[petsc-users] Computing part of the inverse of a large matrix
Jan Grießer griesser.jan at googlemail.com
Tue Oct 8 08:05:01 CDT 2019
Hey,
I tried your proposed way. The factorization seems to work but the I get an error when solving A*X=B. When I run the appended code
I get the following error message:
Traceback (most recent call last):
  File "inverse_matrix.py", line 145, in <module>
    compute_inverse_mat(dynamical_matrix_nn, args.dynamical_matrix_dimension, args.m_cols_rows)
  File "inverse_matrix.py", line 130, in compute_inverse_mat
    greens_function = fac_dyn_matrix.matSolve(B,x)
  File "PETSc/Mat.pyx", line 1509, in petsc4py.PETSc.Mat.matSolve
petsc4py.PETSc.Error: error code 76
[1] MatMatSolve() line 3380 in /Users/griesserj/Libaries/petsc/src/mat/interface/matrix.c
[1] MatMatSolve_MUMPS() line 1177 in /Users/griesserj/Libaries/petsc/src/mat/impls/aij/mpi/mumps/mumps.c
[1] Error in external library
[1] Error reported by MUMPS in solve phase: INFOG(1)=-3
Do you have an idea where this error can come from or did I miss to set some necessary options?
Thank you very much in advance!
Code:
def compute_inverse_mat(dynamical_matrix_nn, dyn_matrix_dim, m_cols_rows):
    # Set up the matrix B
    B = PETSc.Mat().create(comm=comm)
    B.setSizes((dyn_matrix_dim,m_cols_rows))
    B.setType("dense")
    B.setFromOptions()
    B.setUp()
    Rstart, Rend = B.getOwnershipRange()
    print("rank, size, start_frame, end_frame \n", rank, " / ", size, " / ", Rstart, " / ", Rend)
    # Fill the matrix B
    if (Rstart < m_cols_rows) and (Rend <= m_cols_rows):
    	for i in range(Rstart, Rend):
    		B[i,i] = 1
    if (Rstart < m_cols_rows) and (Rend >= m_cols_rows):
    	for i in range(Rstart, m_cols_rows):
    		B[i,i] = 1
    # Assemble B
    B.assemble()
    # Set up matrix x
    x = PETSc.Mat().create(comm=comm)
    x.setSizes((dyn_matrix_dim,m_cols_rows))
    x.setType("dense")
    x.setFromOptions()
    x.setUp()
    x.assemble()
    # Create the linear solver and set various options
    ksp = PETSc.KSP().create(comm=comm)
    # This implements a stub method that applies ONLY the preconditioner.
    ksp.setType("preonly")
    # Set the matrix associated with the linear system
    ksp.setOperators(dynamical_matrix_nn, dynamical_matrix_nn)
    # Define the preconditioner object
    pc = ksp.getPC()
    # Set the preconditioner to LU-factorization
    pc.setType("lu")
    # Use MUMPS
    pc.setFactorSolverType("mumps")
    # Prepares for the use of the preconditioner
    pc.setFromOptions()
    pc.setUp()
    # Sets up the inernal data structures for the later use of an iterative solver
    ksp.setFromOptions()
    ksp.setUp()
    # Get the factorized dynamical matrix
    fac_dyn_matrix = pc.getFactorMatrix()
    # Compute part of the inverse by solving
    # A*X=B
> Am 01.10.2019 um 10:09 schrieb Matthew Knepley <knepley at gmail.com>:
> On Tue, Oct 1, 2019 at 4:07 AM Jan Grießer <griesser.jan at googlemail.com <mailto:griesser.jan at googlemail.com>> wrote:
> Hey Matt,
> Can you elaborate a little bit on your idea for calculating the inverse matrix ?
> It is exactly what you were doing before, except you use KSP with
>   -ksp_type preonly -pc_type lu -pc_mat_solver_package mumps
> and then MatMatSolve on the identity matrix.
>   Thanks,
>      Matt
> Greetings Jan
> Am Mo., 30. Sept. 2019 um 17:50 Uhr schrieb Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>:
> I think the easier way to do it is to use a KSP which is configured to do preonly and LU. That will do the right thing in parallel.
>    Matt
> On Mon, Sep 30, 2019 at 11:47 AM Smith, Barry F. via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>    The Python wrapper for PETSc may be missing some functionality; there is a manual process involved in creating new ones. You could poke around the petsc4py source and see how easy it would be to add more functionality that you need.
> > On Sep 30, 2019, at 10:13 AM, Jan Grießer <griesser.jan at googlemail.com <mailto:griesser.jan at googlemail.com>> wrote:
> > I configured PETSc with MUMPS and tested it already for the spectrum slicing method in Slepc4py but i have problems in setting up the LU factorization in the PETSc4py. Since i do not find the corresponding methods and commands in the source code. Thats why is was wondering if this is even possible in the python version.
> > Am Mo., 30. Sept. 2019 um 16:57 Uhr schrieb Smith, Barry F. <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>:
> >   If you want a parallal LU (and hence the ability to build the inverse in parallel) you need to configure PETSc with --download-mumps --download-scalapack
> >   Barry
> > > On Sep 30, 2019, at 9:44 AM, Jan Grießer <griesser.jan at googlemail.com <mailto:griesser.jan at googlemail.com>> wrote:
> > > Is the MatMumpsGetInverse also wrapped to the python version in PETSc4py ? If yes is there any example for using it ?
> > > My other question is related to the LU factoriation (https://www.mcs.anl.gov/petsc/documentation/faq.html#invertmatrix <https://www.mcs.anl.gov/petsc/documentation/faq.html#invertmatrix>).
> > > Is the LU factorization only possible for sequential Aij matrices ? I read in the docs that this is the case for ordering.
> > > After setting up my matrix A, B and x i tried:
> > >  r, c = dynamical_matrix_nn.getOrdering("nd")
> > >  fac_dyn_matrix = dynamical_matrix_nn.factorLU(r,c)
> > > resulting in an error:
> > > [0] No support for this operation for this object type
> > > [0] Mat type mpiaij
> > > Am Fr., 27. Sept. 2019 um 16:26 Uhr schrieb Zhang, Hong <hzhang at mcs.anl.gov <mailto:hzhang at mcs.anl.gov>>:
> > > See ~petsc/src/mat/examples/tests/ex214.c on how to compute selected entries of inv(A) using mumps.
> > > Hong
> > > On Fri, Sep 27, 2019 at 8:04 AM Smith, Barry F. via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> > > MatMumpsGetInverse() maybe useful. Also simply using MatMatSolve() with the first 1000 columns of the identity and "throwing away" the part you don't need may be most effective.
> > >    Barry
> > > > On Sep 27, 2019, at 3:34 AM, Jan Grießer via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> > > > Hi all,
> > > > i am using petsc4py. I am dealing with rather large sparse matrices up to 600kx600k and i am interested in calculating a part of the inverse of the matrix(I know it will be a dense matrix). Due to the nature of my problem, I am only interested in approximately the first 1000 rows and 1000 columns (i.e. a large block in the upper left ofthe matrix).  Before I start to play around now, I wanted to ask if there is a clever way to tackle this kind of problem in PETSc in principle. For any input I would be very grateful!
> > > > Greetings Jan
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191008/53d56ea9/attachment-0001.html>
