[petsc-users] J^T J p calculation
Park, Heeho heepark at sandia.gov
Thu Apr 9 14:39:19 CDT 2020
Hi PETSc developers,
I am trying to formulate
p^T J^T J p
where p is a solution vector length n, J is Jacobian n-by-n matrix.
Ref: https://en.wikipedia.org/wiki/Gauss%E2%80%93Newton_algorithm under Large-scale optimization
It is known that for parallel computations, the best way to perform this computation (with csr matrix) is
J^T J p = SUM_i [ c_i ( c_i dot p) ] which results in a vector.
In PFLOTRAN, we use mpibaij matrix. I could not find a PETSc command to perform this with one command.
Is there one I couldn't find? if not, is using MATGETROW with C for-loop a good way to do this?
I currently use, MatMult(J,p,w); MatMultTranspose(J,w,w2); VecDotRealPart(p,w2);
Best,
Heeho Daniel Park
Sandia National Laboratories
Org: 08844, R&D
Work: 505-844-1319
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200409/4278bd6c/attachment.html>
