[petsc-users] Converting complex PDE to real for KNL performance ?
Sajid Ali
sajidsyed2021 at u.northwestern.edu
Tue Apr 14 14:30:35 CDT 2020
Hi Matthew,
The TAO manual states that (preface, page vi) "However, TAO is not
compatible with PETSc installations using complex data types." (The tao
examples all require !complex builds. When I tried to run them with a petsc
build with +complex the compiler complains of incompatible pointer types
and the example crashes at runtime)
Is there any plan to support TAO with complex scalars ?
I had planned to re-use the TS object in an optimization loop with the F
vector defined both as a parameter in TS and as the independent variable in
the outer TAO loop.
Thank You,
Sajid Ali | PhD Candidate
Applied Physics
Northwestern University
s-sajid-ali.github.io
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200414/b67abb97/attachment.html>
