[petsc-users] DMPlex memory problem in scaling test
Danyang Su danyang.su at gmail.com
Thu Oct 10 19:59:53 CDT 2019
On 2019-10-10 5:44 p.m., Matthew Knepley wrote:
> On Thu, Oct 10, 2019 at 7:53 PM Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
>     On 2019-10-10 4:28 p.m., Matthew Knepley wrote:
>>     On Thu, Oct 10, 2019 at 4:26 PM Danyang Su <danyang.su at gmail.com
>>         Hi All,
>>         Your guess is right. The memory problem occurs after
>>         DMPlexCreateFromCellList and DMPlexDistribute. The mesh
>>         related memory in the master processor is not released after
>>         that.
>>         The pseudo code I use is
>>         if (rank == 0) then         !only the master processor read
>>         the mesh file and create cell list
>>                 call
>>         DMPlexCreateFromCellList(Petsc_Comm_World,ndim,num_cells, &
>>         num_nodes,num_nodes_per_cell,    &
>>         Petsc_False,dmplex_cells,ndim,   &  !use Petsc_True to create
>>         intermediate mesh entities (faces, edges),
>>         dmplex_verts,dmda_flow%da,ierr)     !not work for prism for
>>         the current 3.8 version.
>>                 CHKERRQ(ierr)
>>         else                                 !slave processors pass
>>         zero cells
>>                 call
>>         DMPlexCreateFromCellList(Petsc_Comm_World,ndim,0,0, &
>>                 CHKERRQ(ierr)
>>         end if
>>         call DMPlexDistribute
>>         call DMDestroy(dmda_flow%da,ierr)
>>         CHKERRQ(ierr)
>>         !c set the global mesh as distributed mesh
>>         dmda_flow%da = distributedMesh
>>         After calling the above functions, the memory usage for the
>>         test case (no. points 953,433, nprocs 160) is shown below:
>>         rank 0 PETSc memory current MB    1610.39 PETSc memory
>>         maximum MB    1690.42
>>         rank 151 PETSc memory current MB     105.00 PETSc memory
>>         maximum MB     104.94
>>         rank 98 PETSc memory current MB     106.02 PETSc memory
>>         maximum MB     105.95
>>         rank 18 PETSc memory current MB     106.17 PETSc memory
>>         maximum MB     106.17
>>         Is there any function available in the master version that
>>         can release this memory?
>>     DMDestroy() releases this memory, UNLESS you are holding other
>>     objects that refer to it, like a vector from that DM.
>     Well, I have some labels set before distribution. After
>     distribution, the labels values are collected but not destroyed. I
>     will try this to see if it makes big difference.
> Labels should be destroyed with the DM. Just make a small code that
> does nothing but distribute the mesh and end. If you
> run with -malloc_test you should see if everythign is destroyed properly.
>   Thanks,
>     Matt
Attached is the output run with -malloc_test using 2 processor. It's a
big file. How can I quick check if something is not properly destroyed?
Danyang
>     Thanks,
>     danyang
>>       Thanks,
>>          Matt
>>         Thanks,
>>         Danyang
>>         On 2019-10-10 11:09 a.m., Mark Adams via petsc-users wrote:
>>>         Now that I think about it, the partitioning and distribution
>>>         can be done with existing API, I would assume, like is done
>>>         with matrices.
>>>         I'm still wondering what the H5 format is. I assume that it
>>>         is not built for a hardwired number of processes to read in
>>>         parallel and that the parallel read is somewhat scalable.
>>>         On Thu, Oct 10, 2019 at 12:13 PM Mark Adams <mfadams at lbl.gov
>>>         <mailto:mfadams at lbl.gov>> wrote:
>>>             A related question, what is the state of having
>>>             something like a distributed  DMPlexCreateFromCellList
>>>             method, but maybe your H5 efforts would work. My bone
>>>             modeling code is old and a pain, but the apps
>>>             specialized serial mesh generator could write an H5 file
>>>             instead of the current FEAP file. Then you reader, SNES
>>>             and a large deformation plasticity element in PetscFE
>>>             could replace my code, in the future.
