[petsc-users] DMPlex Distribution
Mohammad Hassan
mhbaghaei at mail.sjtu.edu.cn
Thu Sep 19 07:15:55 CDT 2019
In fact, I would create my base mesh in DMPlex and use DMForest to construct the non-conformal meshing obtained by my own block-based AMR functions. ForestClaw is based on p4est. However, I may need to implement the AMR algorithm on DM in p4est library and then convert it to DMPlex. Do you think DMForest alone will not allow me to create the AMR for DMPlex?
Thanks
Amir
Sent: Thursday, September 19, 2019 7:23 PM
To: Mohammad Hassan <mhbaghaei at mail.sjtu.edu.cn>
Cc: Matthew Knepley <knepley at gmail.com>; PETSc users list <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] DMPlex Distribution
Note, Forest gives you individual elements at the leaves. Donna Calhoun, a former Chombo user, has developed a block structured solver on p4est (https://math.boisestate.edu/~calhoun/ForestClaw/index.html), but I would imagine that you could just take the Plex that DMForest creates and just call DMRefine(...) on it to get a block structured AMR mesh.
On Wed, Sep 18, 2019 at 11:02 AM Mohammad Hassan via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> > wrote:
Thanks for your suggestion, Matthew. I will certainly look into DMForest for refining of my base DMPlex dm.
From: Matthew Knepley [mailto:knepley at gmail.com <mailto:knepley at gmail.com> ]
Sent: Wednesday, September 18, 2019 10:35 PM
To: Mohammad Hassan <mhbaghaei at mail.sjtu.edu.cn <mailto:mhbaghaei at mail.sjtu.edu.cn> >
Cc: PETSc <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> >
On Wed, Sep 18, 2019 at 10:27 AM Mohammad Hassan <mhbaghaei at mail.sjtu.edu.cn <mailto:mhbaghaei at mail.sjtu.edu.cn> > wrote:
I want to implement block-based AMR, which turns my base conformal mesh to non-conformal. My question is how DMPlex renders a mesh that it cannot support non-conformal meshes.
Mark misspoke. Plex _does_ support geometrically non-conforming meshing, e.g. "hanging nodes". The easiest way to
use Plex this way is to use DMForest, which uses Plex underneath.
There are excellent p4est tutorials. What you would do is create your conformal mesh, using Plex if you want, and
use that for the p4est base mesh (you would have the base mesh be the forest roots).
Matt
If DMPlex does not work, I will try to use DMForest.
Sent: Wednesday, September 18, 2019 9:50 PM
Cc: Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov> >; PETSc <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> >
On Wed, Sep 18, 2019 at 9:35 AM Mohammad Hassan via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> > wrote:
If DMPlex does not support, I may need to use PARAMESH or CHOMBO. Is there any way that we can construct non-conformal layout for DM in petsc?
Lets see. Plex does support geometrically non-conforming meshes. This is how we support p4est. However, if
you want that, you can just use DMForest I think. So you jsut want structured AMR?
Matt
From: Mark Adams [mailto: <mailto:mfadams at lbl.gov> mfadams at lbl.gov]
Sent: Wednesday, September 18, 2019 9:23 PM
To: Mohammad Hassan < <mailto:mhbaghaei at mail.sjtu.edu.cn> mhbaghaei at mail.sjtu.edu.cn>
Cc: Matthew Knepley < <mailto:knepley at gmail.com> knepley at gmail.com>; PETSc users list < <mailto:petsc-users at mcs.anl.gov> petsc-users at mcs.anl.gov>
I'm puzzled. It sounds like you are doing non-conforming AMR (structured block AMR), but Plex does not support that.
On Tue, Sep 17, 2019 at 11:41 PM Mohammad Hassan via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> > wrote:
Mark is right. The functionality of AMR does not relate to parallelization of that. The vector size (global or local) does not conflict with AMR functions.
Thanks
Amir
From: Matthew Knepley [mailto: <mailto:knepley at gmail.com> knepley at gmail.com]
Sent: Wednesday, September 18, 2019 12:59 AM
Cc: PETSc < <mailto:petsc-maint at mcs.anl.gov> petsc-maint at mcs.anl.gov>
On Tue, Sep 17, 2019 at 12:03 PM Mohammad Hassan <mhbaghaei at mail.sjtu.edu.cn <mailto:mhbaghaei at mail.sjtu.edu.cn> > wrote:
Thanks for suggestion. I am going to use a block-based amr. I think I need to know exactly the mesh distribution of blocks across different processors for implementation of amr.
Hi Amir,
How are you using Plex if the block-AMR is coming from somewhere else? This will help
me tell you what would be best.
And as a general question, can we set block size of vector on each rank?
I think as Mark says that you are using "blocksize" is a different way than PETSc.
Matt
Thanks
Amir
Sent: Tuesday, September 17, 2019 11:04 PM
Cc: PETSc < <mailto:petsc-users at mcs.anl.gov> petsc-users at mcs.anl.gov>
On Tue, Sep 17, 2019 at 9:27 AM Mohammad Hassan via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> > wrote:
Hi
I am using DMPlexCreateFromDAG() to construct my DM. Is it possible to set the distribution across processors manually. I mean, how can I set the share of dm on each rank (local)?
You could make a Shell partitioner and tell it the entire partition:
https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/PetscPartitionerShellSetPartition.html
However, I would be surprised if you could do this. It is likely that you just want to mess with the weights in ParMetis.
Matt
Thanks
Amir
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190919/64ef1202/attachment-0001.html>
