[petsc-users] Clarification of INSERT_VALUES for vec with ghost nodes
Zhang, Junchao jczhang at mcs.anl.gov
Wed Sep 25 22:15:09 CDT 2019
On Wed, Sep 25, 2019 at 9:11 AM Aulisa, Eugenio via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I have a vector with ghost nodes where each process may or may not change the value of a specific ghost node  (using INSERT_VALUES).
At the end I would like for each process, that see a particular ghost node, to have the smallest of the set values.
Do you mean owner of ghost nodes gets the smallest values. That is, in your example below, proc0 gets Min(value0, value1, value2)?
I do not think there is a straightforward way to achieve this, but I would like to be wrong.
Any suggestion?
To build a work around I need to understand better the behavior of VecGhostUpdateBegin(...);  VecGhostUpdateEnd(...).
In particular in the documentation I do not see the option
VecGhostUpdateBegin(v, INSERT_VALUES, SCATTER_REVERSE);
VecGhostUpdateEnd(v, INSERT_VALUES, SCATTER_REVERSE);
In case this is possible to be used, what is the behavior of this call in the following two cases?
1) Assume that node-i belongs to proc0, and is ghosted in proc1 and proc2, also
assume that the current value of node-i is value0 and proc0 does not modify it, but proc1 and proc2 do.
start with:
proc0 -> value0
proc1 -> value0
proc2 -> value0
change to:
proc0 -> value0
proc1 -> value1
proc2 -> value2
I assume that calling
will have an unpredictable behavior as
proc0 -> either value1 or value2
proc1 -> value1
proc2 -> value2
2) Assume now that node-i belongs to proc0, and is ghosted in proc1 and proc2, also
assume that the current value of node-i is value0 and proc0 and proc1 do not modify it, but proc2 does.
start with:
proc0 -> value0
proc1 -> value0
proc2 -> value0
change to:
proc0 -> value0
proc1 -> value0
proc2 -> value2
Is the call
still unpredictable?
proc0 -> either value0 or value2
proc1 -> value0
proc2 -> value2
or
proc0 -> value2  (since proc1 did not modify the original value, so it did not reverse scatter)
proc1 -> value0
proc2 -> value2
Thanks a lot for your help
Eugenio
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190926/0a588575/attachment.html>