>>>             How does your H5 thing work? Is it basically a flat file
>>>             (not partitioned) that is read in in parallel by slicing
>>>             the cell lists, etc, using file seek or something
>>>             equivalent, then reconstructing a local graph on each
>>>             processor to give to say Parmetis, then completes the
>>>             distribution with this reasonable partitioning? (this is
>>>             what our current code does)
>>>             Thanks,
>>>             Mark
>>>             On Thu, Oct 10, 2019 at 9:30 AM Dave May via petsc-users
>>>             <petsc-users at mcs.anl.gov
>>>             <mailto:petsc-users at mcs.anl.gov>> wrote:
>>>                 On Thu 10. Oct 2019 at 15:15, Matthew Knepley
>>>                 <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>                     On Thu, Oct 10, 2019 at 9:10 AM Dave May
>>>                     <dave.mayhem23 at gmail.com
>>>                     <mailto:dave.mayhem23 at gmail.com>> wrote:
>>>                         On Thu 10. Oct 2019 at 15:04, Matthew
>>>                         Knepley <knepley at gmail.com
>>>                             On Thu, Oct 10, 2019 at 8:41 AM Dave May
>>>                                 On Thu 10. Oct 2019 at 14:34,
>>>                                 Matthew Knepley <knepley at gmail.com
>>>                                     On Thu, Oct 10, 2019 at 8:31 AM
>>>                                     Dave May
>>>                                     wrote:
>>>                                         On Thu, 10 Oct 2019 at
>>>                                         13:21, Matthew Knepley via
>>>                                         petsc-users
>>>                                         wrote:
>>>                                             On Wed, Oct 9, 2019 at
>>>                                             5:10 PM Danyang Su via
>>>                                             petsc-users
>>>                                             wrote:
>>>                                                 Dear All,
>>>                                                 I have a question
>>>                                                 regarding the
>>>                                                 maximum memory usage
>>>                                                 for the scaling
>>>                                                 test. My code is
>>>                                                 written in Fortran
>>>                                                 with support for
>>>                                                 both structured grid
>>>                                                 (DM) and
>>>                                                 unstructured grid
>>>                                                 (DMPlex). It looks
>>>                                                 like memory
>>>                                                 consumption is much
>>>                                                 larger when DMPlex
>>>                                                 is used and finally
>>>                                                 causew out_of_memory
>>>                                                 problem.
>>>                                                 Below are some test
>>>                                                 using both
>>>                                                 structured grid and
>>>                                                 unstructured grid.
>>>                                                 The memory
>>>                                                 consumption by the
>>>                                                 code is estimated
>>>                                                 based on all
>>>                                                 allocated arrays and
>>>                                                 PETSc memory
>>>                                                 consumption is
>>>                                                 estimated based on
>>>                                                 PetscMemoryGetMaximumUsage.
>>>                                                 I just wonder why
>>>                                                 the PETSc memory
>>>                                                 consumption does not
>>>                                                 decrease when number
>>>                                                 of processors
>>>                                                 increases. For
>>>                                                 structured grid
>>>                                                 (scenario 7-9), the
>>>                                                 memory consumption
>>>                                                 decreases as number
>>>                                                 of processors
>>>                                                 increases. However,
>>>                                                 for unstructured
>>>                                                 grid case (scenario
>>>                                                 14-16), the memory
>>>                                                 for PETSc part
>>>                                                 remains unchanged.
>>>                                                 When I run a larger
>>>                                                 case, the code
>>>                                                 crashes because
>>>                                                 memory is ran out.
>>>                                                 The same case works
>>>                                                 on another cluster
>>>                                                 with 480GB memory
>>>                                                 per node. Does this
>>>                                                 make sense?
>>>                                             We would need a finer
>>>                                             breakdown of where
>>>                                             memory is being used. I
>>>                                             did this for a paper:
>>>                                             https://agupubs.onlinelibrary.wiley.com/doi/full/10.1002/jgrb.50217
>>>                                             If the subdomains, the
>>>                                             halo sizes can overwhelm
>>>                                             the basic storage. It
>>>                                             looks like the
>>>                                             subdomains are big here,
>>>                                             but things are not
>>>                                             totally clear to me. It
>>>                                             would be helpful to send
>>>                                             the output of -log_view
>>>                                             for each case since
>>>                                             PETSc tries to keep
>>>                                             track of allocated memory.
>>>                                         Matt - I'd guess that there
>>>                                         is a sequential
>>>                                         (non-partitioned) mesh
>>>                                         hanging around in memory.
>>>                                         Is it possible that he's
>>>                                         created the PLEX object
>>>                                         which is loaded sequentially
>>>                                         (stored and retained in
>>>                                         memory and never released),
>>>                                         and then afterwards distributed?
>>>                                         This can never happen with
>>>                                         the DMDA and the table
>>>                                         verifies this.
>>>                                         If his code using the DMDA
>>>                                         and DMPLEX are as identical
>>>                                         as possible (albeit the DM
>>>                                         used), then a sequential
>>>                                         mesh held in memory seems
>>>                                         the likely cause.
>>>                                     Dang it, Dave is always right.
>>>                                     How to prevent this?
>>>                                 I thought
>>>                                 you/Lawrence/Vaclav/others... had
>>>                                 developed and provided support  for
>>>                                 a parallel DMPLEX load via a
>>>                                 suitably defined plex specific H5
>>>                                 mesh file.
>>>                             We have, but these tests looked like
>>>                             generated meshes.
>>>                         Great.
>>>                         So would a solution to the problem be to
>>>                         have the user modify their code in the
>>>                         follow way:
>>>                         * they move the mesh gen stage into a
>>>                         seperate exec which they call offline (on a
>>>                         fat node with lots of memory), and dump the
>>>                         appropriate file
>>>                         * they change their existing application to
>>>                         simply load that file in parallel.
