifort', '-lmpi', '-lrt', '-lpthread', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7', '-L/usr/lib64/gcc/x86_64-suse-linux/7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-Wl,-rpath,/usr/x86_64-suse-linux/lib', '-L/usr/x86_64-suse-linux/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath'] []
Successful compile:
Source:
char iessl();
static void _check_iessl() { iessl(); }
int main() {
_check_iessl();;
return 0;
Possible ERROR while running linker: exit code 1
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_iessl':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `iessl'
collect2: error: ld returned 1 exit status
TEST checkPESSL from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:477)
TESTING: checkPESSL from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:477)
Check for the IBM PESSL library - and error out - if used instead of ESSL
Checking for functions [ipessl] in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libflapack.a', '/home/wangzl/moose-compilers/petsc-3.11.4/lib/libfblas.a', 'libm.a', '-lstdc++', '-ldl', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lmpifort', '-lmpi', '-lrt', '-lpthread', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7', '-L/usr/lib64/gcc/x86_64-suse-linux/7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-Wl,-rpath,/usr/x86_64-suse-linux/lib', '-L/usr/x86_64-suse-linux/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath'] []
Successful compile:
Source:
char ipessl();
static void _check_ipessl() { ipessl(); }
int main() {
_check_ipessl();;
return 0;
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_ipessl':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `ipessl'
TEST checkMKL from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:444)
TESTING: checkMKL from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:444)
Check for Intel MKL library
Checking for functions [mkl_set_num_threads] in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libflapack.a', '/home/wangzl/moose-compilers/petsc-3.11.4/lib/libfblas.a', 'libm.a', '-lstdc++', '-ldl', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lmpifort', '-lmpi', '-lrt', '-lpthread', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7', '-L/usr/lib64/gcc/x86_64-suse-linux/7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-Wl,-rpath,/usr/x86_64-suse-linux/lib', '-L/usr/x86_64-suse-linux/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath'] []
Successful compile:
Source:
char mkl_set_num_threads();
static void _check_mkl_set_num_threads() { mkl_set_num_threads(); }
int main() {
_check_mkl_set_num_threads();;
return 0;
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_mkl_set_num_threads':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `mkl_set_num_threads'
TEST checkMissing from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:502)
TESTING: checkMissing from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:502)
Check for missing LAPACK routines
Checking for functions [dgeev_ dgels_ dgelss_ dgeqrf_ dgerfs_ dgesv_ dgesvd_ dgetrf_ dgetri_ dgetrs_ dgges_ dhgeqz_ dhseqr_ dormqr_ dpotrf_ dpotri_ dpotrs_ dpttrf_ dpttrs_ dstebz_ dstein_ dsteqr_ dsyev_ dsyevx_ dsygvx_ dsytrf_ dsytri_ dsytrs_ dtgsen_ dtrsen_ dtrtrs_ dorgqr_] in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libflapack.a'] ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libfblas.a', '/home/wangzl/moose-compilers/petsc-3.11.4/lib/libflapack.a', '/home/wangzl/moose-compilers/petsc-3.11.4/lib/libfblas.a', 'libm.a', '-lstdc++', '-ldl', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lmpifort', '-lmpi', '-lrt', '-lpthread', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7', '-L/usr/lib64/gcc/x86_64-suse-linux/7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-Wl,-rpath,/usr/x86_64-suse-linux/lib', '-L/usr/x86_64-suse-linux/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath']
Successful compile:
Source:
char dgeev_();
char dgels_();
static void _check_dgels_() { dgels_(); }
char dgelss_();
static void _check_dgelss_() { dgelss_(); }
char dgeqrf_();
static void _check_dgeqrf_() { dgeqrf_(); }
char dgerfs_();
static void _check_dgerfs_() { dgerfs_(); }
char dgesv_();
static void _check_dgesv_() { dgesv_(); }
char dgesvd_();
static void _check_dgesvd_() { dgesvd_(); }
char dgetrf_();
static void _check_dgetrf_() { dgetrf_(); }
char dgetri_();
static void _check_dgetri_() { dgetri_(); }
char dgetrs_();
char dgges_();
static void _check_dgges_() { dgges_(); }
char dhgeqz_();
static void _check_dhgeqz_() { dhgeqz_(); }
char dhseqr_();
static void _check_dhseqr_() { dhseqr_(); }
char dormqr_();
static void _check_dormqr_() { dormqr_(); }
char dpotrf_();
static void _check_dpotrf_() { dpotrf_(); }
char dpotri_();
static void _check_dpotri_() { dpotri_(); }
char dpotrs_();
static void _check_dpotrs_() { dpotrs_(); }
char dpttrf_();
static void _check_dpttrf_() { dpttrf_(); }
