[petsc-users] Converting complex PDE to real for KNL performance ?
    Matthew Knepley
    knepley at gmail.com
    Tue Apr 14 14:08:14 CDT 2020
On Tue, Apr 14, 2020 at 2:44 PM Sajid Ali <sajidsyed2021 at u.northwestern.edu>
wrote:
> Hi Hong,
> Apologies for creating unnecessary confusion by continuing the old thread
> instead of creating a new one.
> While I looked into converting the complex PDE formulation to a real
> valued formulation in the past hoping for better performance, my concern
> now is with TAO being incompatible with complex scalars. I would've
> preferred to keep the complex PDE formulation as is (given that I spent
> some time tuning it and it works well now) for cost function and gradient
> evaluation while using TAO for the outer optimization loop.
> Using TAO has the obvious benefit of defining a multi objective cost
> function, parametrized as a fit to a series of measurements and a set of
> regularizers while not having to explicitly worry about differentiating the
> regularizer or have to think about implementing a good optimization scheme.
> But if it converting the complex formulation to a real formulation would
> mean a loss of well conditioned forward solve (and increase in solving time
> itself), I was wondering if it would be better to keep the complex PDE
> formulation and write an optimization loop in PETSc while defining the
> regularizer via a cost integrand.
What exactly is the problem with TAO and complex? Is it only for some
methods?
    Matt
> Thank You,
> Sajid Ali | PhD Candidate
> Applied Physics
> Northwestern University
> s-sajid-ali.github.io
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200414/f803c805/attachment-0001.html>
