[petsc-users] MPI error for large number of processes and subcomms
    Randall Mackie
    rlmackie862 at gmail.com
    Wed Apr 15 10:28:55 CDT 2020
Hi Junchao,
So I was able to create a small test code that duplicates the issue we have been having, and it is attached to this email in a zip file.
Included is the test.F90 code, the commands to duplicate crash and to duplicate a successful run, output errors, and our petsc configuration.
Our findings to date include:
The error is reproducible in a very short time with this script
It is related to nproc*nsubs and (although to a less extent) to DM grid size
It happens regardless of MPI implementation (mpich, intel mpi 2018, 2019, openmpi) or compiler (gfortran/gcc , intel 2018)
No effect changing vecscatter_type to mpi1 or mpi3. Mpi1 seems to slightly increase the limit, but still fails on the full machine set.
Nothing looks interesting on valgrind
Our initial tests were carried out on an Azure cluster, but we also tested on our smaller cluster, and we found the following:
Works:
$PETSC_DIR/lib/petsc/bin/petscmpiexec -n 1280 -hostfile hostfile ./test -nsubs 80 -nx 100 -ny 100 -nz 100
Crashes (this works on Azure)
$PETSC_DIR/lib/petsc/bin/petscmpiexec -n 2560 -hostfile hostfile ./test -nsubs 80 -nx 100 -ny 100 -nz 100
So it looks like it may also be related to the physical number of nodes as well.
In any case, even with 2560 processes on 192 cores the memory does not go above 3.5 Gbyes so you don’t need a huge cluster to test.
Randy M.
> On Apr 14, 2020, at 12:23 PM, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> There is an MPI_Allreduce in PetscGatherNumberOfMessages, that is why I doubted it was the problem. Even if users configure petsc with 64-bit indices, we use PetscMPIInt in MPI calls. So it is not a problem.
> Try -vecscatter_type mpi1 to restore to the original VecScatter implementation. If the problem still remains, could you provide a test example for me to debug?
> --Junchao Zhang
> On Tue, Apr 14, 2020 at 12:13 PM Randall Mackie <rlmackie862 at gmail.com <mailto:rlmackie862 at gmail.com>> wrote:
> Hi Junchao,
> We have tried your two suggestions but the problem remains.
> And the problem seems to be on the MPI_Isend line 117 in PetscGatherMessageLengths and not MPI_AllReduce.
> We have now tried Intel MPI, Mpich, and OpenMPI, and so are thinking the problem must be elsewhere and not MPI.
> Give that this is a 64 bit indices build of PETSc, is there some possible incompatibility between PETSc and MPI calls?
> We are open to any other possible suggestions to try as other than valgrind on thousands of processes we seem to have run out of ideas.
> Thanks, Randy M.
>> On Apr 13, 2020, at 8:54 AM, Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>> --Junchao Zhang
>> On Mon, Apr 13, 2020 at 10:53 AM Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>> Randy,
>>    Someone reported similar problem before. It turned out an Intel MPI MPI_Allreduce bug.  A workaround is setting the environment variable I_MPI_ADJUST_ALLREDUCE=1.arr
>>  Correct:  I_MPI_ADJUST_ALLREDUCE=1
>>    But you mentioned mpich also had the error. So maybe the problem is not the same. So let's try the workaround first. If it doesn't work, add another petsc option -build_twosided allreduce, which is a workaround for Intel MPI_Ibarrier bugs we met.
>>    Thanks.
>> --Junchao Zhang
>> On Mon, Apr 13, 2020 at 10:38 AM Randall Mackie <rlmackie862 at gmail.com <mailto:rlmackie862 at gmail.com>> wrote:
>> Dear PETSc users,
>> We are trying to understand an issue that has come up in running our code on a large cloud cluster with a large number of processes and subcomms.
>> This is code that we use daily on multiple clusters without problems, and that runs valgrind clean for small test problems.
>> The run generates the following messages, but doesn’t crash, just seems to hang with all processes continuing to show activity:
>> [492]PETSC ERROR: #1 PetscGatherMessageLengths() line 117 in /mnt/home/cgg/PETSc/petsc-3.12.4/src/sys/utils/mpimesg.c
>> [492]PETSC ERROR: #2 VecScatterSetUp_SF() line 658 in /mnt/home/cgg/PETSc/petsc-3.12.4/src/vec/vscat/impls/sf/vscatsf.c
>> [492]PETSC ERROR: #3 VecScatterSetUp() line 209 in /mnt/home/cgg/PETSc/petsc-3.12.4/src/vec/vscat/interface/vscatfce.c
>> [492]PETSC ERROR: #4 VecScatterCreate() line 282 in /mnt/home/cgg/PETSc/petsc-3.12.4/src/vec/vscat/interface/vscreate.c
>> Looking at line 117 in PetscGatherMessageLengths we find the offending statement is the MPI_Isend:
>>   /* Post the Isends with the message length-info */
>>   for (i=0,j=0; i<size; ++i) {
>>     if (ilengths[i]) {
>>       ierr = MPI_Isend((void*)(ilengths+i),1,MPI_INT,i,tag,comm,s_waits+j);CHKERRQ(ierr);
>>       j++;
>> We have tried this with Intel MPI 2018, 2019, and mpich, all giving the same problem.
>> We suspect there is some limit being set on this cloud cluster on the number of file connections or something, but we don’t know.
>> Anyone have any ideas? We are sort of grasping for straws at this point.
>> Thanks, Randy M.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200415/fe4ef567/attachment-0002.html>
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200415/fe4ef567/attachment-0001.zip>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200415/fe4ef567/attachment-0003.html>
