[petsc-users] DMPlex partition problem
Matthew Knepley
knepley at gmail.com
Wed Apr 8 11:19:44 CDT 2020
On Wed, Apr 8, 2020 at 12:13 PM Danyang Su <danyang.su at gmail.com> wrote:
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Wednesday, April 8, 2020 at 6:45 AM
> *To: *Danyang Su <danyang.su at gmail.com>
> *Cc: *PETSc <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] DMPlex partition problem
> On Wed, Apr 8, 2020 at 7:25 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Apr 8, 2020 at 12:48 AM Danyang Su <danyang.su at gmail.com> wrote:
> Dear All,
> Hope you are safe and healthy.
> I have a question regarding pretty different partition results of prism
> mesh. The partition in PETSc generates much more ghost nodes/cells than the
> partition in Gmsh, even though both use metis as partitioner. Attached
> please find the prism mesh in both vtk and exo format, the test code
> modified based on ex1f90 example. Similar problem are observed for larger
> dataset with more layers.
> I will figure this out by next week.
> I have run your mesh and do not get those weird partitions. I am running
> in master. What are you using? Also, here is an easy way
> to do this using a PETSc test:
> cd $PETSC_DIR
> make -f ./gmakefile test globsearch="dm_impls_plex_tests-ex1_cylinder"
> EXTRA_OPTIONS="-filename ${HOME}/Downloads/basin2layer.exo -dm_view
> hdf5:$PWD/mesh.h5 -dm_partition_view" NP=5
> ./lib/petsc/bin/petsc_gen_xdmf.py mesh.h5
> and then load mesh.xmf into Paraview. Here is what I see (attached). Is it
> possible for you to try the master branch?
> Hi Matt,
> Thanks for your quick response. If I use your script, the partition looks
> good, as shown in the attached figure. I am working on PETSc 3.13.0 release
> version on Mac OS.
> Does the above script use code /petsc/src/dm/label/tutorials/ex1c.c?
It uses $PETSC_DIR/src/dm/impls/plex/tests/ex1.c
I looked at your code and cannot see any difference. Also, no changes are
in master that are not in 3.13. This is very strange.
I guess we will have to go one step at a time between the example and your
code.
Matt
> Thanks,
> Matt
> Thanks,
> Matt
> For example, in Gmsh, I get partition results using two processors and
> four processors as shown below, which are pretty reasonable.
> However, in PETSc, the partition looks a bit weird. Looks like it takes
> layer partition first and then inside layer. If the number of nodes per
> layer is very large, this kind of partitioning results into much more ghost
> nodes/cells.
> Anybody know how to improve the partitioning in PETSc? I have tried
> parmetis and chaco. There is no big difference between them.
> Thanks,
> Danyang
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/bd2e3b2d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/bd2e3b2d/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/bd2e3b2d/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/bd2e3b2d/attachment-0005.png>
