[petsc-users] DMPlex Distribution
Mark Adams mfadams at lbl.gov
Wed Sep 18 08:22:47 CDT 2019
I'm puzzled. It sounds like you are doing non-conforming AMR (structured
block AMR), but Plex does not support that.
On Tue, Sep 17, 2019 at 11:41 PM Mohammad Hassan via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Mark is  right. The functionality of AMR does not relate to
> parallelization of that. The vector size (global or local) does not
> conflict with AMR functions.
> Thanks
> Amir
> *From:* Matthew Knepley [mailto:knepley at gmail.com]
> *Sent:* Wednesday, September 18, 2019 12:59 AM
> *To:* Mohammad Hassan <mhbaghaei at mail.sjtu.edu.cn>
> *Cc:* PETSc <petsc-maint at mcs.anl.gov>
> *Subject:* Re: [petsc-users] DMPlex Distribution
> On Tue, Sep 17, 2019 at 12:03 PM Mohammad Hassan <
> mhbaghaei at mail.sjtu.edu.cn> wrote:
> Thanks for suggestion. I am going to use a block-based amr. I think I need
> to know exactly the mesh distribution of blocks across different processors
> for implementation of amr.
> Hi Amir,
> How are you using Plex if the block-AMR is coming from somewhere else?
> This will help
> me tell you what would be best.
> And as a general question, can we set block size of vector on each rank?
> I think as Mark says that you are using "blocksize" is a different way
> than PETSc.
>   Thanks,
>     Matt
> Thanks
> Amir
> *Sent:* Tuesday, September 17, 2019 11:04 PM
> *Cc:* PETSc <petsc-users at mcs.anl.gov>
> On Tue, Sep 17, 2019 at 9:27 AM Mohammad Hassan via petsc-users <
> Hi
> I am using DMPlexCreateFromDAG() to construct my DM. Is it possible to set
> the distribution across processors manually. I mean, how can I set the
> share of dm on each rank (local)?
> You could make a Shell partitioner and tell it the entire partition:
> https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/PetscPartitionerShellSetPartition.html
> However, I would be surprised if you could do this. It is likely that you
> just want to mess with the weights in ParMetis.
>   Thanks,
>     Matt
> Thanks
> Amir
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190918/f0dbf284/attachment.html>
