[petsc-users] Errors with ParMETIS
Zhang, Junchao
jczhang at mcs.anl.gov
Fri Oct 18 10:04:04 CDT 2019
Usually due to uninitialized variables. You can try valgrind. Read tutorial from page 3 of https://www.mcs.anl.gov/petsc/petsc-20/tutorial/PETSc1.pdf
--Junchao Zhang
On Fri, Oct 18, 2019 at 6:23 AM Shidi Yan via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Dear developers,
I am using ParMETIS to do dynamic load balancing for the mesh.
If my code is compiled with optimiser options (e.g., -O2 -O3), I have
the following errors when the code calls function from ParMETIS:
***ASSERTION failed on line 176 of file
externalpackages/git.parmetis/libparmetis/comm.c: j == nnbrs
externalpackages/git.parmetis/libparmetis/comm.c:176: libparmetis__CommSetup: Assertion `j == nnbrs' failed.
However, if the code is compiled with debugging mode ( -g), I do
not have any errors.
I am wondering is it the bug from my part.
Thank you very much for your time.
Kind Regards,
Shidi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191018/be491073/attachment.html>