char dpttrs_();
static void _check_dpttrs_() { dpttrs_(); }
char dstebz_();
static void _check_dstebz_() { dstebz_(); }
char dstein_();
static void _check_dstein_() { dstein_(); }
char dsteqr_();
static void _check_dsteqr_() { dsteqr_(); }
char dsyev_();
static void _check_dsyev_() { dsyev_(); }
char dsyevx_();
static void _check_dsyevx_() { dsyevx_(); }
char dsygvx_();
static void _check_dsygvx_() { dsygvx_(); }
char dsytrf_();
static void _check_dsytrf_() { dsytrf_(); }
char dsytri_();
static void _check_dsytri_() { dsytri_(); }
char dsytrs_();
static void _check_dsytrs_() { dsytrs_(); }
char dtgsen_();
static void _check_dtgsen_() { dtgsen_(); }
char dtrsen_();
static void _check_dtrsen_() { dtrsen_(); }
char dtrtrs_();
static void _check_dtrtrs_() { dtrtrs_(); }
char dorgqr_();
static void _check_dorgqr_() { dorgqr_(); }
int main() {
_check_dgeev_();
_check_dgels_();
_check_dgelss_();
_check_dgeqrf_();
_check_dgerfs_();
_check_dgesv_();
_check_dgesvd_();
_check_dgetrf_();
_check_dgetri_();
_check_dgetrs_();
_check_dgges_();
_check_dhgeqz_();
_check_dhseqr_();
_check_dormqr_();
_check_dpotrf_();
_check_dpotri_();
_check_dpotrs_();
_check_dpttrf_();
_check_dpttrs_();
_check_dstebz_();
_check_dstein_();
_check_dsteqr_();
_check_dsyev_();
_check_dsyevx_();
_check_dsygvx_();
_check_dsytrf_();
_check_dsytri_();
_check_dsytrs_();
_check_dtgsen_();
_check_dtrsen_();
_check_dtrtrs_();
_check_dorgqr_();;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.o -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -lflapack -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -lfblas -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -lflapack -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -lfblas -lm -lstdc++ -ldl -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7 -L/usr/lib64/gcc/x86_64-suse-linux/7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lgfortran -lm -lgcc_s -lquadmath -lrt -lm -lpthread -lz -lstdc++ -ldl
TEST checklsame from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:520)
TESTING: checklsame from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:520)
Do the BLAS/LAPACK libraries have a valid lsame() function with correction binding. Lion and xcode 4.2 do not
Checking for functions [lsame_] in library ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libflapack.a', '/home/wangzl/moose-compilers/petsc-3.11.4/lib/libfblas.a', 'libm.a', '-lstdc++', '-ldl', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lmpifort', '-lmpi', '-lrt', '-lpthread', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7', '-L/usr/lib64/gcc/x86_64-suse-linux/7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-Wl,-rpath,/usr/x86_64-suse-linux/lib', '-L/usr/x86_64-suse-linux/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath'] []
Successful compile:
Source:
char lsame_();
static void _check_lsame_() { lsame_(); }
int main() {
_check_lsame_();;
return 0;
Defined "HAVE_LIBM" to "1"
Defined "HAVE_LIBSTDC__" to "1"
Defined "HAVE_LIBDL" to "1"
Defined "HAVE_LIBMPIFORT" to "1"
Defined "HAVE_LIBMPI" to "1"
Defined "HAVE_LIBRT" to "1"
Defined "HAVE_LIBPTHREAD" to "1"
Defined "HAVE_LIBGFORTRAN" to "1"
Defined "HAVE_LIBGCC_S" to "1"
Defined "HAVE_LIBQUADMATH" to "1"
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.packages.metis -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
char *dgeev_(void);
char* testroutine(void){return dgeev_();
}Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.packages.metis -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.setCompilers/conftest.c
Successful compile:
Source:
char *dgeev_(void);
}Executing: mpicc -o /tmp/petsc-wjcu960y/config.setCompilers/libconftest.so -shared -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.setCompilers/conftest.o -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7 -L/usr/lib64/gcc/x86_64-suse-linux/7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -lflapack -lfblas -lflapack -lfblas -lm -lstdc++ -ldl -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lrt -lm -lpthread -lz -lstdc++ -ldl
TEST checkRuntimeIssues from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:579)
TESTING: checkRuntimeIssues from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/BlasLapack.py:579)
Determines if BLAS/LAPACK routines use 32 or 64 bit integers
Checking if BLAS/LAPACK routines use 32 or 64 bit integers All intermediate test results are stored in /tmp/petsc-wjcu960y/config.packages.BlasLapack
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.packages.BlasLapack/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.packages.metis -I/tmp/petsc-wjcu960y/config.packages.BlasLapack -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.packages.BlasLapack/conftest.c
Successful compile:
Source:
#include <sys/types.h>
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
FILE *output = fopen("runtimetestoutput","w");
