[petsc-users] View 3D DMPlex
Amir mhbaghaei at mail.sjtu.edu.cn
Tue Sep 10 11:22:46 CDT 2019
The mesh contains a cube. I tried to change the ordering in cone of dm. In some ordering, in Paraview, I also noticed too many interior edges and saw the interior nodes. I have not yet been able to see the interior edge correctly placed. Do you suggest to output in other format? I do not really know where this misplacing of edges comes from.
PetscInt numPoints[2] = {27, 8};
PetscInt coneSize[35] = {8,8,8,8,8,8,8,8, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
PetscInt cones[64] = { 8, 9, 16, 15, 17, 24, 25, 18,
9, 10,11, 16, 18, 25, 20, 19,
16,11, 12,13, 25, 22, 21, 20,
15,16, 13,14, 24, 23, 22, 25, /////////// Not see the interior node and edge
17,18,25, 24, 26, 33, 34, 27,
18,19,20, 25, 27, 34, 29, 28,
25,20,21, 22, 34, 31, 30, 29,
24,25,22, 23, 33, 32, 31, 34} ;
PetscInt cones2[64] = { 8, 15, 16, 9, 17, 18, 25, 24,
9, 16,11, 10, 18, 19, 20, 25, /////////// See the interior node and edge
16,13, 12,11, 25, 20, 21, 22,
15,14, 13,16, 24, 25, 22, 23,
17,18,25, 24, 26, 27, 34, 33,
18,19,20, 25, 27, 28, 29, 34,
25,20,21, 22, 34, 29, 30, 31,
24,25,22, 23, 33, 34, 31, 32} ;
PetscInt coneOrientations[64] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
PetscScalar vertexCoords[81] = {0.0,0.0,0.0, 1.0,0.0, 0.0, 2.0,0.0,0.0, 2.0,1.0,0.0, 2.0,2.0, 0.0, 1.0,2.0,0.0,
0.0,2.0,0.0, 0.0,1.0, 0.0, 1.0,1.0,0.0,
0.0,0.0,1.0, 1.0,0.0, 1.0, 2.0,0.0,1.0, 2.0,1.0,1.0, 2.0,2.0, 1.0, 1.0,2.0,1.0,
0.0,2.0,1.0, 0.0,1.0, 1.0, 1.0,1.0,1.0,
0.0,0.0,2.0, 1.0,0.0, 2.0, 2.0,0.0,2.0, 2.0,1.0,2.0, 2.0,2.0, 2.0, 1.0,2.0,2.0,
0.0,2.0,2.0, 0.0,1.0, 2.0, 1.0,1.0,2.0};
Thanks
Amir
---------- Forwarded Message ---------
Subject: Re: [petsc-users] View 3D DMPlex
Date: Sep 10 2019, at 9:08 pm
To: Amir <mhbaghaei at mail.sjtu.edu.cn>
Cc: PETSc <petsc-users at mcs.anl.gov>
On Tue, Sep 10, 2019 at 9:00 AM Amir via petsc-users <petsc-users at mcs.anl.gov (mailto:petsc-users at mcs.anl.gov)> wrote:
> Hi
> I am trying to view a cubic mesh constructed by DMPlex. I noticed that the interior point is not seen in the output VTU file.
> It means that I do not see an edge inside the cube. I tried to check some detail of DM using --in_dm_view. The detail does not show any problem. Do you think there is a problem in my vtk output or dm setup.
By default, Paraview does not show interior edges. You have to use a filter, like "Extract Edges".
Matt
> Thanks
> Amir
> DM_0x84000000_0 in 3 dimensions:
> 0-cells: 27
> 1-cells: 54
> 2-cells: 36
> 3-cells: 8
> Labels:
> depth: 4 strata with value/size (0 (27), 1 (54), 2 (36), 3 (8))
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ (http://www.cse.buffalo.edu/~knepley/)
On Sep 10 2019, at 9:08 pm, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Sep 10, 2019 at 9:00 AM Amir via petsc-users <petsc-users at mcs.anl.gov (https://link.getmailspring.com/link/CE107FD7-8BE8-492B-98A7-90F4EEAA18F2@getmailspring.com/0?redirect=mailto%3Apetsc-users%40mcs.anl.gov&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D)> wrote:
> > Hi
> Thanks,
> Matt
> > Thanks
> > Amir
> > 0-cells: 27
> > 1-cells: 54
> > 2-cells: 36
> > 3-cells: 8
> > Labels:
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ (https://link.getmailspring.com/link/CE107FD7-8BE8-492B-98A7-90F4EEAA18F2@getmailspring.com/1?redirect=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190911/76dcdb33/attachment.html>
