[petsc-users] DMPlex memory problem in scaling test
Thu Oct 10 20:15:29 CDT 2019
On Thu, Oct 10, 2019 at 9:00 PM Danyang Su <danyang.su at gmail.com> wrote:
> Labels should be destroyed with the DM. Just make a small code that does
> nothing but distribute the mesh and end. If you
> run with -malloc_test you should see if everythign is destroyed properly.
>   Thanks,
>     Matt
> Attached is the output run with -malloc_test using 2 processor. It's a big
> file. How can I quick check if something is not properly destroyed?
Everything output has not been destroyed. It looks like you did not destroy
the distributed DM.
    Matt
> Thanks,
> Danyang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191010/227d2bb8/attachment.html>