extern double ddot_(const int*,const double*,const int *,const double*,const int*);
double x1mkl[4] = {3.0,5.0,7.0,9.0};
int one1mkl = 1,nmkl = 2;
double dotresultmkl = 0;
dotresultmkl = ddot_(&nmkl,x1mkl,&one1mkl,x1mkl,&one1mkl);
fprintf(output, "-known-64-bit-blas-indices=%d",dotresultmkl != 34);;
return 0;
Executing: mpicc -o /tmp/petsc-wjcu960y/config.packages.BlasLapack/conftest -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.packages.BlasLapack/conftest.o -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -lflapack -Wl,-rpath,/home/wangzl/moose-compilers/petsc-3.11.4/lib -L/home/wangzl/moose-compilers/petsc-3.11.4/lib -lfblas -lm -lstdc++ -ldl -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7 -L/usr/lib64/gcc/x86_64-suse-linux/7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64 -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib -lgfortran -lm -lgcc_s -lquadmath -lrt -lm -lpthread -lz -lstdc++ -ldl
Testing executable /tmp/petsc-wjcu960y/config.packages.BlasLapack/conftest to see if it can be run
Executing: /tmp/petsc-wjcu960y/config.packages.BlasLapack/conftest
Checking for 64 bit blas indices: result 0
TEST checkSharedLibrary from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TESTING: checkSharedLibrary from config.packages.BlasLapack(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TEST alternateConfigureLibrary from config.packages.sundials(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.sundials(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.spai(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.spai(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.pARMS(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.pARMS(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.p4est(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.p4est(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST checkDependencies from config.packages.mkl_sparse_optimize(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TESTING: checkDependencies from config.packages.mkl_sparse_optimize(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TEST configureLibrary from config.packages.mkl_sparse_optimize(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/mkl_sparse_optimize.py:65)
TESTING: configureLibrary from config.packages.mkl_sparse_optimize(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/packages/mkl_sparse_optimize.py:65)
Checking for a functional mkl_sparse_optimize
Checking for library in Compiler specific search MKL_SPARSE_OPTIMIZE: []
Checking for functions [mkl_sparse_optimize mkl_sparse_s_create_bsr] in library [] ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libflapack.a', '/home/wangzl/moose-compilers/petsc-3.11.4/lib/libfblas.a', 'libm.a', '-lstdc++', '-ldl', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lmpifort', '-lmpi', '-lrt', '-lpthread', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7', '-L/usr/lib64/gcc/x86_64-suse-linux/7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-Wl,-rpath,/usr/x86_64-suse-linux/lib', '-L/usr/x86_64-suse-linux/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath']
Executing: mpicc -c -o /tmp/petsc-wjcu960y/config.libraries/conftest.o -I/tmp/petsc-wjcu960y/config.compilers -I/tmp/petsc-wjcu960y/config.utilities.closure -I/tmp/petsc-wjcu960y/config.headers -I/tmp/petsc-wjcu960y/config.utilities.cacheDetails -I/tmp/petsc-wjcu960y/config.atomics -I/tmp/petsc-wjcu960y/config.functions -I/tmp/petsc-wjcu960y/config.utilities.featureTestMacros -I/tmp/petsc-wjcu960y/config.utilities.missing -I/tmp/petsc-wjcu960y/PETSc.options.scalarTypes -I/tmp/petsc-wjcu960y/config.packages.MPI -I/tmp/petsc-wjcu960y/config.types -I/tmp/petsc-wjcu960y/config.packages.pthread -I/tmp/petsc-wjcu960y/config.packages.metis -I/tmp/petsc-wjcu960y/config.packages.BlasLapack -I/tmp/petsc-wjcu960y/config.setCompilers -I/tmp/petsc-wjcu960y/config.libraries -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fopenmp /tmp/petsc-wjcu960y/config.libraries/conftest.c
Successful compile:
Source:
char mkl_sparse_optimize();
static void _check_mkl_sparse_optimize() { mkl_sparse_optimize(); }
char mkl_sparse_s_create_bsr();
static void _check_mkl_sparse_s_create_bsr() { mkl_sparse_s_create_bsr(); }
int main() {
_check_mkl_sparse_optimize();
_check_mkl_sparse_s_create_bsr();;
return 0;
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_mkl_sparse_optimize':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `mkl_sparse_optimize'
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_mkl_sparse_s_create_bsr':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:7: undefined reference to `mkl_sparse_s_create_bsr'
