[petsc-users] DMPlex Distribution
Mohammad Hassan mhbaghaei at mail.sjtu.edu.cn
Tue Sep 17 11:04:56 CDT 2019
Thanks for suggestion. I am going to use a block-based amr. I think I need to know exactly the mesh distribution of blocks across different processors for implementation of amr.
And as a general question, can we set block size of vector on each rank?
Thanks
Amir
From: Matthew Knepley [mailto:knepley at gmail.com]
Sent: Tuesday, September 17, 2019 11:04 PM
To: Mohammad Hassan <mhbaghaei at mail.sjtu.edu.cn>
Cc: PETSc <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] DMPlex Distribution
On Tue, Sep 17, 2019 at 9:27 AM Mohammad Hassan via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> > wrote:
Hi
I am using DMPlexCreateFromDAG() to construct my DM. Is it possible to set the distribution across processors manually. I mean, how can I set the share of dm on each rank (local)?
You could make a Shell partitioner and tell it the entire partition:
  https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/PetscPartitionerShellSetPartition.html
However, I would be surprised if you could do this. It is likely that you just want to mess with the weights in ParMetis.
    Matt
Thanks
Amir
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190918/49a4dcaf/attachment.html>