>>>                     Yes.
>>>                         If there were examples illustrating how to
>>>                         create the file which can be loaded in
>>>                         parallel I think it would be very helpful
>>>                         for the user (and many others)
>>>                     I think Vaclav is going to add his examples as
>>>                     soon as we fix this parallel interpolation bug.
>>>                     I am praying for time in the latter
>>>                     part of October to do this.
>>>                 Excellent news - thanks for the update and info.
>>>                 Cheers
>>>                 Dave
>>>                       Thanks,
>>>                         Matt
>>>                         Cheers
>>>                         Dave
>>>                               Thanks,
>>>                                 Matt
>>>                                     Since it looks like you are okay
>>>                                     with fairly regular meshes, I
>>>                                     would construct the
>>>                                     coarsest mesh you can, and then use
>>>                                     -dm_refine <k>
>>>                                     which is activated by
>>>                                     DMSetFromOptions(). Make sure to
>>>                                     call it after
>>>                                     DMPlexDistribute(). It will
>>>                                     regularly
>>>                                     refine in parallel and should
>>>                                     show good memory scaling as Dave
>>>                                     says.
>>>                                       Thanks,
>>>                                      Matt
>>>                                               Thanks,
>>>                                                  Matt
>>>                                                 scenario 	no. points
>>>                                                 	cell type 	DMPLex
>>>                                                 nprocs 	no. nodes
>>>                                                 mem per node GB
>>>                                                 solver 	Rank 0
>>>                                                 memory MB 	Rank 0
>>>                                                 petsc memory MB
>>>                                                 Runtime (sec)
>>>                                                 1 	2121 	rectangle
>>>                                                 no 	40 	1 	200
>>>                                                 GMRES,Hypre
>>>                                                 preconditioner 	0.21
>>>                                                 	41.6
>>>                                                 2 	8241 	rectangle
>>>                                                 no 	40 	1 	200
>>>                                                 GMRES,Hypre
>>>                                                 preconditioner 	0.59
>>>                                                 	51.84
>>>                                                 3 	32481 	rectangle
>>>                                                 no 	40 	1 	200
>>>                                                 GMRES,Hypre
>>>                                                 preconditioner 	1.95
>>>                                                 	59.1
>>>                                                 4 	128961 	rectangle
>>>                                                 	no 	40 	1 	200
>>>                                                 GMRES,Hypre
>>>                                                 preconditioner 	7.05
>>>                                                 	89.71
>>>                                                 5 	513921 	rectangle
>>>                                                 	no 	40 	1 	200
>>>                                                 GMRES,Hypre
>>>                                                 preconditioner
>>>                                                 26.76 	110.58
>>>                                                 6 	2051841
>>>                                                 rectangle 	no 	40 	1
>>>                                                 	200 	GMRES,Hypre
>>>                                                 preconditioner
>>>                                                 104.21 	232.05
>>>                                                 *7* 	*8199681*
>>>                                                 *rectangle* 	*no*
>>>                                                 *40* 	*1* 	*200*
>>>                                                 *GMRES,Hypre
>>>                                                 preconditioner*
>>>                                                 *411.26* 	*703.27*
>>>                                                 *140.29*
>>>                                                 *8* 	*8199681*
>>>                                                 *rectangle* 	*no*
>>>                                                 *80* 	*2* 	*200*
>>>                                                 *GMRES,Hypre
>>>                                                 preconditioner*
>>>                                                 *206.6* 	*387.25*
>>>                                                 *62.04*
>>>                                                 *9* 	*8199681*
>>>                                                 *rectangle* 	*no*
>>>                                                 *160* 	*4* 	*200*
>>>                                                 *GMRES,Hypre
>>>                                                 preconditioner*
>>>                                                 *104.28* 	*245.3*
>>>                                                 *32.76*
>>>                                                 10 	2121 	triangle
>>>                                                 yes 	40 	1 	200
>>>                                                 GMRES,Hypre
>>>                                                 preconditioner 	0.49
>>>                                                 	61.78
>>>                                                 11 	15090 	triangle
>>>                                                 yes 	40 	1 	200
>>>                                                 GMRES,Hypre
>>>                                                 preconditioner 	2.32
>>>                                                 	96.61
>>>                                                 12 	59847 	triangle
>>>                                                 yes 	40 	1 	200
>>>                                                 GMRES,Hypre
>>>                                                 preconditioner 	8.28
>>>                                                 	176.14
>>>                                                 13 	238568 	triangle
>>>                                                 	yes 	40 	1 	200
>>>                                                 GMRES,Hypre
>>>                                                 preconditioner
>>>                                                 31.89 	573.73
>>>                                                 *14* 	*953433*
>>>                                                 *triangle* 	*yes*
>>>                                                 *40* 	*1* 	*200*
>>>                                                 *GMRES,Hypre
