[petsc-users] Clarification of INSERT_VALUES for vec with ghost nodes
Aulisa, Eugenio Eugenio.Aulisa at ttu.edu
Wed Sep 25 09:04:48 CDT 2019
I have a vector with ghost nodes where each process may or may not change the value of a specific ghost node  (using INSERT_VALUES).
At the end I would like for each process, that see a particular ghost node, to have the smallest of the set values.
I do not think there is a straightforward way to achieve this, but I would like to be wrong.
Any suggestion?
To build a work around I need to understand better the behavior of VecGhostUpdateBegin(...);  VecGhostUpdateEnd(...).
In particular in the documentation I do not see the option
VecGhostUpdateBegin(v, INSERT_VALUES, SCATTER_REVERSE);
VecGhostUpdateEnd(v, INSERT_VALUES, SCATTER_REVERSE);
In case this is possible to be used, what is the behavior of this call in the following two cases?
1) Assume that node-i belongs to proc0, and is ghosted in proc1 and proc2, also
assume that the current value of node-i is value0 and proc0 does not modify it, but proc1 and proc2 do.
start with:
proc0 -> value0
proc1 -> value0
proc2 -> value0
change to:
proc0 -> value0
proc1 -> value1
proc2 -> value2
I assume that calling
will have an unpredictable behavior as
proc0 -> either value1 or value2
proc1 -> value1
proc2 -> value2
2) Assume now that node-i belongs to proc0, and is ghosted in proc1 and proc2, also
assume that the current value of node-i is value0 and proc0 and proc1 do not modify it, but proc2 does.
start with:
proc0 -> value0
proc1 -> value0
proc2 -> value0
change to:
proc0 -> value0
proc1 -> value0
proc2 -> value2
Is the call
still unpredictable?
proc0 -> either value0 or value2
proc1 -> value0
proc2 -> value2
or
proc0 -> value2  (since proc1 did not modify the original value, so it did not reverse scatter)
proc1 -> value0
proc2 -> value2
Thanks a lot for your help
Eugenio
