[petsc-users] MPI error for large number of processes and subcomms
    Junchao Zhang
    junchao.zhang at gmail.com
    Thu Apr 16 21:06:27 CDT 2020
Randy,
  Up to now I could not reproduce your error, even with the biggest mpirun
-n 5120 ./test -nsubs 320 -nx 100 -ny 100 -nz 100
  While I continue doing test, you can try other options. It looks you want
to duplicate a vector to subcomms. I don't think you need the two lines:
call AOApplicationToPetsc(aoParent,nis,ind1,ierr)
call AOApplicationToPetsc(aoSub,nis,ind2,ierr)
 In addition, you can use simpler and more memory-efficient index sets.
There is a petsc example for this task, see case 3 in
https://gitlab.com/petsc/petsc/-/blob/master/src/vec/vscat/tests/ex9.c
 BTW, it is good to use petsc master so we are on the same page.
--Junchao Zhang
On Wed, Apr 15, 2020 at 10:28 AM Randall Mackie <rlmackie862 at gmail.com>
wrote:
> Hi Junchao,
> So I was able to create a small test code that duplicates the issue we
> have been having, and it is attached to this email in a zip file.
> Included is the test.F90 code, the commands to duplicate crash and to
> duplicate a successful run, output errors, and our petsc configuration.
> Our findings to date include:
> The error is reproducible in a very short time with this script
> It is related to nproc*nsubs and (although to a less extent) to DM grid
> size
> It happens regardless of MPI implementation (mpich, intel mpi 2018, 2019,
> openmpi) or compiler (gfortran/gcc , intel 2018)
> No effect changing vecscatter_type to mpi1 or mpi3. Mpi1 seems to slightly
> increase the limit, but still fails on the full machine set.
> Nothing looks interesting on valgrind
> Our initial tests were carried out on an Azure cluster, but we also tested
> on our smaller cluster, and we found the following:
> Works:
> $PETSC_DIR/lib/petsc/bin/petscmpiexec -n 1280 -hostfile hostfile ./test
> -nsubs 80 -nx 100 -ny 100 -nz 100
> Crashes (this works on Azure)
> $PETSC_DIR/lib/petsc/bin/petscmpiexec -n 2560 -hostfile hostfile ./test
> So it looks like it may also be related to the physical number of nodes as
> well.
> In any case, even with 2560 processes on 192 cores the memory does not go
> above 3.5 Gbyes so you don’t need a huge cluster to test.
> Thanks,
> Randy M.
> On Apr 14, 2020, at 12:23 PM, Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> There is an MPI_Allreduce in PetscGatherNumberOfMessages, that is why I
> doubted it was the problem. Even if users configure petsc with 64-bit
> indices, we use PetscMPIInt in MPI calls. So it is not a problem.
> Try -vecscatter_type mpi1 to restore to the original VecScatter
> implementation. If the problem still remains, could you provide a test
> example for me to debug?
> --Junchao Zhang
> On Tue, Apr 14, 2020 at 12:13 PM Randall Mackie <rlmackie862 at gmail.com>
> wrote:
>> Hi Junchao,
>> We have tried your two suggestions but the problem remains.
>> And the problem seems to be on the MPI_Isend line 117 in
>> PetscGatherMessageLengths and not MPI_AllReduce.
>> We have now tried Intel MPI, Mpich, and OpenMPI, and so are thinking the
>> problem must be elsewhere and not MPI.
>> Give that this is a 64 bit indices build of PETSc, is there some possible
>> incompatibility between PETSc and MPI calls?
>> We are open to any other possible suggestions to try as other than
>> valgrind on thousands of processes we seem to have run out of ideas.
>> Thanks, Randy M.
>> On Apr 13, 2020, at 8:54 AM, Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>> --Junchao Zhang
>> On Mon, Apr 13, 2020 at 10:53 AM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> Randy,
>>>    Someone reported similar problem before. It turned out an Intel MPI
>>> MPI_Allreduce bug.  A workaround is setting the environment variable
>>> I_MPI_ADJUST_ALLREDUCE=1.arr
>>  Correct:  I_MPI_ADJUST_ALLREDUCE=1
>>>    But you mentioned mpich also had the error. So maybe the problem is
>>> not the same. So let's try the workaround first. If it doesn't work, add
>>> another petsc option -build_twosided allreduce, which is a workaround for
>>> Intel MPI_Ibarrier bugs we met.
>>>    Thanks.
>>> --Junchao Zhang
>>> On Mon, Apr 13, 2020 at 10:38 AM Randall Mackie <rlmackie862 at gmail.com>
>>> wrote:
>>>> Dear PETSc users,
>>>> We are trying to understand an issue that has come up in running our
>>>> code on a large cloud cluster with a large number of processes and subcomms.
>>>> This is code that we use daily on multiple clusters without problems,
>>>> and that runs valgrind clean for small test problems.
>>>> The run generates the following messages, but doesn’t crash, just seems
>>>> to hang with all processes continuing to show activity:
>>>> [492]PETSC ERROR: #1 PetscGatherMessageLengths() line 117 in
>>>> /mnt/home/cgg/PETSc/petsc-3.12.4/src/sys/utils/mpimesg.c
>>>> [492]PETSC ERROR: #2 VecScatterSetUp_SF() line 658 in
>>>> /mnt/home/cgg/PETSc/petsc-3.12.4/src/vec/vscat/impls/sf/vscatsf.c
>>>> [492]PETSC ERROR: #3 VecScatterSetUp() line 209 in
>>>> /mnt/home/cgg/PETSc/petsc-3.12.4/src/vec/vscat/interface/vscatfce.c
>>>> [492]PETSC ERROR: #4 VecScatterCreate() line 282 in
>>>> /mnt/home/cgg/PETSc/petsc-3.12.4/src/vec/vscat/interface/vscreate.c
>>>> Looking at line 117 in PetscGatherMessageLengths we find the offending
>>>> statement is the MPI_Isend:
>>>>   /* Post the Isends with the message length-info */
>>>>   for (i=0,j=0; i<size; ++i) {
>>>>     if (ilengths[i]) {
>>>>       ierr =
>>>> MPI_Isend((void*)(ilengths+i),1,MPI_INT,i,tag,comm,s_waits+j);CHKERRQ(ierr);
>>>>       j++;
>>>> We have tried this with Intel MPI 2018, 2019, and mpich, all giving the
>>>> same problem.
>>>> We suspect there is some limit being set on this cloud cluster on the
>>>> number of file connections or something, but we don’t know.
>>>> Anyone have any ideas? We are sort of grasping for straws at this point.
>>>> Thanks, Randy M.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200416/431ac9d7/attachment.html>