>>>                                                 preconditioner*
>>>                                                 *119.23* 	*2102.54*
>>>                                                 *44.11*
>>>                                                 *15* 	*953433*
>>>                                                 *triangle* 	*yes*
>>>                                                 *80* 	*2* 	*200*
>>>                                                 *GMRES,Hypre
>>>                                                 preconditioner*
>>>                                                 *72.99* 	*2123.8*
>>>                                                 *24.36*
>>>                                                 *16* 	*953433*
>>>                                                 *triangle* 	*yes*
>>>                                                 *160* 	*4* 	*200*
>>>                                                 *GMRES,Hypre
>>>                                                 preconditioner*
>>>                                                 *48.65* 	*2076.25*
>>>                                                 *14.87*
>>>                                                 17 	55770 	prism
>>>                                                 yes 	40 	1 	200
>>>                                                 GMRES,Hypre
>>>                                                 preconditioner
>>>                                                 18.46 	219.39
>>>                                                 18 	749814 	prism
>>>                                                 yes 	40 	1 	200
>>>                                                 GMRES,Hypre
>>>                                                 preconditioner
>>>                                                 149.86 	2412.39
>>>                                                 19 	7000050 	prism
>>>                                                 yes 	40 to 640 	1 to
>>>                                                 16 	200 	GMRES,Hypre
>>>                                                 preconditioner
>>>                                                 	out_of_memory
>>>                                                 *20* 	*7000050*
>>>                                                 *prism* 	*yes* 	*64*
>>>                                                 	*2* 	*480*
>>>                                                 *GMRES,Hypre
>>>                                                 preconditioner*
>>>                                                 *890.92* 	*17214.41*
>>>                                                 The error
>>>                                                 information of
>>>                                                 scenario 19 is shown
>>>                                                 below:
>>>                                                 kernel messages
>>>                                                 produced during job
>>>                                                 executions:
>>>                                                 [Oct 9 10:41]
>>>                                                 mpiexec.hydra
>>>                                                 invoked oom-killer:
>>>                                                 gfp_mask=0x200da,
>>>                                                 order=0, oom_score_adj=0
>>>                                                 [  +0.010274]
>>>                                                 mpiexec.hydra
>>>                                                 cpuset=/
>>>                                                 mems_allowed=0-1
>>>                                                 [  +0.006680] CPU: 2
>>>                                                 PID: 144904 Comm:
>>>                                                 mpiexec.hydra
>>>                                                 Tainted: G OE
>>>                                                 3.10.0-862.14.4.el7.x86_64
>>>                                                 #1
>>>                                                 [  +0.013365]
>>>                                                 Hardware name:
>>>                                                 Lenovo ThinkSystem
>>>                                                 SD530
>>>                                                 -[7X21CTO1WW]-/-[7X21CTO1WW]-,
>>>                                                 BIOS
>>>                                                 -[TEE124N-1.40]-
>>>                                                 06/12/2018
>>>                                                 [  +0.012866] Call
>>>                                                 Trace:
>>>                                                 [  +0.003945]
>>>                                                 [<ffffffffb3313754>]
>>>                                                 dump_stack+0x19/0x1b
>>>                                                 [  +0.006995]
>>>                                                 [<ffffffffb330e91f>]
>>>                                                 dump_header+0x90/0x229
>>>                                                 [  +0.007121]
>>>                                                 [<ffffffffb2cfa982>]
>>>                                                 ktime_get_ts64+0x52/0xf0
>>>                                                 [  +0.007451]
>>>                                                 [<ffffffffb2d5141f>]
>>>                                                 delayacct_end+0x8f/0xb0
>>>                                                 [  +0.007393]
>>>                                                 [<ffffffffb2d9ac94>]
>>>                                                 oom_kill_process+0x254/0x3d0
>>>                                                 [  +0.007592]
>>>                                                 [<ffffffffb2d9a73d>]
>>>                                                 oom_unkillable_task+0xcd/0x120
>>>                                                 [  +0.007978]
>>>                                                 [<ffffffffb2d9a7e6>]
>>>                                                 find_lock_task_mm+0x56/0xc0
>>>                                                 [  +0.007729]
>>>                                                 [<ffffffffb2d9b4d6>]
>>>                                                 *out_of_memory+0x4b6/0x4f0*
>>>                                                 [  +0.007358]
>>>                                                 [<ffffffffb330f423>]
>>>                                                 __alloc_pages_slowpath+0x5d6/0x724
>>>                                                 [  +0.008190]
>>>                                                 [<ffffffffb2da18b5>]
>>>                                                 __alloc_pages_nodemask+0x405/0x420
>>>                                                 Thanks,
>>>                                                 Danyang
>>>                                             What most experimenters
>>>                                             take for granted before
>>>                                             they begin their
>>>                                             experiments is
>>>                                             infinitely more
>>>                                             interesting than any
>>>                                             results to which their
>>>                                             experiments lead.
