[petsc-users] petsc error disappears when I print something in the function
Kaushik Vijaykumar
kaushikv318 at gmail.com
Tue Apr 21 10:29:01 CDT 2020
Thanks Dave and Mathew. I will keep looking for the bug and here is the
full piece of code.
PetscInt kel_tet10CX(PetscScalar *X, PetscScalar *Y, PetscScalar *Z,
PetscScalar *ke, PetscInt elmat, PetscScalar dmg, PetscInt el_has_orient,
PetscScalar rot[3][3], PetscScalar temperature, PetscScalar *thermforce,
PetscInt damflag, PetscScalar Cmat[6][6], PetscScalar alphavec[6]){
/////////PETSc declarations
PetscErrorCode ierr;
PetscInt ii,jj,kk,k1,ll,l1,i,j,k,l,i1,j1,jj1,ii1,iflag;
PetscInt nope=10; //// nodes on the element
PetscScalar
alpha2[4][4],alpha2unrot[4][4],C[6][6],C4[4][4][4][4],C4unrot[4][4][4][4],eta,etas[9],GP[4],s[100][100],shp[10][4],shpj[4][11],w[4][4],weight,wts[4],xi,xis[4],xl[10][3],xsj,xsjj,zeta,zetas[4];
/////////////Prototypes
PetscInt constit(PetscInt elmat,PetscScalar C4[4][4][4][4], PetscScalar
alpha2[4][4], PetscScalar dmg, PetscScalar temperature, PetscInt damflag,
PetscScalar Cmat[6][6], PetscScalar alphavec[6]);
void shape10tet_(PetscScalar *xi, PetscScalar *eta, PetscScalar *zeta,
PetscScalar xl[4][11], PetscScalar *xsj, PetscScalar shp[5][11], PetscInt
*iflag); // you have to dimension the array arguments to the size Fortran
sees them
// printf("\n Entered SPAF element Tet10 \n");
/////////////Code
if (el_has_orient == 1){ierr =
constit(elmat,C4unrot,alpha2unrot,dmg,temperature,damflag,Cmat,alphavec);ierr
= rot4(rot,C4unrot,C4);ierr = rot2(rot,alpha2unrot,alpha2);}
else {ierr =
constit(elmat,C4,alpha2,dmg,temperature,damflag,Cmat,alphavec);}
// printf("\n Came back from spaf materials to SPAF element Tet10 \n");
// ierr = PetscPrintf(PETSC_COMM_SELF,"In tet10 \n");CHKERRQ(ierr);
// Gauss points and weights
xis[0] = 0.138196601125011;
xis[1] = 0.585410196624968;
xis[2] = 0.138196601125011;
xis[3] = 0.138196601125011;
etas[0] = 0.138196601125011;
etas[1] = 0.138196601125011;
etas[2] = 0.585410196624968;
etas[3] = 0.138196601125011;
zetas[0] = 0.138196601125011;
zetas[1] = 0.138196601125011;
zetas[2] = 0.138196601125011;
zetas[3] = 0.585410196624968;
wts[0] = 0.04166666666667;
wts[1] = 0.04166666666667;
wts[2] = 0.04166666666667;
wts[3] = 0.04166666666667;
// assemble nodal coordinates into xl
// when fortran gets it, it will be transposed and the indices increased by
1
for (ii=0; ii<nope; ii++)
xl[ii][0] = X[ii];//fprintf(outfile,"X[%i] = %f\n",ii,X[ii]);
xl[ii][1] = Y[ii];//fprintf(outfile,"Y[%i] = %f\n",ii,Y[ii]);
xl[ii][2] = Z[ii];//fprintf(outfile,"Z[%i] = %f\n",ii,Z[ii]);
// ke
memset(ke, 0, sizeof(ke[0])*nope*3*nope*3); // why doesn't compiler know
the real size of ke?
memset(s, 0, sizeof(s));
iflag = 3; /// tells shape routine to calculate shape functions,
derivatives and det J
for (kk=0; kk<4; kk++) // Loop 3
weight = wts[kk];
// Integration point
xi = xis[kk];
eta = etas[kk];
zeta = zetas[kk];
shape10tet_(&xi,&eta,&zeta,xl,&xsj,shp,&iflag);
if (xsj<0){fprintf(outfile,"Negative det J on TET10 element!!
