[petsc-users] Stokes-Brinkmann equation preconditioner
Lawrence Mitchell wence at gmx.li
Fri Oct 4 05:04:32 CDT 2019
> On 4 Oct 2019, at 10:46, Matthew Knepley via petsc-users <petsc-users at mcs.anl.gov> wrote:
> On Thu, Oct 3, 2019 at 6:34 PM Salazar De Troya, Miguel via petsc-users <petsc-users at mcs.anl.gov> wrote:
> I am trying to solve the Stokes equation with the Brinkman term to simulate a solid material. My intention is to implement the preconditioner in this paper:https://onlinelibrary.wiley.com/doi/epdf/10.1002/fld.426 (section 2.6)
> Link does not work for me.
Try https://onlinelibrary.wiley.com/doi/epdf/10.1002/fld.426 (mail clients are awful)
> where they solve for the velocity and substitute that expression in the pressure equation. They end up solving a system of the type B K^-1 B^T, i.e. the Schur complement of the problem. For this system of equations, they argue that the preconditioner in page 11 is perfect for a given constant Brinkman penalty term.
> Because I am solving for velocity and pressure without doing any substitution, I thought I could use a PC fieldsplit type Schur (full factorization)
> Yes, this will form the exact factorization and a matrix-free form of the Schur complement.
> and provide the preconditioner in the paper to solve the Schur complement.
> Yes, you can provide a user-defined PC for the Schur complement.
> My question is, should I provide this preconditioner through PCFieldSplitSetSchurPre or through fieldsplit_1_pc_type (probably through the Firedrake interface as inhttps://www.firedrakeproject.org/demos/stokes.py.html) ?
> The name PCFieldSplitSetSchurPre seems to be very misleading. You do not use it to provide a _preconditioner_. You use it to determine
> the _preconditioning matrix_ from which the actual preconditioner is built. The preconditioner itself is defined using -fieldpslit_1_pc_type.
> Since I do not know what the preconditioner looks like, I cannot say what preconditioner matrix you would want. Since Firedrake can construct
> any operator for you, you might not care about the matrix we pass to you.
The action of the PC is defined by:
M^{-1} q = \phi_q + \mu q
\mu is some number, and \phi_q solves the BVP
-div \alpha^{-1} grad \phi_q = q
grad \phi_q \dot n = 0
\int \phi_q = 0
So your PC for the fieldsplit_1 needs to:
1. Discretise and solve this BVP to compute \phi_q
2. Add \mu q.
I.e. the action of PCApply is:
y <- \mu x + Laplace^{-1} x
(Aside, surely a primal-dual error has been made in the analysis here)
You could, I think, do this by providing the discretisation of this laplacian and using an additive PCComposite (although I don't know what PC you would use to just scale the input, it's easy to write one though).
Cheers,
Lawrence
