[petsc-users] Best way to setup TS to use TSBASICSYMPLECTIC
Thu Apr 2 06:12:30 CDT 2020
On Wed, Apr 1, 2020 at 9:31 PM Dharmendar Reddy <dharmareddy84 at gmail.com>
wrote:
> Hello,
> What is the suggested way to used TSBASICSYMPLECTIC.
> Lines below from ./src/dm/impls/swarm/examples/tests/ex5.c:[430-431]
>   /* DM needs to be set before splits so it propogates to sub TSs */
>   ierr = TSSetDM(ts, sw);CHKERRQ(ierr);
>   ierr = TSSetType(ts,TSBASICSYMPLECTIC);CHKERRQ(ierr);
> seem to suggest that DM is necessary to use TSBASICSYMPLECTIC solver.
It is not.
> I am trying to test the solve for a system of coupled particles with all
> to all position dependent interaction:
> For a set of N particles with i=1 to N
> ddt(x_i) = v_i  ;
> ddt(v_i) = (J x X)_i // i th component of matrix J times position vector X;
> where J is the coupling matrix and X is the position vector of all
> particles.
> I tried testing with code similar to
> ./src/ts/examples/tutorials/hamiltonian/ex1.c
> where J will be a diagonal matrix with -omega*omgea as diagonal elements.
What is the problem?
     Matt
> Thanks
> REddy
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200402/4abdc05d/attachment.html>
