[petsc-users] View 3D DMPlex
Matthew Knepley
knepley at gmail.com
Tue Sep 10 13:27:08 CDT 2019
On Tue, Sep 10, 2019 at 12:20 PM Amir <mhbaghaei at mail.sjtu.edu.cn> wrote:
> The mesh contains a cube. I tried to change the ordering in cone of dm. In
> some ordering, in Paraview, I also noticed too many interior edges and saw
> the interior nodes. I have not yet been able to see the interior edge
> correctly placed. Do you suggest to output in other format? I do not really
> know where this misplacing of edges comes from.
How about first using DMPlexCreateBoxMesh(), and seeing if you can
visualize it. Then if that works, we can talk about
inputting your mesh from scratch.
Matt
> PetscInt numPoints[2] = {27, 8};
> PetscInt coneSize[35] = {8,8,8,8,8,8,8,8,
> 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
> PetscInt cones[64] = { 8, 9, 16, 15, 17, 24, 25, 18,
> 9, 10,11, 16, 18, 25, 20, 19,
> 16,11, 12,13, 25, 22, 21, 20,
> 15,16, 13,14, 24, 23, 22, 25, /////////// Not see the interior node
> and edge
> 17,18,25, 24, 26, 33, 34, 27,
> 18,19,20, 25, 27, 34, 29, 28,
> 25,20,21, 22, 34, 31, 30, 29,
> 24,25,22, 23, 33, 32, 31, 34} ;
> PetscInt cones2[64] = { 8, 15, 16, 9, 17, 18, 25, 24,
> 9, 16,11, 10, 18, 19, 20, 25, /////////// See the
> interior node and edge
> 16,13, 12,11, 25, 20, 21, 22,
> 15,14, 13,16, 24, 25, 22, 23,
> 17,18,25, 24, 26, 27, 34, 33,
> 18,19,20, 25, 27, 28, 29, 34,
> 25,20,21, 22, 34, 29, 30, 31,
> 24,25,22, 23, 33, 34, 31, 32} ;
> PetscInt coneOrientations[64] =
> {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
> PetscScalar vertexCoords[81] = {0.0,0.0,0.0, 1.0,0.0, 0.0,
> 2.0,0.0,0.0, 2.0,1.0,0.0, 2.0,2.0, 0.0, 1.0,2.0,0.0,
> 0.0,2.0,0.0, 0.0,1.0, 0.0, 1.0,1.0,0.0,
> 0.0,0.0,1.0, 1.0,0.0, 1.0, 2.0,0.0,1.0, 2.0,1.0,1.0, 2.0,2.0,
> 1.0, 1.0,2.0,1.0,
> 0.0,2.0,1.0, 0.0,1.0, 1.0, 1.0,1.0,1.0,
> 0.0,0.0,2.0, 1.0,0.0, 2.0, 2.0,0.0,2.0, 2.0,1.0,2.0, 2.0,2.0,
> 2.0, 1.0,2.0,2.0,
> 0.0,2.0,2.0, 0.0,1.0, 2.0, 1.0,1.0,2.0};
> Thanks
> Amir
> [image: Sent from Mailspring]
> ---------- Forwarded Message ---------
> From: Matthew Knepley <knepley at gmail.com>
> Subject: Re: [petsc-users] View 3D DMPlex
> Date: Sep 10 2019, at 9:08 pm
> To: Amir <mhbaghaei at mail.sjtu.edu.cn>
> Cc: PETSc <petsc-users at mcs.anl.gov>
> On Tue, Sep 10, 2019 at 9:00 AM Amir via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hi
> I am trying to view a cubic mesh constructed by DMPlex. I noticed that the
> interior point is not seen in the output VTU file.
> It means that I do not see an edge inside the cube. I tried to check some
> detail of DM using --in_dm_view. The detail does not show any problem. Do
> you think there is a problem in my vtk output or dm setup.
> By default, Paraview does not show interior edges. You have to use a
> filter, like "Extract Edges".
> Thanks,
> Matt
> Thanks
> Amir
> DM_0x84000000_0 in 3 dimensions:
> 0-cells: 27
> 1-cells: 54
> 2-cells: 36
> 3-cells: 8
> Labels:
> depth: 4 strata with value/size (0 (27), 1 (54), 2 (36), 3 (8))
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> <https://link.getmailspring.com/link/CE107FD7-8BE8-492B-98A7-90F4EEAA18F2@getmailspring.com/0?redirect=mailto%3Apetsc-users%40mcs.anl.gov&recipient=a25lcGxleUBnbWFpbC5jb20%3D>>
> wrote:
> Hi
> Thanks,
> Matt
> Thanks
> Amir
> 0-cells: 27
> 1-cells: 54
> 2-cells: 36
> 3-cells: 8
> Labels:
> experiments lead.
> -- Norbert Wiener
> <https://link.getmailspring.com/link/CE107FD7-8BE8-492B-98A7-90F4EEAA18F2@getmailspring.com/1?redirect=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&recipient=a25lcGxleUBnbWFpbC5jb20%3D>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190910/110c23ed/attachment.html>