>>>                                             -- Norbert Wiener
>>>                                             https://www.cse.buffalo.edu/~knepley/
>>>                                             <http://www.cse.buffalo.edu/~knepley/>
>>>                                     What most experimenters take for
>>>                                     granted before they begin their
>>>                                     experiments is infinitely more
>>>                                     interesting than any results to
>>>                                     which their experiments lead.
>>>                                     -- Norbert Wiener
>>>                             What most experimenters take for granted
>>>                             before they begin their experiments is
>>>                             infinitely more interesting than any
>>>                             results to which their experiments lead.
>>>                             -- Norbert Wiener
>>>                     What most experimenters take for granted before
>>>                     they begin their experiments is infinitely more
>>>                     interesting than any results to which their
>>>                     experiments lead.
>>>                     -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191010/826a977f/attachment-0001.html>
Read unstructured vtk mesh from file, done.
Build global unstructured mesh, please wait ...
Build global unstructured mesh, done.
Parallel domain decomposition, please wait ...
Create DMPlex from cell list, done
Distribute DMPlex from cell list, done
 terminate program, to be checked later
[ 0]64 bytes PetscSFCreate_Basic() line 1114 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/sf/impls/basic/sfbasic.c
      [0]  PetscMallocA() line 1114 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  PetscSFCreate_Basic() line 1101 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/sf/impls/basic/sfbasic.c
      [0]  PetscSFSetType() line 123 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/sf/interface/sf.c
      [0]  PetscSFSetFromOptions() line 244 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/sf/interface/sf.c
      [0]  DMPlexCreatePointSF() line 1531 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [0]  DMPlexDistributeOverlap() line 1899 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [0]  DMPlexDistribute() line 1738 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
[ 0]16 bytes PetscStrallocpy() line 192 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/utils/str.c
      [0]  PetscMallocA() line 192 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  PetscStrallocpy() line 189 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/utils/str.c
      [0]  PetscObjectChangeTypeName() line 152 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/pname.c
[ 0]800 bytes PetscSFCreate() line 39 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/sf/interface/sf.c
      [0]  PetscMallocA() line 39 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  PetscSFCreate() line 35 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/sf/interface/sf.c
[ 0]832 bytes DMPlexCreatePointSF() line 1605 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [0]  PetscMallocA() line 1605 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]416 bytes DMPlexCreatePointSF() line 1604 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [0]  PetscMallocA() line 1604 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]80 bytes PetscObjectComposedDataIncreaseReal() line 159 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/state.c
      [0]  PetscMallocA() line 159 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  PetscObjectComposedDataIncreaseReal() line 156 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/state.c
      [0]  VecSet() line 539 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/interface/rvector.c
      [0]  VecCreate_Seq() line 31 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/impls/seq/bvec3.c
      [0]  VecSetType() line 36 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/interface/vecreg.c
      [0]  VecCreate_Standard() line 562 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/impls/mpi/pbvec.c
      [0]  DMPlexDistributeField() line 940 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [0]  DMPlexDistributeCoordinates() line 1160 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [0]  DMPlexMigrate() line 1649 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
[ 0]80 bytes PetscObjectComposedDataIncreaseReal() line 158 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/state.c
      [0]  PetscMallocA() line 158 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  VecCreate_Seq_Private() line 897 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/impls/seq/bvec2.c
[ 0]16 bytes PetscLayoutSetUp() line 142 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/pmap.c
      [0]  PetscMallocA() line 142 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  PetscLayoutSetUp() line 124 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/pmap.c
[ 0]32 bytes VecCreate_Seq_Private() line 898 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/impls/seq/bvec2.c
      [0]  PetscMallocA() line 898 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16976 bytes VecCreate_Seq() line 35 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/impls/seq/bvec3.c
      [0]  PetscMallocA() line 35 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]4256 bytes PetscSectionSetChart() line 516 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [0]  PetscMallocA() line 516 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  PetscSectionSetChart() line 506 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [0]  PetscSFDistributeSection() line 2136 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [0]  PetscSectionSetNumFields() line 327 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
[ 0]720 bytes PetscSectionCreate() line 45 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [0]  PetscMallocA() line 45 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  PetscSectionCreate() line 41 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
[ 0]16 bytes PetscSectionSetNumFields() line 335 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [0]  PetscMallocA() line 335 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16 bytes PetscSectionSetNumFields() line 334 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [0]  PetscMallocA() line 334 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16 bytes PetscSectionSetNumFields() line 333 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [0]  PetscMallocA() line 333 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  PetscObjectSetName() line 28 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/pname.c
[ 0]48 bytes PetscLayoutCreate() line 48 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/pmap.c
      [0]  PetscMallocA() line 48 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  PetscLayoutCreate() line 47 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/pmap.c
      [0]  VecCreate() line 30 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/interface/veccreate.c
[ 0]1520 bytes VecCreate() line 35 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/interface/veccreate.c
      [0]  MatCreate() line 83 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/mat/utils/gcreate.c
      [0]  DMCreateCoordinateDM_Plex() line 3608 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
      [0]  DMGetCoordinateDM() line 4493 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [0]  DMGetCoordinateSection() line 4605 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
[ 0]2816 bytes MatCreate() line 89 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/mat/utils/gcreate.c
