[petsc-users] Error Installing Petsc4Py
Kyle Michael Booker
kmbooker at uwaterloo.ca
Thu Apr 2 12:31:31 CDT 2020
Hello,
I've been trying to install petsc4py for the past several days and have had the following errors installing:
"Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-0eWEiE/petsc4py/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-oUZMRL-record/install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-0eWEiE/petsc4py/"
I currently have petsc installed correctly as well as mpich, it is just getting petsc4py installed that I have problems with. Any help would be greatly appreciated.
Sincerely,
Kyle
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200402/1c3452ed/attachment.html>
