[petsc-users] DMPlex partition problem
Matthew Knepley
knepley at gmail.com
Wed Apr 8 06:25:28 CDT 2020
On Wed, Apr 8, 2020 at 12:48 AM Danyang Su <danyang.su at gmail.com> wrote:
> Dear All,
> Hope you are safe and healthy.
> I have a question regarding pretty different partition results of prism
> mesh. The partition in PETSc generates much more ghost nodes/cells than the
> partition in Gmsh, even though both use metis as partitioner. Attached
> please find the prism mesh in both vtk and exo format, the test code
> modified based on ex1f90 example. Similar problem are observed for larger
> dataset with more layers.
I will figure this out by next week.
Matt
> For example, in Gmsh, I get partition results using two processors and
> four processors as shown below, which are pretty reasonable.
> However, in PETSc, the partition looks a bit weird. Looks like it takes
> layer partition first and then inside layer. If the number of nodes per
> layer is very large, this kind of partitioning results into much more ghost
> nodes/cells.
> Anybody know how to improve the partitioning in PETSc? I have tried
> parmetis and chaco. There is no big difference between them.
> Thanks,
> Danyang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/f1dceace/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/f1dceace/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/f1dceace/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/f1dceace/attachment-0005.png>