TEST checkSharedLibrary from config.packages.mkl_sparse_optimize(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TESTING: checkSharedLibrary from config.packages.mkl_sparse_optimize(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TEST checkDependencies from config.packages.mkl_sparse(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TESTING: checkDependencies from config.packages.mkl_sparse(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TEST configureLibrary from config.packages.mkl_sparse(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
TESTING: configureLibrary from config.packages.mkl_sparse(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
Find an installation and check if it can work with PETSc
Checking for library in Compiler specific search MKL_SPARSE: []
Checking for functions [mkl_dcsrmv] in library [] ['/home/wangzl/moose-compilers/petsc-3.11.4/lib/libflapack.a', '/home/wangzl/moose-compilers/petsc-3.11.4/lib/libfblas.a', 'libm.a', '-lstdc++', '-ldl', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lmpifort', '-lmpi', '-lrt', '-lpthread', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7', '-L/usr/lib64/gcc/x86_64-suse-linux/7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/compiler/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64/gcc4.7', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mkl/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/libfabric/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/ipp/lib/intel64', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/daal/lib/intel64_lin', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-L/opt/intel/compilers_and_libraries_2019.5.281/linux/tbb/lib/intel64_lin/gcc4.4', '-Wl,-rpath,/usr/x86_64-suse-linux/lib', '-L/usr/x86_64-suse-linux/lib', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib/debug_mt', '-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.5.281/linux/mpi/intel64/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath']
Successful compile:
Source:
char mkl_dcsrmv();
static void _check_mkl_dcsrmv() { mkl_dcsrmv(); }
int main() {
_check_mkl_dcsrmv();;
return 0;
stderr:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: /tmp/petsc-wjcu960y/config.libraries/conftest.o: in function `_check_mkl_dcsrmv':
/tmp/petsc-wjcu960y/config.libraries/conftest.c:5: undefined reference to `mkl_dcsrmv'
TEST checkSharedLibrary from config.packages.mkl_sparse(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TESTING: checkSharedLibrary from config.packages.mkl_sparse(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:817)
TEST alternateConfigureLibrary from config.packages.mkl_cpardiso(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.mkl_cpardiso(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.fftw(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.fftw(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.elemental(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.elemental(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.ml(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.ml(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST alternateConfigureLibrary from config.packages.mkl_pardiso(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TESTING: alternateConfigureLibrary from config.packages.mkl_pardiso(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:821)
TEST checkDependencies from config.packages.SuperLU_DIST(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TESTING: checkDependencies from config.packages.SuperLU_DIST(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:738)
TEST configureLibrary from config.packages.SuperLU_DIST(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
TESTING: configureLibrary from config.packages.SuperLU_DIST(/tmp/stack_temp.rFVgkc/petsc-3.11.4/config/BuildSystem/config/package.py:763)
Checking for a functional SuperLU_DIST
Looking for SUPERLU_DIST at git.superlu_dist, hg.superlu_dist or a directory starting with ['SuperLU_DIST', 'superlu_dist']
Could not locate an existing copy of SUPERLU_DIST:
['git.slepc', 'petsc-pkg-scotch-c15036faac5f', 'petsc-pkg-metis-49e61501c498', 'petsc-pkg-parmetis-73dab469aa36', 'fblaslapack-3.4.2']
Downloading SuperLU_DIST
Trying to download file:///home/wangzl/packages/superlu_dist-6.1.1.tar.gz for SUPERLU_DIST
Downloading file:///home/wangzl/packages/superlu_dist-6.1.1.tar.gz to /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/_d_superlu_dist-6.1.1.tar.gz
Extracting /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/_d_superlu_dist-6.1.1.tar.gz
Executing: cd /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages; chmod -R a+r superlu_dist-6.1.1;find superlu_dist-6.1.1 -type d -name "*" -exec chmod a+rx {} \;
Found a copy of SUPERLU_DIST in superlu_dist-6.1.1
Have to rebuild SUPERLU_DIST, /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/externalpackages/superlu_dist-6.1.1/superlu_dist.petscconf != /tmp/stack_temp.rFVgkc/petsc-3.11.4/linux-opt/lib/petsc/conf/pkg.conf.superlu_dist
Configuring SUPERLU_DIST with cmake, this may take several minutes
