[petsc-users] DMPlex Distribution
Tue Sep 17 10:04:04 CDT 2019
On Tue, Sep 17, 2019 at 9:27 AM Mohammad Hassan via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi
> I am using DMPlexCreateFromDAG() to construct my DM. Is it possible to set
> the distribution across processors manually. I mean, how can I set the
> share of dm on each rank (local)?
You could make a Shell partitioner and tell it the entire partition:
https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/PetscPartitionerShellSetPartition.html
However, I would be surprised if you could do this. It is likely that you
just want to mess with the weights in ParMetis.
    Matt
> Thanks
> Amir
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190917/599a9d74/attachment.html>