(Integration point %i)\n",kk);}
xsjj = sqrt(xsj);
for (i1=1; i1<nope+1; i1++) // Loop 4a
shpj[1][i1] = shp[i1-1][0]*xsjj; // shape function derivative wrt xi
shpj[2][i1] = shp[i1-1][1]*xsjj; // shape function derivative wrt eta
shpj[3][i1] = shp[i1-1][2]*xsjj; // shape function derivative wrt zeta
shpj[4][i1] = shp[i1-1][3]*xsj; // shape function itself
// printf("\n shp[1][il] %f %f %f %f
\n",shpj[1][i1],shpj[2][i1],shpj[3][i1],shpj[4][i1]);
} // Loop 4a
jj1=1;
for (j=1; j<nope+1; j++) // Loop 4b
ii1=1;
for (i=1; i<nope+1; i++) // Loop 5
for (i1=1; i1<4; i1++) // Loop 6a
for (j1=1; j1<4; j1++) // Loop 7a
w[i1][j1] = shpj[i1][i]*shpj[j1][j];
} // Loop 7a
} // Loop 6a
for (i1=1; i1<4; i1++) // Loop 6b
for (j1=1; j1<4; j1++) // Loop 7b
for (k1=1; k1<4; k1++) // Loop 8
for (l1=1; l1<4; l1++) // Loop 9
s[ii1+i1-1][jj1+j1-1] =
s[ii1+i1-1][jj1+j1-1]+C4[i1][k1][j1][l1]*w[k1][l1]*weight;
ierr = PetscFPrintf(PETSC_COMM_WORLD,outfile,"C4 %f
\n",C4[i1][k1][j1][l1]);CHKERRQ(ierr);
ierr = PetscFPrintf(PETSC_COMM_WORLD,outfile,"w %f
\n",w[k1][l1]);CHKERRQ(ierr);
ierr = PetscFPrintf(PETSC_COMM_WORLD,outfile,"weight %f
\n",weight);CHKERRQ(ierr);
} // Loop 9
} // Loop 8
} // Loop 7b
} // Loop 6b
ii1 = ii1 + 3;
} // Loop 5
jj1 = jj1 + 3;
} // Loop 4b
} // Loop 3
// ierr = PetscFPrintf(PETSC_COMM_WORLD,outfile,"C4 %f
\n",C4[1][1][1][1]);CHKERRQ(ierr);
for (ii=1; ii<nope*3+1; ii++)
for (jj=1; jj<nope*3+1; jj++)
{ ke[(ii-1)*nope*3+(jj-1)] = s[ii][jj];
// printf("\n ke[(%d-1)*nope*3+(%d-1)] = %f \n", ii,jj,
ke[(ii-1)*nope*3+(jj-1)] );
// ierr = PetscPrintf(PETSC_COMM_SELF,"exiting spaf elemnts tet10
%f\n",ke[3200]);CHKERRQ(ierr);
return 0;
Thanks in advance
Kaushik
On Tue, Apr 21, 2020 at 10:51 AM Dave May <dave.mayhem23 at gmail.com> wrote:
> On Tue 21. Apr 2020 at 16:47, Matthew Knepley <knepley at gmail.com> wrote:
>> You are overwriting memory somewhere. The prints just move it around. I
>> suggest running with valgrind.
> Matt is right. However, judging by the code snippet I bet all the arrays
> in question are statically allocated, thus valgrind may be of somewhat
> limited use.
> If you send the entire function, or all the related pieces of code,
> someone in the list might spot the error.
> Thanks
> Dave
>> Thanks,
>> Matt
>> On Tue, Apr 21, 2020 at 10:44 AM Kaushik Vijaykumar <
>> kaushikv318 at gmail.com> wrote:
>>> Hello group,
>>> I have been trying to navigate a weird error that I have found in my FEA
>>> code that I am developing using PetSc. The error occurs when, i execute a
>>> call to stiffness generation of a Tetrahederal element. The code returns an
>>> memory error if I don't print the following statements in the function,
>>> (see the ierr print statements below):
>>> } // Loop 9
>>> } // Loop 8
>>> } // Loop 7b
>>> } // Loop 6b
>>> Any help on this is really appreciated.
>>> Thanks
>>> Kaushik
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200421/27b24232/attachment-0001.html>
