[petsc-users] J^T J p calculation
Thu Apr 9 15:44:40 CDT 2020
On Thu, Apr 9, 2020 at 3:41 PM Park, Heeho via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi PETSc developers,
> I am trying to formulate
> p^T J^T J p
> where p is a solution vector length n, J is Jacobian n-by-n matrix.
> Ref: https://en.wikipedia.org/wiki/Gauss%E2%80%93Newton_algorithm under
> Large-scale optimization
> It is known that for parallel computations, the best way to perform this
> computation (with csr matrix) is
> J^T J p = SUM_i [ c_i ( c_i dot p) ] which results in a vector.
I don't think so. Why not just do
  y = J p
  y^t y = p^T J^T J p
    Matt
> In PFLOTRAN, we use mpibaij matrix. I could not find a PETSc command to
> perform this with one command.
> Is there one I couldn't find? if not, is using MATGETROW with C for-loop a
> good way to do this?
> I currently use, MatMult(J,p,w); MatMultTranspose(J,w,w2);
> VecDotRealPart(p,w2);
> Best,
> Heeho Daniel Park
> Sandia National Laboratories
> Org: 08844, R&D
> Work: 505-844-1319
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200409/9ba91caf/attachment.html>
