[petsc-users] Stokes-Brinkmann equation preconditioner
Matthew Knepley
knepley at gmail.com
Fri Oct 4 04:46:53 CDT 2019
On Thu, Oct 3, 2019 at 6:34 PM Salazar De Troya, Miguel via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> I am trying to solve the Stokes equation with the Brinkman term to
> simulate a solid material. My intention is to implement the preconditioner
> in this paper: https://onlinelibrary.wiley.com/doi/epdf/10.1002/fld.426
> <https://onlinelibrary.wiley.com/doi/epdf/10.1002/fld.426section%202.6>
> (section 2.6)
Link does not work for me.
> where they solve for the velocity and substitute that expression in the
> pressure equation. They end up solving a system of the type B K^-1 B^T,
> i.e. the Schur complement of the problem. For this system of equations,
> they argue that the preconditioner in page 11 is perfect for a given
> constant Brinkman penalty term.
> Because I am solving for velocity and pressure without doing any
> substitution, I thought I could use a PC fieldsplit type Schur (full
> factorization)
Yes, this will form the exact factorization and a matrix-free form of the
Schur complement.
> and provide the preconditioner in the paper to solve the Schur complement.
Yes, you can provide a user-defined PC for the Schur complement.
> My question is, should I provide this preconditioner through
> PCFieldSplitSetSchurPre or through fieldsplit_1_pc_type (probably through
> the Firedrake interface as in
> https://www.firedrakeproject.org/demos/stokes.py.html) ?
The name PCFieldSplitSetSchurPre seems to be very misleading. You do not
use it to provide a _preconditioner_. You use it to determine
the _preconditioning matrix_ from which the actual preconditioner is built.
The preconditioner itself is defined using -fieldpslit_1_pc_type.
Since I do not know what the preconditioner looks like, I cannot say what
preconditioner matrix you would want. Since Firedrake can construct
any operator for you, you might not care about the matrix we pass to you.
Matt
> Thanks
> Miguel
> Miguel A. Salazar de Troya
> Postdoctoral Researcher, Lawrence Livermore National Laboratory
> B141
> Rm: 1085-5
> Ph: 1(925) 422-6411
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191004/73feb4e8/attachment.html>