      [0]  PetscMallocA() line 89 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]32 bytes PetscStrallocpy() line 192 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/utils/str.c
      [0]  PetscFunctionListAdd_Private() line 211 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/dll/reg.c
      [0]  PetscObjectComposeFunction_Petsc() line 681 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/inherit.c
      [0]  PetscObjectComposeFunction_Private() line 816 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/inherit.c
      [0]  DMInitialize_Plex() line 2387 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexcreate.c
      [0]  DMClone_Plex() line 2441 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexcreate.c
      [0]  DMClone() line 114 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
[ 0]32 bytes PetscFunctionListAdd_Private() line 246 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/dll/reg.c
      [0]  PetscMallocA() line 246 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]32 bytes PetscFunctionListAdd_Private() line 213 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/dll/reg.c
      [0]  PetscMallocA() line 213 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  DMSetMatType() line 340 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [0]  DMCreate() line 46 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [0]  DMSetVecType() line 186 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
[ 0]928 bytes PetscDSCreate() line 527 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/dt/interface/dtds.c
      [0]  PetscMallocA() line 527 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  PetscDSCreate() line 522 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/dt/interface/dtds.c
[ 0]4704 bytes DMCreate() line 51 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [0]  PetscMallocA() line 51 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]12192 bytes PetscSectionSetChart() line 516 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [0]  DMPlexCreateSectionInitial() line 3273 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
      [0]  DMPlexCreateSection() line 3587 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
      [0]  DMCreateDefaultSection_Plex() line 6842 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
      [0]  DMGetSection() line 3544 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
[ 0]32 bytes DMAddLabel() line 5838 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [0]  PetscMallocA() line 5838 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  DMAddLabel() line 5834 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [0]  DMPlexDistributeLabels() line 1196 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [0]  DMLabelDistribute() line 1158 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  ISGeneralSetIndices_General() line 697 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/impls/general/general.c
      [0]  ISGeneralSetIndices() line 687 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/impls/general/general.c
      [0]  ISCreateGeneral() line 658 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/impls/general/general.c
      [0]  ISSetType() line 72 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/interface/isreg.c
      [0]  ISCreate_General() line 729 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/impls/general/general.c
[ 0]16 bytes ISCreate_General() line 730 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/impls/general/general.c
      [0]  PetscMallocA() line 730 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  ISCreate() line 35 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/interface/isreg.c
[ 0]784 bytes ISCreate() line 39 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/interface/isreg.c
[ 0]4256 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  PetscMallocA() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16 bytes DMLabelDistribute() line 1204 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  PetscMallocA() line 1204 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16 bytes DMLabelDistribute() line 1203 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  PetscMallocA() line 1203 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16 bytes DMLabelDistribute() line 1194 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  PetscMallocA() line 1194 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16 bytes DMLabelDistribute() line 1183 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  PetscMallocA() line 1183 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16 bytes DMLabelDistribute() line 1181 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  PetscMallocA() line 1181 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  DMLabelCreate() line 23 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]96 bytes DMLabelCreate() line 24 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  PetscMallocA() line 24 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]2096 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]2160 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]2048 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]2208 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]2080 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]2176 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]2128 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]2192 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]2064 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]2144 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]2112 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]7952 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]3680 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]4288 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]3648 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]4304 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]3712 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]4240 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]3776 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]4176 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]3888 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]4080 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]3872 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]3968 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]3984 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]4096 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]3856 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]4000 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  ISCreateStride() line 419 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/impls/stride/stride.c
      [0]  DMPlexStratify() line 2415 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
      [0]  DMPlexDistributeCones() line 1060 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [0]  ISCreate_Stride() line 431 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/impls/stride/stride.c
[ 0]16 bytes ISCreate_Stride() line 432 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/impls/stride/stride.c
      [0]  PetscMallocA() line 432 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16 bytes DMLabelNewStratum() line 179 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  PetscMallocA() line 179 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  DMLabelNewStratum() line 174 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  DMLabelSetValue() line 638 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 0]16 bytes DMLabelNewStratum() line 178 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  PetscMallocA() line 178 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16 bytes DMLabelNewStratum() line 177 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  PetscMallocA() line 177 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16 bytes DMLabelNewStratum() line 176 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  PetscMallocA() line 176 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16 bytes DMLabelNewStratum() line 175 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  PetscMallocA() line 175 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  DMCreateLabel() line 5320 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
