[petsc-users] DMPlex Distribution
Mohammad Hassan mhbaghaei at mail.sjtu.edu.cn
Tue Sep 17 22:41:33 CDT 2019
Mark is  right. The functionality of AMR does not relate to parallelization of that. The vector size (global or local) does not conflict with AMR functions.
Thanks
Amir
From: Matthew Knepley [mailto:knepley at gmail.com]
Sent: Wednesday, September 18, 2019 12:59 AM
To: Mohammad Hassan <mhbaghaei at mail.sjtu.edu.cn>
Cc: PETSc <petsc-maint at mcs.anl.gov>
Subject: Re: [petsc-users] DMPlex Distribution
On Tue, Sep 17, 2019 at 12:03 PM Mohammad Hassan <mhbaghaei at mail.sjtu.edu.cn <mailto:mhbaghaei at mail.sjtu.edu.cn> > wrote:
Thanks for suggestion. I am going to use a block-based amr. I think I need to know exactly the mesh distribution of blocks across different processors for implementation of amr.
Hi Amir,
How are you using Plex if the block-AMR is coming from somewhere else? This will help
me tell you what would be best.
And as a general question, can we set block size of vector on each rank?
I think as Mark says that you are using "blocksize" is a different way than PETSc.
    Matt
Thanks
Amir
From: Matthew Knepley [mailto: <mailto:knepley at gmail.com> knepley at gmail.com]
Sent: Tuesday, September 17, 2019 11:04 PM
To: Mohammad Hassan < <mailto:mhbaghaei at mail.sjtu.edu.cn> mhbaghaei at mail.sjtu.edu.cn>
Cc: PETSc < <mailto:petsc-users at mcs.anl.gov> petsc-users at mcs.anl.gov>
On Tue, Sep 17, 2019 at 9:27 AM Mohammad Hassan via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> > wrote:
Hi
I am using DMPlexCreateFromDAG() to construct my DM. Is it possible to set the distribution across processors manually. I mean, how can I set the share of dm on each rank (local)?
You could make a Shell partitioner and tell it the entire partition:
  https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/PetscPartitionerShellSetPartition.html
However, I would be surprised if you could do this. It is likely that you just want to mess with the weights in ParMetis.
    Matt
Thanks
Amir
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190918/3569903f/attachment.html>
