[petsc-users] configuring on OSX
Brian Van Straalen bvstraalen at lbl.gov
Wed Sep 4 00:41:38 CDT 2019
Thanks Barry.  that gets me further.   now it seems the COPTFLAGS are not
being propagated from PETSC to HYPRE.  I have -framework Accelerate in my
COPTFLAGS, but HYPRE still fails looking for BLAS and LAPACK routines.
_dgetri, _dgetrs, and so on.   Or does PETSc, and Hypre, and SUPERLU all
pull in their own blas and lapack source code and this is from me disabling
Fortran?  I can't use Fortran in PETSc since sowing does not work on OSX as
PETSc configures it (claims "configure: error: cannot run C compiled
programs." but I know that is not true.  I suspect sowing has linux-isms
see attached log).
is there some way to have PETSc configure just run through and
*configure *things,
and have a make command *make* things?    I have to keep re-issuing the
configure command, which prevents me from debugging a build errors.   I'm
about two days into this port to OSX....
Brian
On Tue, Sep 3, 2019 at 9:35 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>    Ahh,  the --download-c2html is not needed; it is used only when
> building all of the PETSc documentation including html versions of the
> source.
>    For some reason it's configure is not doing a good job of selecting
> cpp. Over the years it has been amazingly portable, I guess Apple just went
> a bit too far.
>    Anyways just run without that option,
>     Barry
> > On Sep 3, 2019, at 11:24 PM, Brian Van Straalen via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > I can attach the config log.  mpi breaks for yet other reasons so I was
> trying to simplify things sufficiently.
> > if I put mpi back in and take the compiler choices out, I still end up
> with failure on CPP.   It seems determined to look for "/lib/cpp" which is
> only correct for linux.
> > On Tue, Sep 3, 2019 at 9:11 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> > On Wed, 4 Sep 2019, Balay, Satish via petsc-users wrote:
> > > On Tue, 3 Sep 2019, Brian Van Straalen via petsc-users wrote:
> > > > pulling from git PETSC and on master branch.
> > > > ./configure CPP=/usr/bin/cpp
> > > >              Configuring PETSc to compile on your system
> > > > TESTING: checkCPreprocessor from
> > > > config.setCompilers(config/BuildSystem/config/setCompilers.py:592)
> > > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see
> configure.log for
> > > > details):
> > > > Cannot find a C preprocessor
> > > Its best to send configure.log
> > > > Brian
> > > > my configure script
> > > > configure_options = [
> > > > #   '--with-mpi-dir=/usr/local/opt/open-mpi',
> > Hm - this is commented out anyway. So there is no mpi specified for this
> build (its a mandatory dependency)?
> > > >    '--with-cc=/usr/bin/clang',
> > > >    '--with-cpp=/usr/bin/cpp',
> > > >    '--with-cxx=/usr/bin/clang++',
> > > The above 3 options are redundant - when --with-mpi-dir is provided.
> PETSc configure will pick up mpicc etc from the specified location.
> > > >    '--with-fc=0',
> > > Hm - this conflicts with --download-mumps etc that require fortran
> > > Satish
> > > >     'COPTFLAGS=-g -framework Accelerate',
> > > >     'CXXOPTFLAGS=-g -framework Accelerate',
> > > >     'FOPTFLAGS=-g',
> > > > #  '--with-memalign=64',
> > > >   '--download-hypre=1',
> > > >   '--download-metis=1',
> > > >   '--download-parmetis=1',
> > > >   '--download-c2html=1',
> > > >   '--download-ctetgen',
> > > > #  '--download-viennacl',
> > > > #  '--download-ml=1',
> > > >   '--download-p4est=1',
> > > >   '--download-superlu_dist',
> > > >   '--download-superlu',
> > > >   '--with-cxx-dialect=C++11',
> > > >   '--download-mumps=1',
> > > >   '--download-scalapack=1',
> > > > #  '--download-exodus=1',
> > > > #  '--download-ctetgen=1',
> > > >   '--download-triangle=1',
> > > > #  '--download-pragmatic=1',
> > > > #  '--download-eigen=1',
> > > >   '--download-zlib',
> > > >   '--with-x=1',
> > > >   '--with-sowing=0',
> > > >   '--with-debugging=1',
> > > >   '--with-precision=double',
> > > >   'PETSC_ARCH=arch-macosx-gnu-g',
> > > >   '--download-chaco'
> > > > if __name__ == '__main__':
> > > >   import sys,os
> > > >   sys.path.insert(0,os.path.abspath('config'))
> > > >   import configure
> > > >   configure.petsc_configure(configure_options)
> > Brian Van Straalen         Lawrence Berkeley Lab
> > BVStraalen at lbl.gov        Computational Research
> > (510) 486-4976            Division (crd.lbl.gov)
> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190903/84478334/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190903/84478334/attachment-0001.obj>