[ 0]32 bytes DMCreateLabel() line 5331 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [0]  PetscMallocA() line 5331 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]23840 bytes DMPlexSymmetrize() line 2358 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
      [0]  PetscMallocA() line 2358 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  DMPlexSymmetrize() line 2334 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
[ 0]23840 bytes DMSetUp_Plex() line 2241 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
      [0]  PetscMallocA() line 2241 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  DMSetUp_Plex() line 2236 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
      [0]  DMSetUp() line 794 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
[ 0]23840 bytes DMSetUp_Plex() line 2240 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
      [0]  PetscMallocA() line 2240 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  DMSetType() line 3209 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [0]  DMPlexCreate() line 2548 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexcreate.c
      [0]  DMCreate_Plex() line 2472 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexcreate.c
      [0]  PetscPartitionerSetType() line 400 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexpartition.c
      [0]  PetscPartitionerCreate() line 600 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexpartition.c
[ 0]16 bytes PetscPartitionerCreate_ParMetis() line 1534 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexpartition.c
      [0]  PetscMallocA() line 1534 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  PetscPartitionerCreate_ParMetis() line 1532 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexpartition.c
[ 0]608 bytes PetscPartitionerCreate() line 605 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexpartition.c
      [0]  PetscMallocA() line 605 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]432 bytes DMCreate_Plex() line 2474 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexcreate.c
      [0]  PetscMallocA() line 2474 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16 bytes DMCreate() line 82 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [0]  PetscMallocA() line 82 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 0]16 bytes PetscCommDuplicate() line 143 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/tagm.c
      [0]  PetscMallocA() line 143 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [0]  PetscCommDuplicate() line 130 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/tagm.c
      [0]  PetscHeaderCreate_Private() line 41 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/inherit.c
      [0]  DMLabelMakeValid_Private() line 63 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  DMLabelGetStratumIS() line 866 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [0]  DMPlexBuildFromCellList_Internal() line 2798 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexcreate.c
      [0]  DMPlexCreateFromCellList() line 2910 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexcreate.c
[ 1]64 bytes PetscSFCreate_Basic() line 1114 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/sf/impls/basic/sfbasic.c
      [1]  PetscMallocA() line 1114 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  PetscSFCreate_Basic() line 1101 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/sf/impls/basic/sfbasic.c
      [1]  PetscSFSetType() line 123 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/sf/interface/sf.c
      [1]  PetscSFSetFromOptions() line 244 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/sf/interface/sf.c
      [1]  DMPlexCreatePointSF() line 1531 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [1]  DMPlexDistributeOverlap() line 1899 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [1]  DMPlexDistribute() line 1738 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
[ 1]16 bytes PetscStrallocpy() line 192 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/utils/str.c
      [1]  PetscMallocA() line 192 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  PetscStrallocpy() line 189 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/utils/str.c
      [1]  PetscObjectChangeTypeName() line 152 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/pname.c
[ 1]800 bytes PetscSFCreate() line 39 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/sf/interface/sf.c
      [1]  PetscMallocA() line 39 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  PetscSFCreate() line 35 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/sf/interface/sf.c
[ 1]592 bytes DMPlexCreatePointSF() line 1605 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [1]  PetscMallocA() line 1605 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]304 bytes DMPlexCreatePointSF() line 1604 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [1]  PetscMallocA() line 1604 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]80 bytes PetscObjectComposedDataIncreaseReal() line 159 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/state.c
      [1]  PetscMallocA() line 159 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  PetscObjectComposedDataIncreaseReal() line 156 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/state.c
      [1]  VecSet() line 539 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/interface/rvector.c
      [1]  VecCreate_Seq() line 31 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/impls/seq/bvec3.c
      [1]  VecSetType() line 36 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/interface/vecreg.c
      [1]  VecCreate_Standard() line 562 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/impls/mpi/pbvec.c
      [1]  DMPlexDistributeField() line 940 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [1]  DMPlexDistributeCoordinates() line 1160 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [1]  DMPlexMigrate() line 1649 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
[ 1]80 bytes PetscObjectComposedDataIncreaseReal() line 158 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/state.c
      [1]  PetscMallocA() line 158 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  VecCreate_Seq_Private() line 897 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/impls/seq/bvec2.c
[ 1]16 bytes PetscLayoutSetUp() line 142 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/pmap.c
      [1]  PetscMallocA() line 142 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  PetscLayoutSetUp() line 124 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/pmap.c
[ 1]32 bytes VecCreate_Seq_Private() line 898 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/impls/seq/bvec2.c
      [1]  PetscMallocA() line 898 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]16448 bytes VecCreate_Seq() line 35 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/impls/seq/bvec3.c
      [1]  PetscMallocA() line 35 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]4112 bytes PetscSectionSetChart() line 516 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [1]  PetscMallocA() line 516 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  PetscSectionSetChart() line 506 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [1]  PetscSFDistributeSection() line 2136 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [1]  PetscSectionSetNumFields() line 327 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
