[petsc-users] Computing part of the inverse of a large matrix
Zhang, Hong
hzhang at mcs.anl.gov
Fri Sep 27 09:26:28 CDT 2019
See ~petsc/src/mat/examples/tests/ex214.c on how to compute selected entries of inv(A) using mumps.
Hong
On Fri, Sep 27, 2019 at 8:04 AM Smith, Barry F. via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
MatMumpsGetInverse() maybe useful. Also simply using MatMatSolve() with the first 1000 columns of the identity and "throwing away" the part you don't need may be most effective.
Barry
> On Sep 27, 2019, at 3:34 AM, Jan Grießer via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
> Hi all,
> i am using petsc4py. I am dealing with rather large sparse matrices up to 600kx600k and i am interested in calculating a part of the inverse of the matrix(I know it will be a dense matrix). Due to the nature of my problem, I am only interested in approximately the first 1000 rows and 1000 columns (i.e. a large block in the upper left ofthe matrix). Before I start to play around now, I wanted to ask if there is a clever way to tackle this kind of problem in PETSc in principle. For any input I would be very grateful!
> Greetings Jan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190927/cf9e538c/attachment.html>