[ 1]720 bytes PetscSectionCreate() line 45 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [1]  PetscMallocA() line 45 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  PetscSectionCreate() line 41 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
[ 1]16 bytes PetscSectionSetNumFields() line 335 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [1]  PetscMallocA() line 335 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]16 bytes PetscSectionSetNumFields() line 334 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [1]  PetscMallocA() line 334 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]16 bytes PetscSectionSetNumFields() line 333 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [1]  PetscMallocA() line 333 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  PetscObjectSetName() line 28 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/pname.c
[ 1]48 bytes PetscLayoutCreate() line 48 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/pmap.c
      [1]  PetscMallocA() line 48 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  PetscLayoutCreate() line 47 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/pmap.c
      [1]  VecCreate() line 30 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/interface/veccreate.c
[ 1]1520 bytes VecCreate() line 35 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/vec/interface/veccreate.c
      [1]  MatCreate() line 83 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/mat/utils/gcreate.c
      [1]  DMCreateCoordinateDM_Plex() line 3608 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
      [1]  DMGetCoordinateDM() line 4493 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [1]  DMGetCoordinateSection() line 4605 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
[ 1]2816 bytes MatCreate() line 89 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/mat/utils/gcreate.c
      [1]  PetscMallocA() line 89 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]32 bytes PetscStrallocpy() line 192 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/utils/str.c
      [1]  PetscFunctionListAdd_Private() line 211 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/dll/reg.c
      [1]  PetscObjectComposeFunction_Petsc() line 681 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/inherit.c
      [1]  PetscObjectComposeFunction_Private() line 816 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/objects/inherit.c
      [1]  DMInitialize_Plex() line 2387 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexcreate.c
      [1]  DMClone_Plex() line 2441 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexcreate.c
      [1]  DMClone() line 114 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
[ 1]32 bytes PetscFunctionListAdd_Private() line 246 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/dll/reg.c
      [1]  PetscMallocA() line 246 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]32 bytes PetscFunctionListAdd_Private() line 213 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/dll/reg.c
      [1]  PetscMallocA() line 213 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  DMSetMatType() line 340 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [1]  DMCreate() line 46 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [1]  DMSetVecType() line 186 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
[ 1]928 bytes PetscDSCreate() line 527 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/dt/interface/dtds.c
      [1]  PetscMallocA() line 527 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  PetscDSCreate() line 522 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/dt/interface/dtds.c
[ 1]4704 bytes DMCreate() line 51 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [1]  PetscMallocA() line 51 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]11872 bytes PetscSectionSetChart() line 516 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/utils/vsectionis.c
      [1]  DMPlexCreateSectionInitial() line 3273 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
      [1]  DMPlexCreateSection() line 3587 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
      [1]  DMCreateDefaultSection_Plex() line 6842 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plex.c
      [1]  DMGetSection() line 3544 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
[ 1]32 bytes DMAddLabel() line 5838 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [1]  PetscMallocA() line 5838 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  DMAddLabel() line 5834 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/interface/dm.c
      [1]  DMPlexDistributeLabels() line 1196 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/impls/plex/plexdistribute.c
      [1]  DMLabelDistribute() line 1158 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [1]  ISGeneralSetIndices_General() line 697 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/impls/general/general.c
      [1]  ISGeneralSetIndices() line 687 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/impls/general/general.c
      [1]  ISCreateGeneral() line 658 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/impls/general/general.c
      [1]  ISSetType() line 72 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/interface/isreg.c
      [1]  ISCreate_General() line 729 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/impls/general/general.c
[ 1]16 bytes ISCreate_General() line 730 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/impls/general/general.c
      [1]  PetscMallocA() line 730 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  ISCreate() line 35 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/interface/isreg.c
[ 1]784 bytes ISCreate() line 39 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/vec/is/is/interface/isreg.c
[ 1]4112 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [1]  PetscMallocA() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]16 bytes DMLabelDistribute() line 1204 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [1]  PetscMallocA() line 1204 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]16 bytes DMLabelDistribute() line 1203 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [1]  PetscMallocA() line 1203 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]16 bytes DMLabelDistribute() line 1194 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [1]  PetscMallocA() line 1194 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]16 bytes DMLabelDistribute() line 1183 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [1]  PetscMallocA() line 1183 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]16 bytes DMLabelDistribute() line 1181 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [1]  PetscMallocA() line 1181 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
      [1]  DMLabelCreate() line 23 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 1]96 bytes DMLabelCreate() line 24 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
      [1]  PetscMallocA() line 24 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/sys/memory/mal.c
[ 1]2000 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 1]2128 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 1]2080 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 1]2032 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 1]2064 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 1]1984 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 1]1936 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 1]2176 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 1]2112 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
[ 1]2016 bytes DMLabelDistribute() line 1208 in /home/dsu/Soft/PETSc/petsc-3.10.2/src/dm/label/dmlabel.c
